Page 3 of 19
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Posted: Friday 27 January 2023 14:20
by Xenomes
Varazir wrote: Friday 27 January 2023 14:11
I tried to just delete it from the device list but it didn't help.
That should do the trick. Normally then the device exist creation is skipped. I will do a test tonight.
Edit:
did you delete Plugin 13 TinyTuya ID = 43035720e098061d58bc unit = 1?
Posted: Friday 27 January 2023 14:32
by Varazir
Xenomes wrote: Friday 27 January 2023 14:20
Edit:
I deleted it from the device list and turned the plugin off and on, did even restart domoticz but still got the same error.
Tried to turn off the plugin and delete the device and enabled the plugin again, still same error.
Posted: Friday 27 January 2023 14:41
by Xenomes
Varazir wrote: Friday 27 January 2023 14:32
Is see the problem, forgot a piece of code that do the device exist creation skip procedure.
Posted: Friday 27 January 2023 15:02
by Xenomes
Xenomes wrote: Friday 27 January 2023 14:41
Pushed a update (no version change)
Posted: Friday 27 January 2023 17:35
by Varazir
Xenomes wrote: Friday 27 January 2023 15:02
Updated and restarted domoticz and no errors
Posted: Friday 27 January 2023 19:55
by Xenomes
Varazir wrote: Friday 27 January 2023 17:35
Ha, Great! But can you control the fan?
Posted: Friday 27 January 2023 19:59
by Varazir
No errors when I turned it on from DZ but didn't check if it started. I'll check when I get home again.
Posted: Saturday 28 January 2023 7:47
by Varazir
Checked and it's working
Posted: Saturday 28 January 2023 11:53
by Xenomes
Thanks for reporting back!
Posted: Friday 03 March 2023 18:27
by frenchyyii
Hi everyone, first thanx for the plugin !!
I got some trouble to get it work on one of my DZ, I suspect a Python depency
some informations here:
0 Error: Smartlife Tiny Tuya : Call to function 'onHeartbeat' failed, exception details:
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : Traceback (most recent call last):
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : File "/home/pi/domoticz/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 341, in onHeartbeat
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : _plugin.onHeartbeat()
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : File "/home/pi/domoticz/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 302, in onHeartbeat
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : if time.time() - last_update < 60 and testData == False:
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : NameError: name 'last_update' is not defined
DZ is last beta on a RPI4 with python 3.9.2:
Version: 2023.1 (build 15109)
Build Hash: b3211fe6d
Compile Date: 2023-03-01 16:44:49
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
if someone can help
Eric
Posted: Friday 03 March 2023 19:34
by Xenomes
I checkt the code, this could happen if there are no devices in the tuya account. Can you check that? Also try to press update on the hardware place.
Posted: Friday 03 March 2023 20:19
by frenchyyii
Thanks for your fast response.
Concerning the tuya project, it is ok (22 devices)
But when desactivate reactivate the harware in domotics (with other project credentials) i have seen this message too:
handleThread: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
I checked also Cloud Authorization IP Allowlist and it is off
Datacenter is central Europe
Where . Iottuya or domoticz ?
Oups another thing, now I'm on your dev branch but I've tried on the Master before and same reuslts
Posted: Friday 03 March 2023 20:25
by Xenomes
frenchyyii wrote: Friday 03 March 2023 20:19
You already did it in Domoticz when deactivation reactivate the hardware.
This error is coming from TinyTuya, there is something you forgot re walk the steps to setup the iot account.
Posted: Friday 03 March 2023 20:30
by frenchyyii
if it helsp:
pip list
Package Version
arandr 0.1.10
astroid 2.5.1
asttokens 2.0.4
automationhat 0.2.0
beautifulsoup4 4.9.3
blinker 1.4
blinkt 0.1.2
buttonshim 0.0.2
Cap1xxx 0.1.3
certifi 2020.6.20
chardet 4.0.0
charset-normalizer 3.0.1
click 7.1.2
colorama 0.4.4
colorzero 1.1
cryptography 3.3.2
cupshelpers 1.0
dbus-python 1.2.16
distlib 0.3.6
distro 1.5.0
docutils 0.16
drumhat 0.1.0
enum-compat 0.0.2
envirophat 1.0.0
ExplorerHAT 0.4.2
filelock 3.9.0
Flask 1.1.2
fourletterphat 0.1.0
gpiozero 1.6.2
html5lib 1.1
idna 2.6
isort 5.6.4
itsdangerous 1.1.0
jedi 0.18.0
Jinja2 2.11.3
lazy-object-proxy 0.0.0
logilab-common 1.8.1
lxml 4.6.3
MarkupSafe 1.1.1
mccabe 0.6.1
microdotphat 0.2.1
mote 0.0.4
motephat 0.0.3
mypy 0.812
mypy-extensions 0.4.3
netifaces 0.10.6
numpy 1.19.5
oauthlib 3.1.0
pantilthat 0.0.7
parso 0.8.1
pexpect 4.8.0
pgzero 1.2
phatbeat 0.1.1
pianohat 0.1.0
picamera 1.13
picamera2 0.3.8
pidng 4.0.9
piexif 1.1.3
piglow 1.2.5
pigpio 1.78
Pillow 8.1.2
pip 23.0.1
platformdirs 3.0.0
psutil 5.8.0
pycairo 1.16.2
pycparser 2.18
pycryptodome 3.17
pycups 2.0.1
pygame 1.9.6
Pygments 2.7.1
PyGObject 3.38.0
pyinotify 0.9.6
PyJWT 1.7.1
pylint 2.7.2
PyOpenGL 3.1.5
pyOpenSSL 20.0.1
PyQt5 5.15.2
PyQt5-sip 12.8.1
pyserial 3.5b0
pysmbc 1.0.23
python-apt 2.2.1
python-prctl 1.7
PyYAML 5.3.1
rainbowhat 0.1.0
reportlab 3.5.59
requests 2.28.2
requests-oauthlib 1.0.0
responses 0.12.1
roman 2.0.0
RPi.GPIO 0.7.0
RTIMULib 7.2.1
scrollphat 0.0.7
scrollphathd 1.2.1
Send2Trash 1.6.0b1
sense-hat 2.4.0
setuptools 67.4.0
simplejpeg 1.6.4
simplejson 3.17.2
six 1.11.0
skywriter 0.0.7
sn3218 1.2.7
soupsieve 2.2.1
spidev 3.5
ssh-import-id 5.10
thonny 4.0.1
tinytuya 1.10.3
toml 0.10.1
touchphat 0.0.1
tuyaha 0.0.11
twython 3.8.2
typed-ast 1.4.2
typing-extensions 3.7.4.3
unicornhathd 0.0.4
urllib3 1.26.5
v4l2-python3 0.3.1
virtualenv 20.20.0
webencodings 0.5.1
Werkzeug 1.0.1
wheel 0.34.2
wrapt 1.12.1
Posted: Friday 03 March 2023 20:31
by frenchyyii
cross messaging ... i don't think so but I'll check the autorisations
Posted: Friday 03 March 2023 20:48
by frenchyyii
Everything seems to be ok, but when I check the API errors they are present with the project domoticz2 that is the one on this PI4
No error withe domoticz1 project that uses the other Pi4 with python 3.7
could'nt it be request module or somethink like that ?
Running the tool
same error with line24 added (sudo or not sudo ^^)
debug_discovery: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1 line 24
Posted: Friday 03 March 2023 20:55
by Xenomes
Try running
is something is missing you wil see it i hope.
Posted: Friday 03 March 2023 21:01
by frenchyyii
Done
"apiKey": "xxxxxx",
"apiSecret": "xxxxxx",
"apiRegion": "eu",
"apiDeviceID": xxxxx002462ab3d7a00"
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 434, in prepare_url
scheme, auth, host, port, path, query, fragment = parse_url(url)
File "/usr/lib/python3/dist-packages/urllib3/util/url.py", line 394, in parse_url
return six.raise_from(LocationParseError(source_url), None)
File "<string>", line 3, in raise_from
urllib3.exceptions.LocationParseError: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/runpy.py", line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.9/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.9/dist-packages/tinytuya/__main__.py", line 76, in <module>
wizard.wizard(color=color, retries=retries, forcescan=force)
File "/usr/local/lib/python3.9/dist-packages/tinytuya/wizard.py", line 137, in wizard
cloud = tinytuya.Cloud( **config )
File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 109, in __init__
self._gettoken()
File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 246, in _gettoken
response_dict = self._tuyaplatform('token?grant_type=1')
File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 205, in _tuyaplatform
response = requests.get(url, headers=headers)
File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 573, in request
prep = self.prepare_request(req)
File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 484, in prepare_request
p.prepare(
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 368, in prepare
self.prepare_url(url, params)
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 436, in prepare_url
raise InvalidURL(*e.args)
requests.exceptions.InvalidURL: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
Posted: Friday 03 March 2023 21:27
by Xenomes
Can you try to update urllib3?
Posted: Friday 03 March 2023 22:12
by frenchyyii
python3 -m tinytuya wizard gives me:
File "/usr/local/lib/python3.9/dist-packages/tinytuya/wizard.py", line 128, in wizard
with open(CONFIGFILE, "w") as outfile:
PermissionError: [Errno 13] Permission denied: 'tinytuya.json'
but with sudo it seems to be ok except local devices are not found
it should be a owner problem... but now it's ok with DZ !!!
Thanks again
