dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
dannybloe
Re: dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
Post by dannybloe »
Interesting.. 32bits ARM is way behind indeed. No idea how that works.
Doler
Post by Doler »
Maybe 'forgotten' by @gizmocuz :?:
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
heggink
Domoticz version: 12451
Post by heggink »
Still 8015 on rpi :-( snif.
P1 meter & solar panel
dannybloe
Post by dannybloe »
Yes. It's a hand job. Giz will build it this weekend. But you can build it yourself of course.
ultratoto14
Post by ultratoto14 »
Hi Dannybloe,
Just build it myself and tried two kinds of script, one based on switch and it is triggered and the second one based on time and this one is not triggered.
In debug mode, everything is taken into account, but no trace of triggering events based on time.
Any clue ?
8025 build on RPI3.
dannybloe
Post by dannybloe »
Make sure you get the on-syntax right. Did you verify this?
In my video you can see an example (around 21:30 minutes):
ultratoto14
Ok, just created one with the editor, like in your video and was working. Updated my script compared to that one and it's ok also.
Thanks a lot. Did not keep the old one, do not know whats wrong. Grrrr
Thanks.
dannybloe
Post by dannybloe »
Probably a typo or something like that.
ultratoto14
Ok seems that i found it.
Perhaps i've got something wrong on my repo but it seems that the examples are not up to date in scripts/dzVents/examples:
https://github.com/domoticz/domoticz/bl ... evices.lua
The timer is in [] and on the editor example it's now {}.
jeanclic
Post by jeanclic »
Hello everyone,
any news on when we will have dzVents available on RPI ?
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
Gizmocus was abroad but he planned to build it today (1/7).
jeanclic
Post by jeanclic »
Thanks dannybloe for your answer.
I am looking forward to test your dzVents ! -> seems very good (never tested the 1.0 version).
x4 fibaro / x1 PIR
randytsuch
Post by randytsuch »
I just updated my Pi Domoticz beta version, and it is now 8027 :)
And indeed I see dzvents on the events page so seems pi users can now update and use the new dzvents.
edit
dzvents is also now on the setup/settings/other page
jeanclic
Post by jeanclic »
got it too ! thanks Gizmocuz !
x4 fibaro / x1 PIR
Doler
Post by Doler »
Got it running too (thanks @gizmocuz, @dannybloe), just noticed that Log Level setting doesn't represent the chosen value (after Apply Settings).
Mark
randytsuch
One comment.
If you use the domoticz events editor (which is very convenient), the example still uses [] for definitions instead of the new convention ()
Randy
heggink
Post by heggink »
Some people appear to have issues (high cpu) with 8027 on rpi3. Anyone without these problems on rpi3?
Doler
Post by Doler »
No high CPU here, CPU is around 5%. Busy migrating from dzVents 1.02 to 2.0, no problems so far.
Mark
jeanclic
Post by jeanclic »
The 3.8034 beta has been released this morning, fixing the cpu usage a bit.
On my setup, there is stil issues when I activate dzVents, even if I keep the logs to "silent"...
On the 3.8027, I had 100% cpu usage or higher, except when I disabled all event system, not only dzVents...
x4 fibaro / x1 PIR
dannybloe
Post by dannybloe »
Interesting.. running 3.8025 on my Pi3 and it hardly has any cpu usage here.
