experience with the OTGW from NODO-shop?
For OpenTherm-gateway related questions in Domoticz
Hobbybob
Re: experience with the OTGW from NODO-shop?
Post by Hobbybob »
skippy711 wrote: Thursday 05 July 2018 22:08 Hi
I installed this in March (when it was cold) and it I experienced frequent dropouts. I suspected it had to do with overheating. My (crude) solution: an old fashioned timer in the wall socket which turns off the OTGW every 4 hours for 15 minutes. This solved the problem, although the you will see error messages in the log...
Skippy
Although my problem does only exist when the OTGW has been running for some time (which would indicate a heating-problem I thought), I do find it strange that OTMonitor can read it perfectly, while Domoticz cannot read or control it at all after about one hour or so...
Too bad, I was really looking forward to being able to control the thermostat with Domoticz, but it looks like it is not going to work.
skippy711
Domoticz version: 2025.2
Post by skippy711 »
My (not so elegant) solution works. I can control the thermostat. I did so in April, just make sure you increase the setpoint 1 whole degree or more, won't accept 0,5 degree.
Skippy
Hobbybob
Post by Hobbybob »
Yes, I also noticed about the half degree setpoint-change when I turned it on the first time. That is fine by me however, I don't mind that.
But I don't think turning it off every hour for 15 minutes (because after an hour it wil not work anymore, after half an hour it already starts to malfunction on and off) does not make for a useful OTGW, because that would mean that it be off or malfunctioning for about 50% of the time.
skippy711
Post by skippy711 »
I checked again the exact interval I set in the timer: I started with every 2 hours, then stretched to 3 hours and now it's 4. Originally I planned to go to 5 or 6 hours, but forgot. I do agree it's far from ideal, but for me it works.
Ron
Domoticz version: 2.2284
Post by Ron »
Yesterday i modified the OTGW and casing.
First i soldered a heatsink directly on the L7805 voltage regulator, as this is the component which get way to hot.
Secondly i drilled som extra holes directly above the mounted heatsink, next to the already drilled holes i made.
At third i dropped the power supply voltage from 24V DC to 19V DC.
As discribed on the PCB the input should be between 19 and 24V but this voltage goes directly to the L7805 regulator.
The output of the L7805 is 5V DC, thus the energy dissipation of the regulator should be approx. (24V-5V) * A.
When dropping the input voltage to 19V the energy dissipation should be (19V-5V) * A
V = Voltage
A = Amperage
So in this case the regulator has to dissipate less energy, and with the extra heatsink it should work a lot better.
20180708_131237 [1024x768].jpg (198.37 KiB) Viewed 12024 times
20180708_131301 [1024x768].jpg (165.29 KiB) Viewed 12024 times
20180708_131312 [1024x768].jpg (180.72 KiB) Viewed 12024 times
Ron
Post by Ron »
20180708_131320 [1024x768].jpg (180.79 KiB) Viewed 12023 times
20180708_130914 [1024x768].jpg (181.04 KiB) Viewed 12023 times
Ron
Post by Ron »
The gateway is more stable now with the new changes.
Just looked at the Nodo shop and it is clearly to see that the voltage regulator has been changed now to a step down converter.
My conclusions were right, otherwise they didn't have to change this.
Than i did some more research, and found this:
https://www.domoticaforum.eu/viewtopic. ... d985ca45a7
Some problem, same conclusion...
Without wifi add on the voltage regulator should work fine, but with wifi add there is more power dissipation on the voltage regulator.
The only way to improve this is to drop down the voltage and apply some kind of heatsink like i did.
(other solution, buy the new version of this kit)
The new version:
matthew73210
Post by matthew73210 »
Hey all,
I happen to have the infamous OTGW from NODO-shop, all works well, otmonitor etc..
I can send commands via the hardware tab; CS=x works fine and the boiler starts up. Ps=1 updates most of the values.
The problem is with the control setpoint device in the temp tab, if I edit that value it does not get reflected back to the OTGW.
Nor does the CS command get updated to the control setpoint device.
Any ideas?
Here's a log :
2018-08-28 19:55:21.689 (Boiler) Temp (Control Setpoint)
2018-08-28 19:55:21.692 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:55:21.693 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:55:21.694 (Boiler) Temp (Room Temperature)
2018-08-28 19:55:21.695 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:55:21.696 (Boiler) Temp (DHW Temperature)
2018-08-28 19:55:21.697 (Boiler) Temp (Outside Temperature)
2018-08-28 19:55:21.698 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:55:21.699 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:55:21.700 (Boiler) Thermostat (Max_CH Water Setpoint)
2018-08-28 19:55:51.702 (Boiler) Temp (Control Setpoint)
2018-08-28 19:55:51.704 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:55:51.704 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:55:51.705 (Boiler) Temp (Room Temperature)
2018-08-28 19:55:51.706 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:55:51.706 (Boiler) Temp (DHW Temperature)
2018-08-28 19:55:51.706 (Boiler) Temp (Outside Temperature)
2018-08-28 19:55:51.707 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:55:51.708 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:55:51.709 (Boiler) Thermostat (Max_CH Water Setpoint)
2018-08-28 19:56:21.716 (Boiler) Temp (Control Setpoint)
2018-08-28 19:56:21.718 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:56:21.719 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:56:21.719 (Boiler) Temp (Room Temperature)
2018-08-28 19:56:21.720 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:56:21.720 (Boiler) Temp (DHW Temperature)
2018-08-28 19:56:21.720 (Boiler) Temp (Outside Temperature)
2018-08-28 19:56:21.721 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:56:21.721 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:56:21.722 (Boiler) Thermostat (Max_CH Water Setpoint)
2018-08-28 19:57:21.738 (Boiler) Temp (Control Setpoint)
2018-08-28 19:57:21.739 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:57:21.740 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:57:21.740 (Boiler) Temp (Room Temperature)
2018-08-28 19:57:21.741 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:57:21.741 (Boiler) Temp (DHW Temperature)
2018-08-28 19:57:21.742 (Boiler) Temp (Outside Temperature)
2018-08-28 19:57:21.743 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:57:21.743 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:57:21.744 (Boiler) Thermostat (Max_CH Water Setpoint)
2018-08-28 19:57:51.751 (Boiler) Temp (Control Setpoint)
2018-08-28 19:57:51.752 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:57:51.754 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:57:51.754 (Boiler) Temp (Room Temperature)
2018-08-28 19:57:51.756 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:57:51.757 (Boiler) Temp (DHW Temperature)
2018-08-28 19:57:51.757 (Boiler) Temp (Outside Temperature)
2018-08-28 19:57:51.759 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:57:51.759 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:57:51.760 (Boiler) Thermostat (Max_CH Water Setpoint)
2018-08-28 19:58:05.466 Status: User: matt73210 initiated a manual command: CS=15
2018-08-28 19:58:05.755 Status: OTGW: CS: 15.00
2018-08-28 19:58:20.888 Status: User: matt73210 initiated a manual command: PS=1
2018-08-28 19:58:50.145 Status: EventSystem: reset all device statuses...
2018-08-28 19:58:51.772 (Boiler) Temp (Control Setpoint)
2018-08-28 19:58:51.773 (Boiler) Thermostat (Room Setpoint)
2018-08-28 19:58:51.775 (Boiler) General/Percentage (Relative modulation level)
2018-08-28 19:58:51.775 (Boiler) Temp (Room Temperature)
2018-08-28 19:58:51.776 (Boiler) Temp (Boiler Water Temperature)
2018-08-28 19:58:51.776 (Boiler) Temp (DHW Temperature)
2018-08-28 19:58:51.776 (Boiler) Temp (Outside Temperature)
2018-08-28 19:58:51.777 (Boiler) Temp (Return Water Temperature)
2018-08-28 19:58:51.777 (Boiler) Thermostat (DHW Setpoint)
2018-08-28 19:58:51.778 (Boiler) Thermostat (Max_CH Water Setpoint)
As you can see it sends the command and the controller replies, and PS=1 does its magic. Although i'd rather use the PS=0 and decode the data as it comes in.
Any ideas ?
Matthew
Ron
Post by Ron »
I returned the OTGW to the Nodo shop and they replaced the voltage regulator.
Now i have the new version, and i expect it will work as it should.
As we just bought a new (beatiful old) house, i cannot test the gateway while the Nefit Excellent heating has no OT connection.
When i have time enough i will install a converter for that, and hopefully it wil work again.
matthew73210
Hey,
That is good news, silly of them to use a linear voltage regulator. When I got my one it already came with the buck converter. Although if I was them I would have gone with a forward converter as it's more efficient.
May I ask, where is this newly old house?
Do you think I should move my "help request" to a new sub? As it is only partly linked to the nodo_otgw!
Cheers,
Matthew
Ron
Post by Ron »
Our new house is in the northern region of Den Bosch, Bokhoven.
Domotibart
Domoticz version: V3.8153
Post by Domotibart »
matthew73210 wrote: Tuesday 28 August 2018 20:01 Hey all,
Any ideas?
Here's a log :
Any ideas ?
Matthew
Hi Matthew,
You can try using the firmware i made for the esp8266. It does not use the PS=1 setting. The ESP is scanning the output from the gateway and only send the data to domoticz if the value has changed. In my case this method is much more stable. I had a lot of problems with the "standard" getaway solution in domoticz. Another advantage is that you can use domoticz and the OT monitor at the same time.
greetz
Bart
Synology DS214play - esp8266 Opentherm Gateway - esp8266 somfyremote - esp8266 poolcontrol - esp8266 energyreader - zwave - Philips hue
quazar
Post by quazar »
My OTGW works great in combination with a ThermoSmart thermostat. However, in the log I do get a error 02 message every few minutes. I do have a NodeMcu installed and connected a 12v power supply.
This error 02 should indicate that the communication with my Calenta ACE heater is not exactly 1.25v....
However, as the voltage regulator is not perfect, this error may be due to a measurement error instead of an actual issue (OTGW works perfectly fine for more than a month). With other OTGW versions that need a 5.0v power supply, you can get errors when the voltage provided is not exactly 5.00v....
Iḿ not sure if I can ignore this error, or whether Iḿ slowly frying my heater :?
/edit: 19v adapter does not solve the issue. Hope to receive a 24v adapter soon.
Jack007
Domoticz version: 2023.2
Post by Jack007 »
Merry Christmas,
I'm using the OTGW (via nodeMCU) from Nodo-shop successfully in a stand-alone mode for some time now. The OTmonitor runs on a RPi 3,
On the same Rpi Domoticz (4.10717) runs. As I have some time now i wanted to add the OTGW to Domoticz.
I've added the hardware (opentherm gateway with LAN interface) to Domoticz on ip=192.168.1.12 and port 6638. These settings are displayed in ESP Easy under Devices-serial server.
Now the following entries appear in the Domoticz log every 30 sec.:
2019-12-27 18:58:52.387 Status: OTGW: connected to: 192.168.1.12:6638
2019-12-27 18:58:52.532 Status: OTGW: BC0770000
2019-12-27 18:58:52.541 Status: OTGW: AF0050000
2019-12-27 18:58:52.554 Status: OTGW: Connection reset!
The second and third row are not always shown.
No new devices are shown in Domoticz.
What am I doing wrong here?
