Listen to your favourite radios V2
Gianni
Re: Listen to your favourite radios V2
Post by Gianni »
just tested
MP3 did not solve my problem
if i go to my terminal then it's work like that(i used without the extra parameters to see my output)
gianni@xxxxxx:~ $ mplayer http://icecast.vrtcdn.be/mnm_urb-mid.mp3
MPlayer 1.3.0 (Debian), built with gcc-6.2.1 (C) 2000-2016 MPlayer Team
do_connect: could not connect to socket
connect: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing http://icecast.vrtcdn.be/mnm_urb-mid.mp3.
Resolving icecast.vrtcdn.be for AF_INET6...
Couldn't resolve name for AF_INET6: icecast.vrtcdn.be
Resolving icecast.vrtcdn.be for AF_INET...
Connecting to server icecast.vrtcdn.be[5.79.75.39]: 80...
Name   : MNM UrbaNice | Kwaliteit**
Genre  : Urban
Public : no
Bitrate: 64kbit/s
Cache size set to 320 KBytes
Cache fill:  0.00% (0 bytes)
ICY Info: StreamTitle='';
if i run the script in domoticz my terminal get not any input
this is my selector
and this is my code
-- This script play a streaming radio when the device is changed
-- Start files with "mplayer -noconsolecontrols radiostation.mp3 &> /dev/null"
-- Start playlists with "mplayer -noconsolecontrols -playlist radiostation.m3u &> /dev/null"
if (devicechanged['Radio'] == 'Off') then
    os.execute ("killall mplayer")
if (devicechanged['Radio'] == 'MNM') then
    os.execute ("mplayer -noconsolecontrols http://icecast.vrtcdn.be/mnm-mid.mp3 &> /dev/null")
if (devicechanged['Radio'] == 'TopRadio') then
    os.execute ("mplayer -noconsolecontrols http://loadbalancing.topradio.be/topradio.mp3 &> /dev/null")
0n370uch
Domoticz version: Latest
Post by 0n370uch »
Hi, please try
-noconsolecontrols
Gianni
Post by Gianni »
you mean in my terminal?
this works.
i just try in my terminal without to see the output
if i start mplayer manual in my terminal (putty) en then i select MNM then mplayer get the quit command so that works.
The problem must be in the stream url.
  --  os.execute ("mplayer -noconsolecontrols http://icecast.vrtcdn.be/mnm-mid.mp3 &> /dev/null")
if i try your solution no test Folder
    os.execute ("sudo mkdir ~/test &> /dev/null")
    os.execute ("sudo mplayer -noconsolecontrols http://icecast.vrtcdn.be/mnm-mid.mp3 &> /dev/null")
If i do it manual
gianni@xxxx:~ $ mkdir ~/test &> /dev/null
gianni@xxxxx:~ $ ls
bluez-5.49  bluez-5.49.tar.xz  bluez-5.49.tar.xz.1  domoticz  habridge  mosquitto-repo.gpg.key  test
gianni@xxxxx:~ $
0n370uch
Post by 0n370uch »
I use mplayer without sudo and it works nice. Please test the command without sudo (like in your last example).
I executed this command in Fedora 28 without any problem some seconds ago:
Gianni
Post by Gianni »
yeah my fold
my script is without sudo this was just a test if it made any different.
like you say if i executed this command on my pi in putty it's works direct.
if i try it from within domoticz nothing happens :-)
0n370uch
Post by 0n370uch »
Oh one Idea. Check the main settings:
Gianni
Post by Gianni »
exact the same ;-)
0n370uch
Post by 0n370uch »
Very frustrating... I cannot see any sort of configuration mistake. One last idea: check the domoticz log after switching. I hope there is an error message.
Gianni
Post by Gianni »
nope just a switch message :-)
 2018-09-19 11:10:18.526 (Radio) Light/Switch (Radio)
2018-09-19 11:10:18.519 Status: User: Admin initiated a switch command (60/Radio/Set Level)
2018-09-19 11:10:19.968 (Radio) Light/Switch (Radio)
2018-09-19 11:10:19.960 Status: User: Admin initiated a switch command (60/Radio/Set Level)
2018-09-19 11:10:23.444 (Radio) Light/Switch (Radio)
2018-09-19 11:10:23.437 Status: User: Admin initiated a switch command (60/Radio/Set Level)
where are the log files from domoticz self i cannot find them in my console
I'm not home right now but i see in my problem log the test from yesterday and i have 1 line
2018-09-18 21:52:25.747 Error: EventSystem: Warning!, lua script Radio has been running for more than 10 seconds
0n370uch
Post by 0n370uch »
OK. No helpful message there... Sry no idea from my side at the moment.
Gianni
Post by Gianni »
np i have no idea 2 but thx for trying to help :-)
0n370uch
Post by 0n370uch »
Yeah... Tell me if you find a solution.
Gianni
Post by Gianni »
do you know where the log file from domoticz are in the terminal?
0n370uch
Post by 0n370uch »
Oh not in the terminal. Just under settings.
Gianni
Post by Gianni »
yeah i know but maybe there is a log with more information in the terminal
Gianni
Post by Gianni »
the only thing i can think about is the bluetooth driver.
how did you install your speaker?
i have to install bleuz and then pulseaudio to work but every time i reboot i need to redo this.
0n370uch
Post by 0n370uch »
I wrote about this on page 2. I think this is a good way... I use this way for one year.
Gianni
Post by Gianni »
but i use the stretch lite,so i need to preinstall the Alsa en Pulseaudio?
witch version do you use?
0n370uch
Post by 0n370uch »
I only use the latest version from the stock package sources.
Gianni
Post by Gianni »
hmm strange if i set my backup back and use the standard version without installing any other software i get this error
agent on error
power on error
etc
ps pic is from google but the same error
