Dashticz - v3.4.9 beta
madpatrick
Domoticz version: 2026.1
Re: Dashticz - v3.4.9 beta
Post by madpatrick »
Lokonli wrote: Thursday 28 May 2020 23:26
Something like:
function getStatus_145(block){
var idx = block.idx;
var device = block.device;
   if(parseFloat(device['Data'])>23){
      block.addClass='warning';
   else {
      block.addClass='';
To set the color in the icon part:
.warning .col-icon {
   color: red !important
Is it possible to get data from 1 block, but change the colour of another block.
What i like to have is a message or color change of a block on the standby screen when a value reached a high value.
Since the standby screen is almost always on you will not see the alarms. Espacially when they are on page 2 or 3
Vomera
Post by Vomera »
madpatrick wrote: Sunday 11 October 2020 11:52
Something like:
   else {
      block.addClass='';
Here is an example i use.
// geeft regenmelding een kleur op basis van aantal mm per uur
	function getStatus_9450(block){
	var Data = block.device.Data;
   if(parseFloat(Data) > 100){
     Dashticz.setBlock('3962', {addClass: 'bovendehonderd'});
   else if(parseFloat(Data) >10){
     Dashticz.setBlock('3962', {addClass: 'tientothonderd'});
   else if(parseFloat(Data) >5){
      Dashticz.setBlock('3962', {addClass: 'vijftottien'});
   else if(parseFloat(Data) >2){
        Dashticz.setBlock('3962', {addClass: 'tweetotvijf'});
   else if(parseFloat(Data) >0){
      Dashticz.setBlock('3962', {addClass: 'nultottwee'});
   else {
     Dashticz.setBlock('3962', {addClass: 'none'});
madpatrick
Vomera wrote: Monday 12 October 2020 11:17
Thanks. This is working.
I'm trying to make 2 sensors change, but only 1 is changing.
This is what i've tried
// geeft alarm melding van andere sensor
	function getStatus_262(block){
   else if(parseFloat(Data) <1.5){
     Dashticz.setBlock('regen', {addClass: 'warning'});
     Dashticz.setBlock('262', {addClass: 'warning'});
   else {
     Dashticz.setBlock('regen', {addClass: 'none'});
Vomera
Post by Vomera »
madpatrick wrote: Monday 12 October 2020 19:08
   else {
And you are sure "regen" and "262" are valid blocks ? maybe you can insert some script from your config.js
Lokonli
Post by Lokonli »
   else {
Your function is not complete. You start with an 'else' statement, but you should start with an 'if' statement.
Further, the getStatus_262 is called when device 262 changes. You can modify this block directly with:
   block.addClass = 'warning'
(no need to use the setBlock function)
So, I think you are trying to achieve the following:
function getStatus_262(block) {
     		block.addClass = 'warning';		// set the addClass parameter for block 262
   	else {
     		block.addClass = ''; // reset the addClass parameter for block 262
madpatrick
Thanks guys.
This works !
The else if function was because i deleted some line to make the post smaller
madpatrick
Guys,
Need you support again.
When i want to use more sensors in the script, theupdate of block "regen" doesn't work any more.
Only the applicable sensors gets a warning.
/ geeft alarm melding sensor
   	else {
// geeft alarm melding sensor
function getStatus_25(block) {
	if(parseFloat(Data) >80){
   	else {
The trick is that i want to set this up for a the sensors and when the alarm of one of the is triggered i see this also on the main screen (block "regen")
Lokonli
Post by Lokonli »
madpatrick wrote: Tuesday 13 October 2020 16:48 Guys,
   	else {
   	else {
I think I would approach it as follows:
var trigger_262 = false;
var trigger_25 = false;
function handleRegen() {
    if (trigger_262 || trigger_25)
        Dashticz.setBlock('regen', { addClass: 'warning' });
        Dashticz.setBlock('regen', { addClass: '' });
    if (parseFloat(Data) < 1.5) {
        trigger_262 = true;
    else {
    handleRegen();
    if (parseFloat(Data) > 80) {
        trigger_25 = true;
    else {
        trigger_25 = false;
    handleRegen();
madpatrick
Lokonli wrote: Tuesday 13 October 2020 17:40
Many thanks Lokonli !!
Added 10 sensors with the script
madpatrick
Is it also possible to get a sound when the warning is triggered ?
The speech function is not working on my tablet (viewtopic.php?t=20426)
Lokonli
Post by Lokonli »
Do you have an Android tablet? Did you install Google speech synthesis engine, and set it as default?
You can use the playsound block parameters to play a sound.
See:
https://dashticz.readthedocs.io/en/mast ... parameters
madpatrick
Hi Lokonli,
Yes. It is an Android tablet.
I've found out that it is related to Fully Kiosk browser app.
When i'm using the chrome browser it is working
madpatrick
I know you play a sound when you click on a block, but is it possible when the warning gets trigger via custom.js
function handleMessage() {
   if (trigger_182 && trigger_188)
        Dashticz.setBlock('emptyblock1', { addClass: 'message4' });
   else if (trigger_182)
        Dashticz.setBlock('emptyblock1', { addClass: 'message2' });
   else if (trigger_188)
        Dashticz.setBlock('emptyblock1', { addClass: 'message3' });
        Dashticz.setBlock('emptyblock1', { addClass: '' });
