NUT Mini BATTERY SERVICE
Re: NUT Mini BATTERY SERVICE
https://yadi.sk/i/G_ZX4_7_TVBXEg
- emme
- Domoticz version: latest
you do need to install the noBle node:
Settings/Manage Palettes/Install
then search for node-red-contrib-noble
and install it
and install it
"We always done this way"
Welcome to Node-RED
21 Jan 11:16:42 - [info] Node-RED version: v0.19.5
21 Jan 11:16:42 - [info] Node.js version: v10.15.0
21 Jan 11:16:42 - [info] Linux 4.14.92-v7+ arm LE
21 Jan 11:16:43 - [info] Loading palette nodes
21 Jan 11:16:49 - [warn] ------------------------------------------------------
21 Jan 11:16:49 - [warn] [node-red-contrib-noble/noble] Error: Cannot find module 'bluetooth-hci-socket'
21 Jan 11:16:49 - [info] Settings file : /root/.node-red/settings.js
21 Jan 11:16:49 - [info] Context store : 'default' [module=memory]
21 Jan 11:16:49 - [info] User directory : /root/.node-red
21 Jan 11:16:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
21 Jan 11:16:49 - [info] Flows file : /root/.node-red/flows_raspberrypi.json
- emme
try with
sudo npm install bluetooth-hci-socket
sudo reboot
and the reinstall noble node
sudo reboot
Переустановил Node-Red заново. все заработало. СПАСИБО
- Domoticz version: 2020.1
Please write in english !
Emme do you have a simple lua script that sends a notification when battery (user variable) goes < 10 ?
I'm trying to write it with no success...
I had the idea to send a notification when <10 and another one when <5
For both of us (2 tags in the house) in one single script. Is this possible or do I need to write a script for each person ?
- emme
mmh you can do that.... I had it once, but then I delete it
as soon as both thatteries has the same unique prefix (like BattNut_) you can have a script that checks every day and send a message
but I would also suggest you NOT to claim battery as it drawn it quickly
..at least create a device for battery and add a notification on it...
Too bad you deleted it. I've spend last evening trying to make it work with no luck...
If I do a battery check one time a week will it drain the battery quickly ?
- emme
what did'n work?... the battery check or the notification script?
if you provide me the device names I can write it back in few hours
Here is the script I tried to make but it was only for testing purposes and only for one device. We have in fact 2 nuts : one with user variable batterie_pim and the other one with user variable batterie_ben
It doesn't work so don't use it...
If you can make it working with both tags.... Thx
if (uservariables_lastupdate['batterie_pim']) then
if (uservariables['batterie_pim']>"5") and (uservariables['batterie_pim']<"12") then
commandArray['SendNotification']='Le niveau de la batterie du tag de pim est faible '
elseif (uservariables['batterie_pim']<="5") then
commandArray['SendNotification']='Le niveau de la batterie du tag de pim est extrêmement bas ! Il faut changer la batterie'
- emme
I'm more familiar with dzVents:
this should works for any variable whose name start with 'batterie_'
ciao
M
local lowTrigger = 5
local highTrigger = 12
variables = { 'batterie_*' },
logging = {
level = domoticz.LOG_FORCE,
marker = '[BLE Battery Service]'
execute = function(dz, devVar)
local actValue = tonumber(devVar.value)
if actValue > lowTrigger and actValue < highTrigger then
dz.notify('Battery Service','Le niveau de la batterie du tag de pim '..devVar.name..' est faible ')
elseif actValue <= lowTrigger then
dz.notify('Battery Service','Le niveau de la batterie du tag de pim '..devVar.name..' est extrêmement bas ! Il faut changer la batterie')
ciao
M
Grazie mille
It works like a charm. I wish I would have to knowledge to write such scripts.
Where could I start ? Better to learn lua or dzVents ? Is there a tutorial somewhere ?
- emme
I did not even know LUA!!!
I took 3 month to understand LUA for domoticz related issues.... you you would not take longer
at the end thay are just if.. then.. else... end statements...
start with this script and "unpack" it to understand what it is doing....
then I create a pushbutton named TEST that trigger a script for... well.. test purpose
dzVents is LUA program language in a json string... so it has few statements to well understand but after that it is quite easy!
Danny made a great work even on the tutorial!!!
https://yadi.sk/i/9Jt1hhnhuo-01g Yesterday everything worked. Today booted and everything again ......
