Refused to execute script from 'http://192.168.0.11:8080/json.htm?username=&password=&type=command¶m=getuservariable&idx=1&jsoncallback=jQuery22406583362093528788_1521322394438&_=1521322394439' because its MIME type ('application/json') is not executable, and strict MIME type checking is enabled.[/quote]
Googled to find an answer, but didn't come to much more info
Having a strange problem with the moon pictures since today.
Dashticz gives a broken image
I checked the user variable in Domoticz and the image with MoonPicture was indeed a non exiting number.
I changed the image line to the right one and the moon picture was back in Dashticz.
After a WU update the pucture was broken again. Changing WU site did not help.
When looking to the script, you can guess that it supposed to use only half of moon pictures (0->50 then 50->0).
You are right but that was not the problem. The first 9 pictures in the moon folder are 01, 02, 03 etc. Donoticz started using 1, 2, etc. The 0 fell off and i wunder why.
I solved it by changing the image names of the first 9 moon pictures. Now wait and see what happens when he starts using 10, 11...
And the problems are changing...
I now get errors in the log about the script
It loads a moon picture but its the wrong one. Moon percentage is ok (85%) but the picture does not match this.
It gives almost a full moon (picture 6)
Will see if deleting the script and re install after a reboot of the Pi helps. It had worked for more than a month so very strange. Haven’t updates Domoticz and or Dashticz in a while so this can’t be the problem.
If you change to :
CODE: SELECT ALL
picnumber=math.floor(percentIlluminated)
n=tostring(picnumber)
if n.length==1 then
n='0'+n
It will run with all moon pictures (in 'DashBoard2/img/moon' folder)
Before starting over i decided to change this and indeed it uses al of the images now but there is still a problem. The image is now the other way around. The wrong side is dark. The percentage however matches the image now but again, the other way around. I keep searching...
RezaRose wrote: Friday 17 April 2020 16:23
I have problems with the scrips my log say this:
2020-04-17 16:20:00.369 Error: EventSystem: in Maanfase: [string "-- Variables to customize -------------------..."]:77: attempt to concatenate a nil value (global 'percentIlluminated')
2020-04-17 16:21:00.020 Status: LUA: Moonphase - Collecting data from: http://api.wunderground.com/api/REEKSME ... eppel.json
2020-04-17 16:21:00.322 Status: LUA: Moonrise: --:--
2020-04-17 16:21:00.322 Status: LUA: Moonset: --:--
2020-04-17 16:21:00.322 Error: EventSystem: in Maanfase: [string "-- Variables to customize -------------------..."]:77: attempt to concatenate a nil value (global 'percentIlluminated')
I made a weatherstation in Wunderground, but it is not a real one. Maybe that is why i get no values. Is there another option to get data?
You are in a pretty old Dashticz thread. I guess you have a Domoticz related question, so it's better to post it somewhere in the Domoticz forum.
If you want to display the moonphase in Dashticz I probably can help.
Could you help me with the moonphase? I have a api key, but i do not own weather station so I got zero values.
Raspberry Pi 4 - Raspbian bullseye - Python 3.9 - stable
Dashticz on apache2 - Mqqt - node red
Zigate - USB Tll - Philips hue - Ikea - Innr - Xiaomi - TPlink - Nest -v3
