Python Plugin: Samsung TV
sennheiser
Re: Python Plugin: Samsung TV
Post by sennheiser »
@zak45
I installed python plugin SamsungTV and it's ok but I want to use the Kodi remote but I have this message :
(Samsung TV) Remote command not defined: Select
But I don't know how to defined this commande ?
Thx
zak45
Domoticz version: V2024.4
Post by zak45 »
Wiki need to be updated .... :oops:
Which version you have ?
sennheiser
@zak45
samsungctl-0.6.0.tar.gz
zak45
Post by zak45 »
sennheiser wrote: Friday 08 September 2017 19:18 @zak45
what's your plugin version ?
2017-09-08 20:03:44.935 (Samsung TV Salon) Initialized version 2.0.0, author 'zak45'
Yustmenl
Domoticz version: 3.5997
Post by Yustmenl »
Hello when tying to run
sudo samsungctl -i --host 192.168.X.X --port 8001 --method websocket
I get this as a result
  File "/usr/local/bin/samsungctl", line 11, in <module>
    load_entry_point('samsungctl==0.6.0', 'console_scripts', 'samsungctl')()
  File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 93, in main
    config = _read_config()
  File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 37, in _read_config
    except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not defined
it looks like the plugin is trying to use python 2.7 even though python 3 is installed
I also tryed this https://linuxconfig.org/how-to-change-f ... bian-linux but this didn't turned out to be a sollution.
anyone have any idea what could be the issue?
[edit] somehowe i could install samsungctl again with pip install samsungctl
and the same goes for websocket
also when testing from the commandline it works and i see responce on my TV but the plugin gives the folowing error in the log
2017-09-09 17:34:59.658 Error: (SamsungTV) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/samsungtv/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-09-09 17:34:59.658 Error: (TV Woonkamer) Module Import failed, exception: 'ImportError'
2017-09-09 17:34:59.658 Error: (TV Woonkamer) Module Import failed: ' Name: samsungctl'
[Edit 2] i found the problem, i overlooked one line in the wiki
sudo cp -r /usr/local/lib/python3.4/dist-packages/samsungctl/ /usr/lib/python3.4/
Rasberry Pi 3; Razberry 2.0; RFXCOM
zak45
Post by zak45 »
@Yustmenl
nice that you have been able to help yourself ;-)
sennheiser
@zak45
I don't know what's happen but I create a folder SamsungTV but when I reboot my raspberry this folder is automatically delete !
I'm lost....
EDIT : It's the same with domoticz ... if I add a switch for exemple it's remove if I reboot my raspberry :(
zak45
Post by zak45 »
Looks like your Domoticz re install at each boot !! ??
sennheiser
Looks like my raspberry is in read only mode !
I tried to install the new beta domoticz software... after this installation, it was ok but after the raspberry reboot I was back at the last version of domoticz.
EDIT : I was clone my SD CARD and it's ok with the new SD CARD ! ...
mircer
Post by mircer »
Hello
First, i want to Thank you all for the information you share.
I have a problem and I will be glad if someone can help
when I try to turn off the TV, I getting this error:
2017-09-23 20:47:45.100 Error: (SamsungTV) 'onCommand' failed 'WebSocketBadStatusException'.
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 170 in C:\Program Files (x86)\Domoticz\plugins\SamsungTV\plugin.py, function onCommand
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 287 in C:\Program Files (x86)\Domoticz\plugins\SamsungTV\plugin.py, function SamsungSend
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 10 in C:\Program Files (x86)\Python35-32\Lib\site-packages\samsungctl\remote.py, function __init__
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 23 in C:\Program Files (x86)\Python35-32\Lib\site-packages\samsungctl\remote_websocket.py, function __init__
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 220 in C:\Program Files (x86)\Python35-32\Lib\site-packages\websocket\_core.py, function connect
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 69 in C:\Program Files (x86)\Python35-32\Lib\site-packages\websocket\_handshake.py, function handshake
2017-09-23 20:47:45.101 Error: (SamsungTV) ----> Line 129 in C:\Program Files (x86)\Python35-32\Lib\site-packages\websocket\_handshake.py, function _get_resp_headers
i'm using Python 3.5.2.
I found the problem. now there is no error, but the commands not work (only ON command working)
Last edited by mircer on Saturday 23 September 2017 20:09, edited 1 time in total.
emme
Domoticz version: latest
Post by emme »
Let me just say
OMG! this plugin is AMAZING!!! :D :D
THANK YOU SO MUCH!!!
"We always done this way"
zak45
Post by zak45 »
emme wrote: Saturday 23 September 2017 20:03 Let me just say
Happy you like it ;-)
felix63
Domoticz version: 2020.1
Post by felix63 »
mircer wrote: Saturday 23 September 2017 19:55 I found the problem. now there is no error, but the commands not work (only ON command working)
I use the following script to turn off the tv
samsungctl --method websocket --host 192.168.x.x --port 8001 -v KEY_POWER
Depending on your version of TV you might need to change the method parameter and the port.
mircer
Post by mircer »
Hello felix63,
I try:
C:\WINDOWS\system32>samsungctl --method websocket --host 192.168.1.189 --port 8001 -v KEY_POWER
Sending control command: KEY_POWER
But nothing happens.
I have 2017 model, 75mu7000
someone know what i'm doing wrong ?
Thanks for the help
felix63
Post by felix63 »
Sorry... difficult to answer that question. I am running on linux not windows. And without any other than 'nothing happens' it's difficult to debug. Can't help you out.
emme
Post by emme »
mircer wrote: Tuesday 26 September 2017 23:49 Hello felix63,
I try:
Thanks for the help
Are you trying to switch it on or off? is that the only one button that does not work?
some models does not support wake up on lan, especially if you have it WiFi connected (the interface is down while tv is off)
If you're trying to switch it off... ensure the remote connection is enabled and the plugin is paired with the device
ciao
M
gijsje
Domoticz version: Stable
Post by gijsje »
i think it is seeing the tv
2017-10-16 20:30:54.511 (Samsung TV) Calling message handler 'onHeartbeat'.
2017-10-16 20:30:54.512 (Samsung TV) isAlive status :True
When i want to change something i get
2017-10-16 20:28:07.724 Error: (Samsung TV) 'onCommand' failed 'ImportError'.
2017-10-16 20:28:07.724 Error: (Samsung TV) ----> Line 170 in /home/pi/domoticz/plugins/samsungctl/plugin.py, function onCommand
2017-10-16 20:28:07.724 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/samsungctl/plugin.py, function SamsungSend
2017-10-16 20:28:07.724 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__
2017-10-16 20:28:07.724 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__
Any idea?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
zak45
Post by zak45 »
Looks like you do not have copied in the folder that can be found by the plugin system. Please take a look at the wiki.
gijsje
Post by gijsje »
i do have the plugin.py in the folder plugins/samsungctl did try also to change the folder to SamsungTV and Samsung TV without suc6
also checked if /usr/lib/python3.5/samsungctl/remote.py and /usr/lib/python3.5/samsungctl/remote_websocket.py are there and they are
If i restart domoticz i do get
2017-10-16 23:44:03.107 Error: (Samsung TV) 'onStart' failed 'ImportError'.
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 134 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onStart
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__
2017-10-16 23:44:03.107 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__
if i try button mute i get
017-10-16 23:47:51.587 User: Admin initiated a switch command (117/Samsung TV - Volume/Set Level)
2017-10-16 23:47:51.619 (Samsung TV) Calling message handler 'onCommand'.
2017-10-16 23:47:51.619 (Samsung TV) onCommand called for Unit 3: Parameter 'Off', Level: 0, Connected: True
2017-10-16 23:47:51.621 Error: (Samsung TV) 'onCommand' failed 'ImportError'.
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 182 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function onCommand
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 287 in /home/pi/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 10 in /usr/lib/python3.5/samsungctl/remote.py, function __init__
2017-10-16 23:47:51.621 Error: (Samsung TV) ----> Line 13 in /usr/lib/python3.5/samsungctl/remote_websocket.py, function __init__
I do have a K series tv so maybe it does not work ue49ks7000s
if i do samsungctl --host 192.168.0.112 --method websocket KEY_VOLUP that is working also samsungctl --host 192.168.0.112 --method websocket KEY_MUTE
dextm80
Domoticz version: 4.10159
Post by dextm80 »
Hi guys, a guide for linux installation (ubuntu) and domoticz?
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
