Page 3 of 3
Re: Persistent data as a variable
Posted: Thursday 13 December 2018 23:32
by waaren
pvklink wrote: Thursday 13 December 2018 10:14 I get errors with the second script with a nil value. No variable is mentioned in the logging and there was a line mentioned but my script does not have so much lines.
local huidwaarde = dz.utils.round(device.usage,1)
and the device with my father in law says Usage electric so i think thats:
local huidwaarde = dz.utils.round(device.WhActual,1)
Does it makes any different qua functionality ?
Probably not but to be sure it would help to see the actual error in the log. Can you share the relevant loglines ?
Posted: Friday 14 December 2018 17:48
by pvklink
something about x has a nill value on a non existing line...
problem is gone by using whactual..
Posted: Monday 17 December 2018 12:32
by pvklink
My Switch went to often on and off because of a outside temperature that is flipping. Risc is that the heating device connected to it, runs defect.
So i use variable DurTImer. When the switch is On because off the temperatureaverage is above the norm, i wait For DurTimer minutes before switching the switch back to off.
But i got a error on my if then else statement...
:20.527 Status: dzVents: Info: Temperatuur trend: --------------------------------------------
2018-12-17 12:14:20.527 Status: dzVents: Info: Temperatuur trend: 03 Sensor info = Huidig gemiddelde temperatuur (8.4) is boven de norm(4), device: Zuiderparklaan-Diversen
2018-12-17 12:14:20.527 Status: dzVents: Error (2.4.9): Temperatuur trend: An error occured when calling event handler DZ_temperatuur
2018-12-17 12:14:20.527 Status: dzVents: Error (2.4.9): Temperatuur trend: ...icz/scripts/dzVents/generated_scripts/DZ_temperatuur.lua:131: attempt to index field 'lastupdate' (a nil value)
2018-12-17 12:14:20.527 Status: dzVents: Info: Temperatuur trend: ------ Finished DZ_temperatuur
if switch.state == 'On' and onoff == 'Yes' then
if tonumber(switch.lastupdate.minutesAgo) > tonumber(DurTimer) then
switch.switchOff().checkFirst().silent()
dz.log("04 Sensor info = device: " .. name .. " Niet uitgezet omdat timer nog niet is verlopen: " .. DurTimer )
Logging: strange that there a two historic records with a value and Verbruik.gemiddeld = 0 ????
14:04:24.255 (weather underground rijswijk) General/Solar Radiation (Zuiderparklaan6)
2018-12-17 14:04:24.680 (dummydevices) Light/Switch (Sonoff1)
2018-12-17 14:04:24.554 Status: dzVents: Info: Temperatuur trend: ------ Start internal script: DZ_temperatuur: Device: "Zuiderparklaan-Diversen (weather underground rijswijk)", Index: 681
2018-12-17 14:04:24.556 Status: dzVents: Debug: Temperatuur trend: Processing device-adapter for Sonoff1: Switch device adapter
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 History data van 2018-12-17 13:04:22 = 8.5 graden
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 History data van 2018-12-17 13:34:23 = 8.5 graden
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: Deviceinfo----------------------------------
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 Kwh-device................= Zuiderparklaan-Diversen
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 Switch-device.............= Sonoff1
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 Switch.onoff..............= Yes
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: Verbruikinfo--------------------------------
2018-12-17 14:04:24.556 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.norm.............= 4
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.gemiddeld........= 0
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.huidige waarde...= 9.8
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.vorige waarde....= 8.5
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.gemid. hist......= 8.5
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.minimumwaarde....= 8.5
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Verbruik.maximumwaarde....= 8.5
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: Notificatie---------------------------------
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.norm(in.min)..= 30
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.verzonden.....= false
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.aan...........= Yes
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.receivers.....= pvkmobiel
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.prio..........= PRIORITY_NORMAL
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 00 Notificatie.sound.........= siren
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: --------------------------------------------
2018-12-17 14:04:24.557 Status: dzVents: Debug: Temperatuur trend: Constructed timed-command: On
2018-12-17 14:04:24.557 Status: dzVents: Debug: Temperatuur trend: Constructed timed-command: On NOTRIGGER
2018-12-17 14:04:24.557 Status: dzVents: Info: Temperatuur trend: 05 Sensor info = Huidig gemiddelde temperatuur (0) is onder of gelijk aan de norm(4), device: Zuiderparklaan-Diversen
2018-12-17 14:04:24.559 Status: dzVents: Info: Temperatuur trend: ------ Finished DZ_temperatuur
2018-12-17 14:04:24.645 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-12-17 14:04:24.681 Status: Notification: Domoticz device:Sonoff1
--[[ wordt de vervanger van dz_buitentemperatuur aanzetten van lint en een timer om aan uit te voorkomen..
      https://github.com/dannybloe/dzVents#historical-variables-api <<<<< This is quite old ; better use
      https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#Accessing_values_in_historical_variables
      script uses a temp sensor Zuiderparklaan which uses Weather Underground with pws:ITHEHAGU40
local USAGE_SENSORS =     {
    ['Zuiderparklaan-Diversen'] = 'Zuiderparklaan-Diversen',  -- Adjust to your needs. Between every line you need to add a ",".
    --['Zuiderparklaan'] = 'Zuiderparklaan',  -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_SWITCHES = {
    ['Zuiderparklaan-Diversen'] = 'Sonoff1',                     -- Name of device that switch kw_1 On/ Off
    --['Zuiderparklaan'] = 'stroomlint',                     -- Name of device that switch kw_1 On/ Off
local USAGE_Norm = {
    ['Zuiderparklaan-Diversen'] = 4,                   -- is de norm, onder deze waarde gaat het device aan als onoff aanstaat
    --['Zuiderparklaan'] = 4,                   -- is de norm, onder deze waarde gaat het device aan als onoff aanstaat
local USAGE_DurTimer = {
    ['Zuiderparklaan-Diversen'] = 30,                   -- is de periode waarover gemiddelde wordt berekend om pieken te voorkomen, zie gemwaarden (deze kun je niet parametriseren)
    --['Zuiderparklaan'] = 30,                   -- is de periode waarover gemiddelde wordt berekend om pieken te voorkomen, deze wordt niet gebruikt, zie gemwaarden (deze kun je niet parametriseren)
local USAGE_SwitchOnOff = {
    ['Zuiderparklaan-Diversen'] = 'Yes',                -- Adjust to your needs. Between every line you need to add a ",".
    --['Zuiderparklaan'] = 'Yes',                -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_Notify = {
   -- ['Zuiderparklaan'] = 'Yes',
local USAGE_Pushoverreceivers = {
    ['Zuiderparklaan-Diversen'] = 'pvkmobiel',
    --['Zuiderparklaan'] = 'pvkmobiel',
local USAGE_Pushoverprio = {
    ['Zuiderparklaan-Diversen'] = 'PRIORITY_NORMAL',           --domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY
   --['Zuiderparklaan'] = 'PRIORITY_NORMAL',           --domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY
local USAGE_Pushoversound = {
    ['Zuiderparklaan-Diversen'] = 'siren',
    --['Zuiderparklaan'] = 'siren',
    on      =   {   devices = USAGE_SENSORS },
    logging =   {
                    level   = domoticz.LOG_DEBUG ,                  -- Uncomment to override the dzVents global logging setting
                    marker  = "Temperatuur trend"
    data    =   {
                    prevhistwaarde = { history = true,  maxHours = 1 },
                    sendnotification = {initial = {}},
    execute = function(dz, device)
        if dz.data.prevhistwaarde.getOldest() == nil then  -- Check if history is already filled (initial does not work with history persistent data
          dz.data.prevhistwaarde.add(4)                    -- ook deze kun je niet parametriseren
        local name          = device.name
        local name2         = USAGE_SWITCHES[name]
        local switch        = dz.devices(USAGE_SWITCHES[name])
        local onoff         = USAGE_SwitchOnOff[USAGE_SENSORS[name]]
        local norm          = USAGE_Norm[USAGE_SENSORS[name]]
        local notify        = USAGE_Notify[USAGE_SENSORS[name]]
        local receivers     = USAGE_Pushoverreceivers[USAGE_SENSORS[name]]
        local prio          = USAGE_Pushoverprio[USAGE_SENSORS[name]]
        local sound         = USAGE_Pushoversound[USAGE_SENSORS[name]]
        local DurTimer      = USAGE_DurTimer[USAGE_SENSORS[name]]
        local huidwaarde    = dz.utils.round(device.temperature,1)
        local prevwaarde    = dz.utils.round(dz.data.prevhistwaarde.getLatest().data,1)
        local gemwaarden    = dz.utils.round(dz.data.prevhistwaarde.avgSince('00:30:00'),1)                 --check als deze geen waarde heeft, dan prevwaarde! neem niet een te klein bereik
        local avgwaarde     = dz.utils.round(dz.data.prevhistwaarde.avg(),1)
        local minwaarde     = dz.utils.round(dz.data.prevhistwaarde.min(),1)
        local maxwaarde     = dz.utils.round(dz.data.prevhistwaarde.max(),1)
        local now           = os.time(os.date('*t'))
        if huidwaarde == nil then               -- onderstaande checks moeten na de locals omdat ze deze ook gebruiken!
            dz.log("01 Sensor info         = Geen waarde opgehaald")
       if gemwaarde == 0 then
            dz.log("02 Sensor info         = Geen gemiddelde waarde opgehaald, nu vorige waarde gebruikt")
        if dz.data.sendnotification[name] == nil then
            dz.data.sendnotification[name] = false -- eerste waarde teller op false gezet  -- geen notify gedaan
        for i = dz.data.prevhistwaarde.size,1,-1 do
            item = dz.data.prevhistwaarde.get(i)
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime ..
                                    " = " .. item.data .. " graden")
        dz.log("Deviceinfo----------------------------------")
        dz.log("00 Kwh-device................= " .. name)
        dz.log("00 Switch-device.............= " .. name2)
        dz.log("00 Switch.onoff..............= " .. onoff)
        dz.log("Verbruikinfo--------------------------------")
        dz.log("00 Verbruik.norm.............= " .. norm)
        dz.log("00 Verbruik.gemiddeld........= " .. gemwaarden)
        dz.log("00 Verbruik.huidige waarde...= " .. huidwaarde)
        dz.log("00 Verbruik.vorige waarde....= " .. prevwaarde)
        dz.log("00 Verbruik.gemid. hist......= " .. avgwaarde)
        dz.log("00 Verbruik.minimumwaarde....= " .. minwaarde)
        dz.log("00 Verbruik.maximumwaarde....= " .. maxwaarde)
        dz.log("Notificatie---------------------------------")
        dz.log("00 Notificatie.norm(in.min)..= " .. DurTimer)
        dz.log("00 Notificatie.verzonden.....= " .. tostring(dz.data.sendnotification[name]))
        dz.log("00 Notificatie.aan...........= " .. notify)
        dz.log("00 Notificatie.receivers.....= " .. receivers)
        dz.log("00 Notificatie.prio..........= " .. prio)
        dz.log("00 Notificatie.sound.........= " .. sound)
        dz.log("--------------------------------------------")
    if  gemwaarden > norm then
        dz.log("03 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarden ..") is boven de norm(".. norm .. "), device: " .. name ..  "")
        if switch.state == 'Off' and onoff == 'Yes' then
            switch.switchOn().checkFirst().silent()
            msg3=' Switch: ' .. name2 .. ' is aangezet'
            msg3=' '
        if (dz.data.sendnotification[name] == false) then
            if (notify == 'Yes') then
                msg1 = 'Domoticz device:' .. name2
                msg2 = 'Gemiddelde temperatuur (' .. gemwaarden .. ') <= (' .. norm .. '),  voor een periode van (' .. tostring(DurTimer) .. ' min)' .. msg3
                dz.notify(msg1,msg2,prio,sound,receivers,dz.NSS_PUSHOVER)
                dz.data.sendnotification[name] = true
        dz.log("05 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarden ..") is onder of gelijk aan de norm(".. norm .. "), device: " .. name ..  "")
        dz.data.prevhistwaarde.add(huidwaarde)
Posted: Monday 17 December 2018 15:10
by waaren
pvklink wrote: Monday 17 December 2018 12:32 But i got a error on my if then else statement...
Almost everything in dzVents is case sensitive. Try lastUpdate
Posted: Monday 17 December 2018 18:01
by pvklink
sh..... Everything works again :lol:
I solved the problem with flipping on/off by using .lastupdate icm DurTimer
I want to display the time of switch.LatsUpdate en calculate the estimated time
dz.log("00 Notificatie.switch.laatste update= " .. tostring(switch.lastUpdate.rawTime)) -- deze is goed
dz.log("00 Notificatie.switch.eind tijd.....= " .. tostring(now - tonumber(switch.lastUpdate.rawTime))) -- arithmetic on a nil value
ABOVE SECOND RULE DOES NOT SEEMS TO WORK
    ['Zuiderparklaan'] = 200,                   -- is de periode die verstreken moet zijn na de laatte update van de switch in minuten om uitgezet te worden
    logging =   {
    data    =   {
                    prevhistwaarde = { history = true,  maxHours = 2 },
        local function secondsToClock(sec)
          local seconds = tonumber(sec)
          if seconds <= 0 then
            return "00:00:00"
            hours = string.format("%02.f", math.floor(seconds/3600))
            mins = string.format("%02.f", math.floor(seconds/60 - (hours*60)))
            secs = string.format("%02.f", math.floor(seconds - hours*3600 - mins *60))
            return hours..":"..mins..":"..secs
        local gemwaarde     = dz.utils.round(dz.data.prevhistwaarde.avgSince('00:60:00'),1)                 --check als deze geen waarde heeft, dan prevwaarde! neem niet een te klein bereik
        --  soms is gemwaarde 0 terwijl er twee records zijn met waarde! probeer het eerst op te lossen met doorlooptijden gemwaarde en histwaarde WAT NU ALS gemmiddelde echt 0 is ?
        if tonumber(gemwaarde) == 0 or gemwaarde == nil then
            gemwaarde = avgwaarde
            dz.log("02b Sensor info         = Gemwaarde was 0, daarom op avgwaarde gezet, gemwaarde:" .. tostring(gemwaarde) .. "")
            dz.log("02c Sensor info         = Gemwaarde was <> 0, , gemwaarde:" .. tostring(gemwaarde) .. "")
        dz.log("Deviceinfo---------------------------------------")
        dz.log("00 Kwh-device.......................= " .. name)
        dz.log("00 Switch-device....................= " .. name2)
        dz.log("00 Switch.onoff.....................= " .. onoff)
        dz.log("Verbruikinfo-------------------------------------")
        dz.log("00 Verbruik.norm....................= " .. norm)
        dz.log("00 Verbruik.gemiddeld...............= " .. gemwaarde)
        dz.log("00 Verbruik.huidige waarde..........= " .. huidwaarde)
        dz.log("00 Verbruik.vorige waarde...........= " .. prevwaarde)
        dz.log("00 Verbruik.gemid. hist.............= " .. avgwaarde)
        dz.log("00 Verbruik.minimumwaarde...........= " .. minwaarde)
        dz.log("00 Verbruik.maximumwaarde...........= " .. maxwaarde)
        dz.log("Notificatie--------------------------------------")
        dz.log("00 Notificatie.norm(in.min).........= " .. DurTimer)
        -- deze kunnen weg als t niet lukt zie ook internet rawTime is een eigenschap
        --dz.log("00 Notificatie.switch.eind tijd.....= " .. tostring(now - tonumber(switch.lastUpdate.rawTime))) -- deze geeft een fout aritmic on a nul value
        dz.log("00 Notificatie.verzonden............= " .. tostring(dz.data.sendnotification[name]))
        dz.log("00 Notificatie.aan..................= " .. notify)
        dz.log("00 Notificatie.receivers............= " .. receivers)
        dz.log("00 Notificatie.prio.................= " .. prio)
        dz.log("00 Notificatie.sound................= " .. sound)
        dz.log("-------------------------------------------------")
    if  gemwaarde > norm then
        dz.log("03 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarde ..") is boven de norm(".. norm .. "), device: " .. name ..  "")
            if tonumber(switch.lastUpdate.minutesAgo) > tonumber(DurTimer) then
            msg3=' '
                msg2 = 'Gemiddelde temperatuur (' .. gemwaarde .. ') <= (' .. norm .. '),' .. msg3
        dz.log("05 Sensor info         = Huidig gemiddelde temperatuur (".. gemwaarde ..") is onder of gelijk aan de norm(".. norm .. "), device: " .. name ..  "")
/code]
