Gearoticz | Galaxy Watch, Gear S3 and S2 Tizen implementation
ehallq
Re: Gearoticz | Gear S3 and S2 Tizen implementation
Post by ehallq »
chatainsim wrote: Thursday 28 September 2017 17:14 Hello,
Since the last update, app stop working on my Gear S2.
I add my server but then I'm not able to add temp device or switch or anything else.
Is there a way to get logs ?
Sorry for responing so late, but I think we have talked on email, right? :)
dynammo wrote: Wednesday 18 October 2017 17:37 Hi,
I bought the app, i see my switchs and temp switchs, i selected what i want, return to home of app, but ... Action on them don't work.
Temp switch indicate "Temperature". Switch tap : the gear S3 buzz but nothing work.
I'm alone to have a problem ?
Domoticz app on my phone works fine.
Gear S3 / Domoticz Version: 3.8590
Any help will be appreciated :) Many thanks.
Really strange issue... If you get the list of devices, sending requests should work. In the app, there is no difference between getting all the devices and sending a command. Its exactly the same thing from a tech point of view. Are your running the latest stable version of Domoticz?
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
Yes, we have talked by mail.
I think the issue is on https side.
Are you able to connect trought https ?
Henrik
Post by Henrik »
After an update to the Gear Watch the does no longer work.
The only thing I see when starting the app is "Gearoticz" on the top, and then no more.
ehallq
Post by ehallq »
Hi everybody
I know that the app has stopped working after the latest update and I will solve it as soon as I can :)
ehallq
Post by ehallq »
Spoke to soon....
Progress, I finally solved the bug and I am doing some minor adjustments before I will release the update. Just letting you know that I am working on it :-)
Solved one of the bugs that didnt let the application run. Now I have a new bug which for some reason doesnt grant me access to internet unless I have a wifi connection to the watch. (When developing the watch is always connected to wifi). So now I have to figure out why, the Tizen docs are awful, nothing is correct now when using Tizen 3.0.. damn it samsung..
Basically all functions I am using are supposed to be unchanged since Tizen 2.3.2 according to the docs , however that is not the truth. So for a dev point of view its a guessing game
vidjer
Domoticz version: 4.10548
Post by vidjer »
ehallq wrote:Hi everybody
I just bought the app on Galaxy App. It's very frustrating to have nothing functional. Thank you for doing the best.
Envoyé de mon SM-G935F en utilisant Tapatalk
ehallq
Post by ehallq »
Update is being validated by Samsung.
I have noticed that the system api of the watch got broken by the Tizen 3.0 update for alot of user. That is why this (any many other) app is not working. The solution is to reset the watch. This is not caused by my app, this is a bug caused by Samsung for the whole watch. If your watch is effected by this bug, my app will alert you and ask you to reset the watch. Resetting the watch is done in the settings app of the watch, not in the settings in this app.
Thank you for being patient!
Henrik
Post by Henrik »
Looking forward to see the new app.
I'm am probably affected by the bug, as my Endomondo app is not working either.
skybehind
Post by skybehind »
Got one for Christmas, first app I looked for was Domoticz, lol. Was happy to see it existed. So I added server and got it working, so far so good.
Question, can we add by domain name or is address only? Domain would be beneficial when not at home and in the case of dynamic is.
Sent from my Nexus 6 using Tapatalk
vidjer
Post by vidjer »
Hello
I do reset. Reinstall all soft.
Now I can see devices.
Temperature looks like switch. Swith too.... But no effect! I test in http and https. I test on stable and beta server. I have 2 domoticz server.
Help please
Thank's ImageImage
xavier1306
Post by xavier1306 »
Same for me.
Access to all switches and temperatures but no action on click...
Envoyé de mon MI 5s en utilisant Tapatalk
delboydell
Post by delboydell »
Hello will this app work on the original gear s (tyzen os) the one with the curved screen? I have followed the link on the 1st page and it takes me to the Samsung home page, just like if you want opera mini outside the areas they don't want you to have it.
Do you have a direct link to the .wgt file and I will side load it and give it a try?
thanks in advance
BenoitD
Post by BenoitD »
I just bought the app from the Samsung store. It was not scored so I Put 5 stars to boost it :)
Tested on Samsung Gear Sport.
Some issues :
- when connection with phone is lost, buttons appear but does not work anymore. Even killing the app does not work.
- Temperature inputs are not shown, only temperature measures (outputs), I can solve the issue by creating some virtual buttons in domoticz (virtual buttons seem to work well in Gear App)
- Z-Wave Electricity consumption device is not shown too
skybehind
Post by skybehind »
I have another question (in addition to the one about server via domain name vs ip address); do you plan to add any widgets? Ideally I'd like to use a widget to unlock the front door instead of having to open the app and scroll to the switch for it.
delboydell
can I buy this app anywhere else but the Samsung store please? as it is not available to the uk.
ehallq
Post by ehallq »
vidjer wrote: Wednesday 27 December 2017 9:09
Hello
Help please
Thank's ImageImage
xavier1306 wrote: Wednesday 27 December 2017 9:15 Same for me.
You are in the wrong menu. Your are in the settings menu where you toggle the switches and temps to be on the startscreen. :)
BenoitD wrote: Saturday 06 January 2018 23:37 Hello,
Some issues :
- You still need internetconnection, either by LTE or WIFI, when you loose connection with the phone.
- I only show temp outputs, I have not temp input device at home, so I cant currently test this :/
- This is not added (yet). Currently have no plan for it, but I could maybe add it in the future
skybehind wrote: Wednesday 10 January 2018 3:18 I have another question (in addition to the one about server via domain name vs ip address); do you plan to add any widgets? Ideally I'd like to use a widget to unlock the front door instead of having to open the app and scroll to the switch for it.
No, I have no plan for it. A tip could be to create scenes to unlock/lock your door. Then it will be at the top :)
delboydell wrote: Thursday 11 January 2018 21:32 can I buy this app anywhere else but the Samsung store please? as it is not available to the uk.
No sorry, its not possible, and thats Samsungs fault :/
ehallq
Post by ehallq »
jimmy777 wrote: Sunday 14 January 2018 22:01 @ehallq do you wan't fix tizen 3 problems in your aplication? Or you just scamming money in galaxy apps?
It's real question, your app is a joke. Give people money back and delete this shit from store!
Hi jimmy777!
Not sure why you are so negative. There is a update out since 7 december, and no one have reported a problem to me after that update. Have you read the app description?
The Tizen 3.0 cause some bugs in the system api. This is not a problem cause by the app, but a problem caused by Samsung. Currently there is a check which tells you if your device was effected by this bug during the update. If so, the app will tell you that, you need to do a reset of the watch. A reset of the watch is done in the settings of the Gear S2/S3 watch, not in the app.
A tip is to first, update the app and read the description. If this doesnt solve/answer your question, ask here or report the problem to the developer throught the store (me in this case obviously). Dont start of being rude, it wont help anyone.
xavier1306
Hi Ehallq
I dis not see the answer regarding the fact of using domain name instead of IP in the server parameters.
For those who dont have a fixed IP, this is a must when outside the house wifi...
I can easily access to domoticz with any brother using https://mydomainname:myport but it does not work with gearoticz.
Any idea?
ehallq
Post by ehallq »
skybehind wrote: Wednesday 27 December 2017 1:23 Got one for Christmas, first app I looked for was Domoticz, lol. Was happy to see it existed. So I added server and got it working, so far so good.
xavier1306 wrote: Tuesday 16 January 2018 17:04 Hi Ehallq
Any idea?
I use a domain instead of IP for Gearoticz, and it works. You shouldnt enter https://mydomainname:myport in the IP field
Since you use SSL (HTTPS)
You should have the following settings:
IP: mydomainname
Port: myport
User: username
Password: password
HTTPS?: yes
In my case I navigate to https://www.mydomain.com
Then
IP: www.mydomain.com
Port: 443
HTTPS?: yes
xavier1306
Thanks for the answer. But that is what i did :(
I'll keep trying
