Page 3 of 8
Re: Tado Thermostat plugin
Posted: Saturday 15 December 2018 8:05
by manutremo
Did you restart the plug-in after allowing devices creation? That should trigger detection of new devices
Posted: Saturday 15 December 2018 23:48
by Davince
With restarting the plugin, do you mean removing tado hardware and adding again in the hardware section? Will that remove the history of my tado temp devices, etc too? (Not the biggest issue, as long as this would solve the issue with some devices not showing).
Posted: Sunday 16 December 2018 9:09
by manutremo
No, just select it in the hardware tab, click on Enable, click on Update, select or again, click on Enable, then on Update. That should trigger it. If not, you can always restart the full domoticz.
Posted: Tuesday 18 December 2018 12:44
by Davince
Super, that did the trick for me! Very happy with it, thanks!
Posted: Saturday 05 January 2019 20:40
by dotms
Just a quick message that I have decided to replace my Tado thermostat by a different heating solution. Since I don't have any way to properly test or validate any changes I make I will cease my development activities on this hardware. In its current form the plugin is quite usable and bug free and very much suitable for daily use.
As the code is in the public Domoticz repository anyone who feels like it is free to take over any further development.
Posted: Thursday 17 January 2019 20:26
by vamp
Hello there,
I add a new device to Tado (smart radiator thermostat) but i can not control it. I see the values, but not set it (like only "read" right)
The old two devices (normal thermostat and a another radiator thermostat) working well.
I not see any special on Domoticz log.
Posted: Wednesday 23 January 2019 0:37
by vamp
vamp wrote: Thursday 17 January 2019 20:26 Hello there,
Notice:
It not important, what device use it on third room. The problem is the third room. If i add it, can not change the values.
Posted: Wednesday 30 January 2019 18:30
by rjblake
Heads up for all - I received this notification today:
tado is discontinuing the old OAuth2 endpoints at my.tado.com. Starting March 2019, authentication will require retrieving access and refresh tokens from auth.tado.com. The client public-api-preview can be used as is (with the same client secret) on the new endpoint.
The new authentication will also be a standard OAuth2 system, but will use JWT as a format for refresh tokens. So be aware that this will increase the size of the refresh tokens.
Additionally, the new endpoints implement refresh token rotation. A new refresh token is issued with every access token refresh response. The previous refresh token is invalidated.
Refresh token rotation info here.
I have checked the Tado code for Domoticz and it looks like it should continue to work as the endpoints are determined by pretending that it is URL call being made.
Posted: Sunday 10 March 2019 17:38
by coen17st
vamp wrote: Wednesday 23 January 2019 0:37
Notice:
I thought I had the same problem, could not set the temperature of no more than two rooms.
It still looks like it but i have discovered that there is a twist. (program mistake?) As an example, when I change the manual setpoint from Domoticz of the bedroom, the setpoint of the living room changes, the setpoint of the bedroom remains at the old value. It seems read only but in the background a completely different / wrong room changes.
Someone who has this, or even better is there a solution?
re-adding the hardware does not solve anything
Posted: Thursday 21 March 2019 14:48
by DarkAllMan
I would also like to turn off the thermostat via domoticz... but I don't think it's possible at the moment.
Who can help in adding this function?
Posted: Monday 15 April 2019 9:45
by vamp
Now i use IFTTT to control Tado via Domoticz. It is bit slower (about 2-3 sec response time) but work without any error.
Posted: Wednesday 27 November 2019 21:05
by bxlouis
First thanks for this amazing plugin.
I am wondering if someone is still maintaining it and could allow to retrieve and control the "Home/Away" and "Open Window" switches.
I know the plugin already retrieves the "Home/Away" status, but it seems that it is read-only as I cannot switch it on or off.
I saw on this page: https://shkspr.mobi/blog/2019/02/tado-a ... -for-2019/
That there is an endpoint to control these 2 values (cf. Georgi P comment on 2019-11-19 at 12:25).
Modifying the plugin to support this feature would make it even better but I am not sure how to proceed.
Any idea?
Cheers!
Posted: Friday 29 November 2019 22:15
by bxlouis
vamp wrote: Thursday 17 January 2019 20:26 I thought I had the same problem, could not set the temperature of no more than two rooms.
Exact same issue here, I noticed that in the "Devices" section of Domoticz, the setpoint which are inverted share almost the same "ID".
My bedroom has ID 000002E and my kitchen ID 0000002.
Not sure if it is linked to the issue but that's the only thing I see that could explain this behaviour.
Sadly, I cannot keep using the plugin due to this error and based on the thread activity, it seems that it is not maintained anymore :(
Posted: Wednesday 04 December 2019 11:38
by gavacac
How do I extract the temperature from the 'Temp/Hum' so I can use it in events?
Gavin
Posted: Wednesday 01 January 2020 22:56
by nigels0
I’m trying this with the Air Conditioning modules, but get this error
[2020-01-01 22:46:21.377 Status: Tado: Worker started. Will poll every 30 seconds.
2020-01-01 22:46:26.378 Tado: Attempting login.
2020-01-01 22:46:27.277 Status: Tado: Retrieved webapp environment from API.
2020-01-01 22:46:37.808 Error: Tado: GetAuthToken: HTTP/1.1 28 Timeout was reached
Any thoughts on what this could be?
Posted: Sunday 26 April 2020 10:43
by Zygoun
I also work to add my tado device to my conf.
That's works good !!
Recently, I found a node.
/homes/homeID/airComfort who return this values :
-freshness: object
-value: "FAIR"
lastOpenWindow: "2020-04-25T17:47:56Z"
-comfort: array[1]
-0: object
roomId: 1
temperatureLevel: "COLD"
humidityLevel: "COMFY"
-coordinate: object
radial: 0.51
angular: 276
These are in the bottom of the "air comfort skill" in V3+, but i am not able to find others like pollens or outside air.
All screenshots are here :
https://support.tado.com/en/articles/34 ... fort-skill
I try some others node with no success..
Any ideas ?
Posted: Sunday 26 April 2020 10:53
by bxlouis
@Zygoun
To retrieve the information about pollens and outside air, the app uses the following call:
https://acme.tado.com/v1/homes/homeID/airComfort?longitude=LONGITUDE&latitude=LATITUDE
Are you working on a plugin or something?
Posted: Friday 09 October 2020 8:43
by gvrgvr
I added an extra zone to my setup. Domoticz sees it:
2020-10-09 07:20:17.607 Status: Tado: Worker started. Will poll every 30 seconds.
2020-10-09 07:20:22.972 Status: Tado: Retrieved webapp environment from API.
2020-10-09 07:20:23.682 Status: Tado: Received access token from API.
2020-10-09 07:20:23.682 Status: Tado: Received refresh token from API.
2020-10-09 07:20:23.997 Status: Tado: Registered Home 'Thuis' with id 177002
2020-10-09 07:20:24.303 Status: Tado: Registered Zone 1 'Woonkamer' of type HEATING
2020-10-09 07:20:24.303 Status: Tado: Registered Zone 2 'Badkamer' of type HEATING
2020-10-09 07:20:24.303 Status: Tado: Registered Zone 0 'Warm water' of type HOT_WATER
But I don't see any devices of the new zone 'Badkamer'.
Does the tado plugin support multiple zones ?
Posted: Thursday 22 October 2020 10:44
by gvrgvr
gvrgvr wrote: Friday 09 October 2020 8:43 I added an extra zone to my setup. Domoticz sees it:
Fixed. I removed and added the tado hardware, but I think "accepting new hardware/sensors" was the only right thing to do.
Posted: Tuesday 10 November 2020 21:28
by gvrgvr
bxlouis wrote: Friday 29 November 2019 22:15
I have the exact same issue now I use multiple zones with Tado.
