Page 3 of 6
Re: Pushnotification when dishwasher/washing machine is read
Posted: Thursday 19 November 2015 9:16
by ThinkPad
I still think a script that uses some sort of counter, is the best approach.
For my motion sensor i use
this script. Every minute the script is executed (script_time_nomotion.lua), a check is done if the motionsensor has activated. If not, the counter is upped with +1. When the counter reaches 30, a virtual switch is turned off.
For the washingmachine i would do something like this:
--script_time_washingmachine.lua
--Change the values below to reflect to your own setup
local switch_washingmachine = 'virt_wasmachine' --Name of virtual switch that will show the state of the washingmachine (on/off)
local energy_consumption = 'Actual_wasmachine' --Name of Z-Wave plug that contains actual consumption of washingmachine (in Watts)
local washer_uservar = 'washingmachine_counter' --Name of the uservariable that will contain the counter that is needed
local idle_minutes = '10' --The amount of minutes the consumption has to stay below the 'consumption_lower' value
local consumption_upper = 4.0 --If usage is higher than this value (Watts), the washingmachine has started
local consumption_lower = 3.0 --If usage is lower than this value (Watts), the washingmachine is idle for a moment/done washing
--Virtual switch is off, but consumption is higher than configured level, so washing has started
if (tonumber(otherdevices_svalues[energy_consumption])) > consumption_upper and otherdevices[switch_washingmachine] == 'Off' then
commandArray[switch_washingmachine]='On'
print('Washingmachine is now ON')
commandArray['Variable:' .. washer_uservar]=tostring(idle_minutes)
else --Washing machine is not using a lot of energy, subtract the counter
if (tonumber(otherdevices_svalues[energy_consumption])) <= consumption_lower and otherdevices[switch_washingmachine] == 'On' then
commandArray['Variable:' .. washer_uservar]=tostring(math.max(uservariables[washer_uservar] - 1, 0))
--Washingmachine is done
if (otherdevices[switch_washingmachine] == 'On' and uservariables[washer_uservar] == 0) then
print('Washingmachine is DONE')
commandArray['SendNotification']='Washingmachine#Washingmachine is done, please go empty it!#0' --Use Domoticz to send a notification, replace line for your own command if needed.
commandArray[switch_washingmachine]='Off'
Haven't tested it, maybe i will use this script later when i got myself an extra Z-Wave plug. Line #21 might need changing into:
commandArray['Variable:' .. washer_uservar]=tostring(math.max(tonumber(uservariables[washer_uservar]) - 1, 0))
Including a 'timedifference' piece of code would also be nice, that could tell you how long the washingmachine needed for it's program, e.g. "Washing machine done, please empty it! Program took 1hr30mins".
Something for later
Posted: Friday 20 November 2015 13:48
by thorbj
I'm testing your script @ThinkPad, but I think it doesn't get the readings right from energy_consumption. Nothing happens to switch_washingmachine when the washingmachine starts.
Posted: Saturday 21 November 2015 10:33
by ThinkPad
I just ordered some extra Z-Wave plugs yesterday, i expect them to arrive next week.
So i will try my own script in a few days. Might take a few days, we don't use the washingmachine every day.
To be continued.....
Posted: Monday 30 November 2015 10:11
by ThinkPad
thorbj wrote:I'm testing your script @ThinkPad, but I think it doesn't get the readings right from energy_consumption. Nothing happens to switch_washingmachine when the washingmachine starts.
I think i made some mistakes with the brackets in the comparison part (is usage higher than the defined upper limit). Try this script:
local energy_consumption = 'Wasmachine' --Name of Z-Wave plug that contains actual consumption of washingmachine (in Watts)
local idle_minutes = 10 --The amount of minutes the consumption has to stay below the 'consumption_lower' value
sWatt, sTotalkWh = otherdevices_svalues[energy_consumption]:match("([^;]+);([^;]+)")
if (tonumber(sWatt) > consumption_upper) and otherdevices[switch_washingmachine] == 'Off' then
if (tonumber(sWatt) <= consumption_lower) and otherdevices[switch_washingmachine] == 'On' then
In this case i use a Z-Wave plug that has multiple devices, one for actual usage (Watt) and one for cumulative (kWh). The last one also contains actual usage, so i don't use the Domoticz device anymore that only contains actual usage. So the script has changed a little bit, i needed an extra line of code (sWatt, sTotalkWh) to extract the actual power consumption.
I would recommend to also use only the Domoticz device that contains both cumulative + actual usage. Otherwise change the Lua script a bit, i think you can figure that out (see the script in my previous post, there i was still using a Domoticz device with only actual usage).
I still haven't got time to test it myself unfortunately. But maybe it works now, let me know
Posted: Monday 30 November 2015 13:39
by thorbj
Thanks, I'm testing the new script
I'm probably gonna wash some clothes later today, so I will post back with results
Posted: Monday 30 November 2015 21:25
by G3rard
I use the following script to check if my dryer is ready.
It uses a Everspring AN158 to measure the current usage.
Droger_gestart (dryer started) and Droger_gereed (dryer ready) are 2 user variables (integer).
The dryer uses ~3W when ready and then frequently goes on to prevent wrinkles which takes ~170W. So when the dryer is using ~3W I know it's ready.
That's what this script is looking for.
Maybe it is usefull for someone.
-- Purpose: Send message when dryer is ready
-- Author : G3rard
-- Date : 01-08-2015
-- Functions
function fprint(fMessage, fDebug)
if (fDebug == "True") then
print("Droger: " .. fMessage)
function Notification(fNotification, fDebug)
if (fDebug == "False") then
commandArray['SendNotification'] = "" .. fNotification .. ""
-- Set variables
-- Dryer uses ~3W when ready and then frequently goes on to prevent wrinkles which takes ~170W
sDebug = "True"
var_UsageTrigger_0 = 0 -- Usage trigger (Watt)
var_UsageTrigger_1 = 1 -- Usage trigger (Watt) --was 100
var_UsageTrigger_2 = 100 -- Usage trigger (Watt) --was 300
var_UsageTrigger_3 = 1000 -- Usage trigger (Watt)
var_dryer = 'Verbruik - droger' -- Dryer
DeviceUsage = tonumber(otherdevices_svalues[var_dryer]) -- Usage of dryer
lastUpdatedUsrVar = uservariables_lastupdate[var_dryer] -- Last update of dryer
var_dryer_started = 'Droger_gestart' -- Dryer started 0-1
var_dryer_ready = 'Droger_gereed' -- Dryer ready 0-1
dryer_started = uservariables[var_dryer_started] -- Dryer started 0-1
dryer_ready = uservariables[var_dryer_ready] -- Dryer ready 0-1
if (DeviceUsage > var_UsageTrigger_3) then -- > 1000W, dryer is on
if(dryer_started == 0) then
fprint("Verbruik droger > " .. var_UsageTrigger_3 .. " W: droger aan", sDebug)
fprint("Verbruik droger " .. DeviceUsage .. " W", sDebug)
dryer_started = 1
commandArray['Variable:' .. var_dryer_started] = tostring(dryer_started)
elseif(DeviceUsage > var_UsageTrigger_1 and DeviceUsage < var_UsageTrigger_2) then -- > 1 and < 100W, dryer is ready
if(dryer_started == 1 and dryer_ready == 0) then
fprint("Verbruik droger tussen " .. var_UsageTrigger_1 .. " W en " .. var_UsageTrigger_2 .. ": droger gereed", sDebug)
commandArray['SendNotification']='Droger#De droger is klaar#1'
os.execute('curl --url "http://192.168.1.102/domoticz/fp/sonos/index.php?zone=115&action=sendMessage&message=droger_gereed&volume=30" &') --Play on Sonos
dryer_ready = 1
commandArray['Variable:' .. var_dryer_ready] = tostring(dryer_ready)
elseif(DeviceUsage == var_UsageTrigger_0) then --0W, dryer is off
if(dryer_started == 1 or dryer_ready == 1) then --was and
fprint("Verbruik droger " .. var_UsageTrigger_0 .. " W: droger gestopt",sDebug)
dryer_started = 0
dryer_ready = 0
Posted: Wednesday 02 December 2015 10:48
by ThinkPad
That won't work with my washingmachine, already tried a script like that.
My washer is rotating clockwise (usage > 50W or so), then stops for a few seconds (usage: 3-4W), then rotates counterclockwise (usage > 50W). And this happens a few times during the complete program (to prevent wrinkles in the laundry).
Those moments between changing turning direction create false positives with a script like yours. That's why i use the counter (minutes), the energy usage has to stay below minimum for a few minutes, only then the machine is really done.
But i am still very busy this week, haven't had time yet to try the script i posted earlier grrrrr. My hopes are on thorbj to test and debug in reallife situation
Posted: Wednesday 02 December 2015 12:03
by thorbj
thorbj wrote:Thanks, I'm testing the new script
Script still gives me a lot of notifications. I will try to increase the timer to maybe 15 or 20 sec.
Posted: Wednesday 02 December 2015 12:07
by ThinkPad
Hmmm that's stupid.
I will try to find a moment soon to test the script, maybe with a lightbulb, so i don't have to wait for the moment we need the washingmachine again.
Posted: Wednesday 02 December 2015 15:32
by mvveelen
Subscribed to this topic to see what will be the result. I think this is really fun to use. Do not really need it, but it's just fun to be able to tell when the machine is ready.
Posted: Wednesday 02 December 2015 15:44
by Minglarn
Same here
This gives me the opportunity to convince my wife that more nodes have to be bought
Sent from space using an app.
Posted: Wednesday 02 December 2015 21:10
by ThinkPad
I put some effort in it, and tested it for a while by using the Z-Wave plug between my TV.
That resulted in
this script.
I think it should work now, please let me know if you have tested it
The values (idle_minutes, consumption_upper & consumption_lower) might need some changing depending on your type of washing machine.
- idle_minutes = the amount of minutes that the washer should use less than 'consumption_lower' to assume it is ready
- consumption_upper = If the washingmachine uses more than this amount, we assume that it has been turned on and started washing
- consumption_lower = If the washingmachine uses less than this amount, it is idle (waiting before changing tumbling direction), or ready
It also needs two uservars of type 'integer', fill them with '0' (zero) when you create them. Then fill in their names in the local: 'washer_status_uservar' and 'washer_counter_uservar'.
Posted: Friday 04 December 2015 16:21
by ThinkPad
Today we had to run the washingmachine. Unfortunately my Z-Wave plug (Greenwave) was doing weird things (it gave a lot of timeouts and stuff), but i was able to heal the network/restart Domoticz before the washer ended.
Conclusion: it works!!!
I used this settings:
local idle_minutes = 5
local consumption_upper = 20
Let me know how the script works at your setups!
Posted: Tuesday 08 December 2015 10:51
by ThinkPad
Yesterday we had the washingmachine running again, this time my Z-Wave network didn't have any issues anymore.
Again: i only received one notification, when the washing machine was ready, just like it should.
So i consider
the script working stable and ready to be used
But like i said: it depends on the parameters, you need to adapt those to your washingmachine.
Posted: Friday 25 December 2015 0:05
by plutonium
Very nice script! Will love to use it, or my wife would.
But I get this error and I have tried everything that I can imagine.
Error: EventSystem: ...e/pi/domoticz/scripts/lua/script_time_washingmachine.lua:17: attempt to compare number with nil
I have i dummy switch named virt_wasmachine and user variables washingmachine_status and washingmachine_counter.
Line 17:
if (washer_usage > consumption_upper) and uservariables[washer_status_uservar] == 0 then
Posted: Friday 25 December 2015 0:36
by nayr
my switch (Aeon Labs DSC06106) has an output that has only wattage in the svalue, nothing else.. so I modified it as thus:
-- sWatt, sTotalkWh = otherdevices_svalues[energy_consumption]:match("([^;]+);([^;]+)")
washer_usage = tonumber(otherdevices_svalues[energy_consumption])
and that seemed to work fine, the lastest script he published seems to not need the virtual switch at all.. which is good.. Works well enough I am going to get more switches for the Dish Washer and Dryer (Gas)..
I just finished testing it on a spin cycle and it worked perfectly, my switch just came in the mail today and I am hoping to have this setup as a surprise christmas gift.. Thanks @ThinkPad, got it all working within about 10mins of hooking up the laundry cleaner. With them located in basement they cant be heard when cycle has finished, too many times we have to rewash a load we forgot about.. not to mention our house keeper tossing a load in laundry and forgetting to inform us about it.
Now to put a motion sensor in the laundry room and have the notifications keep bugging us every hour or so until someone actually goes down there.. and script basement flood sensor to kill the washer if sewer pipe is clogged..
Posted: Friday 25 December 2015 0:51
by plutonium
Thanks that did the trick!
Will try it tomorrow and test this script on my dryer, washer machine and dishwasher.
Posted: Friday 25 December 2015 4:04
by nayr
modified your script a bit @ThinkPad to fix a lil bug,
copied the counter setup line from the first if statment, and added it to the second as an elseif condition:
if (washer_usage < consumption_lower) and uservariables[washer_status_uservar] == 1 then --Washing machine is not using a lot of energy, subtract the counter
commandArray['Variable:' .. washer_counter_uservar]=tostring(math.max(tonumber(uservariables[washer_counter_uservar]) - 1, 0))
print('Current power usage (' ..washer_usage.. 'W) is below lower boundary (' ..consumption_lower.. 'W), washer is idle or almost ready')
print('Subtracting counter with 1, new value: ' ..uservariables[washer_counter_uservar].. ' minutes')
elseif ((uservariables[washer_counter_uservar] ~= idle_minutes) and uservariables[washer_status_uservar] == 1) then
commandArray['Variable:' .. washer_counter_uservar]=tostring(idle_minutes)
my full script:
http://pastebin.com/w9aWiu3B
this way the counter resets if its not idle for consecutive mins.. Watching a load wash now and I noticed wattage dropped real low but the counter did not reset after it went back up before timeout. My Washer gives a reminder tone @ 5mins and the notification came in within seconds of that going off.
Posted: Friday 25 December 2015 10:18
by ThinkPad
Nice! I don't fully understand what bug you did fix.
But great both of you could get it working
About the meter, all of my plugs that do energy measurement have both Watt and kWh meters. I prefer the kWh meters, because they also contain the actual Watt value. This way you only need one device, where you can see the actual usage AND the accumulated power (kWh).
Posted: Friday 25 December 2015 17:20
by nayr
basically its just else washer counter does not equal idle mins and the washer is on, then reset washer counter to idle mins.. now it will count down the timer like before, but if the power consumption goes back up before the timer expires, the timer will reset.
I think my switch can be reconfigured to show watt/kwh in the same field, or each one individually.. I may change it, but I didnt buy the energey tracking switch to actually track energy.. just to detect when the cycle was complete.. I have a whole house power monitor on my main panel and another on my subpanel, tracking individual appliance energy consumption might be worth while.. havent put too much thought into it yet.. Wish I could just get a Smart Fuse Box that let me track each circuit's consumption and status.
