Page 3 of 4
Re: PlayBlub (Bluetooth Bulb) Python Plugin - Beta tester Wanted
Posted: Sunday 14 May 2017 15:33
by deennoo
Does your device is powered ?
Are you sure that your phone or tablet isn't connected to the raam Links ?
How many playbulb device (hardware page) have you on domoticz ?
Posted: Sunday 14 May 2017 15:47
by poudenes
deennoo wrote:Does your device is powered ?
I have 5 PlayBulbs in Domoticz, not connected in app (removed it from iPhone, and they are not in bluetooth list as well)
I can use the bulbs normal thats the strange thing.
Activate Status: TRUE or FALSE it doesn't matter. Still got the errors:
All Mac adresses are correct.
2017-05-14 15:43:02.188 (Buiten) Error getting status
2017-05-14 15:43:02.212 (Buiten) Error connecting device - is it up ? (btle error code : 1)
2017-05-14 15:43:06.969 (Muur Rechts) Error getting status
2017-05-14 15:43:06.992 (Muur Rechts) Error connecting device - is it up ? (btle error code : 1)
2017-05-14 15:43:12.264 (Muur Links) Error getting status
2017-05-14 15:43:12.288 (Muur Links) Error connecting device - is it up ? (btle error code : 1)
2017-05-14 15:43:17.068 (Raam Rechts) Error getting status
2017-05-14 15:43:17.092 (Raam Rechts) Error connecting device - is it up ? (btle error code : 1)
2017-05-14 15:43:26.111 Hardware Monitor: Fetching data (System sensors)
2017-05-14 15:43:38.225 (Raam Links) Error getting status
2017-05-14 15:43:38.250 (Raam Links) Error connecting device - is it up ? (btle error code : 1)
Posted: Tuesday 23 May 2017 8:38
by poudenes
When the bulbs are switched on by domoticz, i still get the errors as well... Even when they are on.
Posted: Tuesday 23 May 2017 10:32
by zaraki673
i will check this
thk's
Posted: Wednesday 24 May 2017 8:06
by poudenes
zaraki673 wrote:i will check this
thk's
great thanks and hope you will find out what it can be :D
Posted: Sunday 28 May 2017 9:10
by poudenes
I see many problems accure now with the bulbs. Seems bluetooth disconnect the connection. When a scene has to be start, first domoticz need to reconnect first and then the action.
Now i see that it don't connect anymore. I have to restart domoticz, sometimes restart OS at all. Then use rfkill unblock all to unblock bluetooth and then wait until domoticz connects all bulbs normal...
Can this be the problem of my earlier error?
2017-05-28 09:08:55.439  (Raam Rechts) Calling message handler 'onHeartbeat'.
2017-05-28 09:08:55.479  (Raam Rechts) Error getting status
2017-05-28 09:08:55.503  (Raam Rechts) Error connecting device - is it up ? (btle error code : 1)
2017-05-28 09:08:55.654  (Muur Links) Calling message handler 'onHeartbeat'.
2017-05-28 09:08:55.707  (Muur Links) Error getting status
2017-05-28 09:08:55.731  (Muur Links) Error connecting device - is it up ? (btle error code : 1)
2017-05-28 09:08:55.832  (Muur Rechts) Calling message handler 'onHeartbeat'.
2017-05-28 09:08:55.887  (Muur Rechts) Error getting status
2017-05-28 09:08:55.912  (Muur Rechts) Error connecting device - is it up ? (btle error code : 1)
2017-05-28 09:08:56.012  (Buiten) Calling message handler 'onHeartbeat'.
2017-05-28 09:08:56.075  (Buiten) Error getting status
2017-05-28 09:08:56.099  (Buiten) Error connecting device - is it up ? (btle error code : 1)
2017-05-28 09:08:56.199  (Raam Links) Calling message handler 'onHeartbeat'.
2017-05-28 09:08:56.262  (Raam Links) Error getting status
2017-05-28 09:08:56.287  (Raam Links) Error connecting device - is it up ? (btle error code : 1)
Is there a way to hold the connection alive... so it never disconnect again? Im having : Activate Status: True on.
Posted: Monday 29 May 2017 9:51
by poudenes
To be sure it is not the config or some other problems. I created a second config , full clear install Domoticz, and put only the bluetooth bulb in. The error of BTLE ERROR still there. So a clear install didn't solve the problem as well...
(EDIT) 16:17: Did also al full clear install Rasbian, Domoticz, and got same errors even more:
mei 29 16:11:11 RPi3 domoticz[656]: Error: Domoticz received fatal signal 11 !...
mei 29 16:11:11 RPi3 domoticz[656]: Error: /home/pi/domoticz/domoticz() [0x1c7df4]
mei 29 16:11:11 RPi3 domoticz[656]: Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1c7eac]
mei 29 16:11:11 RPi3 domoticz[656]: Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a9b180]
mei 29 16:11:11 RPi3 domoticz[656]: Error: /home/pi/domoticz/domoticz(_ZStplIcSt11char_traitsIcESaIcEESbIT_T0_T1_EPKS3_RKS6_+0x28) [0x1c49e0]
mei 29 16:11:11 RPi3 domoticz[656]: Error: /home/pi/domoticz/domoticz() [0x48153c]
When i want change something about the setting of a bulb in hardware section
Posted: Wednesday 31 May 2017 21:21
by poudenes
Domoticz has change something so the script won't work in latest beta, check Python framework breaking change - advance warning
https://github.com/domoticz/domoticz/pull/1571
http://www.domoticz.com/forum/viewtopic ... 4&p=135840
Verzonden vanaf mijn iPhone met Tapatalk Pro
Posted: Tuesday 06 June 2017 21:16
by poudenes
any news for a updated version with new python script? :roll:
Posted: Wednesday 07 June 2017 0:36
by zaraki673
code updated ;)
Posted: Wednesday 07 June 2017 8:11
by poudenes
Tried it with latest beta update but whole plugin is not visible.
I will try later again. Have 2 versions on RPi
1) - Domoticz version installed by: sudo curl -L install.domoticz.com | sudo bash
2) - Domoticz version installed by: git clone https://github.com/domoticz/domoticz.git dev-domoticz
The plugin not work with option 1 updated to beta
Have to backup everything to switch to beta with option 2 and try.
Now running 3.5876 perfectly, so don't wanna break it down.
Posted: Wednesday 07 June 2017 10:38
by poudenes
Plugin work. But when you shutdown Domoticz it gives errors:
2017-06-07 10:37:23.176  Error: (Raam Rechts) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:23.176  Error: (Raam Rechts) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.176  Error: (Raam Rechts) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.176  Error: (Raam Rechts) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:23.176  Error: (Raam Rechts) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:23.177  Error: (Raam Rechts) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
Exception ignored in: <module 'threading' from '/usr/lib/python3.4/threading.py'>
  File "/usr/lib/python3.4/threading.py", line 1292, in _shutdown
    t = _pickSomeNonDaemonThread()
  File "/usr/lib/python3.4/threading.py", line 1299, in _pickSomeNonDaemonThread
    for t in enumerate():
  File "/usr/lib/python3.4/threading.py", line 1269, in enumerate
    return list(_active.values()) + list(_limbo.values())
TypeError: bad argument type for built-in operation
2017-06-07 10:37:23.521  (Raam Rechts) Exiting work loop...
2017-06-07 10:37:23.522  (Raam Rechts) Stopped.
2017-06-07 10:37:23.541  Error: (Raam Links) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:23.542  Error: (Raam Links) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.542  Error: (Raam Links) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.542  Error: (Raam Links) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:23.542  Error: (Raam Links) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:23.542  Error: (Raam Links) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-06-07 10:37:23.771  (Raam Links) Exiting work loop...
2017-06-07 10:37:23.771  (Raam Links) Stopped.
2017-06-07 10:37:23.809  Error: (Muur Links) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:23.809  Error: (Muur Links) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.809  Error: (Muur Links) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:23.809  Error: (Muur Links) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:23.809  Error: (Muur Links) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:23.809  Error: (Muur Links) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-06-07 10:37:23.998  (Muur Links) Exiting work loop...
2017-06-07 10:37:23.999  (Muur Links) Stopped.
2017-06-07 10:37:24.013  Error: (Muur Rechts) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:24.013  Error: (Muur Rechts) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.013  Error: (Muur Rechts) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.013  Error: (Muur Rechts) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:24.013  Error: (Muur Rechts) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:24.013  Error: (Muur Rechts) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-06-07 10:37:24.232  (Muur Rechts) Exiting work loop...
2017-06-07 10:37:24.233  (Muur Rechts) Stopped.
2017-06-07 10:37:24.274  Error: (Buiten) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:24.274  Error: (Buiten) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.274  Error: (Buiten) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.274  Error: (Buiten) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:24.274  Error: (Buiten) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:24.274  Error: (Buiten) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-06-07 10:37:24.464  (Buiten) Exiting work loop...
2017-06-07 10:37:24.464  (Buiten) Stopped.
2017-06-07 10:37:24.496  Error: (Hal) 'onStop' failed 'BrokenPipeError'.
2017-06-07 10:37:24.496  Error: (Hal) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.496  Error: (Hal) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-07 10:37:24.496  Error: (Hal) ----> Line 577 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-07 10:37:24.496  Error: (Hal) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-07 10:37:24.497  Error: (Hal) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
And those errors are still there also:
jun 07 10:56:16 raspberrypi domoticz[2261]: (Raam Rechts) Error getting status
jun 07 10:56:16 raspberrypi domoticz[2261]: (Raam Rechts) Error connecting device - is it up ? (btle error code : 1)
jun 07 10:56:16 raspberrypi domoticz[2261]: (Raam Links) Error getting status
jun 07 10:56:16 raspberrypi domoticz[2261]: (Raam Links) Error connecting device - is it up ? (btle error code : 1)
jun 07 10:56:16 raspberrypi domoticz[2261]: (Muur Links) Error getting status
jun 07 10:56:16 raspberrypi domoticz[2261]: (Muur Links) Error connecting device - is it up ? (btle error code : 1)
jun 07 10:56:17 raspberrypi domoticz[2261]: (Muur Rechts) Error getting status
jun 07 10:56:17 raspberrypi domoticz[2261]: (Muur Rechts) Error connecting device - is it up ? (btle error code : 1)
jun 07 10:56:17 raspberrypi domoticz[2261]: (Buiten) Error getting status
jun 07 10:56:17 raspberrypi domoticz[2261]: (Buiten) Error connecting device - is it up ? (btle error code : 1)
jun 07 10:56:17 raspberrypi domoticz[2261]: (Hal) Error getting status
jun 07 10:56:17 raspberrypi domoticz[2261]: (Hal) Error connecting device - is it up ? (btle error code : 1)
Posted: Wednesday 07 June 2017 16:42
by zaraki673
ok, thk's
will publish a new version this night
Posted: Thursday 08 June 2017 9:44
by poudenes
Did some test in Domoticz 3.7681 with colotpicker-dev plugin
Removed all hardware of Mipow
updated the plugin
start domoticz, add spot again.
But it doesn’t work.
Did some test in Domoticz 3.7681 with rugby plugin
updated the plugin
does work correct. only see the errors: (Hal) Error connecting device - is it up ? (btle error code : 1)
When i stop domoticz i get this error:
2017-06-08 08:35:45.746 Error: (Hal) 'onStop' failed 'BrokenPipeError'.
2017-06-08 08:35:45.746 Error: (Hal) ----> Line 399 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-08 08:35:45.746 Error: (Hal) ----> Line 165 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function onStop
2017-06-08 08:35:45.746 Error: (Hal) ----> Line 574 in /home/pi/dev-domoticz/plugins/Mipow/plugin.py, function disconnect
2017-06-08 08:35:45.746 Error: (Hal) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-06-08 08:35:45.746 Error: (Hal) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-06-08 08:35:45.956 (Hal) Exiting work loop...
2017-06-08 08:35:45.957 (Hal) Stopped.
Posted: Thursday 08 June 2017 15:21
by zaraki673
oki, this error should be a handles code error (for rgb), for colorpicker i will check again :(
Posted: Friday 09 June 2017 7:51
by poudenes
zaraki673 wrote:oki, this error should be a handles code error (for rgb), for colorpicker i will check again :(
Ok. let me know when you updated it, then i gonna test it :)
Thanks already for the scripting :D
Posted: Monday 12 June 2017 9:34
by poudenes
any news ? :P
Posted: Thursday 31 August 2017 10:13
by poudenes
Are there more people who using the Mipow LED Bulbs ?
Wondering how many people use them. I have almost replace all bulbs with Mipow :D
Posted: Tuesday 19 September 2017 10:28
by poudenes
Hi All,
In latest stable Domoticz v.3.8153 the latest plugin from GitHub v1.0.2 when i add all the bulbs everything work great.
All bulbs are doing what expected. Until when you do a restart of Domoticz. You get several errors sometimes with error lines sometimes not.
The Colorpicker version of v.1.0.2 its working correct. All bulbs start and domoticz won't crash. Only you can't use the colorpicker in Scenes etc. So not the best solution to use at moment.
Segmentation fault
2017-09-09 13:00:18.745  Error: Domoticz received fatal signal 11 while backtracing !...
2017-09-09 13:00:18.746  Error:   /home/pi/domoticz/domoticz() [0x1cdc48]
2017-09-09 13:00:18.747  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-09-09 13:00:18.747  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ab7180]
2017-09-09 15:21:21.439  Error:   /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x38) [0x76a6bf70]
2017-09-09 15:21:21.437  Error: Domoticz received fatal signal 6 !...
2017-09-09 15:21:21.439  Error:   /home/pi/domoticz/domoticz() [0x1cdc48]
2017-09-09 15:21:21.439  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-09-09 15:21:21.439  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76a6d180]
2017-09-10 16:49:19.346  Error:   /home/pi/domoticz/domoticz(_ZN7Plugins7CPlugin5StartEv+0xbb0) [0x497d5c]
2017-09-10 16:49:19.346  Error:   /home/pi/domoticz/domoticz(_ZN7Plugins13StartCallback7ProcessEv+0x14) [0x49ab6c]
2017-09-10 16:49:19.346  Error:   /home/pi/domoticz/domoticz(_ZN7Plugins13CPluginSystem7Do_WorkEv+0x2b4) [0x49bfac]
2017-09-10 16:49:19.346  Error:   /home/pi/domoticz/domoticz() [0x5b6730]
2017-09-12 14:29:12.772  Error: (Raam Links) 'onStop' failed 'BrokenPipeError'.
2017-09-12 14:29:12.772  Error: (Raam Links) ----> Line 394 in /home/pi/domoticz/plugins/mipow-rgb/plugin.py, function onStop
2017-09-12 14:29:12.772  Error: (Raam Links) ----> Line 172 in /home/pi/domoticz/plugins/mipow-rgb/plugin.py, function onStop
2017-09-12 14:29:12.772  Error: (Raam Links) ----> Line 559 in /home/pi/domoticz/plugins/mipow-rgb/plugin.py, function disconnect
2017-09-12 14:29:12.772  Error: (Raam Links) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-09-12 14:29:12.772  Error: (Raam Links) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
2017-09-16 07:46:51.909  Error: (Hal) 'onStop' failed 'BrokenPipeError'.
2017-09-16 07:46:51.909  Error: (Hal) ----> Line 397 in /home/pi/domoticz/plugins/MipowTEST/plugin.py, function onStop
2017-09-16 07:46:51.910  Error: (Hal) ----> Line 175 in /home/pi/domoticz/plugins/MipowTEST/plugin.py, function onStop
2017-09-16 07:46:51.910  Error: (Hal) ----> Line 562 in /home/pi/domoticz/plugins/MipowTEST/plugin.py, function disconnect
2017-09-16 07:46:51.910  Error: (Hal) ----> Line 416 in /usr/lib/python3.4/bluepy/btle.py, function disconnect
2017-09-16 07:46:51.910  Error: (Hal) ----> Line 268 in /usr/lib/python3.4/bluepy/btle.py, function _writeCmd
Posted: Thursday 28 September 2017 19:14
by joostnl
I am trying to use your plugin, only after instalaltion i get this warning in my log:
2017-09-28 19:05:25.366 Error: PluginList: Parsing '/home/pi/domoticz/plugins/Mipow/', 'Error document empty.' at line 0 column 0 in XML ''.
I also cannot connect my playbulb with the BAD app from Mipow tried 2 phones... I can find it with bluetooth on my phone and raspberry..
Can it be I use python 3.5? (i had to change the commands from the wiki to python3.5)
