Bosh Dishwasher with Home-Connect
- Thuis
Re: Bosh Dishwasher with Home-Connect
Yes, well almost, i have the haId from the api doc home connect website, i got the flow to start the program, in domoticz i see the selector switch, i see the door is closed i see the dishwasher is on, but when i select a program it tells me i need to close the door, but it is already closed.
If you can not handle a computer, you buy a Mac. If you can not handle domotica, you use Homeassistant!
- FireWizard
Hi, @Thuis,
Honestly, I have no idea, what goes wrong in your setup.
I don't think it is, because I use simulation instead of a real appliance.
I, also don't think, it has something to do with the mobile app. Or is only 1 connection allowed?
Your call-back URL is your Domoticz device?
Can you send the flow, so that I can test against the simulation?
- Thuis
Well ofcourse the door is closed and it keeps telling me to close the door, so probably it does not get the data from the api, just like the identifyapplication.
but look im getting closer but im going too fast. At least i see something now. Im playing around with the scopes
- Spoiler: show
- Thuis
I also see now, that the haId is the same as my serial number
- Thuis
Yes great, here is my the flow:
But i can see that the text sensor said "vaatwasser aan" and this changed to "vaatwasser loopt" so this seems to work.
Before i turned it on, when ever i selected eco on the selector switch in domoticz, i always get the door is not closed warning.
however i see the other text sensor saying the door is closed.
If i try to control the led light i get 403, and also i think if i want to control it from domoticz i get 403. Out of scope. But all the scopes are granted when i authorize so ? huh ?
but thanks for your time in trying to help, much appreciated
- Spoiler: show
- Thuis
I have the idea, that i can only see the status of the dishwasher, but am unable to control.
But i put in all the scopes so have no idea whats going on.
When i start eco50 with the selector switch from inside domoticz i get this in node red debug:
- Spoiler: show
- Spoiler: show
- Thuis
No, my callbackurl is nodered server
- FireWizard
Hello @Thuis,
As you might have seen, I have received a HAID for a simulator. I try to get a little more familiar with the possibilities of this device.
So that is not the problem.
If you get msg.payload : undefined, it normally means that the input has not been received.
Check that by inserting more debug nodes.
Do the home-connect nodes show "ready"?
Okay, that is correct, I thought that you might had mixed the Domoticz and Node-Red server.No, my callbackurl is nodered server
- Thuis
Yes they are green and say ready.
- Thuis
I gave up. I uninstalled everything, made different email addresses. Deleted accounts. Made new accounts. It keeps returning the same thing after identifyApliences namely:
payload: undefined
status: 200
statusText: "OK"
So the auth is OK but the data is never coming and im too stupid to find out why it is. Sadly, would be fun to control it from domoticz.
Thanks for all the help though, have a nice day
payload: undefined
status: 200
statusText: "OK"
- kiddigital
I maybe could be of assistance but I don’t own any of these connected machines myself. If you don’t mind ‘lending’ me your credentials and machine data during development. Send me a PM if interested.Thuis wrote:I gave up…
- FireWizard
Hello @Thuis
As it was quite simple to create an account, which simulates the devices. It should be possible to use real devices.
Can you create an account with simulated devices?
@kiddigital
You can create your account with simulated devices.
Can you try that?
Do you plan to create a plugin, like you did before with Mercedes ME, or do you follow the Node Red approach, like I did before, but that has been unsuccessful with @Thuis?
That is pitty. Usely giving up is not in my vocabulary.I gave up. I uninstalled everything, made different email addresses. Deleted accounts. Made new accounts. It keeps returning the same thing after identifyApliences namely:
payload: undefined
status: 200
statusText: "OK"
@kiddigital
Can you try that?
- Thuis
Yes well, ok i could try that simulation.
Im getting, when i identify the dishwasher:
The crazy thing is, when i use the bsh connect API website all works. That is how i got my haId.
I know the authorization works, i get "ok" after authorization from nodered and all nodes say ready with the green thingy next to it.
But i will try with simulation. I already factory reset the dishwasher too. Changed other mail adresses etc.
Thanks, im normally not give up, but i just have no clue and when all logic (for me) slips away, i dont want to put any more hours in it as i dont see why its not working.
- Spoiler: show
- Spoiler: show
- kiddigital
I will look into the simulated devices…FireWizard wrote:…
@kiddigital
Can you try that?
My idea would be indeed to do the similar thing as done for MercedesMe, Tesla, OpenWeatherMap, Buienradar, etc. Have a native (C++) module consuming the API.
But if there are good arguments to use a different approach, I am open for suggestions.
- Thuis
Well, finaly had time to do some simulated device test. Sadly, it gives the same return, namely:
- Spoiler: show
- Spoiler: show
- Thuis
Well i could do that, but what credentials do you need?kiddigital wrote: Friday 05 November 2021 16:16 I maybe could be of assistance but I don’t own any of these connected machines myself. If you don’t mind ‘lending’ me your credentials and machine data during development. Send me a PM if interested.
- Thuis
No idea if im using simulation the correct way
mariopeters
Currently I'm supporting a couple of Home Connect devices.
Shortly I want to implement some more.
Special the devices Hob and Fridge/Freezer or Refrigerator (with camera) are interesting me.
For testing purposes I'm searching for people who own these devices.
Please let me know by creating an issue in https://github.com/mario-peters/Domotic ... ect-Plugin
