Page 3 of 6
Re: GoodWe Solar: get data from the new semsportal (lua script)
Posted: Wednesday 08 May 2019 9:10
by sandeman684
Flitske wrote: Wednesday 08 May 2019 7:51
I'm trying to get this working however i cannot get the curl command to work. I run windows 10 on my desktop and domoticz on a raspberry pi. Where do i put in the curl command? In de CMD on win 10 or in on the Raspberry Pi??
I think in Windows 10 you can run curl (
https://stackoverflow.com/questions/950 ... on-windows) but it is probably better to do it on the RPi as domoticz will also use it from there. You should get the same response on both.
Posted: Sunday 12 May 2019 11:18
by Marcjeok
CrazyFrog wrote: Monday 22 April 2019 20:52
you have create your own sensor.
for hardware you have to create a virtual sensor from the type "Dummy (Does nothing, use for virtual switches only)".
then click on "Create Virtual Sensors", name the sensor "solar panels" and choose "sensor type" - "Electric (instant + counter)"
Do you have to create a new sensor or is it possible to use your existing "Goodwe solar inverter via Web API" idx-code?
Posted: Sunday 19 May 2019 7:59
by CrazyFrog
you have to create your own sensor.
Posted: Tuesday 04 June 2019 15:14
by Marktap
I have implemented this script without to much problems. The only thing i see after a couple of days is that the total value of monday is al wrong. It's not 19.2 kWh, but more around 8.8 kWh if i check it in the semsportal.
All of the other days are correct, i dont get it. Does anybody have an idea?
Posted: Wednesday 05 June 2019 14:56
by Kencirot
I experience the same issue as Marktap. The daily total of previous day is being used untill the currect day is higher for me.
I also notice when there is no power output I still get the last remain known output showing up (e.g 36Watts from 22:00h onwards till the morning).
Is there a way to set it to "0" when the solar system is offline?
- solar.PNG (222.85 KiB) Viewed 4759 times
Posted: Friday 07 June 2019 11:14
by Merlin1201
I have installed the script and it works great.
There is one error remaining:
2019-06-08 07:28:10.493 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:36:10.126 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:44:10.300 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:48:10.291 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 07:52:10.378 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
2019-06-08 08:00:10.419 Error: EventSystem: Warning!, lua script Solar Panels has been running for more than 10 seconds
i also try the upload to pvoutput script, but that needs some more work and my scripting is not that good.
https://www.domoticz.com/wiki/Upload_en ... o_PVoutput
Posted: Saturday 08 June 2019 20:58
by sincze
lua script works like a charm. Up and running in no time. Thank you so much.
As by default I always build the stuff in Pass2PHP (and have some sort of multi-threading).
I updated my Github.
https://github.com/sincze/Domoticz/blob ... Goodwe.php
Posted: Sunday 09 June 2019 15:53
by Merlin1201
? so you make a php file from the Lua script?
Posted: Sunday 09 June 2019 17:12
by sincze
Merlin1201 wrote: Sunday 09 June 2019 15:53
Yes, basically I rewrote the whole thing in PHP. As all my scripts use PHP. (Pass2PHP user)
This for me has the following advantages:
- I can run it outside of Domoticz and not be scared of 'script has been running for more than 10 seconds ' clogging up my 850 devices and 10 (different branded) inverters.
- In addition I could build some additional failure checks. If the webserver is not available.
- It integrates in Pass2PHP
- It can be used for non Pass2PHP users.
However for the typical user I would go for the lua.
- It works fine.
- Easy to implement
I even have it running on my spare pi.
Posted: Sunday 09 June 2019 17:32
by Merlin1201
impressive, ia'm truck with copy and paste only.
Posted: Friday 14 June 2019 22:21
by pvdgulik
Also same problem.. Think of editing the database to correct..
Kencirot wrote: Wednesday 05 June 2019 14:56
Posted: Saturday 15 June 2019 14:47
by sincze
pvdgulik wrote: Friday 14 June 2019 22:21
This seems to be an issue with all my different branded inverters indeed within domoticz.
Seems like a Domoticz representation graph issue to me as the json request is processed correctly and device is updated correctly as well. I am running Domoticz V4.10730.
That I corrected with a statement (not within lua) to check if the current time is after sunset. If so I update the device with
- Goodwe-0Watt.JPG (44.01 KiB) Viewed 4621 times
Posted: Tuesday 18 June 2019 21:02
by klaaspiet
Merlin1201 wrote: Friday 07 June 2019 11:14
ik got this problem 2 how to solve it?? i can't gat the solution
if have made som changed so i have a 0 value when de inverter is nog genarating
i get de status of the inverter
Status = getValue(splitString, "status")
if that is
1 = Generating,
0 = Waiting</option>
2 = Fault
-1 = Offline
if Status == "1" then
status_text = "Generating"
elseif Status == "0" then
status_text = "Waiting"
elseif Status == "2" then
status_text = "Fault"
status_text = "Offline"
so i can create a 0 when the status is 0,2 of -1
UpdateDevice(sensorSolarPanels, current..";"..zonTotal)
current = "0"
print("current :" .. current)
and i use eTotal = getValue(splitString, "eTotal")
so i can get the total of my production
Posted: Sunday 23 June 2019 16:29
by pvdgulik
Thank you for your response. I’m not that experienced with Domoticz, can you tell in detail how to:
Thank you!
Posted: Sunday 23 June 2019 18:22
by sincze
pvdgulik wrote: Sunday 23 June 2019 16:29
Thank you!
I can help you if you are willing to consider moving to a Pass2PHP script kind of a solution.
- Goodwe_Scheme.JPG (62.82 KiB) Viewed 4549 times
Posted: Friday 19 July 2019 15:36
by Wiljums
I get the following error:
2019-07-19 15:32:00.126 Error: EventSystem: in script_device_solar.lua: [string "-- Created by Raymond Wiertz
..."]:129: bad argument #1 to 'sub' (string expected, got nil)
How to fix this?
Posted: Friday 19 July 2019 15:49
by Wiljums
Wiljums wrote: Friday 19 July 2019 15:36
How to fix this?
And now this one:
2019-07-19 15:49:01.219 Error: EventSystem: in script_device_solar.lua: [string "-- Created by Raymond Wiertz
..."]:102: attempt to perform arithmetic on global 'endPos' (a nil value)
Posted: Friday 19 July 2019 16:12
by Wiljums
dospider wrote: Tuesday 30 April 2019 9:14
I still have a problem retrieving the data.
Does anybody have an idea how to solved this error?
2019-04-30 09:08:43.249 Error: EventSystem: in Goodwe portal: [string "
..."]:88: attempt to perform arithmetic on global 'endPos' (a nil value)
Have you been able to fix this error?
Posted: Tuesday 30 July 2019 23:14
by Peter2807
Anybody who has this script working on a Synolgy NAS, as I'm unable to find much about syntax differences between Pi and Synology if there are any.
First error already occurs at the first line of executable code: local Username = ... Unexpected keyword local near Username
Posted: Wednesday 31 July 2019 9:09
by sincze
Peter2807 wrote: Tuesday 30 July 2019 23:14
Yes it is working on a DS412 as an alternative I created
However you could also look at:
