Zigbee For Domoticz plugin - presence sensors settings
JanZorz
Re: Zigbee For Domoticz plugin - presence sensors settings
Post by JanZorz »
pipiche wrote: Monday 05 February 2024 12:05
JanZorz wrote: Sunday 04 February 2024 13:42
pipiche wrote: Sunday 04 February 2024 10:56
If I switch off (disconnect) Sonoff sensor but do not disable it in the Z4D web admin panel - the Aquara sensor still doesn't work. I'll do more tests today.
Cheers, Jan
Hum, the fact that the Aqara sensor doesn't work, as nothing to do with the Sonoff presence sensor.
Did you try to put the plugin in pairing mode and re-pair the Aqara sensor ?
I know... It doesn't make any sense... specially since the 2 other Aquara sensors work just fine...
I deleted Aquara sensor from Domoticz and Z4D and re-paired it (few times, actually), same for Sonoff sensor...
But - If I disable Sonoff sensor - the Aquara sensor starts working right away. With Sonoff sensor enabled - the symptom is that Aquara sensor would go to "On" state when motion is detected and then would not go back to "Off" ever again. It just stays on "On" infinitely. The moment that I disable Sonoff sensor - Auara goes to "Off" immediately. If I just delete all the settings for Sonoff sensor and leave just {} - then the Aquara sensor starts working after some time (sometimes even few hours), but Sonoff sensor doesn't work or just works sporadically here and there.
Does this make any possible sense? I can give you the plugin log with Sonoff disabled and then with Sonoff enabled, if you want.
Cheers, Jan
pipiche
Post by pipiche »
can you try the following
switch to stable7
git checkout stable7
sudo python3 -m pip install -r requirements.txt --upgrade
the restart the plugin
in that context you won't get the recent changes for the Sonoff, but the basic functionallity should work.
how does the Aqara vs. Sonoff behave
JanZorz
Post by JanZorz »
pipiche wrote: Monday 05 February 2024 16:28 can you try the following
switch to stable7
Now the plugin is on 7.1.008 [3.211]. Before switching back to stable branch I completely removed the Sonoff sensor just in case.
The aquara sensor works, Sonoff sensor also showed some activity, but it's just using of Motion and not the Presence to activate the switch in domoticz, like it was the case at the beginning...
If you could just change in the code that the Sonoff uses the Presence and not Motion for flipping the switch we could say that the basic functionality works...
Cheers, Jan
JanZorz
Post by JanZorz »
JanZorz wrote: Monday 05 February 2024 20:16
Cheers, Jan
Pipiche - would this small change be possible? That would render the Sonoff sensor usable.
Cheers, Jan
pipiche
Post by pipiche »
For now, I wouldn't change much, because I'm waiting for a sample from Sonoff, so I can cleanup the integration.
And last I still don't see any plugin rationals to get some confusion. The only thing I can think is that with the branch we were pushing some settings to the Sonoff device (like sensibility). Maybe that could be the issue, as this is the only change which can affect the device b ehaviour
Could you let me know what is the Aqara Sensor ?
JanZorz
Post by JanZorz »
pipiche wrote: Wednesday 07 February 2024 17:53 For now, I wouldn't change much, because I'm waiting for a sample from Sonoff, so I can cleanup the integration.
Aquara sensor is recognized as lumi.sensor_motion.aq2 , the model is this one: https://www.aqara.com/en/product/human-motion-sensor/
I have 3 of them, but the problem was just with one. Interesting, unexplainable.
Ok. let me know when you get the sample from Sonoff. However, in that special branch it correctly used the Presence instead of Motion to flip the switch and keep the switch on.
Cheers, Jan
wvries
Domoticz version: latest B
Post by wvries »
Hi WaltervL,
i look at the wiki page for changing parameters for a device, working perfectly from the Z4D interface.
waltervl wrote: Thursday 18 January 2024 17:51 See zigbee4Domoticz wiki page https://zigbeefordomoticz.github.io/wik ... eters.html
As some of these parameters are usefull to have changed from Domoticz, is there a way (like the REST API - https://zigbeefordomoticz.github.io/wik ... T-API.html) to change them?
usecase:
A tuya Siren (https://zigbee.blakadder.com/Neo_NAS-AB02B2.html) has several tunes. I would like to use it as a doorbell (so tune ID=0) in normal use. When I detect an alarm, I would like to be able to switch the tune to id=6 to have the alarm sound. Also be able to increase the volume for the alarm.
Posible solutions:
1) create 2 devices in Domoticz with the tunes and one with the volume level.
2) implement (or is it there already) a REST API call to use it through scripting.
Any ideas for this?
Thanks in advance for your help.
I have no clue if this can be set by an API. user pipiche is the authour of the plugin. Perhaps you can write him a PM as he is not scanning this forum regularly. Or create an issue on the Z4D github.
