Moderators: leecollings , htilburgs , robgeerts
jake
Posts: 753 Joined: Saturday 30 May 2015 22:40
Post
by jake » Saturday 27 May 2017 11:14
htilburgs wrote:
Thnx... And updated the wiki too....
I would like to propose a litte change in the Wiki regarding the change of color, based on value xyz:
- Start with the paragraph about finding the right variable for monitoring, so before explaining what to add to custom.js (common practice for manuals, since people try to follow the manual line by line and won't recognize the next paragraph while they get stuck in the paragraph before)
- Don't use the example json command for all devices, but start with the one for the specific device, since that is what the user is after in the first place:
and point for all other json command to the Domoticz wiki:
http://www.domoticz.com/wiki/Domoticz_A ... rtain_type
mvveelen
Posts: 721 Joined: Friday 31 October 2014 10:22
Post
by mvveelen » Saturday 27 May 2017 15:30
htilburgs wrote:
I also noticed a minor in .trashcan. After height the : is missing. (I know, I'm a nitpicker
Hahaha, added the : after height
htilburgs
Posts: 464 Joined: Tuesday 03 November 2015 11:01
Post
by htilburgs » Saturday 27 May 2017 21:19
I understand what you mean. Take a look at it tomorow...
Hardware:
htilburgs
Post
by htilburgs » Tuesday 30 May 2017 13:28
Finaly found some time and changed the Wiki. Thanks for your possitive reply.
Btw, when you've an account, you can edit the wiki yourself....
Hardware:
EdwinK
Posts: 1820 Joined: Sunday 22 January 2017 21:46
Post
by EdwinK » Thursday 08 June 2017 21:45
Why wouldn't this work?
// temp
function getStatus_176(idx,value,device){
if(parseFloat(device['Data'])>20){
$('div.block_176').removeClass('warning').addClass('warningorange');
else if(parseFloat(device['Data'])>23){
$('div.block_176').removeClass('warningorange').addClass('warning');
else {
$('div.block_176').removeClass('warning').removeClass('warningorange');
mvveelen
Post
by mvveelen » Thursday 08 June 2017 21:52
EdKo66 wrote: Why wouldn't this work?
// temp
else {
Change Data to Temp
EdwinK
Post
by EdwinK » Thursday 08 June 2017 23:04
mvveelen wrote: EdKo66 wrote: Why wouldn't this work?
Change Data to Temp
Of course... Thanks
gielie
Posts: 290 Joined: Tuesday 12 January 2016 11:40
Domoticz version: latest β
Post
by gielie » Friday 09 June 2017 12:26
I have tried this one, but it doesnt work, can someone tell me why and give me a solution.
// temp
function getStatus_304(idx,value,device){
if(parseFloat(device['Temp'])>20){
$('div.block_304').removeClass('warningred').removeClass('warningorange').addClass('warning');
else if(parseFloat(device['Temp'])>22){
$('div.block_304').removeClass('warning').removeClass('warningred').addClass('warningorange');
else if(parseFloat(device['Temp'])>24){
$('div.block_304').removeClass('warningorange').removeClass('warning').addClass('warningred');
else {
$('div.block_304').removeClass('warning').removeClass('warningorange').removeClass('warningred');
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
htilburgs
Post
by htilburgs » Friday 09 June 2017 12:44
gielie wrote: I have tried this one, but it doesnt work, can someone tell me why and give me a solution.
// temp
else {
I think there are two errors:
- the device['Temp'] and should be device['Data']
- Start with the highest and work down to the lowest temperature
if(parseFloat(device['Data'])>24){
$('div.block_304').removeClass('warning').removeClass('warningorange').addClass('warningred');
else if(parseFloat(device['Data'])>22){
else if(parseFloat(device['Data'])>20){
$('div.block_304').removeClass('warningorange').removeClass('warningred').addClass('warning');
else {
Hardware:
EdwinK
Post
by EdwinK » Friday 09 June 2017 12:51
Don't know why it wouldn't work for you. You did put it in custom.js?
I have the problem because it is a sensor with a '_1' in it.
Mmm. Yesterday I was told to change it from 'Data' to 'Temp'.
Even rain isn't flashing anymore
EdwinK on Friday 09 June 2017 13:09, edited 1 time in total.
htilburgs
Post
by htilburgs » Friday 09 June 2017 13:02
EdKo66 wrote: Don't know why it wouldn't work for you. You did put it in custom.js?
That can be, but it's not right...
When you check your device with http://domoticz_url:port/json.htm?type=devices&rid=304, you wil see there is no parameter
Temp . What you find is
Data . So it should be
Data .
Furthermore, you started with the lowest values. In that case the formule won't work. Work down from high to low.
Example in you're case when it is 22,5 degree the warningorange AND warningred are true. Which one should be picked??
Hardware:
EdwinK
Post
by EdwinK » Friday 09 June 2017 13:13
htilburgs wrote: EdKo66 wrote: Don't know why it wouldn't work for you. You did put it in custom.js?
Data .
but... there is a Temp parameter. Are so I think.
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 0,
"Data" : "18.1 C, 0 %",
"Description" : "",
"DewPoint" : "18.10",
"Favorite" : 1,
"HardwareID" : 13,
"HardwareName" : "RFXcom",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveTimeout" : false,
"Humidity" : 0,
"HumidityStatus" : "Dry",
"ID" : "1001",
"LastUpdate" : "2017-06-09 13:10:33",
"Name" : "Buiten temp",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 6,
"SubType" : "Rubicson/IW008T/TX95",
[b] "Temp" : 18.100000000000001,
[/b]
htilburgs
Post
by htilburgs » Friday 09 June 2017 13:18
Ok, that differs from mine. Use this code in config.js and it should work.
else if(parseFloat(device['Temp])>20){
else {
Hardware:
EdwinK
Post
by EdwinK » Friday 09 June 2017 13:36
Put this in, but for now it will not be working because of the multi-sensor thing even if the humidity doesn't really work
EdwinK
Post
by EdwinK » Friday 09 June 2017 13:42
htilburgs wrote: Ok, that differs from mine. Use this code in config.js and it should work.
Shouldn't it be in custom.js?
htilburgs
Post
by htilburgs » Friday 09 June 2017 14:00
Sorry, it should be config.js. My mistake...
Hardware:
EdwinK
Post
by EdwinK » Friday 09 June 2017 14:05
*flashing buttoons* Screen Shot 2017-06-09 at 14.03.31.png (108.15 KiB) Viewed 4069 times
Yes... It works. Had fixed a little typo (You forgot the closing ' ).
htilburgs
Post
by htilburgs » Friday 09 June 2017 14:13
Ok, happy and sorry.... Probably a Cut & Paste error.
Nice to hear it works!!
Hardware:
gielie
Post
by gielie » Friday 09 June 2017 14:20
Yes the code works, tanks. And like Ed told, the last Temp misses a '
- FIBARO FGS223
- Toon
- Kodi Media Server
lukev
Posts: 66 Joined: Friday 21 October 2016 10:42
Post
by lukev » Sunday 25 June 2017 22:13
Any method to extract temp from tem/hum sensor?
My data reads this:
so the tigger doesn't work...
