Page 3 of 3
Re: Rain counter
Posted: Friday 19 August 2022 13:47
by JackD
Just looking at your log, a quick remark.
rainrate 81000.0 mm/hr....? and 0.45mm/m2 total today?
should that not be the other way round.... rainrate 0.45mm/hr and total 81000.mm/m2 in total today
But a daycount of 81000 is impossible unless you put your rainmeter under a waterfall
Good luck with your quest on solving this.
Regards,
Jack
Re: Rain counter
Posted: Friday 19 August 2022 23:09
by Peter83
hey
no it should be right, as rainrate is not 81000mm/hr its 810mm/hr wich means, that i used the switch manualy every second second. Or its 1620mm/hr using switch every second.
But yes, it would also be nice to have something like a blockage for like 5 seconds. I know you can set it up in Tasmota but i do now want it to work too much since its ment to work on battery.
So if you have an advice to change skrit so its working at maximum every 5 seconds i would like to know it
im still clueless with rainTotal not growing.
Re: Rain counter
Posted: Saturday 20 August 2022 9:24
by Peter83
So i set up a Wemos d1 yesterday with Tasmota and used the same skript with new virtual devices.
It was working perfektly yesterday but today its adding randomly numbers again.
No its not random its 3,9mm witch was yesterdays rainTotal in the end.
so maybe i have to reset activly at 0:00 again or still unnecessary?
Re: Rain counter
Posted: Monday 22 August 2022 8:52
by Peter83
so this is the same problem, 3 people mentionen before. But i cant find a proper solution.
Changed skript to below and resettet at 00:01. Now it added -129 first time and its staying a 0 from now on.
Is it, because trigger is reset at 00:01 and has to be at 0:00? Or is there another way working?
return
on =
timer =
"at 00:01"
devices =
"WippeOhlau"
logging =
level = domoticz.LOG_DEBUG, -- INFO, ERROR or DEBUG
marker = "ESP test",
execute = function(dz, item, trigger)
local rainDevice = dz.devices("RegenOhlau") -- Your (virtual) rain device
local rainSwitch = dz.devices("WippeOhlau") -- Your (triggered by bucket full) switch
local rainmm = 45 -- find out what 1 bucket full means in terms of mm
local rainTotal = 0
local timeSlice = math.min( (rainDevice.lastUpdate.secondsAgo / 3600), 10) -- at least 1 bucket in 10 hours
local rainAmountHour = dz.utils.round((rainmm / timeSlice),1)
if
trigger.isTimer then
rainDevice.updateRain(dz.utils.round(rainDevice.rainRate,0),0) -- reset rainTotal
rainSwitch.switchOff().silent()
dz.log("Reset raintotal to 0",dz.log_DEBUG)
elseif item.active then
rainTotal = dz.utils.round(((rainmm / 100) + rainDevice.rain),2)
rainDevice.updateRain(rainAmountHour, rainTotal)
dz.log("One bucket full ==>> updating raindevice. rainrate: " .. rainAmountHour .. " mm/hr, " .. rainTotal .." mm in total today ", dz.LOG_DEBUG )
dz.log("Old value raindevice.rain: " .. rainDevice.rain .." mm in total today ", dz.LOG_DEBUG )
Re: Rain counter
Posted: Monday 22 August 2022 9:38
by waltervl
I think you should not have to reset the rainTotal value at night as it should be a normal counter (like your electricity counter at home). So Domoticz should calculate the daily values for you.
Re: Rain counter
Posted: Monday 22 August 2022 18:17
by Peter83
ok, but how can i work arround this than?:
waaren wrote: Monday 31 August 2020 18:44
The value shown on the title row of a rain device shows the latest send value minus the first value of today. So if you have send the same value it will show 0.
I wonder if one has solved this befor, since i wont find any answer to this:/
Re: Rain counter
Posted: Saturday 25 February 2023 8:49
by gizmocuz
For anyone finding this thread:
device.rain provides the actual rain of today (not the counter)
to get the counter, you have to retrieve this from the sValue of the device with
local f_rainValTable = domoticz.utils.stringSplit(rain_sensor.sValue,';')
local actual_rain = f_rainValTable[2]
(First value is rain-rate, second value is the counter value)
A complete dzVents example which increments the counter via a door-sensor is provided below:
devices = {
'RegenSensorSwitch'
logging = {
level = domoticz.LOG_INFO,
marker = 'rain-zigbee',
--domoticz.log('Device ' .. device.name .. ' was changed: ' .. device.state, domoticz.LOG_INFO)
if (device.state == 'Closed') then
local rain_sensor = domoticz.devices("RainZigbee")
--domoticz.log('total rain: ' .. actual_rain, domoticz.LOG_INFO)
local rain2add = 0.30303
local new_rain = domoticz.utils.round((rain2add + actual_rain),2)
--domoticz.log('new_rain: ' .. new_rain, domoticz.LOG_INFO)
rain_sensor.updateRain(0, new_rain)
Re: Rain counter
Posted: Tuesday 26 September 2023 21:14
by ssk17051980
hello,
need some help,
so I created an open/closed switch. he confirms to me that the sensor in the rain gauge works and changes its state. dummy name is "rain-zigbee"
i created a custom counter type sensor, called "RegenSensorSwitch" that expresses the quantity in liters/square meter
at the end in setup/events I created a new dzvents script and pasted the above script . however, in the log it appears that the script is being created, but then nothing about couter named RegenSensorSwitch
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 18:23:44
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 31 2022, 14:04:00) [GCC 8.3.0]
any help ?
thx
Re: Rain counter
Posted: Tuesday 26 September 2023 23:12
by waltervl
It is all in the details. For the script above the devices needed are:
Rain sensor name should be RainZigbee and not rain-zigbee
The dummy switch name should be RegenSensorSwitch
Re: Rain counter
Posted: Wednesday 27 September 2023 17:30
by ssk17051980
now the problem is this :
2023-09-27 18:27:20.934 Error: dzVents: Error: (3.1.8) rain-zigbee: An error occurred when calling event handler Precipitatii
2023-09-27 18:27:20.934 Error: dzVents: Error: (3.1.8) rain-zigbee: ...oticz/scripts/dzVents/generated_scripts/Precipitatii.lua:21: attempt to perform arithmetic on a nil value (local 'actual_rain')
Re: Rain counter
Posted: Wednesday 27 September 2023 18:34
by waltervl
What happens if you uncomment the log statements (remove the -- before domoticz.log )?
Do you have the security settings right?
Re: Rain counter
Posted: Wednesday 27 September 2023 20:24
by ssk17051980
so, i made another sensor, like in the foto.
i have data now, but they are not to good.
Re: Rain counter
Posted: Sunday 01 October 2023 18:27
by ssk17051980
and a second problem. i receive "time out" from the rain sensor.
