Domoticz Premium apk has stopped working
juankar
Domoticz version: 4.
Re: Domoticz Premium apk has stopped working
Post by juankar »
Yes, you're right
Marathon2010
Domoticz version: 2024.7
Post by Marathon2010 »
LucVolders wrote: Sunday 05 November 2023 19:33 You could build your own app and customize it like you want.
I build one for my girlfriend as I did not want her to mess around with settings etc.
It is really easy to build your own app with MIT's app inventor.
But you could equally easy build it in Javascript.
Here is the link to my story on building your own app.
http://lucstechblog.blogspot.com/2018/1 ... n-app.html
Based on your reply I've build my first app as well, great stuff :D. For documenting and knowlegde purposes I'd like to share how I did setup the new security (as from 2023.1). Next is my procedure performAPI to fire the API:
API Headers.jpg (70.56 KiB) Viewed 675 times
DomoticzAPI is the webcomponent defined in MIT app inventor (like you described in your blog).
Variables are:
APIauth has value "Basic QWxhxxxxxxxxkNDpyMFguKj1xxxxx" (so the base64 of <username>:<password>)
APIbase has value "http://<ip address>:<port>/json.htm?type=command&param="
APIdetail is parameter for the performAPI procedure, is for instance "getsettings" to retrieve Domoticz settings.
Will look like below (APIsettings has the value "getsettings" assigned:
Call API.jpg (28.44 KiB) Viewed 675 times
Processing is for the rest the same as in your blog, so GotText is used to process responseContent of the API call.
Synology NAS DS920+ DSM7 (Docker) | Integrations: Audio, Heating, Gas, Electricity, Water, Alarm, Car, Camera, Doorbell, Garage | SW: Tasmota, DzVents, Pushbullet | Plugins: GPSLogger, BatteryLevel, Hyundai KIA
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
how do you have all that option in blockly ?
Marathon2010
It isn't blocky, it's MIT's app inventor. See Luc's blog for more details.
