Dashticz - Module - Spotify (new version!)
capman
Re: Dashticz - Module - Spotify
Post by capman »
freakshock wrote: Wednesday 09 August 2017 13:22 A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
Could you please explain this how to do this ? Thanks.
pvm
Domoticz version: 4.10538
Post by pvm »
Can you open a new topic for this? (Install picoreplayer) more in New topic :)
vgr2
Post by vgr2 »
vgr2 wrote: Monday 10 July 2017 21:10 I mean, empty playlist
Something changed on last updates? I have again the empty playlist.
nvb1989
Post by nvb1989 »
Hi Rob,
I'm very happy with the Spotify plugin. I was curious if you can integrated Spotify Connect within the plugin.
It would be awesome if I can choose the device to listen spotify on.
pvm
Post by pvm »
Is it possible to create a similar layout for LMS?
More info in viewtopic.php?t=18835#p146316
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
nvb1989 wrote: Tuesday 15 August 2017 18:22 Hi Rob,
Working on it ;)
robgeerts
Post by robgeerts »
pvm wrote: Tuesday 15 August 2017 19:21 Is it possible to create a similar layout for LMS?
Will check this asap..
Trigun
Domoticz version: 4.10717
Post by Trigun »
Wow, would me an amazing add on rob!
nvb1989
Post by nvb1989 »
robgeerts wrote: Wednesday 16 August 2017 10:24
Working on it ;)
Great job! If you need someone to test, I'm available :)
pvm
Post by pvm »
Nice
codesnipper
Post by codesnipper »
Not works :(
I have empty page with bar (clock,title,settings icon).
In console: "Enter your Spotify ClientID in CONFIG.JS"
CONFIG.js:
var config = {}
config['domoticz_ip'] = 'http://192.168.1.24:8080';
var _CLIENTID_SPOTIFY = 'hereismyclientid';
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['spotify']
columns[1]['width'] = 5;
Redirect URIs:
http://localhost:8080/dash/
http://192.168.1.24:8080/dash/
robgeerts
Post by robgeerts »
The variable where you entered the spotify id is old, take a look at my example config.js in this topic:
http://www.domoticz.com/forum/viewtopic ... 67&t=17426
Trigun
Post by Trigun »
Hi Guys, the spotify plug-in works like a charm, great job!! Allthough do you guys also experience that the songs only play for 30seconds? After that it asks me to open up the app. Hopefully I'm doing something wrong. Thnx!
Trigun
Post by Trigun »
Trigun wrote: Tuesday 29 August 2017 23:25 Hi Guys, the spotify plug-in works like a charm, great job!! Allthough do you guys also experience that the songs only play for 30seconds? After that it asks me to open up the app. Hopefully I'm doing something wrong. Thnx!
when I run it on an Ipad it keeps asking to play the song in the spotify app.
wheni run it on a laptop, after 30 seconds i get the following message(and the music stops)
any chance someone knows how to workaround this?
jjnj
Post by jjnj »
How is the play on other device going? I'm using a Multiroom setup in my house, that would be a great addition!!!
dlefol
Post by dlefol »
I've tried to follow the instructions but I end up with the empty playlist box (I see the select playlist box, but no playlist to select inside it).
I have spotify installed on the tablet where I use Dashticz and spotify in the app is running fine, however I cannot make it show my playlist within Dashticz :(
One thing is not clear for me, do I need spotify app to run also on the server where domoticz and dashticz are hosted or is it only on the client side (the tablet in my case) that I need the spotify app (I run domoticz on a RPi so I cannot test easily the installation of spotify on it and want to know if that s the source of the problem before I dig deeper that way...)
Thanks in advance :)
woody4165
Post by woody4165 »
Spotify is not needed on the server.
Try to open Spotify on the same browser you use for Dashticz, login and play a song in one of your playlist.
If I don't do like this, I have your same issue.
dlefol
Post by dlefol »
It worked :) Great!
Thanks a lot for the tip. I had tried playing songs and playlists on the tablet but always through the spotify app installed on the tablet. Opening the web player on a browser tab and playing a song from there was needed.
Thanks for the quick reply
basxcore
Post by basxcore »
Working on it ;)
I really (want) like this feature. Do you have it available yet? Beta perhaps? Thanks!
robgeerts
Post by robgeerts »
Sorry not yet, trying to find some spare time to finish this..
