Page 3 of 4
Re: Energy measurement with espeasy and pzem-004t
Posted: Monday 27 January 2020 18:00
by Sherco49
Hi !
i am trying to connect 2 PZEM-004t V3 on a Wemos D1 mini pro with ESP Easy then link them to Domoticz. The purpose is to monitor consuption and solar production.
I read many posts here and on "Let's Control it" forum, but i get lost now, like "papperone" wrote on the Let's control forum
-many different solutions, but not in the same unique post, so i can't understand wich software comes with wich wiring !
All of the authors are great to share their work, and i feel ashame not understanding all their explanations
I tried multi softwareserial solution from aleph0 (ESPEasy-2.0.0-dev12_test_4096.bin.zip), with two modules: the system polls (i see the same led on PZEM flashing 12 times on each PZEM one after the other ( i suppose it is espeasy request to the PZEM) without any reponse.
The same happens when swapping RX and TX, just the led flashing is different.
By the way, i can't be sure which is the right Rx/Tx wiring as i don't understand the comment under Software serial gpios field.
I didn't made any 5v to 3.3V conversion, but i have an ESP32 is working like that with HW serial, but could it be a direction ?
Does the pins in Espeasy hardware has to be set (input or output)?
I loaded "firmware_PZEM004T multiple.bin" wich looks like a sequential polling of the PZEM 5V, but hardly imagine the wiring
So if someone could kindly link or post a working solution (software and wiring) ?
Posted: Monday 27 January 2020 18:26
by aleph0
Did you put 220v on the pzem while trying ? Mine does not respond without 220v
Edit : I just read again the thread on let's control it and they say the protocol have changed for pzem v3 ; my precompiled firmware won't work with those ones, sorry
Posted: Tuesday 28 January 2020 8:45
by Sherco49
OK,thanks for your answer
Yes i tried it with 220v, but if the protocol has changed, i can understand the lack of answers ( library pzemt30v30 ?).
just have to find a 3.0 solution
Posted: Tuesday 28 January 2020 16:17
by Sherco49
So i solved my problem abandoning Espeasy and using multi instances of Software serial, it works even if it not the most elegant way
Posted: Tuesday 28 January 2020 20:07
by salvacalatayud
Sherco49 wrote:So i solved my problem abandoning Espeasy and using multi instances of Software serial, it works even if it not the most elegant way
Tasmota is suposed to work, i'll test in a few days
Enviado desde mi Mi A2 mediante Tapatalk
Posted: Monday 10 February 2020 15:34
by ABCArt
Hi, pzem users!
Is there any way to calclate day/night power consumption with esp and pzem004 connected to it?
I have already four virtual counters in my Domoticz system for: Voltage, Current, Energy and Power (delivered by espeasy rules from WeMos D1 mini).
The problem is in that Power is counted continiously as increasing value, and i need to divide it into two dummy counters: increasing day power consumtion (kWh) and the samre thing for the night time (kWh). Is it possible to do using some variables/scripts?
And for pzem-004 we have another problem - it drops power usage counter when it reaches 9999 value.
Posted: Monday 10 February 2020 16:32
by aleph0
Hi !
This is the function I use for this usage
function pzem_read(pzem,HC,dev_V,dev_A,dev_W,dev_CP)
--[[Read measures from a pzem in a 3Amps device
and dispatch measures for voltage, current and power in corresponding devices
Input :
pzem : type 3phase current
HC : switch "On"=night time
Output :
dev_V : type voltage
dev_A : type current
dev_W : type P1 smart counter
dev_CP : type custom, for cos phi
Variable : you need to create a variable with the same name as the pzem device followed by _idx to store the index
local u1, u2, p1, p2
local val_V,val_A,val_W,val_Wh
local local_dbg=0
old_Wh=uservariables[pzem.."_idx"]
u1, u2, p1, p2 = string.match(otherdevices_svalues[dev_W],"(.-);(.-);(.-);(.-);.*")
-- Usefull for newly created counters
u1=u1 or 0
u2=u2 or 0
p1=p1 or 0
p2=p2 or 0
val_V,val_A,val_W,val_Wh=string.match(otherdevices_svalues[pzem],"(.-);(.-);(%d*);(%d*)")
if local_dbg==1 then
print(otherdevices_svalues[pzem])
print("V "..val_V)
print("A "..val_A)
print("W "..val_W)
print("Wh "..val_Wh)
print("Old Wh "..old_Wh)
print("------")
if tonumber(val_V)>1 then UpdateDev(dev_V,0,val_V) end
UpdateDev(dev_A,0,val_A)
if tonumber(val_A)>0 and tonumber(val_W)>0 then
-- If we don't have a measurement for voltage, we take previous one
if tonumber(val_V)==0 then val_V=otherdevices[dev_V] end
val_CP=val_W/val_V/val_A
print("V "..val_V)
print("A "..val_A)
print("W "..val_W)
print("CP "..val_CP)
if val_CP>=0 and val_CP<=1 then UpdateDev(dev_CP,0,round(val_CP,2)) end
if tonumber(val_Wh)>=tonumber(old_Wh) then
if otherdevices[HC] == 'Off' then
-- svalue=USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
UpdateDev(dev_W,0,tostring(u1+val_Wh-old_Wh)..';'..tostring(u2)..';0;0;'..tostring(val_W)..';0')
UpdateDev(dev_W,0,tostring(u1)..';'..tostring(u2+val_Wh-old_Wh)..';0;0;'..tostring(val_W)..';0')
if val_Wh>0 then UpdateVar(pzem.."_idx",val_Wh) end
Posted: Wednesday 19 February 2020 13:32
by djelau
the solution to work with Espeasy on WEMOS and PZEM-004tv30 (modbus) can be found
here
Posted: Tuesday 03 March 2020 12:03
by yo3hjv
NiCOOLaS wrote: Thursday 23 January 2020 14:08
yo3hjv wrote: Thursday 25 April 2019 4:22
Hello and thank you for the nice "How to".
I did it and it is working.
Seems to work properly, I also included the ">0" mod.
I have only one observation: the "Current" value is showing the last maximum current.
I wonder if someone can help me with LUA script to make the "Current" show the "now" value of the current.
Thank you and please forgive my stupidity.
LE. I think I got it like this:
UpdateDev(dev_A,0,val_A) end
-- if tonumber(val_A)>0 then UpdateDev(dev_A,0,val_A) end--
Can you please show full script and how it's run
Sorry for late answer!
Here is the code:
--[[Script to read infos from espeasy/pzem-004t and disptach it in correct devices
-- Edit the dummies name below to match yours
local dev_HC ="Elec happy hours"
local dev_pzem1 ="pzem1"
local dev_V1 ="Retea"
local dev_A1 ="Curent_Instant"
local dev_W1 ="Consum"
-- End of user-edit part
function UpdateVar(variable,valeur)
--Update une variable Domoticz
commandArray[#commandArray+1] = {['Variable:'..variable] = tostring(valeur)}
function UpdateDev(device,nvalue,svalues)
--Met à jour un device numérique Domoticz
commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
function pzem_read(pzem,HC,dev_V,dev_A,dev_W)
--[[Read values from a 3ph-amp dummies and dispatch them in sensor for voltage, current, and power
Input :
pzem : type 3ph amp, updated by espeasy
HC : switch "On"=happy hours for electricity
Output :
dev_W : P1 smart counter
local local_dbg=0
u1=u1 or 0
u2=u2 or 0
p1=p1 or 0
p2=p2 or 0
print(val_V)
print(val_A)
print(val_W)
print(val_Wh)
if devicechanged[dev_pzem1] then pzem_read(dev_pzem1,dev_HC,dev_V1,dev_A1,dev_W1) end
I monitor the instant current even when there is no consumption. I like to see when it's starting and when it's stopping.
Best regards, Adrian
Posted: Saturday 30 May 2020 8:59
by Dane01000
Bonjour, je suis ce fil depuis quelques jours et n'arrive pas à m'en sortir seul.
J'ai un seul PZEM-004T V30 sur WEMOS D1 Mini et tourne sur un firmware perso ESPEASY.
J'ai bien mes valeurs dans ESPEASY, je n'arrive à envoyer que Voltage dans Domoticz.
J'ai essayé avec Rules par plusieurs moyens dans Domoticz (capteurs virtuels....) mais je ne reçoit rien
Rules Espeasy
on PZEM#Current do
SendToHTTP 192.168.1.151,8080,/json.htm?type=command¶m=udevice&idx=1402&nvalue=0&svalue=[PZEM#Voltage]
SendToHTTP 192.168.1.151,8080,/json.htm?type=command¶m=udevice&idx=1403&nvalue=0&svalue=[PZEM#Current]
SendToHTTP 192.168.1.151,8080,/json.htm?type=command¶m=udevice&idx=1404&nvalue=0&svalue=[PZEM#Power]
SendToHTTP 192.168.1.151,8080,/json.htm?type=command¶m=udevice&idx=1405&nvalue=0&svalue=[PZEM#Energy]
endon
- Capture1.JPG (82.03 KiB) Viewed 13827 times
- Capture2.JPG (121.23 KiB) Viewed 13827 times
- Capture3.JPG (222.72 KiB) Viewed 13827 times
Posted: Saturday 30 May 2020 9:02
by Dane01000
- Capture4.JPG (115.19 KiB) Viewed 13826 times
- Capture5.JPG (110.05 KiB) Viewed 13826 times
Pouvez-vous m'aider je ne suis que débutant en script,
Je ne sais pas ce que j'ai oublié dans Domoticz ou ESPEASY.
Merci de m'aider
Posted: Tuesday 23 June 2020 14:25
by Vladio
hi
Posted: Sunday 14 February 2021 14:14
by spike318
can some please help me with this subject or renew it i can't see the pictures,
Posted: Saturday 20 February 2021 9:45
by tontze
spike318 wrote: Sunday 14 February 2021 14:14
All pictures are there
Posted: Saturday 12 February 2022 19:36
by eremuson
Are you able to share the original pictures of the beginning of this tread ?
I can not see its...
Sorry
Eric
Posted: Saturday 12 February 2022 20:38
eremuson wrote: Saturday 12 February 2022 19:36
Sorry
Eric
Please reload the page. Something's the webserver acts strange.I can see all the images.
Posted: Saturday 12 February 2022 20:51
by jvdz
waltervl wrote: Saturday 12 February 2022 20:38
Sorry
Eric
That means you allow to show external links that have an invalid certificate!
SO... those images are stored on server with a different domainname than the link contains ...hence the CERT error and them not being displayed.
Posted: Tuesday 15 March 2022 13:07
by mojso
Thanks, it works great for now. only kWh need to be converted to Wh P1 meter ( Domoticz)
Posted: Thursday 21 December 2023 11:48
by psubiaco
Maybe you can
try the new PZEM plugin that permits to connect up to 51 PZEM meters to the same bus, using a cheap RS485/USB adapter or RS485/net/wifi module:
https://github.com/CreasolTech/domoticz-pzem-016
Actually it was tested with PZEM-004T, PZEM-014 and PZEM-016.
Device names can be translated in your preferred language: if you write here the translated device names and language code, I can add that language in the plugin.
Many thanks for any feedback / suggestion / translation !
- domoticz-pzem-016-screenshot.jpg (85.45 KiB) Viewed 10259 times
- domoticz-pzem-016-hardware.png (71.65 KiB) Viewed 10259 times
Posted: Saturday 06 January 2024 3:32
by mrfunk
psubiaco wrote: Thursday 21 December 2023 11:48
Maybe you can
Thanks for making this!!!!
Unfortunately I just can't read data
my PZEM-004T has both tx,/Rx LEDs flashing, and if I flip the polarity of the rs 485 they stop. I'm using a pi with a usb 2wire 485:adapter as shown on the GitHub tutorial. I installed plugin via the plugin manager. I'm not sure if this is an issue with pyserial or the other module? I've tried installing pyserial bit get thrown an error.. is this installed as part of the plugin? Same with the other file.
I'm selecting USB0 from the drop-down
Any help obviously appreciated.
