Page 3 of 3
Re: Zigate and Tradfri 5 button remote in group
Posted: Friday 14 February 2020 17:10
by pipiche
soulearth wrote: Friday 14 February 2020 11:34 Yes I understand. the widget should correspond to a white light dimming bulb with change white color (spectre).
Yes. I will pairing when I get home and I will give the log.
Could this problem explain the incoherent behavior of the web interface that we see at the end of the video? But this is another problem...
Could you kindly switch to the 'beta' branch and redo the pairing of the Bulb ?
Then after pairing check what Widget has been created . In case you have the correct Widget ( WW ), then you can go to the Group stuff with the Remote
Posted: Friday 14 February 2020 17:14
by pipiche
BTW, for the error you pointed on the Video at startup, this is something related to the RPI GPIOs. I'm currently investigating that issue with the Zigate creator.
On Beta, the message won't come
Posted: Saturday 15 February 2020 0:51
by soulearth
Yes !!!! It's OK.
The stable plugin does not detect the bulb correctly or does not use the right widget. It's much better with beta plugin.
There is one very small problem that I have workaround.
After a Rescan Groups -> plugin restart, after waiting 6 minutes nothing happens. Same thing after a modification on the group and a restart of the plugin.
But the command "systemctl restart domoticz" is effective and gets around the problem.
First impression, the change white temperature work but color/temperature is not very the same. The light almost blue is less blue and the orange is more orange. And it's no very reactive. Sometimes you have to press several times to change the color. Unless it's just long.
Last detail, the widget does not update when changing white temperature from the remote control.
But all that I think is detail. It's for futur release ;)
But it's already very good. :D :)
I join the pairing log in beta and stable.
stable_domoticz_log.txt
(8.71 KiB) Downloaded 60 times
beta_log_domoticz.txt
(7.23 KiB) Downloaded 47 times
Pipiche, thank you very much.
Posted: Saturday 15 February 2020 9:27
by pipiche
Great ... Problem is then link to the Bulb model which is unknown on the stable branch. i'll retrofit that .
As regards to the Plugin Restart which seems to not work, you need to check your domoticz configuration and make sure that localhost (127.0.0.* ) do not need UserName/Password
Screenshot 2020-02-15 at 09.25.51.png (51.13 KiB) Viewed 746 times
As the Changes, what usally people are doing is they do it by themselves with a dzVent or a LUA script and they pilot the bulb as they want.
Last, indeed changes needs to be done slowly as you need to leave time for the Bulb to change the color. This is not instant.
Posted: Saturday 15 February 2020 10:10
by soulearth
Hello ,
I understand. I think we have solved all the problems. A big thank you, I would never succeeded without you.
I'm going to watch dzVent and the LUA scripts.
For a discovery of domoticz, it was the sport version :lol:
Best regards
Posted: Sunday 29 November 2020 0:06
by TonkaNL
pipiche wrote: Wednesday 12 February 2020 22:34 Here are the steps I have done
If still no working , please enable debugGroup
press the Scene control Left-Right and then attach the logs
In addition please do provide the following exports from Tools Menu
Plugin group (json)
zGroup-lst-devices (json)
Hi Pipiche,
I've done all your steps, but to no avail. The color warmth is not adjustable through the 5 button remote. In the groups menu of the Zigate plugin, all the correct groups with the remotes are visible. However, I am not able to add the Zigate to the group. When I click the tickbox behind the group and validate, the tickbox returns empty after restarting the plugin.
I have these lamps (3) for the "Zolder" group: E27 1000lm. Dimmable and CW adjustable: Domoticz recognises these lamps and let's you set the color temp in Domoticz with the round color slider. 5 button remote does not let you set color temp. Remote input is also not visible in Domoticz.
I also have these lamps (2) for the "Afzuigkap" group: E14 470lm. Also dimmable and CW adjustable. Domoticz does not let you adjust the CW value via Domoticz. It does not recognize these lamps as CW adjustable. In the Zigate/Conf/Certified folder, there is no file of this lamp type. Do you know where to get this? Or perhaps make it myself?
Content of Plugin group.json:
0: Object {"Cluster":"0008","Devices":[{"Ep":"01","IEEE":"ec1bbdfffe376813","_NwkId":"32af"}],"GroupName":"Zigate - Zigate Group f062","WidgetStyle":"LvlControl","_GroupId":"f062"}
1: Object {"Cluster":"0008","Devices":[{"Ep":"01","IEEE":"680ae2fffe15f9aa","_NwkId":"a7d6"},{"Ep":"01","IEEE":"680ae2fffe156b68","_NwkId":"574d"},{"Ep":"01","IEEE":"ec1bbdfffe30d77b","_NwkId":"8ca5"}],"GroupName":"Zigate - Zigate Group 6644","WidgetStyle":"","_GroupId":"6644"}
2: Object {"Cluster":"0008","Devices":[{"Ep":"01","IEEE":"bc33acfffe8407d9","_NwkId":"3f3d"},{"Ep":"01","IEEE":"bc33acfffe5f00ae","_NwkId":"46ac"},{"Ep":"01","_NwkId":"d6c4"}],"GroupName":"Zigate - Zigate Group 2a2f","WidgetStyle":"LvlControl","_GroupId":"2a2f"}
3: Object {"Cluster":"0008","Devices":[{"Ep":"01","IEEE":"588e81fffe41f425","_NwkId":"3c62"},{"Ep":"01","IEEE":"ec1bbdfffe360d58","_NwkId":"d46c"},{"Ep":"01","IEEE":"842e14fffe194dfd","_NwkId":"4b3e"},{"Ep":"01","_NwkId":"ffa9"}],"GroupName":"Zigate Group 413e","WidgetStyle":"","_GroupId":"413e"}
Content of zGroup-lst-devices.json:
0: Object {"WidgetList":[{"Ep":"01","IEEE":"00158d00021e11ad","Name":"","ZDeviceName":"Zigate (Coordinator)","_ID":""}],"_NwkId":"0000"}
1: Object {"WidgetList":[{"Ep":"01","IEEE":"14b457fffe33db5f","Name":"Lamp voordeur rechts","ZDeviceName":"Lamp voordeur rechts","_ID":58}],"_NwkId":"7686"}
2: Object {"WidgetList":[{"Ep":"01","IEEE":"14b457fffe3f5671","Name":"Lamp voordeur links","ZDeviceName":"Lamp voordeur links","_ID":79}],"_NwkId":"5a8d"}
3: Object {"WidgetList":[{"Ep":"01","IEEE":"680ae2fffea9bf2d","Name":"Lamp terras beneden 1","ZDeviceName":"","_ID":106}],"_NwkId":"52d2"}
4: Object {"WidgetList":[{"Ep":"01","IEEE":"680ae2fffea9903a","Name":"Lamp terras beneden 2","ZDeviceName":"","_ID":107}],"_NwkId":"8c9f"}
5: Object {"WidgetList":[{"Ep":"01","IEEE":"ec1bbdfffe376813","Name":"Spotjes buffetkast","ZDeviceName":"Spotjes buffetkast","_ID":41}],"_NwkId":"32af"}
6: Object {"WidgetList":[{"Ep":"01","IEEE":"680ae2fffe15f9aa","Name":"Lamp hal 1","ZDeviceName":"Lamp hal 1","_ID":81}],"_NwkId":"a7d6"}
7: Object {"WidgetList":[{"Ep":"01","IEEE":"680ae2fffe156b68","Name":"Lamp hal 2","ZDeviceName":"Lamp hal 2","_ID":80}],"_NwkId":"574d"}
8: Object {"WidgetList":[{"Ep":"01","IEEE":"ec1bbdfffe30d77b","Name":"Spotjes kapstok","ZDeviceName":"Spotjes kapstok","_ID":43}],"_NwkId":"8ca5"}
9: Object {"WidgetList":[{"Ep":"01","IEEE":"bc33acfffe8407d9","Name":"Lamp afzuigkap 1","ZDeviceName":"","_ID":262}],"_NwkId":"3f3d"}
10: Object {"WidgetList":[{"Ep":"01","IEEE":"bc33acfffe5f00ae","Name":"Lamp afzuigkap 2","ZDeviceName":"","_ID":263}],"_NwkId":"46ac"}
11: Object {"WidgetList":[{"Ep":"01","IEEE":"588e81fffe40a906","Name":"Remote afzuigkap","ZDeviceName":"","_ID":264}],"_NwkId":"d6c4"}
12: Object {"WidgetList":[{"Ep":"01","IEEE":"588e81fffe41f425","Name":"Lamp zolder 2","ZDeviceName":"","_ID":266}],"_NwkId":"3c62"}
13: Object {"WidgetList":[{"Ep":"01","IEEE":"ec1bbdfffe360d58","Name":"Lamp zolder 1","ZDeviceName":"","_ID":267}],"_NwkId":"d46c"}
14: Object {"WidgetList":[{"Ep":"01","IEEE":"842e14fffe194dfd","Name":"Lamp zolder 3","ZDeviceName":"","_ID":268}],"_NwkId":"4b3e"}
15: Object {"WidgetList":[{"Ep":"01","IEEE":"588e81fffe3c9600","Name":"Remote zolder","ZDeviceName":"","_ID":269}],"_NwkId":"ffa9"}
I'm not sure where to find the debug group switch.
Awaiting your kind reply.
Best regards,
Tonka.
