Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Xenomes
Domoticz version: 2026.4
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Post by Xenomes »
Varazir wrote: Friday 27 January 2023 14:11 I tried to just delete it from the device list but it didn't help.
That should do the trick. Normally then the device exist creation is skipped. I will do a test tonight.
Edit:
did you delete Plugin 13 TinyTuya ID = 43035720e098061d58bc unit = 1?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Varazir
Post by Varazir »
Xenomes wrote: Friday 27 January 2023 14:20
Edit:
I deleted it from the device list and turned the plugin off and on, did even restart domoticz but still got the same error.
Tried to turn off the plugin and delete the device and enabled the plugin again, still same error.
Xenomes
Post by Xenomes »
Varazir wrote: Friday 27 January 2023 14:32 I deleted it from the device list and turned the plugin off and on, did even restart domoticz but still got the same error.
Is see the problem, forgot a piece of code that do the device exist creation skip procedure.
Tinytuya
Xenomes
Post by Xenomes »
Xenomes wrote: Friday 27 January 2023 14:41
Pushed a update (no version change)
Tinytuya
Varazir
Post by Varazir »
Xenomes wrote: Friday 27 January 2023 15:02
Updated and restarted domoticz and no errors
Xenomes
Post by Xenomes »
Varazir wrote: Friday 27 January 2023 17:35 tarted domoticz and no errors
Ha, Great! But can you control the fan?
Tinytuya
Varazir
Post by Varazir »
No errors when I turned it on from DZ but didn't check if it started. I'll check when I get home again.
Varazir
Post by Varazir »
Checked and it's working
Xenomes
Post by Xenomes »
Thanks for reporting back!
Tinytuya
frenchyyii
Post by frenchyyii »
Hi everyone, first thanx for the plugin !!
I got some trouble to get it work on one of my DZ, I suspect a Python depency
some informations here:
0 Error: Smartlife Tiny Tuya : Call to function 'onHeartbeat' failed, exception details:
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : Traceback (most recent call last):
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : File "/home/pi/domoticz/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 341, in onHeartbeat
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : _plugin.onHeartbeat()
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : File "/home/pi/domoticz/plugins/Domoticz-TinyTUYA-Plugin/plugin.py", line 302, in onHeartbeat
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : if time.time() - last_update < 60 and testData == False:
2023-03-03 18:20:23.061 Error: Smartlife Tiny Tuya : NameError: name 'last_update' is not defined
DZ is last beta on a RPI4 with python 3.9.2:
Version: 2023.1 (build 15109)
Build Hash: b3211fe6d
Compile Date: 2023-03-01 16:44:49
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
if someone can help
Eric
Xenomes
Post by Xenomes »
I checkt the code, this could happen if there are no devices in the tuya account. Can you check that? Also try to press update on the hardware place.
Tinytuya
frenchyyii
Thanks for your fast response.
Concerning the tuya project, it is ok (22 devices)
But when desactivate reactivate the harware in domotics (with other project credentials) i have seen this message too:
handleThread: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
I checked also Cloud Authorization IP Allowlist and it is off
Datacenter is central Europe
Where . Iottuya or domoticz ?
Oups another thing, now I'm on your dev branch but I've tried on the Master before and same reuslts
Xenomes
Post by Xenomes »
frenchyyii wrote: Friday 03 March 2023 20:19 Where . Iottuya or domoticz ?
You already did it in Domoticz when deactivation reactivate the hardware.
frenchyyii wrote: Friday 03 March 2023 20:19 But when desactivate reactivate the harware in domotics (with other project credentials) i have seen this message too:
This error is coming from TinyTuya, there is something you forgot re walk the steps to setup the iot account.
Tinytuya
frenchyyii
if it helsp:
 pip list
Package            Version
arandr             0.1.10
astroid            2.5.1
asttokens          2.0.4
automationhat      0.2.0
beautifulsoup4     4.9.3
blinker            1.4
blinkt             0.1.2
buttonshim         0.0.2
Cap1xxx            0.1.3
certifi            2020.6.20
chardet            4.0.0
charset-normalizer 3.0.1
click              7.1.2
colorama           0.4.4
colorzero          1.1
cryptography       3.3.2
cupshelpers        1.0
dbus-python        1.2.16
distlib            0.3.6
distro             1.5.0
docutils           0.16
drumhat            0.1.0
enum-compat        0.0.2
envirophat         1.0.0
ExplorerHAT        0.4.2
filelock           3.9.0
Flask              1.1.2
fourletterphat     0.1.0
gpiozero           1.6.2
html5lib           1.1
idna               2.6
isort              5.6.4
itsdangerous       1.1.0
jedi               0.18.0
Jinja2             2.11.3
lazy-object-proxy  0.0.0
logilab-common     1.8.1
lxml               4.6.3
MarkupSafe         1.1.1
mccabe             0.6.1
microdotphat       0.2.1
mote               0.0.4
motephat           0.0.3
mypy               0.812
mypy-extensions    0.4.3
netifaces          0.10.6
numpy              1.19.5
oauthlib           3.1.0
pantilthat         0.0.7
parso              0.8.1
pexpect            4.8.0
pgzero             1.2
phatbeat           0.1.1
pianohat           0.1.0
picamera           1.13
picamera2          0.3.8
pidng              4.0.9
piexif             1.1.3
piglow             1.2.5
pigpio             1.78
Pillow             8.1.2
pip                23.0.1
platformdirs       3.0.0
psutil             5.8.0
pycairo            1.16.2
pycparser          2.18
pycryptodome       3.17
pycups             2.0.1
pygame             1.9.6
Pygments           2.7.1
PyGObject          3.38.0
pyinotify          0.9.6
PyJWT              1.7.1
pylint             2.7.2
PyOpenGL           3.1.5
pyOpenSSL          20.0.1
PyQt5              5.15.2
PyQt5-sip          12.8.1
pyserial           3.5b0
pysmbc             1.0.23
python-apt         2.2.1
python-prctl       1.7
PyYAML             5.3.1
rainbowhat         0.1.0
reportlab          3.5.59
requests           2.28.2
requests-oauthlib  1.0.0
responses          0.12.1
roman              2.0.0
RPi.GPIO           0.7.0
RTIMULib           7.2.1
scrollphat         0.0.7
scrollphathd       1.2.1
Send2Trash         1.6.0b1
sense-hat          2.4.0
setuptools         67.4.0
simplejpeg         1.6.4
simplejson         3.17.2
six                1.11.0
skywriter          0.0.7
sn3218             1.2.7
soupsieve          2.2.1
spidev             3.5
ssh-import-id      5.10
thonny             4.0.1
tinytuya           1.10.3
toml               0.10.1
touchphat          0.0.1
tuyaha             0.0.11
twython            3.8.2
typed-ast          1.4.2
typing-extensions  3.7.4.3
unicornhathd       0.0.4
urllib3            1.26.5
v4l2-python3       0.3.1
virtualenv         20.20.0
webencodings       0.5.1
Werkzeug           1.0.1
wheel              0.34.2
wrapt              1.12.1
frenchyyii
cross messaging ... i don't think so but I'll check the autorisations
frenchyyii
Everything seems to be ok, but when I check the API errors they are present with the project domoticz2 that is the one on this PI4
No error withe domoticz1 project that uses the other Pi4 with python 3.7
could'nt it be request module or somethink like that ?
Running the tool
same error with line24 added (sudo or not sudo ^^)
debug_discovery: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1 line 24
Xenomes
Post by Xenomes »
Try running
python3 -m tinytuya wizard
is something is missing you wil see it i hope.
Tinytuya
frenchyyii
Done
    "apiKey": "xxxxxx",
    "apiSecret": "xxxxxx",
    "apiRegion": "eu",
    "apiDeviceID": xxxxx002462ab3d7a00"
  File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 434, in prepare_url
    scheme, auth, host, port, path, query, fragment = parse_url(url)
  File "/usr/lib/python3/dist-packages/urllib3/util/url.py", line 394, in parse_url
    return six.raise_from(LocationParseError(source_url), None)
  File "<string>", line 3, in raise_from
urllib3.exceptions.LocationParseError: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/__main__.py", line 76, in <module>
    wizard.wizard(color=color, retries=retries, forcescan=force)
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/wizard.py", line 137, in wizard
    cloud = tinytuya.Cloud( **config )
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 109, in __init__
    self._gettoken()
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 246, in _gettoken
    response_dict = self._tuyaplatform('token?grant_type=1')
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/Cloud.py", line 205, in _tuyaplatform
    response = requests.get(url, headers=headers)
  File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 73, in get
    return request("get", url, params=params, **kwargs)
  File "/usr/local/lib/python3.9/dist-packages/requests/api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 573, in request
    prep = self.prepare_request(req)
  File "/usr/local/lib/python3.9/dist-packages/requests/sessions.py", line 484, in prepare_request
    p.prepare(
  File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 368, in prepare
    self.prepare_url(url, params)
  File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 436, in prepare_url
    raise InvalidURL(*e.args)
requests.exceptions.InvalidURL: Failed to parse: https://openapi.tuyaeu.com/v1.0/token?grant_type=1
Xenomes
Post by Xenomes »
Can you try to update urllib3?
pip3 install -U urllib3
Tinytuya
frenchyyii
python3 -m tinytuya wizard gives me:
  File "/usr/local/lib/python3.9/dist-packages/tinytuya/wizard.py", line 128, in wizard
    with open(CONFIGFILE, "w") as outfile:
PermissionError: [Errno 13] Permission denied: 'tinytuya.json'
but with sudo it seems to be ok except local devices are not found
it should be a owner problem... but now it's ok with DZ !!!
Thanks again 8-)
