Rooted Toon plugin
pvdgulik
Domoticz version: 2023.1
Re: Rooted Toon plugin
Post by pvdgulik »
After installing this plugin for the third time, I do still have the same problem.
All my devices seemed to be lost. Although everything works fine.
This happens after installing the Rootd Toon Plugin, start "accept new devices for 5 minutes, and than set the Hardware RootedToon on active.
What to do?
Other suggestion :
What would be nice is to have the humidity sensor of the Toon 2 in Domoticz.
Thank you!
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
pvdgulik wrote: Wednesday 03 March 2021 19:48
Other suggestion :
Don’t believe this accesable.
rick083
Post by rick083 »
madpatrick wrote: Wednesday 03 March 2021 19:20
rick083 wrote: Wednesday 03 March 2021 12:09 After installing the Plugin (v 1.09) looks like there's one device missing in my device list ( IDX 114 ). After IDX 113 the list is showing IDX 115, 116 etc.
My Logfile Shows:
2021-03-03 11:30:00.839 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 114, sValue: '', sUsage: '0', dType: 251, sType: 2)
2021-03-03 11:33:13.485 Error: Gas - invalid value: ''
2021-03-03 11:35:00.491 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 114, sValue: '', sUsage: '0', dType: 251, sType: 2)
2021-03-03 11:40:00.108 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 114, sValue: '', sUsage: '0', dType: 251, sType: 2)
2021-03-03 11:42:05.540 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connected.
2021-03-03 11:42:13.500 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connected.
2021-03-03 11:45:00.660 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 114, sValue: '', sUsage: '0', dType: 251, sType: 2)
Looks like the Gas counter is not present; Any way to correct this ? Thanks...
You can try to remove the hardware and reinstall the plugin.
After installing of the plugin, the hardware will be created
Magical: I removed the hard,- and software; Performed a new install; The devices were for 2 minutes complete; including the gasmeter!
After that the Gasmeter again dispeared out of the devicelist...Now it's IDX 106..Strange
2021-03-03 20:34:06.670 Error: Gas - invalid value: ''
2021-03-03 20:35:00.896 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 106, sValue: '', sUsage: '0', dType: 251, sType: 2)
rick083
Post by rick083 »
Looks like something has been changed for unit 7...
       if 6 not in Devices:
            Domoticz.Device(Name="Program info", Unit=6, TypeName="Text").Create()
        if 7 not in Devices:
            Domoticz.Device(Name="Gas", Unit=7, TypeName="Gas").Create()
            #Domoticz.Device(Name="Gas", Unit=7, Type=243, Subtype=33, Switchtype=1).Create()
        if 8 not in Devices:
            #Domoticz.Device(Name="Electricity", Unit=8, TypeName="Usage").Create()
            Domoticz.Device(Name="Electricity", Unit=8, TypeName="kWh").Create()
Butt.. my knowledge is to limited; Someone having the same problem ?
madpatrick
What have set as value in your config of the plugin.
The error says “ Gas - invalid value: ‘’ “
madpatrick
Is your version number a type ? 1.09 ?
Latest i see is v1.07
Can you check your Toon JSON output and look for "CurrentGasFlow"
http://IP_TOON/hdrv_zwave?action=getDevices.json
This is my output
  "dev_2.1": {
    "uuid": "d9c5dbad-517f-4107-8c07-3be0596e42b3",
    "name": "HAE_METER_v3_1",
    "internalAddress": "2.1",
    "type": "HAE_METER_v3_1",
    "supportsCrc": "0",
    "ccList": "5e 59 85 8e 3c 3d 3e",
    "supportedCC": "5e 59 85 8e 3c 3d 3e",
    "nodeFlags": [
    "CurrentGasFlow": "68.00",
    "CurrentGasQuantity": "6767969.00",
    "DeviceName": "HAE_METER_v3_1",
    "CurrentSensorStatus": "OPERATIONAL"
Your dev number must be same as in the plugin (2.1)
rick083
Post by rick083 »
Correct: its version 1.07.
OK; There was no device name stated in JSON for the gasmeter; I Update the name to HAE_METER_v3_1; Than it was clear the device / internal adress is in an other range 3.1 / 3.2 etc. I corrected the adress nr in Domoticz Hardware; Is that enough, or is it better to change the internaladress nr to the 2.* range ? Is the devicename related to the internetadres ?
So after several restart the gasmeter showed up..and kept present ! This is the JSON reading after correction:
 "dev_3.1": {"uuid": "6f4c1571-18d8-4eb5-8d11-6f1441205494",
 "internalAddress": "3.1",
 "type": "gas",
 "supportsCrc": "0",
 "nodeFlags": [],
 "CurrentGasFlow": "37.00",
 "CurrentGasQuantity": "1653385.00",
 "DeviceName": "HAE_METER_v3_1"},
My logfile changed from red error lines to statuslines:
2021-03-04 21:41:09.261 (Toon Thermostaat) One or more Zwave internal address not configured correctly?
2021-03-04 21:41:19.482 (Toon Thermostaat) One or more Zwave internal address not configured correctly?
2021-03-04 21:41:29.810 (Toon Thermostaat) One or more Zwave internal address not configured correctly?
Ok, step by step getting there: elektricity was ok, but by now stil on "zero", Wait if they will come back again.
BTW; Is it possible to import the CurrentGasFlow into Domoticz ?
marigo
Post by marigo »
I used the python script from this thread and it is working. I also saw the output, like rick083, and had to change the predefined Gas and Elec parameters. For somehow the log was filled with an error.
onMessage aborted, response format not JSON
<?xml version="1.0" encoding="iso-8859-1"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>404 - Not Found</title>
</head>
<body>
<h1>404 - Not Found</h1>
</body>
</html>
Ended up it has something to do with the boiler pressure. I saw in the script this can only be red if you have an Opentherm connection with your CV installation, which I don't have. I use my rooted toon only as an "On/Off" device.
So I commented out all of the "boiler" status syntax in the "plugin.py" and no more log messages of the JSON format.
@hansaplast31
Thank you for this Plugin. :)
madpatrick
rick083 wrote: Thursday 04 March 2021 22:24
What do you exactly want.
Do wnt the values from an old sensor to the new sensor ?
This is easy when press at the switch : change (aanpassen) and then replace (vervang)
rick083
Post by rick083 »
By now the plugin is almost working stable; Only the electricity readings are starting the day with "0".
After changing some device settings its giving readings again: Can't find the exact problem yet..
All the other features are working fine, without Errors in the logfiles; Thanks for the plugin, and the assistance !
rick083
Post by rick083 »
Since this evening the logfile is full with red errorline; even after a restart no changes:
2021-03-07 19:57:18.388 (Toon Thermostaat) onStart called
2021-03-07 19:57:18.416 (Toon Thermostaat) {"HardwareID": 8, "HomeFolder": "/usr/local/domoticz/var/plugins/domoticz-rooted-toon/", "StartupFolder": "/usr/local/domoticz/", "UserDataFolder": "/usr/local/domoticz/var/", "WebRoot": "", "Database": "/usr/local/domoticz/var/domoticz.db", "Language": "en", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon Thermostaat", "Address": "192.168.1.###", "Port": "10080", "SerialPort": "", "Username": "", "Password": "", "Key": "RootedToonPlug", "Mode1": "3.1", "Mode2": "2.4", "Mode3": "2.6", "Mode4": "3.4", "Mode5": "3.6", "Mode6": "", "DomoticzVersion": "2020.2 (build 12731)", "DomoticzHash": "7933f659d-modified", "DomoticzBuildTime": "2020-12-06 10:22:02"}
2021-03-07 19:57:18.126 Status: (Toon Thermostaat) Started.
2021-03-07 19:57:18.381 Status: (Toon Thermostaat) Entering work loop.
2021-03-07 19:57:18.382 Status: (Toon Thermostaat) Initialized version 1.0.7, author 'Hansaplast31'
2021-03-07 19:57:33.726 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
2021-03-07 19:57:33.736 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
2021-03-07 19:57:33.746 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
2021-03-07 19:57:38.856 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
2021-03-07 19:57:38.866 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
2021-03-07 19:57:38.876 Error: CConnection_connect, connect request from 'Toon Thermostaat' ignored. Transport is connecting.
Except the temperatuur reading everything looks to be working...Any sugestions ?
EdwinK
Post by EdwinK »
Trying this plugin again.
Now I get the following in the error-log:
2021-03-08 11:00:14.036 Error: dzVents: Error: (3.1.5) Discarding device. No last update info found: {["rawData"]={"18.5"}, ["switchType"]="On/Off", ["subType"]="SetPoint", ["lastLevel"]=255, ["lastUpdate"]="", ["image"]="", ["deviceID"]="", ["data"]={["hardwareName"]="Toon (Test)", ["customImage"]=0, ["icon"]="override_mini", ["hardwareType"]="Rooted Toon", ["hardwareTypeValue"]=94, ["setPoint"]=18.5, ["hardwareID"]=58, ["_state"]="18.5", ["_nValue"]=0, ["protected"]=false, ["unit"]=2}, ["description"]="", ["name"]="Toon (Test) - Setpoint Temperature", ["switchTypeValue"]=0, ["id"]=1054, ["batteryLevel"]=1958209912, ["signalLevel"]=2, ["deviceType"]="Thermostat", ["baseType"]="device", ["changed"]=true, ["timedOut"]=false, ["protected"]=false, ["iconNumber"]=91}
Also in the devices tab:
Toon (Test) 0036000A 10 Toon (Test) - P1 Electricity P1 Smart Meter Energy Invalid!:
Would this because I don't have any solarpanels?
EdwinK
Post by EdwinK »
No one?
additional error message:
2021-03-23 22:05:32.430 Python Plugin System: (Toon) One or more Zwave internal address not configured correctly?
i'm using a Toon 1, and entered the numbers that were listed on the plugin page.
EdwinK
Post by EdwinK »
rick083 wrote: Sunday 07 March 2021 20:06 Since this evening the logfile is full with red errorline; even after a restart no changes:
Did you get this fixed?
madpatrick
EdwinK wrote: Tuesday 23 March 2021 22:06 No one?
Edwin,
Unfortunately is the writer of the plugin not responding
The plugin is in the base a good plugin, but not yet completed.
I'm not in to depth of programming, but trying to help
I've tested the plugin and it was working fine. Still thinking whether to switch to the plugin or stay with my script.....
Now your problem
Did you check your devices. The number can be differenent per Toon. Also on a Toon1 can the something be different device numbers
Can you check the output of
http://xxx.xxx.x.x./hdrv_zwave?action=getDevices.json
and look for
"internalAddress": "x.x",
EdwinK
Post by EdwinK »
Been looking at that output for some time, and see that 'Internal Adress' 10 times
dev_2: {
uuid: "613a67ae-0412-45b3-9a1a-c147570fa19a",
internalAddress: "2",
type: "HAE_METER_v3",
supportsCrc: "1",
ccList: "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
supportedCC: "5e 86 72 32 56 5a 59 85 73 7a 60 8e 22 70 8b 3c 3d 3e",
nodeFlags: [ ],
IsConnected: "1",
HealthValue: "10",
DeviceName: "HAE_METER_v3",
CurrentSensorStatus: "UNKNOWN"
dev_2.1: {
uuid: "f2393423-dde2-4f30-a5ea-561a19361126",
internalAddress: "2.1",
type: "HAE_METER_v3_1",
supportsCrc: "0",
ccList: "5e 59 85 8e 3c 3d 3e",
supportedCC: "5e 59 85 8e 3c 3d 3e",
nodeFlags: [ ],
CurrentGasFlow: "123.00",
CurrentGasQuantity: "2439151.00",
DeviceName: "HAE_METER_v3_1",
CurrentSensorStatus: "OPERATIONAL"
dev_2.2: {
uuid: "84ecf9de-3ff7-4b94-b14e-9add4e9a55c5",
internalAddress: "2.2",
type: "HAE_METER_v3_2",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_2",
CurrentSensorStatus: "UNKNOWN",
CurrentElectricityFlow: "NaN",
CurrentElectricityQuantity: "NaN"
dev_2.3: {
uuid: "956d126a-a3c5-4964-91c0-1af315fb9f2c",
internalAddress: "2.3",
type: "HAE_METER_v3_3",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_3",
CurrentElectricityQuantity: "NaN",
dev_2.4: {
uuid: "ed4642ef-285a-487c-b1e5-e5fd9f7e1aa1",
internalAddress: "2.4",
type: "HAE_METER_v3_4",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_4",
CurrentElectricityFlow: "317.00",
CurrentElectricityQuantity: "6017853.00",
dev_2.5: {
uuid: "95a0485e-f462-43c4-a2b6-a58b47230f53",
internalAddress: "2.5",
type: "HAE_METER_v3_5",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_5",
CurrentElectricityFlow: "0.00",
CurrentElectricityQuantity: "0.00",
dev_2.6: {
uuid: "ec38b1d6-fa71-43e6-bc36-a26acceb7c52",
internalAddress: "2.6",
type: "HAE_METER_v3_6",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_6",
CurrentElectricityQuantity: "6227531.00",
dev_2.7: {
uuid: "7400faa9-f92f-4fb5-b7f2-4ffde650469f",
internalAddress: "2.7",
type: "HAE_METER_v3_7",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_7",
dev_2.8: {
uuid: "95f2ab46-e8b5-4ae1-bd95-b599782e5852",
internalAddress: "2.8",
type: "HAE_METER_v3_8",
supportsCrc: "0",
nodeFlags: [ ],
DeviceName: "HAE_METER_v3_8",
CurrentHeatQuantity: "NaN",
dev_settings_device: {
uuid: "6b6a1f78-bea9-46f9-a053-87461583d393",
internalAddress: "settings_device",
type: "settings_device"
madpatrick
Looks good.
In fact the plugin should work with your setting.
Did you try to remove all hardware created by the plugin and re-installation which will recreated the devices again ?
EdwinK
Post by EdwinK »
Nope, did not. Might as well try that later tomorrow ;)
EdwinK
Post by EdwinK »
Well, back to the script it is.
Nodri
Post by Nodri »
Hello all,
after my domotica raspi crashed i had to do a fres install.
I installed the "Rooted Toon" plugin and activated it.
My devices disapear when i enable the plugin.
This is what the log says:
2021-03-29 18:13:11.862 (Toon) {"HardwareID": 5, "HomeFolder": "/home/pi/domoticz/plugins/domoticz-rooted-toon-master/", "StartupFolder": "/home/pi/domoticz/", "UserDataFolder": "/home/pi/domoticz/", "WebRoot": "", "Database": "/home/pi/domoticz/domoticz.db", "Language": "en", "Version": "1.0.7", "Author": "Hansaplast31", "Name": "Toon", "Address": "xxxxxxxxxx", "Port": "80", "SerialPort": "", "Username": "", "Password": "", "Key": "RootedToonPlug", "Mode1": "2.1", "Mode2": "2.3", "Mode3": "2.5", "Mode4": "2.4", "Mode5": "2.6", "Mode6": "", "DomoticzVersion": "2020.2", "DomoticzHash": "b63341bc0", "DomoticzBuildTime": "2020-04-26 12:47:55"}
What am i missing?
PS. i ghosted my IP adress
