Python plugin: Battery Level for Z-Wave Devices
Egregius
Domoticz version: v2024.7
Re: Python plugin: Battery Level for Z-Wave Devices
Post by Egregius »
In my case the XML isn't good either.
I replaced all batteries of my smoke sensors yesterday. All battery levels went to 100%.
Today, one reports as 0%. So I looked at the devices table, all devices from that node just have a - as battery level...
Logread
Post by Logread »
Egregius wrote:In my case the XML isn't good either.
Not clear to me if you are saying the domoticz/Config/zwcfg_0x????????.xml file on your system does not hold an accurate COMMAND_CLASS_BATTERY data for that node, or if my plugin has a bug ?
That being said, you may want to try to manually wake up the culprit smoke sensor and see what happens (may have to wait for one hour to see any change though) ?
Egregius
Post by Egregius »
Yes, the /Config/zwcfg_0x????????.xml contains value="0" for that node.
Or maybe it's a faulty battery, haven't received temps in the last 6 hours... Damn, up to the attic that is.
capman
Post by capman »
A tryded the script , but got a error in my log.
2017-05-27 09:38:25.534 (Baterijen Z-Wave) Initialized version 0.4.0, author 'logread'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) Debug log level set to: 'true'.
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Key':'BatteryLevel'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Mode6':'Debug'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Port':'0'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'HardwareID':'55'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Version':'0.4.0'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Author':'logread'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Name':'Baterijen Z-Wave'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'HomeFolder':'/usr/local/domoticz/var/plugins/BatteryLevel/'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) 'Mode1':'60'
2017-05-27 09:38:25.590 (Baterijen Z-Wave) Device count: 0
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Number of icons loaded = 4
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 120 batterylevelok
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 118 batterylevelfull
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 119 batterylevellow
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Icon 117 batterylevelempty
2017-05-27 09:38:25.591 (Baterijen Z-Wave) Using polling interval of 60 minutes
Error: (Baterijen Z-Wave) Enable to find a zwave controller configuration file !
And all 10 seconds get this message
2017-05-27 09:38:45.459 (Baterijen Z-Wave) Calling message handler 'onHeartbeat'.
Logread
Post by Logread »
@capman,
I assume that indeed you have a zwave stick connected and functional ? If so, what is the platform you are running Domoticz on (Linux, Windows, ...) ? Can you locate the zwcfg_0x????????.xml file on your system (where ???????? is the unique homeid of your zwave controller)... it should be in the Config subfolder of the Domoticz install folder. If it is not there, then please report on where that file is on your system (you might have a non standard directory setup ?)
capman
Post by capman »
Logread wrote:@capman,
I have it installed on synology beta 3.7468
On my config folder a have a file called 'zwcfg.xsd'. It's located in /volume1/@appstore/domoticz/Config/zwcfg.xsd
Code showing under.
<?xml version='1.0'?>
<xs:schema
xmlns:xs='http://www.w3.org/2001/XMLSchema'
targetNamespace='http://code.google.com/p/open-zwave/'
xmlns:Driver='http://code.google.com/p/open-zwave/'
elementFormDefault='qualified'>
<xs:element name='Driver'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Node' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='version' type='xs:string' use='required'/>
<xs:attribute name='home_id' type='xs:string' use='required'/>
<xs:attribute name='node_id' type='xs:string' use='required'/>
<xs:attribute name='api_capabilities' type='xs:string' use='required'/>
<xs:attribute name='controller_capabilities' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Node'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Manufacturer'/>
<xs:element ref='Driver:CommandClasses'/>
</xs:sequence>
<xs:attribute name='id' type='xs:string' use='required'/>
<xs:attribute name='name' type='xs:string' use='required'/>
<xs:attribute name='location' type='xs:string' use='optional'/>
<xs:attribute name='basic' type='xs:string' use='optional'/>
<xs:attribute name='generic' type='xs:string' use='optional'/>
<xs:attribute name='specific' type='xs:string' use='optional'/>
<xs:attribute name='type' type='xs:string' use='optional'/>
<xs:attribute name='listening' use='optional'>
<xs:simpleType>
<xs:restriction base='xs:string'>
<xs:enumeration value='true'/>
<xs:enumeration value='false'/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='frequentListening' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='beaming' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='routing' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='max_baud_rate' type='xs:string' use='optional'/>
<xs:attribute name='version' type='xs:string' use='optional'/>
<xs:attribute name='query_stage' type='xs:string' use='optional'/>
<xs:attribute name='security' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='nodeinfosupported' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:element>
<xs:element name='Manufacturer'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Product'/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name='Product'>
<xs:complexType>
<xs:attribute name='type' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='CommandClasses'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:CommandClass' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name='CommandClass'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Instance' minOccurs='0' maxOccurs='unbounded'/>
<xs:element ref='Driver:Value' minOccurs='0' maxOccurs='unbounded'/>
<xs:element ref='Driver:Associations' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='after_mark' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='create_vars' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='getsupported' use='optional'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='request_flags' type='xs:string' use='optional'/>
<xs:attribute name='base' type='xs:string' use='optional'/>
<xs:attribute name='override_precision' type='xs:string' use='optional'/>
</xs:complexType>
</xs:element>
<xs:element name='Instance'>
<xs:complexType>
<xs:attribute name='index' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Value'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Help' minOccurs='0' maxOccurs='1'/>
<xs:element ref='Driver:Item' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='genre' type='xs:string' use='required'/>
<xs:attribute name='instance' type='xs:string' use='required'/>
<xs:attribute name='label' type='xs:string' use='required'/>
<xs:attribute name='units' type='xs:string' use='required'/>
<xs:attribute name='read_only' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='write_only' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='verify_changes' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:attribute name='poll_intensity' type='xs:string' use='required'/>
<xs:attribute name='min' type='xs:string' use='required'/>
<xs:attribute name='max' type='xs:string' use='required'/>
<xs:attribute name='value' type='xs:string' use='optional'/>
<xs:attribute name='vindex' type='xs:string' use='optional'/>
<xs:attribute name='affects' type='xs:string' use='optional'/>
<xs:attribute name='size' type='xs:string' use='optional'/>
</xs:complexType>
</xs:element>
<xs:element name='Help'>
<xs:complexType mixed='true'>
</xs:complexType>
</xs:element>
<xs:element name='Item'>
<xs:complexType>
<xs:attribute name='value' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Associations'>
<xs:complexType>
<xs:sequence>
<xs:element ref='Driver:Group' minOccurs='0' maxOccurs='unbounded'/>
</xs:sequence>
<xs:attribute name='num_groups' type='xs:string' use='required'/>
</xs:complexType>
</xs:element>
<xs:element name='Group'>
<xs:complexType>
<xs:sequence>
<xs:element name='Node' minOccurs='0' maxOccurs='unbounded'>
<xs:complexType>
</xs:complexType>
</xs:element>
</xs:sequence>
<xs:attribute name='max_associations' type='xs:string' use='required'/>
<xs:attribute name='auto' use='required'>
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:complexType>
</xs:element>
</xs:schema>
And a screenshot from my zwave device. I hope you can do something with it (or not) ;)
Logread
Post by Logread »
@capman,
The .xsd file is of no use for the plugin... only the zwcfg_0x????????.xml file (where ???????? is the unique homeid of your zwave controller) is required for the plugin to work... I note your zwave stick is a Vision one, while I tested on a Aeotec, so may be openzwave works differently with that controller ? Not sure. Can you send me by pm a directory listing of your domoticz/Config folder ?
capman
Post by capman »
I search in my domoticz structure folders to 'zwcfg' , but nothing found. I send you a pm. Thanks 4 looking :)
Derik
Post by Derik »
m,mmm
Did have this plugin working.
Only need to upgrade my cb to a Xu4...[ more power needed.. :-) ]
Now i do the [ same ] trick..
Only no plugin in domoticz hardware section......
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo chmod +x plugin.py
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo apt-get install git
Reading package lists... Done
Building dependency tree
Reading state information... Done
git is already the newest version (1:2.7.4-0ubuntu1.1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ sudo /etc/init.d/domoticz.sh restart
[ ok ] Restarting domoticz.sh (via systemctl): domoticz.service.
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ cd
linaro@odroidxu4:~$ cd ~/domoticz/plugins/BatteryLevel
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ git reset --hard
HEAD is now at dd0d29b Version 0.4.2
linaro@odroidxu4:~/domoticz/plugins/BatteryLevel$ git pull --force
Already up-to-date.
And in the ftp area is see everything i need...
Do i need to start the script or??
Where do i go wrong..
Logread
Post by Logread »
Derik wrote:m,mmm
I think the sequence of shell commands you send is not finished... you need to restart domoticz AFTER you update the plugin and make the script executable...
This should do it
Derik
Post by Derik »
strange,
Do everything i need to do for the 3 time.
No plugin
ast beta..
Do the thing as subscribe here in the topic...
see the map an all the stuff.
Reboot
Refresh hardware list
no plugin
Logread
Post by Logread »
Derik wrote:strange,
No plugin
ast beta..
Reboot
no plugin
Which version of Domoticz are you running ? I saw on the forum that some of the recent beta builds had python disabled... do you have other python plugins installed and working (or not)... If no plugin works, then definitely a domoticz issue
Derik
Post by Derik »
Last beta..
New hardware xu4 ..
With other kernell perhaps that??
Or can i mananual install python
Or check the versions
Logread
Post by Logread »
A new version (0.4.3) is available from the GitHub repository. The plugin should now work on Synology platforms (different location of the openzwave files compared to "standard" Linux or Windows installs). Thanks to @capman for raising the issue and testing the new version :)
TakeAway
Domoticz version: 3.7722
Post by TakeAway »
I have the same problem as derik, also latest beta. Can't see the plugin in the hardware list.
Raspberry Pi 3 - Domoticz 3.7722 - Aeon Labs Z-Stick GEN5 - RFXcom version: Ext/1012- Logitech Harmony Elite - Homebridge - Fibaro FGMS-001-ZW5 - Fibaro FGDW-002-01 - KAKU stuff.
TakeAway
Post by TakeAway »
Problem solved by installing python from the wiki:https://www.domoticz.com/wiki/Using_Python_plugins
Derik
Post by Derik »
Not by me:
linaro@odroidxu4:~/domoticz$ dpkg -l | grep libpython3
ii  libpython3-dev:armhf                 3.5.1-3        armhf        header files and a static library for Python (default)
ii  libpython3-stdlib:armhf              3.5.1-3        armhf        interactive high-level object-oriented language (default python                                                    3 version)
ii  libpython3.5:armhf                   3.5.2-2ubuntu0~16.04.1        armhf        Shared Python runtime library (version 3.5)
ii  libpython3.5-dev:armhf               3.5.2-2ubuntu0~16.04.1        armhf        Header files and a static library for Python (v3.5)
ii  libpython3.5-minimal:armhf           3.5.2-2ubuntu0~16.04.1        armhf        Minimal subset of the Python language (version 3.5)
ii  libpython3.5-stdlib:armhf            3.5.2-2ubuntu0~16.04.1        armhf        Interactive high-level object-oriented language (standard libra                                                    ry, version 3.5)
linaro@odroidxu4:~/domoticz$ cd
linaro@odroidxu4:~$ sudo apt-get install python3-dev
python3-dev is already the newest version (3.5.1-3).
The following packages were automatically installed and are no longer required:
  gir1.2-javascriptcoregtk-3.0 gir1.2-soup-2.4 gir1.2-webkit-3.0 inxi
  libarchive13 libboost-python1.58.0 libexiv2-14 libgd3 libgdata-common
  libgdata22 libglib2.0-bin libgoa-1.0-0b libgoa-1.0-common libgphoto2-6
  libgphoto2-port12 libimobiledevice6 libjavascriptcoregtk-3.0-0 libmate-menu2
  libmtp-common libmtp9 liboauth0 libpcre16-3 libpcre3-dev libpcre32-3
  libpcrecpp0v5 libplist3 libusbmuxd4 libwebkitgtk-3.0-0
  libwebkitgtk-3.0-common python3-polib
Use 'sudo apt autoremove' to remove them.
linaro@odroidxu4:~$
And instal the plugin
reboot
check and double ..
No hardware in my list for the battery
Phantom
Domoticz version: 4.11652
Post by Phantom »
Thanks for the plugin.
I have installed it today and works great.
TakeAway
Post by TakeAway »
Works for some time, but domoticz crashes. Is there a solution for this?
bdormael
Post by bdormael »
TakeAway wrote:Works for some time, but domoticz crashes. Is there a solution for this?
Same issue here, 2 times a day Domoticz crashes now, when disabling the plugin, no crashes anymore
Verzonden vanaf mijn iPad met Tapatalk
