zigate tuya siren
Re: zigate tuya siren
@marktn I'm ready to help you, but I do not understand what is your issue.
The logs are incomplete - or at least do not show what I'm looking with debugPairing and debugTuya enabled
In the the export.json you provided I see 2 sirens:
804b50fffe048336 (seems the new one)
- Temp+Hum, Temp and Humi widget have been created
- looks no data have been provided by the device
From your video where the siren is flashing, I don't know what is that. Anything in the Siren manual about that behaviour ?
On the other side, I see 40 devices connected to the ZiGate and you might be at the limit
BTW, I don't think that it is plan to recharge the battery. My understanding is ether running on Battery or on USB Power, the the USB power do not recharge
Is there a limit... is there a way to get more devices?On the other side, I see 40 devices connected to the ZiGate and you might be at the limit
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
- Domoticz version: 2026.3
The official limit is 40 directly and 30 extra when connected with a router. Mine was full way earlier (32 devices) due to some kind of poor memory management. I updated to firmware 31e and now I have 34 devices connected without issues.
Is there a way to expand that to more devices?waltervl wrote: Sunday 04 July 2021 10:46 The official limit is 40 directly and 30 extra when connected with a router. Mine was full way earlier (32 devices) due to some kind of poor memory management. I updated to firmware 31e and now I have 34 devices connected without issues.
there is the 31e OptiPDM version , but would required a full Erase EEPROM and Erase PDM so you'll have to repair all your devices
When repairing, the IDX stays the same?pipiche wrote: Sunday 04 July 2021 12:07 there is the 31e OptiPDM version , but would required a full Erase EEPROM and Erase PDM so you'll have to repair all your devices
Maybe good to solve that firts before fixing the siren. The seller send me a new siren!
- firefox_2021-07-04_13-13-59.jpg (35.58 KiB) Viewed 2230 times
When you redo the pairing you have just reset the Zigate, not the plugin nor Domoticz, so all devices will reconnect to the Domoticz widget automaticaly, no lost of history and stuff like.
Thanks, i will do that later! Need some time for that, better after the holiday.pipiche wrote: Sunday 04 July 2021 13:24 When you redo the pairing you have just reset the Zigate, not the plugin nor Domoticz, so all devices will reconnect to the Domoticz widget automaticaly, no lost of history and stuff like.
Never expexcted to have that much devices...
Then there will always 2 different firmware's in the future, i will go to the OptiPDM.
Is there a wiki to erease PDM?
Is there also a v3.1f as OptiPDM? I just was reading the wiki, and see the new version.
There is no 3.1f voor Zigate V1 only for V2 (or +)
https://github.com/fairecasoimeme/ZiGate/tags
Yes I think I confused everyone, my apologies for that.
The update is done, it took some time to repair al devices. But it works!
I removed the sirens complete, and did a new pair.
But they don't work. Only one is working, the first one i bought.
Attached some logs of domoticz, is this is problem? send a Leave indication and will be outside of the network. LQI: 0
And what is this, Error: Zigate: (Zigate) Firmware 0320 is not yet supported
2021-09-11 11:01:24.091 Status: buitenzitweer uitgeschakeld
2021-09-11 11:01:28.724 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:01:39.661 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Active Endpoint Response Ep: 01 LQI: 189
2021-09-11 11:01:39.663 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Request Simple Descriptor for Ep: 01
2021-09-11 11:01:39.403 Error: Zigate: (Zigate) DeviceExist - Found some inconsistency Inputs: 7d61 804b50fffe047063 instead of None
2021-09-11 11:01:40.412 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Simple Descriptor Response EP: 0x01 LQI: 189
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 ProfileID 0104
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 ZDeviceID 0051
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Application Version 0001
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster IN Count: 04
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster In 1: 0000 (Basic)
2021-09-11 11:01:40.413 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster In 2: 0004 (Groups)
2021-09-11 11:01:40.414 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster In 3: 0005 (Scenes)
2021-09-11 11:01:40.414 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster In 4: ef00
2021-09-11 11:01:40.414 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster OUT Count: 02
2021-09-11 11:01:40.414 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster Out 1: 0019 (Over-the-Air Upgrade)
2021-09-11 11:01:40.414 Status: Zigate: (Zigate) [ZiGateForwarder_16] [-] NEW OBJECT: 7d61 Cluster Out 2: 000a (Time)
2021-09-11 11:01:43.074 Status: Zigate: (Zigate) [0] NEW OBJECT: 7d61 Model Name: TS0601-sirene
2021-09-11 11:01:46.262 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:01:58.730 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:01:58.761 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:02:45.691 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:02:45.817 Error: dzVents: Error: (3.1.7) Discarding device. No last update info found: {["switchType"]="Selector", ["batteryLevel"]=1821354840, ["protected"]=false, ["deviceType"]="Light/Switch", ["subType"]="Selector Switch", ["image"]="", ["changed"]=true, ["lastUpdate"]="", ["data"]={["_state"]="Alarm 1", ["hardwareTypeValue"]=94, ["levelVal"]=10, ["hardwareName"]="Zigate", ["unit"]=23, ["customImage"]=0, ["Image"]="Light", ["icon"]="Light", ["levelNames"]="Off|Alarm 1|Alarm 2|Alarm 3|Alarm 4|Alarm 5", ["hardwareID"]=1972728, ["maxDimLevel"]=100, ["levelOffHidden"]=false, ["hardwareType"]="Zigate plugin", ["usedByCamera"]=false, ["protected"]=false, ["levelActions"]="|||||", ["_nValue"]=1}, ["signalLevel"]=1821354768, ["iconNumber"]=88, ["switchTypeValue"]=18, ["name"]="Zigate - TS0601-sirene_TuyaSiren-804b50fffe047063-01", ["baseType"]="device", ["timedOut"]=true, ["id"]=5021, ["rawData"]={"10"}, ["deviceID"]="", ["lastLevel"]=255, ["description"]=""}
2021-09-11 11:02:58.781 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:18.680 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 7d61 Ieee: 804b50fffe047063 MacCap: 80
2021-09-11 11:21:20.355 Status: Zigate: (Zigate) [ZiGateForwarder_16] (7d61/804b50fffe047063) send a Leave indication and will be outside of the network. LQI: 0
2021-09-11 11:18:52.561 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:18:56.239 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:18:59.433 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:18:59.467 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:19:02.668 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:19:05.072 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-11 11:19:10.267 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:19:14.522 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:19:19.466 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:19:19.498 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-11 11:19:24.313 EventSystem: Event triggered: Buitenzit weer_2
2021-09-11 11:19:24.332 Dummy: Light/Switch (Buitenzit weer)
2021-09-11 11:19:24.314 Status: buitenzitweer uitgeschakeld
2021-09-11 11:19:27.617 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:61192' ignored.
2021-09-11 11:19:27.671 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:61194' ignored.
2021-09-11 11:19:29.473 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:19:44.540 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:19:59.489 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:20:00.515 Status: dzVents: Info: EnergyCost: ------ Start internal script: Energieverbruik Jacuzzi:, trigger: "every 10 minutes"
2021-09-11 11:20:00.536 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Jacuzzi verbruik: kWh device adapter
2021-09-11 11:20:00.537 Status: dzVents: Debug: EnergyCost: Processing device-adapter for Stroomkosten Jacuzzi: Custom sensor device adapter
2021-09-11 11:20:00.538 Status: dzVents: Info: EnergyCost: ------ Finished Energieverbruik Jacuzzi
2021-09-11 11:20:02.678 Status: Notification sent (Email)
2021-09-11 11:20:15.740 Slave Synolgy: Light/Switch (Phone-Mark)
2021-09-11 11:20:15.885 Slave Synolgy: Light/Switch (Phone-Minke)
2021-09-11 11:20:15.984 Slave Synolgy: Light/Switch (Phone-Maud)
2021-09-11 11:20:16.073 Slave Synolgy: Light/Switch (Phone-Mark_werk)
2021-09-11 11:20:16.281 Slave Synolgy: Light/Switch (Extender-3)
2021-09-11 11:20:24.125 EventSystem: Event triggered: Buitenzit weer_2
2021-09-11 11:20:24.171 Dummy: Light/Switch (Buitenzit weer)
2021-09-11 11:20:24.125 Status: buitenzitweer uitgeschakeld
2021-09-11 11:20:29.506 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:20:39.507 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:20:39.527 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-11 11:20:44.532 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:20:45.840 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:20:47.474 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:20:51.105 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-11 11:20:59.515 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:08.327 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:61196' ignored.
2021-09-11 11:21:08.327 Error: Zigate: (Zigate) No transport, write directive to '192.168.1.41:61195' ignored.
2021-09-11 11:21:13.915 Status: Zigate: (Zigate) [ZiGateForwarder_16] (7d61/804b50fffe047063) send a Leave indication and will be outside of the network. LQI: 0
2021-09-11 11:21:14.057 Slave Synolgy: Light/Switch (Phone-Mark)
2021-09-11 11:21:14.158 Slave Synolgy: Light/Switch (Phone-Minke)
2021-09-11 11:21:14.260 Slave Synolgy: Light/Switch (Phone-Maud)
2021-09-11 11:21:14.370 Slave Synolgy: Light/Switch (Phone-Mark_werk)
2021-09-11 11:21:14.460 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:21:14.626 Slave Synolgy: Light/Switch (Extender-3)
2021-09-11 11:21:24.292 EventSystem: Event triggered: Buitenzit weer_2
2021-09-11 11:21:24.336 Dummy: Light/Switch (Buitenzit weer)
2021-09-11 11:21:24.293 Status: buitenzitweer uitgeschakeld
2021-09-11 11:21:25.297 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 7d61 Ieee: 804b50fffe047063 MacCap: 80
2021-09-11 11:21:29.527 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:44.500 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:21:44.096 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 37fc Ieee: 804b50fffe048336 MacCap: 80
2021-09-11 11:21:49.565 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:59.570 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:59.603 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:21:59.634 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-11 11:22:02.859 Status: Notification sent (Email)
2021-09-11 11:22:14.895 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:22:24.132 EventSystem: Event triggered: Buitenzit weer_2
2021-09-11 11:22:24.176 Dummy: Light/Switch (Buitenzit weer)
2021-09-11 11:22:24.132 Status: buitenzitweer uitgeschakeld
2021-09-11 11:22:29.599 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:22:29.198 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:22:44.908 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:22:44.894 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:22:46.694 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:22:59.608 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:23:03.344 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: cd62 Ieee: 5c0272fffecea9d6 MacCap: 80
2021-09-11 11:23:07.147 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:23:13.606 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:23:42.436 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: cd62 Ieee: 5c0272fffecea9d6 MacCap: 80
2021-09-11 11:23:44.902 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:23:45.572 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 37fc Ieee: 804b50fffe048336 MacCap: 80
2021-09-11 11:23:48.344 Status: Zigate: (Zigate) [ZiGateForwarder_16] (37fc/804b50fffe048336) send a Leave indication and will be outside of the network. LQI: 0
2021-09-11 11:23:51.718 Status: Zigate: (Zigate) NetworkID : fd7e is replacing 37fc and is attached to IEEE : 804b50fffe048336
2021-09-11 11:23:51.887 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: fd7e Ieee: 804b50fffe048336 MacCap: 80
2021-09-11 11:23:56.642 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - KastTV -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:23:59.632 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:24:00.258 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-11 11:25:10.975 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 7d61 Ieee: 804b50fffe047063 MacCap: 80
2021-09-11 11:25:14.387 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:25:15.746 Status: Zigate: (Zigate) [ZiGateForwarder_16] (7d61/804b50fffe047063) send a Leave indication and will be outside of the network. LQI: 0
2021-09-11 11:25:19.375 Status: Zigate: (Zigate) NetworkID : 2eed is replacing 7d61 and is attached to IEEE : 804b50fffe047063
2021-09-11 11:25:19.554 Status: Zigate: (Zigate) [ZiGateForwarder_16] Device Annoucement: NwkId: 2eed Ieee: 804b50fffe047063 MacCap: 80
2021-09-11 11:25:20.104 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:25:22.112 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-11 11:25:24.226 EventSystem: Event triggered: Buitenzit weer_2
2021-09-11 11:25:24.242 Dummy: Light/Switch (Buitenzit weer)
2021-09-11 11:25:24.226 Status: buitenzitweer uitgeschakeld
2021-09-11 11:25:26.427 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:25:29.700 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:25:44.412 Slave Synolgy: Light/Switch (Extender-1)
2021-09-11 11:25:47.519 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-11 11:25:53.359 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-11 11:25:59.716 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:25:59.749 Slave Synolgy: General/Percentage (Unknown)
2021-09-11 11:25:59.782 Slave Synolgy: General/Custom Sensor (Unknown)
keros
The 3.20 firmware came a few days ago. Do you have your plugin up to date ? What is your version and branch ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
Thanks for your support. I did a update of the plugin.keros wrote: Saturday 11 September 2021 22:04 The 3.20 firmware came a few days ago. Do you have your plugin up to date ? What is your version and branch ?
DomoticzVersion : 2021.1
FirmwareVersion : 0320
HardwareID : 16
PluginBranch : beta
PluginVersion : 4.12.107
keros
As said on the other topic, since 4.12.107, you have to change the branch to stable5 to continue to receive the updates.
I have 3 sirens, gave them a number.keros wrote: Saturday 11 September 2021 23:25 As said on the other topic, since 4.12.107, you have to change the branch to stable5 to continue to receive the updates.
number 1, not working
number 2, working!
number 3 not working
Done!
PluginBranch : stable5
PluginVersion : 5.1.003
2021-09-12 09:55:18.911 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-12 09:55:22.116 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-12 09:55:30.228 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-12 09:55:32.893 Status: buitenzitweer uitgeschakeld
2021-09-12 09:55:49.341 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5021/Zigate - nummer1 -TS0601-sirene_TuyaSiren-804b50fffe047063-01/Set Level)
2021-09-12 09:55:52.588 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5027/Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01/Set Level)
2021-09-12 09:56:07.542 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Leve
2021-09-12 09:55:58.710 Zigate: (Zigate) tuya_response - Model: TS0601-sirene Nwkid: cd62/01 dp: 66 dt: 04 data: 01
2021-09-12 09:55:58.710 Zigate: (Zigate) tuya_siren_response - Nwkid: cd62 dp: 66 data: 01
2021-09-12 09:55:58.710 Zigate: (Zigate) tuya_siren_response - Alarm Melody 0x0473 1
2021-09-12 09:55:58.815 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: af, Data: 00cd6201ef0077, LQI: 0
2021-09-12 09:55:58.832 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: a0, Data: 00cd6201ef0078, LQI: 0
2021-09-12 09:55:58.940 Zigate: (Zigate) ZigateRead - MsgType: 8002, MsgLength: 0018, MsgCRC: f3, Data: 000104ef00010102cd6202000009260200046801000101, LQI: 108
2021-09-12 09:55:58.941 Zigate: (Zigate) Reception Data indication, Source Address : cd62 Destination Address : 0000 ProfilID : 0104 ClusterID : ef00 Message Payload : 09260200046801000101
2021-09-12 09:55:58.941 Zigate: (Zigate) Decode8002 - NwkId: cd62 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 02 Data: 00046801000101
2021-09-12 09:55:58.941 Zigate: (Zigate) inRawAps Nwkid: cd62 Ep: 01 Cluster: ef00 ManufCode: None Cmd: 02 Data: 00046801000101
2021-09-12 09:55:58.941 Zigate: (Zigate) inRawAps Nwkid: cd62 Ep: 01 Cluster: ef00 ManufCode: None manuf: 1002 manuf_name: _TZE200_d0yu2xgi Cmd: 02 Data: 00046801000101
2021-09-12 09:55:58.942 Zigate: (Zigate) tuya_response - Model: TS0601-sirene Nwkid: cd62/01 dp: 68 dt: 01 data: 01
2021-09-12 09:55:58.942 Zigate: (Zigate) tuya_siren_response - Nwkid: cd62 dp: 68 data: 01
2021-09-12 09:55:58.995 Zigate: (Zigate) UpdateDevice - (Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01) 1:10
2021-09-12 09:55:59.041 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: a1, Data: 00cd6201ef0079, LQI: 0
2021-09-12 09:55:59.058 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: a2, Data: 00cd6201ef007a, LQI: 0
2021-09-12 09:55:59.500 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 2e, Data: 0b2e2b0b030000040021000269a2, LQI: 72
2021-09-12 09:55:59.501 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:55:59.504 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:55:59.504 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:55:59.504 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: c4, Data: 0b2e2b0b0300000300210002785e, LQI: 72
2021-09-12 09:55:59.504 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:55:59.507 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:55:59.507 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:55:59.508 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 62, Data: 0b2e2b0b03000007002100020185, LQI: 72
2021-09-12 09:55:59.508 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:55:59.510 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:55:59.510 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:00.511 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: ae, Data: 0b861f0b030000040021000269a2, LQI: 84
2021-09-12 09:56:00.511 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:00.515 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:00.515 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:00.515 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 44, Data: 0b861f0b0300000300210002785e, LQI: 84
2021-09-12 09:56:00.515 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:00.519 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:00.519 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:00.520 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: e2, Data: 0b861f0b03000007002100020185, LQI: 84
2021-09-12 09:56:00.520 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0b ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:00.522 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:00.522 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:03.923 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 21, Data: 01dce301000600000010000100, LQI: 132
2021-09-12 09:56:03.923 Zigate: (Zigate) Decode8102 - Attribute Reports : [dce3:01] MsgSQN: 01 ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2021-09-12 09:56:03.924 Zigate: (Zigate) ReadCluster - 0006 - dce3/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2021-09-12 09:56:03.927 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2021-09-12 09:56:03.928 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: da, Data: 00dce30100067b, LQI: 0
2021-09-12 09:56:04.173 Slave Synolgy: General/Percentage (Unknown)
2021-09-12 09:56:04.364 Zigate: (Zigate) ZigateRead - MsgType: 8002, MsgLength: 0018, MsgCRC: f3, Data: 000104ef00010102cd6202000009270200046801000100, LQI: 108
2021-09-12 09:56:04.364 Zigate: (Zigate) Reception Data indication, Source Address : cd62 Destination Address : 0000 ProfilID : 0104 ClusterID : ef00 Message Payload : 09270200046801000100
2021-09-12 09:56:04.365 Zigate: (Zigate) Decode8002 - NwkId: cd62 Ep: 01 Cluster: ef00 GlobalCommand: False Command: 02 Data: 00046801000100
2021-09-12 09:56:04.365 Zigate: (Zigate) inRawAps Nwkid: cd62 Ep: 01 Cluster: ef00 ManufCode: None Cmd: 02 Data: 00046801000100
2021-09-12 09:56:04.365 Zigate: (Zigate) inRawAps Nwkid: cd62 Ep: 01 Cluster: ef00 ManufCode: None manuf: 1002 manuf_name: _TZE200_d0yu2xgi Cmd: 02 Data: 00046801000100
2021-09-12 09:56:04.366 Zigate: (Zigate) tuya_response - Model: TS0601-sirene Nwkid: cd62/01 dp: 68 dt: 01 data: 00
2021-09-12 09:56:04.366 Zigate: (Zigate) tuya_siren_response - Nwkid: cd62 dp: 68 data: 00
2021-09-12 09:56:04.387 Zigate: (Zigate) UpdateDevice - (Zigate - nummer2- TS0601-sirene_TuyaSiren-5c0272fffecea9d6-01) 0:00
2021-09-12 09:56:04.415 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: a4, Data: 00cd6201ef007c, LQI: 0
2021-09-12 09:56:04.428 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: a5, Data: 00cd6201ef007d, LQI: 0
2021-09-12 09:56:07.594 Zigate: (Zigate) tuya_siren_alarm - fd7e onoff: 1
2021-09-12 09:56:07.595 Zigate: (Zigate) tuya_siren_alarm_duration - fd7e duration: 5
2021-09-12 09:56:07.595 Zigate: (Zigate) raw_APS_request - ackIsDisabled: False Addr: fd7e Ep: 01 Cluster: ef00 ProfileId: 0104 Payload: 11270000226702000400000005
2021-09-12 09:56:07.596 Zigate: (Zigate) tuya_cmd - fd7e/01 cmd: 00 payload: 11270000226702000400000005
2021-09-12 09:56:07.596 Zigate: (Zigate) tuya_siren_alarm_volume - fd7e volume: 2
2021-09-12 09:56:07.596 Zigate: (Zigate) raw_APS_request - ackIsDisabled: False Addr: fd7e Ep: 01 Cluster: ef00 ProfileId: 0104 Payload: 11270000237404000102
2021-09-12 09:56:07.597 Zigate: (Zigate) tuya_cmd - fd7e/01 cmd: 00 payload: 11270000237404000102
2021-09-12 09:56:07.597 Zigate: (Zigate) tuya_siren_alarm_melody - fd7e onoff: 1
2021-09-12 09:56:07.599 Zigate: (Zigate) raw_APS_request - ackIsDisabled: False Addr: fd7e Ep: 01 Cluster: ef00 ProfileId: 0104 Payload: 11270000246604000101
2021-09-12 09:56:07.600 Zigate: (Zigate) tuya_cmd - fd7e/01 cmd: 00 payload: 11270000246604000101
2021-09-12 09:56:07.600 Zigate: (Zigate) raw_APS_request - ackIsDisabled: False Addr: fd7e Ep: 01 Cluster: ef00 ProfileId: 0104 Payload: 11270000256801000101
2021-09-12 09:56:07.601 Zigate: (Zigate) tuya_cmd - fd7e/01 cmd: 00 payload: 11270000256801000101
2021-09-12 09:56:07.654 Zigate: (Zigate) UpdateDevice - (Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01) 1:10
2021-09-12 09:56:07.672 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 007e0530017e0001, LQI: 0
2021-09-12 09:56:07.542 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-12 09:56:08.526 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: d0, Data: 0c2e2b0b000600000010000100, LQI: 72
2021-09-12 09:56:08.526 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0c ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2021-09-12 09:56:08.533 Zigate: (Zigate) ReadCluster - 0006 - 2e2b/0b AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2021-09-12 09:56:08.536 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2021-09-12 09:56:08.540 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 50, Data: 0c861f0b000600000010000100, LQI: 84
2021-09-12 09:56:08.540 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0c ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2021-09-12 09:56:08.547 Zigate: (Zigate) ReadCluster - 0006 - 861f/0b AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2021-09-12 09:56:08.550 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2021-09-12 09:56:09.535 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 28, Data: 0d2e2b0b030000040021000269a2, LQI: 72
2021-09-12 09:56:09.536 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:09.536 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:09.537 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:09.542 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: c2, Data: 0d2e2b0b0300000300210002785e, LQI: 72
2021-09-12 09:56:09.542 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:09.543 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:09.543 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:09.544 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 64, Data: 0d2e2b0b03000007002100020185, LQI: 72
2021-09-12 09:56:09.544 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:09.548 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:09.548 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:09.973 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 8a, Data: 00fd7e01ef007e, LQI: 0
2021-09-12 09:56:10.022 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 007f0530017f0001, LQI: 0
2021-09-12 09:56:10.548 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: a8, Data: 0d861f0b030000040021000269a2, LQI: 84
2021-09-12 09:56:10.548 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:10.549 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:10.549 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:10.550 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 42, Data: 0d861f0b0300000300210002785e, LQI: 84
2021-09-12 09:56:10.550 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:10.551 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:10.551 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:10.552 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: e4, Data: 0d861f0b03000007002100020185, LQI: 84
2021-09-12 09:56:10.552 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0d ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:10.553 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:10.553 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:10.642 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 53, Data: 8ca56401000600000010000101, LQI: 132
2021-09-12 09:56:10.643 Zigate: (Zigate) Decode8102 - Attribute Reports : [a564:01] MsgSQN: 8c ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-09-12 09:56:10.651 Zigate: (Zigate) ReadCluster - 0006 - a564/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2021-09-12 09:56:10.653 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2021-09-12 09:56:13.160 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 6a, Data: 00b9c101000a80, LQI: 0
2021-09-12 09:56:14.451 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 002a, MsgCRC: da, Data: 29c14c010000ff010042001d0121c70b03281a0421a81305211300062407000101010a210000641000, LQI: 120
2021-09-12 09:56:14.451 Zigate: (Zigate) Decode8102 - Attribute Reports : [c14c:01] MsgSQN: 29 ClusterID: 0000 AttributeID: ff01 Status: 00 Type: 42 Size: 001d ClusterData: >0121c70b03281a0421a81305211300062407000101010a210000641000<
2021-09-12 09:56:14.455 Zigate: (Zigate) ReadCluster - 0000 - c14c/01 AttrId: ff01 AttrType: 42 Attsize: 001d Status: 00 AttrValue: 0121c70b03281a0421a81305211300062407000101010a210000641000
2021-09-12 09:56:14.455 Zigate: (Zigate) ReadCluster - 0000 ff01 Saddr: c14c ClusterData: 0121c70b03281a0421a81305211300062407000101010a210000641000
2021-09-12 09:56:15.018 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 8b, Data: 00fd7e01ef007f, LQI: 0
2021-09-12 09:56:15.046 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 0081053001810001, LQI: 0
2021-09-12 09:56:16.376 Slave Synolgy: Light/Switch (Extender-1)
2021-09-12 09:56:18.591 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 7c, Data: ceb9c101000600000010000100, LQI: 81
2021-09-12 09:56:18.592 Zigate: (Zigate) Decode8102 - Attribute Reports : [b9c1:01] MsgSQN: ce ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2021-09-12 09:56:18.601 Zigate: (Zigate) ReadCluster - 0006 - b9c1/01 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2021-09-12 09:56:18.609 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2021-09-12 09:56:19.548 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 2b, Data: 0e2e2b0b030000040021000269a2, LQI: 72
2021-09-12 09:56:19.548 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:19.549 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:19.549 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:19.550 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: c1, Data: 0e2e2b0b0300000300210002785e, LQI: 72
2021-09-12 09:56:19.550 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:19.551 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:19.551 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:19.552 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 67, Data: 0e2e2b0b03000007002100020185, LQI: 72
2021-09-12 09:56:19.552 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:19.552 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:19.553 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:20.087 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 75, Data: 00fd7e01ef0081, LQI: 0
2021-09-12 09:56:20.119 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 0082053001820001, LQI: 0
2021-09-12 09:56:20.498 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: b2, Data: 0f2e2b0b00080000002000015f, LQI: 72
2021-09-12 09:56:20.499 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 0f ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >5f<
2021-09-12 09:56:20.505 Zigate: (Zigate) ReadCluster - 0008 - 2e2b/0b AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 5f
2021-09-12 09:56:20.505 Zigate: (Zigate) ReadCluster - ClusterID: 0008 Addr: 2e2b MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: 5f
2021-09-12 09:56:20.506 Zigate: (Zigate) ReadCluster - ClusterId=0008 - 2e2b/0b Level Control: 5f
2021-09-12 09:56:20.526 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: a8, Data: 0e861f0b030000040021000269a2, LQI: 87
2021-09-12 09:56:20.526 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:20.531 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:20.531 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:20.555 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 42, Data: 0e861f0b0300000300210002785e, LQI: 87
2021-09-12 09:56:20.555 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:20.560 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:20.560 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:20.573 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: e4, Data: 0e861f0b03000007002100020185, LQI: 87
2021-09-12 09:56:20.573 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0e ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:20.576 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:20.576 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:20.800 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 3f, Data: 0026210100080000002000011a, LQI: 135
2021-09-12 09:56:20.801 Zigate: (Zigate) Decode8102 - Attribute Reports : [2621:01] MsgSQN: 00 ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >1a<
2021-09-12 09:56:20.806 Zigate: (Zigate) ReadCluster - 0008 - 2621/01 AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 1a
2021-09-12 09:56:20.806 Zigate: (Zigate) ReadCluster - ClusterID: 0008 Addr: 2621 MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: 1a
2021-09-12 09:56:20.807 Zigate: (Zigate) ReadCluster - ClusterId=0008 - 2621/01 Level Control: 1a
2021-09-12 09:56:20.833 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 14, Data: 00262101000883, LQI: 0
2021-09-12 09:56:21.499 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 32, Data: 0f861f0b00080000002000015f, LQI: 84
2021-09-12 09:56:21.499 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 0f ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >5f<
2021-09-12 09:56:21.504 Zigate: (Zigate) ReadCluster - 0008 - 861f/0b AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 5f
2021-09-12 09:56:21.504 Zigate: (Zigate) ReadCluster - ClusterID: 0008 Addr: 861f MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: 5f
2021-09-12 09:56:21.504 Zigate: (Zigate) ReadCluster - ClusterId=0008 - 861f/0b Level Control: 5f
2021-09-12 09:56:24.203 Slave Synolgy: General/Percentage (Unknown)
2021-09-12 09:56:24.228 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:25.119 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 76, Data: 00fd7e01ef0082, LQI: 0
2021-09-12 09:56:29.512 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 38, Data: 102e2b0b030000040021000269a2, LQI: 69
2021-09-12 09:56:29.512 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:29.529 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:29.529 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:29.551 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: d2, Data: 102e2b0b0300000300210002785e, LQI: 69
2021-09-12 09:56:29.551 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:29.552 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:29.552 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:29.553 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 74, Data: 102e2b0b03000007002100020185, LQI: 69
2021-09-12 09:56:29.553 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:29.553 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:29.554 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:29.844 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:29.870 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:29.895 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:29.919 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:29.941 Slave Synolgy: General/Percentage (Unknown)
2021-09-12 09:56:29.954 Slave Synolgy: General/Custom Sensor (Unknown)
2021-09-12 09:56:30.517 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: b6, Data: 10861f0b030000040021000269a2, LQI: 87
2021-09-12 09:56:30.517 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:30.517 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:30.517 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:30.518 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 5c, Data: 10861f0b0300000300210002785e, LQI: 87
2021-09-12 09:56:30.518 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:30.521 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:30.521 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:30.521 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: fa, Data: 10861f0b03000007002100020185, LQI: 87
2021-09-12 09:56:30.522 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 10 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:30.524 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:30.524 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:32.892 EventSystem: Event triggered: Buitenzit weer_2
2021-09-12 09:56:32.915 Dummy: Light/Switch (Buitenzit weer)
2021-09-12 09:56:32.892 Status: buitenzitweer uitgeschakeld
2021-09-12 09:56:34.210 Slave Synolgy: General/Percentage (Unknown)
2021-09-12 09:56:38.148 Zigate: (Zigate) tuya_siren_alarm - fd7e onoff: 0
2021-09-12 09:56:38.148 Zigate: (Zigate) raw_APS_request - ackIsDisabled: False Addr: fd7e Ep: 01 Cluster: ef00 ProfileId: 0104 Payload: 11270000266801000100
2021-09-12 09:56:38.149 Zigate: (Zigate) tuya_cmd - fd7e/01 cmd: 00 payload: 11270000266801000100
2021-09-12 09:56:38.185 Zigate: (Zigate) UpdateDevice - (Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01) 0:Off
2021-09-12 09:56:38.186 Zigate: (Zigate) ZigateRead - MsgType: 8000, MsgLength: 0009, MsgCRC: bc, Data: 0084053001840001, LQI: 0
2021-09-12 09:56:38.120 Status: User: Admin (IP: 192.168.1.41) initiated a switch command (5033/Zigate - nummer3 - TS0601-sirene_TuyaSiren-804b50fffe048336-01/Set Level)
2021-09-12 09:56:39.232 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 62, Data: 47beb501000800000020000106, LQI: 141
2021-09-12 09:56:39.232 Zigate: (Zigate) Decode8102 - Attribute Reports : [beb5:01] MsgSQN: 47 ClusterID: 0008 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >06<
2021-09-12 09:56:39.238 Zigate: (Zigate) ReadCluster - 0008 - beb5/01 AttrId: 0000 AttrType: 20 Attsize: 0001 Status: 00 AttrValue: 06
2021-09-12 09:56:39.239 Zigate: (Zigate) ReadCluster - ClusterID: 0008 Addr: beb5 MsgAttrID: 0000 MsgAttType: 20 MsgAttSize: 0001 MsgClusterData: 06
2021-09-12 09:56:39.239 Zigate: (Zigate) ReadCluster - ClusterId=0008 - beb5/01 Level Control: 06
2021-09-12 09:56:39.273 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 1e, Data: 00beb501000885, LQI: 0
2021-09-12 09:56:39.513 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 34, Data: 112e2b0b030000040021000269a2, LQI: 72
2021-09-12 09:56:39.513 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:39.517 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:39.518 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:39.536 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: de, Data: 112e2b0b0300000300210002785e, LQI: 72
2021-09-12 09:56:39.537 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:39.541 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:39.541 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:39.560 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 78, Data: 112e2b0b03000007002100020185, LQI: 72
2021-09-12 09:56:39.561 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:39.564 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:39.564 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:40.235 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 70, Data: 00fd7e01ef0084, LQI: 0
2021-09-12 09:56:40.512 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: b7, Data: 11861f0b030000040021000269a2, LQI: 87
2021-09-12 09:56:40.513 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:40.518 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:40.518 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:40.540 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 5d, Data: 11861f0b0300000300210002785e, LQI: 87
2021-09-12 09:56:40.540 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:40.545 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:40.545 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:40.564 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: fb, Data: 11861f0b03000007002100020185, LQI: 87
2021-09-12 09:56:40.565 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 11 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:40.569 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:40.569 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:43.328 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: d5, Data: 00a56401000a86, LQI: 0
2021-09-12 09:56:43.721 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 0051, MsgCRC: 7f, Data: 2e9916010000ff010042004403281f0521160007270000000000000000082124120921000c6410006510006e20006f200094200195395c8f623d96392fa40f459739f029a43b983900e0533c9b210000, LQI: 111
2021-09-12 09:56:43.721 Zigate: (Zigate) Decode8102 - Attribute Reports : [9916:01] MsgSQN: 2e ClusterID: 0000 AttributeID: ff01 Status: 00 Type: 42 Size: 0044 ClusterData: >03281f0521160007270000000000000000082124120921000c6410006510006e20006f200094200195395c8f623d96392fa40f459739f029a43b983900e0533c9b210000<
2021-09-12 09:56:43.729 Zigate: (Zigate) ReadCluster - 0000 - 9916/01 AttrId: ff01 AttrType: 42 Attsize: 0044 Status: 00 AttrValue: 03281f0521160007270000000000000000082124120921000c6410006510006e20006f200094200195395c8f623d96392fa40f459739f029a43b983900e0533c9b210000
2021-09-12 09:56:43.729 Zigate: (Zigate) ReadCluster - 0000 ff01 Saddr: 9916 ClusterData: 03281f0521160007270000000000000000082124120921000c6410006510006e20006f200094200195395c8f623d96392fa40f459739f029a43b983900e0533c9b210000
2021-09-12 09:56:46.382 Slave Synolgy: Light/Switch (Extender-1)
2021-09-12 09:56:46.676 Zigate: (Zigate) ZigateRead - MsgType: 8011, MsgLength: 0008, MsgCRC: 9a, Data: 00991601000a87, LQI: 0
2021-09-12 09:56:48.596 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: a2, Data: 09b9c102000600000010000100, LQI: 75
2021-09-12 09:56:48.597 Zigate: (Zigate) Decode8102 - Attribute Reports : [b9c1:02] MsgSQN: 09 ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >00<
2021-09-12 09:56:48.607 Zigate: (Zigate) ReadCluster - 0006 - b9c1/02 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 00
2021-09-12 09:56:48.610 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 00
2021-09-12 09:56:49.512 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 3a, Data: 122e2b0b030000040021000269a2, LQI: 69
2021-09-12 09:56:49.513 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:49.520 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:49.521 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:49.540 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: d0, Data: 122e2b0b0300000300210002785e, LQI: 69
2021-09-12 09:56:49.541 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:49.545 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:49.545 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:49.563 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 76, Data: 122e2b0b03000007002100020185, LQI: 69
2021-09-12 09:56:49.563 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:49.567 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:49.567 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:50.523 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: b4, Data: 12861f0b030000040021000269a2, LQI: 87
2021-09-12 09:56:50.523 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:50.529 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:50.529 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:50.550 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 5e, Data: 12861f0b0300000300210002785e, LQI: 87
2021-09-12 09:56:50.550 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:50.557 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:50.557 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:50.575 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: f8, Data: 12861f0b03000007002100020185, LQI: 87
2021-09-12 09:56:50.575 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 12 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:50.579 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:50.579 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:56:57.648 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: ca, Data: eca56402000600000010000101, LQI: 126
2021-09-12 09:56:57.648 Zigate: (Zigate) Decode8102 - Attribute Reports : [a564:02] MsgSQN: ec ClusterID: 0006 AttributeID: 0000 Status: 00 Type: 10 Size: 0001 ClusterData: >01<
2021-09-12 09:56:57.656 Zigate: (Zigate) ReadCluster - 0006 - a564/02 AttrId: 0000 AttrType: 10 Attsize: 0001 Status: 00 AttrValue: 01
2021-09-12 09:56:57.659 Zigate: (Zigate) ReadCluster - ClusterId=0006 - reception General: On/Off: 01
2021-09-12 09:56:59.526 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 3b, Data: 132e2b0b030000040021000269a2, LQI: 69
2021-09-12 09:56:59.526 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:56:59.527 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:56:59.527 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:56:59.555 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: d1, Data: 132e2b0b0300000300210002785e, LQI: 69
2021-09-12 09:56:59.555 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:56:59.556 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:56:59.556 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:56:59.567 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 77, Data: 132e2b0b03000007002100020185, LQI: 69
2021-09-12 09:56:59.567 Zigate: (Zigate) Decode8102 - Attribute Reports : [2e2b:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:56:59.571 Zigate: (Zigate) ReadCluster - 0300 - 2e2b/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:56:59.571 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:57:00.511 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: b5, Data: 13861f0b030000040021000269a2, LQI: 87
2021-09-12 09:57:00.511 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0004 Status: 00 Type: 21 Size: 0002 ClusterData: >69a2<
2021-09-12 09:57:00.514 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0004 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 69a2
2021-09-12 09:57:00.514 Zigate: (Zigate) ReadCluster0300 - CurrentY: 27042
2021-09-12 09:57:00.525 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 5f, Data: 13861f0b0300000300210002785e, LQI: 87
2021-09-12 09:57:00.525 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0003 Status: 00 Type: 21 Size: 0002 ClusterData: >785e<
2021-09-12 09:57:00.528 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0003 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 785e
2021-09-12 09:57:00.528 Zigate: (Zigate) ReadCluster0300 - CurrentX: 30814
2021-09-12 09:57:00.538 Zigate: (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: f9, Data: 13861f0b03000007002100020185, LQI: 87
2021-09-12 09:57:00.538 Zigate: (Zigate) Decode8102 - Attribute Reports : [861f:0b] MsgSQN: 13 ClusterID: 0300 AttributeID: 0007 Status: 00 Type: 21 Size: 0002 ClusterData: >0185<
2021-09-12 09:57:00.541 Zigate: (Zigate) ReadCluster - 0300 - 861f/0b AttrId: 0007 AttrType: 21 Attsize: 0002 Status: 00 AttrValue: 0185
2021-09-12 09:57:00.541 Zigate: (Zigate) ReadCluster0300 - ColorTemperatureMireds: 389
2021-09-12 09:57:04.242 Slave Synolgy: General/Percentage (Unknown) - Attachments
- export.rar
- (15.3 KiB) Downloaded 78 times
keros
I think your plugin is still not up to date > git pull
You are right, did again a git pull, Plugin: 5.1.009
But the problem is still there.
Siren 1 en 3 not working, Siren 2 works.
A strange behavior is, when selecting a alarm of siren 1 or 3, the switch stays on.
keros
In the WebUI, can you go to Tool / Debug and activate Debug Tuya. Restart the plugin. Post us the starting log of the plugin.
Make the siren 2 work and post us the log.
Try to make the siren 1 work and post us the log.
I won't be able to make the corrections, but Pipiche will certainly ask for it.
