Page 3 of 5
Re: SMA Sunny Boy 1.5
Posted: Wednesday 10 June 2020 14:35
by Joske
It works!!!!!!
After an second time reboot it worked!
Thanks to your script!
Posted: Wednesday 10 June 2020 16:26
by Joske
A little side note:
After i installed this has 'hardware' Domoticz keeps giving problems.
The GUI is only fir a few minutes accesible and then not anymore.
Via SSH (putty) i have to restart then en then again.
Also lot of messages that the command couldn't be sent to the (433mhz) devices.
Agter setting the SMA setting 'active' to OFF al the problems are gone.
So there's maybe an bug in my script.
I will play withe the setting first.
Has DEBUG to be on TRUE or FALSE?
Interval is at 1 minute.
Any ideas?
Posted: Tuesday 15 September 2020 12:42
by Carthman
Does someone knows if it's possible to change the query interval to 1 second to be more precise ?
Thanks !
Posted: Tuesday 15 September 2020 12:44
by rklomp
Are you using my version? Interval can be set to 5 seconds.
https://github.com/rklomp/Domoticz-SMA-SunnyBoy
Posted: Tuesday 15 September 2020 22:08
by Carthman
rklomp wrote: Tuesday 15 September 2020 12:44 Are you using my version? Interval can be set to 5 seconds.
Yes, I use yours and I have already set it to 5 seconds.
1 second would be more accurate for regulation purpose.
Posted: Saturday 10 October 2020 18:04
by fdemees
Hello All,
Please let me share my experience.
I have a problem already described above: only 2 devices are created and not 3, and the device with the daily counter is messed up with the instant production.
In detail:
I copied your script (copy/paste) from /github.com/merlot-dev/Domoticz-SMA-SunnyBoy/
restarted Dz service,
added successfully the hardware, and it has created 2 devices (not 3) which showed always zero.
I had to edit the 3 occurrences of '012F-730B00E6' and replace with values reported by my inverter(0156-76BCFF**)
How to catch the values without wireshark ?
First launch this command:
curl -H "Content-Type: application/json, Accept-Charset: UTF-8" -X POST -d '{"pass" : "password", "right" : "usr"}' http://pv/dyn/login.json
You get a session ID: {"result":{"sid":"NHIsYKZaBmBa7KJG"}}
Quickly send the second command on one line:
curl -H "Content-Type: application/json, Accept-Charset: UTF-8" -X POST -d '{"destDev":[],"keys":["6400_00260100","6400_00262200","6100_40263F00"]}' http://pv/dyn/getValues.json?sid=NHIsYKZaBmBa7KJG
and you get the JSON result:
{"result":{"0156-76BCFF**":{"6400_00260100":{"1":[{"val":12020721}]},"6400_00262200":{"1":[{"val":17570}]},"6100_40263F00":{"1":[{"val":831}]}}}}
I interpret the results as this:
12020 total production, 17.5 production of today, 831 W instant production
and I have my system number 0156-76BCFF** to transcript in the plugin script.
Now the problem with the display:
The hardware has created 2 devices: (don't be confused with SD1a, it was already there prior)
2020-10-10 17_49_31-Domoticz.jpg (31.04 KiB) Viewed 3925 times
but in the utility the values shown are the instant values ??
2020-10-10 17_51_44-Domoticz.jpg (37.08 KiB) Viewed 3925 times
Here is the web page of the inverter:
2020-10-10 17_52_33-Appareil SMA - Accueil.jpg (38.55 KiB) Viewed 3925 times
I cannot pinpoint the mistake ... any help is welcome !
Posted: Saturday 10 October 2020 18:22
by rklomp
fdemees wrote: Saturday 10 October 2020 18:04 I copied your script (copy/paste) from /github.com/merlot-dev/Domoticz-SMA-SunnyBoy/
Please try my improved version from https://github.com/rklomp/Domoticz-SMA-SunnyBoy
Posted: Saturday 10 October 2020 19:22
by fdemees
@rklomp: Here is the feedback
deleted hardware (the 2 device have gone too)
stopped Dz service
replaced the script, no modification brought
Start Dz service
Added hardware, configure IP and password, run every 3 minutes
Found that only 2 devices are created
Added them with the green button
Here is the Devices pane:
2020-10-10 19_13_09-Domoticz.png (85.53 KiB) Viewed 3921 times
Here is the Utility pane:
2020-10-10 19_14_04-Domoticz.png (70.29 KiB) Viewed 3921 times
Zero is probably valid. It is now dark.
But the devices pane shows an invalid value, and the total production of the day cannot be found anywhere.
__
Dz Version 2020.1 (March 22th 2020). I will never ever re-enable auto-update since it broke and required a full Debian fresh install.
Running on Rpi 3B.
Posted: Saturday 10 October 2020 21:08
by rklomp
That looks correct. The total production on the day will probably be shown tomorrow as soon as some power has been generated. It can also be found in de log view then.
Posted: Saturday 10 October 2020 21:32
by fdemees
Thanks, I'll check tomorrow.
Greetings from Brussels
Posted: Sunday 11 October 2020 13:43
by fdemees
Great ! it works fine !
2020-10-11 13_39_47-Domoticz.png (73.75 KiB) Viewed 3903 times
2020-10-11 13_40_27-Domoticz.png (90.48 KiB) Viewed 3903 times
Frédéric
Posted: Tuesday 27 October 2020 10:23
by hclardij
Hi All,
I have 2 SMA inverters, a SunnyBoy 1.5 and a TriPower 6.0. The SunnyBoy uses HTTP and the TriPower HTTPS.
The script works flawless for me!
Thank you!
Posted: Friday 27 November 2020 17:26
by artstam
Hi there i'm trying to read my sunny boy with domosticz installed on my synology.
Could you help me with the neccesary steps?
TX!
Thomas
svdhaar wrote: Friday 10 April 2020 12:29 jeeeej, hardware and devices are visable.
one question about this error.
In the hardware config i specified the ipadres. It is an internal adres, so no https is configured.
It seems that port 443 is automatically added?
2020-04-10 12:25:05.084 (SMA omvormer) Error accessing SMA inverter on 192.168.0.200; HTTPSConnectionPool(host='192.168.0.200', port=443): Max retries exceeded with url: /dyn/login.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x4850ac50>: Failed to establish a new connection: [Errno 111]
Posted: Friday 27 November 2020 18:50
by fdemees
Hello, we would gladly help, please explain what you have done, and what you have not done, from the steps described in our previous posts.
artstam wrote: Friday 27 November 2020 17:26 Hi there i'm trying to read my sunny boy with domosticz installed on my synology.
TX!
Thomas
Posted: Friday 27 November 2020 19:44
by svdhaar
TX!
Thomas
Which step are you on?
Posted: Friday 27 November 2020 22:33
by artstam
i'm still at the beginning. One of the problems is that my synology is a bit old (211+). I managed to install Domoticz on my computer (domoticz_88f6282-6.2_3.0.9483-7.spk) from Jadahl.com. I can read my power and gas consumption from the P1 port. I first tried an virtual interface with https://github.com/sincze/Domoticz/blob ... a-inverter, but i could not get that to work.
Domoticz:
Version: 3.9483
Build Hash: a74f7c4-modified
Compile Date: 2018-05-24 11:42:36
dzVents Version: 2.4.5
Python Version: None
I am not sure if i can use the github script in this thread.
Sorry that i am pretty new with linux, synology and python scripts!
I much appreciate any help i can get,
Thomas
Posted: Saturday 28 November 2020 7:29
by svdhaar
I used this script from rklomp: https://github.com/rklomp/Domoticz-SMA-SunnyBoy
At first you will need to install the necessary components on your synology: Python 3.7 & Git.
When the installation is done, just follow the instruction which rklomp described:
Assuming that domoticz directory is installed in your home directory.
cd ~/domoticz/plugins
git clone https://github.com/rklomp/Domoticz-SMA-SunnyBoy
# restart domoticz:
sudo systemctl restart domoticz
In the web UI, navigate to the Hardware page. In the hardware dropdown there will be an entry called "SMA Sunny Boy".
Posted: Saturday 28 November 2020 9:08
by artstam
I installed python & Git and followed the instructions.
- i installed it in /usr/local/domoticz/plugins
- restart is not working (systemctl not recognised)
- i did a restart in domoticz
- in the hardware section there is no SMA sunny Boy
I probably did something wrong!
Posted: Sunday 29 November 2020 9:19
by svdhaar
No errors during the installation of git, python and or the project from Ronald?
Strange.. are you sure you rebooted Domoticz?
You can force a reboot by stopping the app proces via synology package center. Of just reboot you syno.
Installing the project is mostly the simple part😁.
After rebooting the new hardware should be visible.
Hardware device name should be: sma sunnyboy solar inverter plugin
Posted: Sunday 29 November 2020 20:16
by Huff002
I managed to install this plugin thanks to the previous posts in this topic.
It took some searching to get pip3 installed and I think it worked out correctly in the end.
I was able to add the hardware and 2 devices but I get errors in the log.
Below you see the log (with debugging on).
I suspect that "No cipher can be selected" is the cause but I cannot find a cause or solution.
2020-11-29 19:59:17.675 Status: (SMA Sunny Boy Solar Inverter) Started.
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'HardwareID':'7'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'HomeFolder':'/usr/local/domoticz/var/plugins/SMA Sunny Boy Solar Inverter/'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'StartupFolder':'/usr/local/domoticz/'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'UserDataFolder':'/usr/local/domoticz/var/'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Database':'/usr/local/domoticz/var/domoticz.db'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Language':'en'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Version':'1.0.4'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Author':'rklomp'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Name':'SMA Sunny Boy Solar Inverter'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Address':'192.168.0.4'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Port':'0'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Password':'xxxx'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Key':'SMASunnyBoy'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Mode1':'https'
2020-11-29 19:59:18.507 (SMA Sunny Boy Solar Inverter) 'Mode3':'12'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) 'Mode6':'Debug'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) 'DomoticzVersion':'2020.2 (build 12227)'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) 'DomoticzHash':'36016cd13-modified'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) 'DomoticzBuildTime':'2020-07-14 15:33:21'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device count: 2
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device: 1 - ID: 183, Name: 'SMA Sunny Boy Solar Inverter - PV Generation', nValue: 0, sValue: ''
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device ID: '183'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device Name: 'SMA Sunny Boy Solar Inverter - PV Generation'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device nValue: 0
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device sValue: ''
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device LastLevel: 0
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device: 2 - ID: 184, Name: 'SMA Sunny Boy Solar Inverter - kWh total', nValue: 0, sValue: ''
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device ID: '184'
2020-11-29 19:59:18.508 (SMA Sunny Boy Solar Inverter) Device Name: 'SMA Sunny Boy Solar Inverter - kWh total'
2020-11-29 19:59:18.509 (SMA Sunny Boy Solar Inverter) Base URL is set to https://192.168.0.4/dyn
2020-11-29 19:59:18.526 (SMA Sunny Boy Solar Inverter) Error accessing SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/login.json (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 19:59:18.526 (SMA Sunny Boy Solar Inverter) Pushing 'PollIntervalDirective' on to queue
2020-11-29 19:59:18.526 (SMA Sunny Boy Solar Inverter) Processing 'PollIntervalDirective' message
2020-11-29 19:59:18.526 (SMA Sunny Boy Solar Inverter) Heartbeat interval set to: 5.
2020-11-29 19:59:18.504 Status: (SMA Sunny Boy Solar Inverter) Entering work loop.
2020-11-29 19:59:18.504 Status: (SMA Sunny Boy Solar Inverter) Initialized version 1.0.4, author 'rklomp'
2020-11-29 19:59:28.531 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:28.558 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:28.559 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:28.559 (SMA Sunny Boy Solar Inverter) onHeartbeat called 0
2020-11-29 19:59:28.569 (SMA Sunny Boy Solar Inverter) Error accessing SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/login.json (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 19:59:28.580 (SMA Sunny Boy Solar Inverter) No data from SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/getValues.json?sid=None (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 19:59:28.580 (SMA Sunny Boy Solar Inverter) Previous attempt failed, trying new login...
2020-11-29 19:59:28.591 (SMA Sunny Boy Solar Inverter) Error accessing SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/login.json (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 19:59:28.602 (SMA Sunny Boy Solar Inverter) No data from SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/getValues.json?sid=None (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 19:59:28.602 Error: (SMA Sunny Boy Solar Inverter) Failed to retrieve data from 192.168.0.4, cancelling...
2020-11-29 19:59:33.541 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:33.551 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:33.619 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:33.620 (SMA Sunny Boy Solar Inverter) onHeartbeat called 1
2020-11-29 19:59:38.552 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:38.570 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:38.739 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:38.739 (SMA Sunny Boy Solar Inverter) onHeartbeat called 2
2020-11-29 19:59:43.562 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:43.585 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:43.586 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:43.586 (SMA Sunny Boy Solar Inverter) onHeartbeat called 3
2020-11-29 19:59:48.573 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:48.585 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:48.586 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:48.586 (SMA Sunny Boy Solar Inverter) onHeartbeat called 4
2020-11-29 19:59:53.583 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:53.588 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:53.589 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:53.589 (SMA Sunny Boy Solar Inverter) onHeartbeat called 5
2020-11-29 19:59:58.593 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 19:59:58.640 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 19:59:58.674 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 19:59:58.674 (SMA Sunny Boy Solar Inverter) onHeartbeat called 6
2020-11-29 20:00:03.604 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:03.623 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:03.624 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:03.624 (SMA Sunny Boy Solar Inverter) onHeartbeat called 7
2020-11-29 20:00:08.614 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:08.622 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:08.622 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:08.623 (SMA Sunny Boy Solar Inverter) onHeartbeat called 8
2020-11-29 20:00:13.624 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:13.673 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:13.707 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:13.707 (SMA Sunny Boy Solar Inverter) onHeartbeat called 9
2020-11-29 20:00:18.634 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:18.657 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:18.657 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:18.658 (SMA Sunny Boy Solar Inverter) onHeartbeat called 10
2020-11-29 20:00:23.644 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:23.656 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:23.656 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:23.657 (SMA Sunny Boy Solar Inverter) onHeartbeat called 11
2020-11-29 20:00:28.654 (SMA Sunny Boy Solar Inverter) Pushing 'onHeartbeatCallback' on to queue
2020-11-29 20:00:28.658 (SMA Sunny Boy Solar Inverter) Processing 'onHeartbeatCallback' message
2020-11-29 20:00:28.745 (SMA Sunny Boy Solar Inverter) Calling message handler 'onHeartbeat'.
2020-11-29 20:00:28.745 (SMA Sunny Boy Solar Inverter) onHeartbeat called 0
2020-11-29 20:00:28.755 (SMA Sunny Boy Solar Inverter) Error accessing SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/login.json (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 20:00:28.766 (SMA Sunny Boy Solar Inverter) No data from SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/getValues.json?sid=None (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 20:00:28.767 (SMA Sunny Boy Solar Inverter) Previous attempt failed, trying new login...
2020-11-29 20:00:28.777 (SMA Sunny Boy Solar Inverter) Error accessing SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/login.json (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 20:00:28.790 (SMA Sunny Boy Solar Inverter) No data from SMA inverter on 192.168.0.4; HTTPSConnectionPool(host='192.168.0.4', port=443): Max retries exceeded with url: /dyn/getValues.json?sid=None (Caused by SSLError(SSLError('No cipher can be selected.')))
2020-11-29 20:00:28.791 Error: (SMA Sunny Boy Solar Inverter) Failed to retrieve data from 192.168.0.4, cancelling...
