Python Plugin : Xiaomi Philips LED Ball Lamp Topic is solved
mgabor
Re: Python Plugin : Xiaomi Philips LED Ball Lamp
Dear,
I have found that the token has changed, so the bulb did not work. I change the token in domoticz, but when I have added the new bulb with new token, the device does not appear in the list. In the log file I have found this.
2019-03-02 07:54:30.700 Error: Lámpa1 hardware (9) thread seems to have ended unexpectedly
2019-03-02 07:55:00.781 Error: Lámpa1 hardware (9) thread seems to have ended unexpectedly
2019-03-02 07:55:30.790 Error: Lámpa1 hardware (9) thread seems to have ended unexpectedly
2019-03-02 07:56:00.795 Error: Lámpa1 hardware (9) thread seems to have ended unexpectedly
I have done this:
update, upgrade, restart, nothing changes
What is the problem?
Gabor
I have done this:
Gabor
Samael
- Domoticz version: 4.9701
First of all, you have to test a new token with MyBulb.py. Run command with lamp IP and it's tokenmgabor wrote: Saturday 02 March 2019 8:03 Dear,
MyBulb.py 192.168.10.102 89bedfa9123841a44030fd4ae2a0db09 status-
mgabor
the answer:
File "MyBulb.py", line 11, in <module>
import miio.philips_bulb
ImportError: No module named miio.philips_bulb
Samael
Did you install python-miio library? Please read this guide https://python-miio.readthedocs.io/en/l ... overy.htmlmgabor wrote: Saturday 02 March 2019 16:25 the answer:
mgabor
Yes, I have installed. I have used the Bulb, but the token has changed, since I have to add again the hardver
Samael
If someone switched to the development branch of Domoticz, then I recommend to pick up the plugin from the dev branch:
https://github.com/deennoo/domoticz-Xia ... p/tree/dev
This version is faster.
Samael
Hmm. You can change the token on Hardware tab and simply press update. No need to remove and add.mgabor wrote: Sunday 03 March 2019 14:44 Yes, I have installed. I have used the Bulb, but the token has changed, since I have to add again the hardver
koles142
I'm using your plugin. I can control my bulb, can change color, level light but i can't turn off the bulb from Domoticz. In my log I have:
Error: [bulb name] Call command failed: Command '['./MyBulb.py', '192.168.31.103', 'bulb token', '--scene', '0']' returned non-zero exit status 2.
When I turn off my bulb from xiaomi app i can turn on it again from Domoticz. I can do anything with bulb except the turning off. Have you any idea?
thnaks
thnaks
Samael
At the moment I am using a development version of the plugin with a beta version of domoticz, since it does not use the launch of an additional script to execute commands. I hope the release of stable version of domoticz will be soon..
fecus
- Domoticz version: 4.11597
First of all, thank you for your efforts.
I installed your plugin from git.
It made two devices.
The scenes device is working well.
The CCCW device requires a password. What kind of password are asking?
Samael
There is no any passwords and can not be. Source code is open. I assume this is related to the work environment. Currently I use Python 3.6.8.
C:\Python>pip3 list miio
Package Version
android-backup 0.2.0
appdirs 1.4.3
asn1crypto 0.24.0
attrs 18.2.0
certifi 2018.11.29
cffi 1.11.5
Click 7.0
construct 2.9.45
cryptography 2.4.2
idna 2.8
ifaddr 0.1.6
netifaces 0.10.9
pip 19.3.1
pipenv 2018.11.26
pretty-cron 1.2.0
pycparser 2.19
python-miio 0.4.4
pytz 2018.9
setuptools 40.8.0
six 1.12.0
tqdm 4.29.1
virtualenv 16.2.0
virtualenv-clone 0.4.0
virtualenvwrapper-win 1.2.5
zeroconf 0.21.3
Package Version
appdirs 1.4.3
asn1crypto 0.24.0
attrs 18.2.0
certifi 2018.11.29
cffi 1.11.5
Click 7.0
construct 2.9.45
cryptography 2.4.2
idna 2.8
ifaddr 0.1.6
netifaces 0.10.9
pip 19.3.1
pipenv 2018.11.26
pretty-cron 1.2.0
pycparser 2.19
python-miio 0.4.4
pytz 2018.9
setuptools 40.8.0
six 1.12.0
tqdm 4.29.1
virtualenv 16.2.0
zeroconf 0.21.3
jstruik
- Domoticz version: 2020.1
@Samuel
thank you so much for your effort. I accidentally bought this Xiaomi Philips LED bulb. I wanted to buy the Xiaomi ZNLDP12LM which has Zigbee support to match my xiaomi mijia temperature sensors...
Nevertheless, your plugin saved me from reverse-engineering the protocol and building a domoticz plugin myself!
In the complete process of setting up domoticz on a synology NAS, configuring Zigbee2mqtt, configuring NefitEasyServer and now configuring this LEDbulb I already spend so much hours searching this forum and this is my first message to thank you (all).
running on DSM 6.2.2-24922 Update 4 @ Synology DS216j
Zigbee2mqtt @ CC2531 USb stick
2 * xiaomi mijia temperature sensor
Xiaomi Philips E27 LEDbulb
NefitEasyServer
Dashticz v3
NefitEasyServer
Dashticz v3
jstruik
for future reference: after the synology DSM upgrade the plugin didn't work anymore. I had to rethink the steps taken previous month
bash expects a file python3 in the /usr/bin directory. In my case (Synology DS216j), it wasn't present. With a symbolic link it worked again:
cd /usr/bin
sudo ln -s /opt/bin/pyhton3.7 python3running on DSM 6.2.2-24922 Update 4 @ Synology DS216j
NefitEasyServer
Dashticz v3
NefitEasyServer
Dashticz v3
manjh
- Domoticz version: 2025.2
I'm trying to get started with this bulb. First step was to learn how to reset it (5 consecutive on/off switches), and add it to Mi Home.
The reset worked, but Mi Home does not want to see the lamp.
I tried scanning without result. Then tried manually, connected to the lamp's WiFi. That worked, but still Mi Home will not connect the lamp.
Seems to me I should get this working before attempting to control the lamp from Domoticz...
Can someone give me a hint?
Hans
Hello, I try to use this plugin and I have an error
On master Domoticz say :
On console when I type "python ./MyBulb.py 192.168.0.90 fc6e962c38a7ae378fe164acc278f556" I have this response:
So it's work on console but not in domoticz
If I switch on dev branch I dont no work in console with this error:
version of python-miio 0.5.9.2
Domoticz Version: 2021.1
Build Hash: 8547c5b7e
Compile Date: 2021-04-17 17:29:11
dzVents Version: 3.1.7
Python Version: 3.7.3
Someone can help me?
Get status failed: Command '['./MyBulb.py', '192.168.0.90', 'fc6e962c38a7ae378fe164acc278f556']' returned non-zero exit status 1.Code: Select all
<PhilipsBulbStatus brightness=100 color_temperature=1 delay_off_countdown=0 is_on=True power=on scene=0>
File "/home/pi/.local/lib/python3.7/site-packages/miio/miioprotocol.py", line 193, in send
data, addr = s.recvfrom(4096)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
File "./MyBulb.py", line 55, in <module>
print(MyBulb.status())
File "/home/pi/.local/lib/python3.7/site-packages/miio/click_common.py", line 186, in _wrap
self._fetch_info()
File "/home/pi/.local/lib/python3.7/site-packages/miio/device.py", line 149, in _fetch_info
devinfo = DeviceInfo(self.send("miIO.info"))
File "/home/pi/.local/lib/python3.7/site-packages/miio/device.py", line 104, in send
command, parameters, retry_count, extra_parameters=extra_parameters
File "/home/pi/.local/lib/python3.7/site-packages/miio/miioprotocol.py", line 237, in send
extra_parameters=extra_parameters,
File "/home/pi/.local/lib/python3.7/site-packages/miio/miioprotocol.py", line 161, in send
self.send_handshake()
File "/home/pi/.local/lib/python3.7/site-packages/miio/miioprotocol.py", line 74, in send_handshake
raise DeviceException("Unable to discover the device %s" % self.ip)
miio.exceptions.DeviceException: Unable to discover the device 192.168.0.90
