Page 3 of 4
Re: Z-Wave not working under Zwave-JS-UI
Posted: Saturday 16 March 2024 15:30
by keef
no this one doesn't work like that I took the device to the stick
Posted: Saturday 16 March 2024 22:47
by bvdf0251
BartSr wrote: Sunday 10 March 2024 23:03
prefix to be changed both in zwavejs as well as domoticz hardwarepage
You need to set the prefix under 'dicovery prefix' in the 'homeassistant' settings on Zwave js ui
Posted: Sunday 17 March 2024 17:54
by keef
bvdf0251 wrote: Saturday 16 March 2024 22:47
To what? I've set everything to zwavejs
Posted: Sunday 17 March 2024 21:08
Discovery prefix (default homeassistant) in Zwave-JS-UI cannot be the same as the normal prefix (default zwave). So they cannot be all Zwavejs.... So check your settings in Zwave-JS-UI that you not made them the same.
The discovery prefix of Zwave-JS-UI (default homeassistant) should be filled in Domoticz MQTT auto discover configuration.
Posted: Sunday 17 March 2024 23:11
by bvdf0251
- Screenshot_20240317_230902_Chrome.jpg (397.13 KiB) Viewed 3312 times
- Screenshot_20240317_230931_Chrome.jpg (362.22 KiB) Viewed 3312 times
I've set it to 'domoticz' can be anything you like.
Make sure to set domoticz to allow new devices and hit save in Zwave js ui
Posted: Sunday 17 March 2024 23:47
Also Domoticz is not a very smart choice as it is the same as the default Domoticz topic when using the Domoticz MQTT hardware gateway. Better leave it all just default....
Posted: Monday 18 March 2024 10:49
by BartSr
@waltervl
I should not advise to keep all prefix to be homeassistant.
In case you are using AD for different sources such as zwave, zigbee, otgw etc. it makes it difficult to see relevant data in mqtt explorer.
Posted: Monday 18 March 2024 11:35
Yes, so for users not so knowledgable and only using Zwave-JS-UI default settings is the best to avoid situations like this.
If you add Zigbee2MQTT you can choose to change the Discovery prefix settings in Zigbee2MQTT or Zwave-js-ui. But is is not needed. And only change the Discovery prefix as both platforms already use different prefixes for their own topics by default (zigbee2mqtt and zwave).
Posted: Monday 18 March 2024 13:36
by BartSr
@waltervl
for the records. prefix zwavejs works like a charm whereas just zwave don't.
Posted: Monday 18 March 2024 15:06
BartSr wrote: Monday 18 March 2024 13:36
@waltervl
Are you talking on the zwave-js-ui MQTT prefix or the zwave-js-ui Discovery prefix?
There should be no difference between zwave or zwavejs for MQTT prefix unless you use prefix zwave also for something else in your MQTT environment.
Posted: Monday 18 March 2024 18:04
by BartSr
when I was in process of getting the zwavejs-ui the mqtt prefix zwave (aof course same in domoticz) did not work.
After changing into zwavejs it did.
Posted: Monday 18 March 2024 19:10
BartSr wrote: Monday 18 March 2024 18:04
Again you are mixing up things. In Domoticz you should enter the Zwave-JS-UI Discovery prefix (default: homeassistant).
Posted: Monday 18 March 2024 19:38
by BartSr
well of course you shouldnot .
once in zwavejs-ui you set zwavejs as prefix in domoticz it has to be same
Posted: Monday 18 March 2024 19:50
by jvdz
Guys, please take this offline as this doesn't contribute to the current issue which is with ZWAVEJS2MQTT & the ZWAVEME usb stick, which currently doesn't allow to join the devices again to it!
You seem to be agreeing without knowing it... so PM is a great tool for that!
Posted: Monday 18 March 2024 21:16
by BartSr
@Keef
Do you have more info about type of zwave stick apart from zwaveme??
Posted: Tuesday 19 March 2024 12:15
by keef
Something like this?
Posted: Tuesday 19 March 2024 15:08
by bvdf0251
That seems about right, are you able to see the devices in Zwave js Anyway? And control them from there?
I don't get that from what's currently posted.
Posted: Tuesday 19 March 2024 15:09
by keef
I can only see my zwave stick and I can't add anything
Posted: Tuesday 19 March 2024 16:14
by jvdz
Did you look for support on this issue on the ZwaveJS2Mqtt github site?
What have you done in an effort to try and debug this?
Did you look at the Logfiles in ZwaveJS2Mqtt for errors?
Posted: Tuesday 19 March 2024 16:53
by bvdf0251
Yeah, first it needs to work on Zwave-JS, otherwise it will never work on Domoticz.
