Page 3 of 8
Re: Python plugin: Kodi
Posted: Monday 05 June 2017 14:07
by G3rard
capman wrote:Domoticz version beta 3.7468 with python from Jadahl on synology. Plugin version 1.7.1
Get some errors in the log
The plugin 1.7.1 is for the latest Domoticz beta versions, you have an older version (I actually have the same version).
So you need the 1.6.0 version of the plugin.
Posted: Monday 05 June 2017 16:05
by capman
G3rard wrote:capman wrote:Domoticz version beta 3.7468 with python from Jadahl on synology. Plugin version 1.7.1
Rollback 2 version 1.6.0. It's working now. I don't won't to update my previous version of domoticz because there are some issues with
the plugins. So a wait until ...
Thanks 4 helping
Posted: Thursday 08 June 2017 8:00
by Luuc_a
With the latest beta (3.7686) the Kodi plugin doesn't work anymore.
Version 1.7.1 will crash domoticz and version 1.6.0 result in the folowing error
OnStart:
2017-06-08 07:57:11.198 Error: (Kodi Woonkamer) 'onStart' failed 'AttributeError':''module' object has no attribute 'Transport''.
2017-06-08 07:57:11.198 Error: (Kodi Woonkamer) ----> Line 528 in /home/pi/domoticz/plugins/Kodi/plugin.py, function onStart
2017-06-08 07:57:11.198 Error: (Kodi Woonkamer) ----> Line 96 in /home/pi/domoticz/plugins/Kodi/plugin.py, function onStart
OnHeartbeat:
2017-06-08 07:57:40.746 Error: (Kodi Woonkamer) 'onHeartbeat' failed 'AttributeError':''module' object has no attribute 'Connect''.
2017-06-08 07:57:40.746 Error: (Kodi Woonkamer) ----> Line 556 in /home/pi/domoticz/plugins/Kodi/plugin.py, function onHeartbeat
2017-06-08 07:57:40.746 Error: (Kodi Woonkamer) ----> Line 446 in /home/pi/domoticz/plugins/Kodi/plugin.py, function onHeartbeat
Is there a solution for this?
Posted: Thursday 08 June 2017 16:04
by Dnpwwo
@Luuc_a,
I'm not sure.
It would be more useful if you posted the log for version 1.7.1 (preferably with debug enabled for the plugin) rather than the version that we know doesn't work with the new beta, also the operating system you are running.
Posted: Thursday 08 June 2017 17:04
by Luuc_a
Dnpwwo wrote:@Luuc_a,
I'm not sure.
Well. That would be a problem. I don't have the log for version 1.7.1 because domoticz is not reachable with this version.
The web interface says that it is offline. Is there another method to get the log?
I use Domoticz on a raspberry pi3.
Posted: Thursday 08 June 2017 23:57
by Dnpwwo
@Luuc_a,
Yes. If you go onto the Pi into the domoticz directory you can run it using somthing like
then you will see the output
Posted: Monday 12 June 2017 9:54
by Luuc_a
Thanks. I get different errors when I try this. But also found the solution.
It was a permission error.
The solution
sudo chmod 755 domotiz/plugins/kodi/plugin.py
Posted: Saturday 05 August 2017 11:25
by jake
jake wrote:@Dnpwwo, do you think you will be able to complete the feature request to add another Kodi state (besides on/off/video/audio): something like sleep, by detecting when the screensaver is active?
@Dnpwwo: I did some research if my original request to get a Kodi 'idle' or 'sleep' state in Domotizc. Would it be possible to integrate the OnScreenSaverActivated functionality in your plugin? In this forum someone tries to use OnScreenSaverActivated, but gets into trouble because Kodi dims the screen while playing audio:
https://www.google.nl/url?sa=t&source=w ... l2r-jEMtAQ
UPDATE: I found the plugin for Kodi "Kodi Callbacks" and their I could use an http command to enable/disable a new virtual switch in Domoticz at the Kodi state of 'OnIdle' and 'onResumeAfterIdle'
However, the 'idle' state in Domoticz directly, would be preferred, of course
Posted: Sunday 06 August 2017 23:55
by Brutus
After upgrading to Domoticz version V3.8235 on Windows i'm getting these errors using plugin version 1.7.1:
2017-08-06 23:53:51.387 Error: (Kodi Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
2017-08-06 23:55:41.394 Error: (Kodi Woonkamer) 'onHeartbeat' failed 'AttributeError':'module 'Domoticz' has no attribute 'Disconnect''.
2017-08-06 23:55:41.394 Error: (Kodi Woonkamer) ----> Line 546 in C:\Program Files (x86)\Domoticz\plugins\Kodi\plugin.py, function onHeartbeat
2017-08-06 23:55:41.394 Error: (Kodi Woonkamer) ----> Line 423 in C:\Program Files (x86)\Domoticz\plugins\Kodi\plugin.py, function onHeartbeat
Posted: Monday 07 August 2017 12:05
by Dnpwwo
@Brutus,
There was a breaking change to the Python Framework at the start of the month.
Good news for you is that there is a a Kodi v1.8.0 plugin in the 'examples' folder that should work with the new API.
Let me know if it doesn't.
Posted: Monday 07 August 2017 12:11
by Brutus
Dnpwwo wrote:@Brutus,
And were can I find this "Examples" Folder? The only folder I can find is in the dzvents folder.
Posted: Monday 07 August 2017 12:15
by Dnpwwo
Posted: Monday 07 August 2017 12:17
by Brutus
Thank you that folder did not exist on my Windows Installation.
Posted: Monday 07 August 2017 12:37
by Brutus
@Dnpwwo,
Maybe its me but in the examples folder there is one file named: Kodi.py
The "Old" Kodi plugin 1.7.1 has multiple files but no Kodi.py
So I can't replace it. How to update to version 1.8.0?
Posted: Monday 07 August 2017 13:26
by Dnpwwo
@Brutus,
Just rename it plugin.py and drop it in your existing Kodi folder. In the Domoticz Hardware page select your Kodi and hit update to reload it.
Posted: Monday 07 August 2017 19:16
by jake
jake wrote:jake wrote:@Dnpwwo, do you think you will be able to complete the feature request to add another Kodi state (besides on/off/video/audio): something like sleep, by detecting when the screensaver is active?
I figured it out how to get the
http://kodi.wiki/view/Add-on:Kodi_Callbacks working within Kodi:
-Install the add-on via de built in add-on manager in Kodi
-In the configuration of the add-on
-- create a task: http, url = domoticz url:8080/json.htm and as type: GET
-- create an event on the activity 'OnIdle' with 'Task 1' and the custom text the JSON command parameters as described in the
https://www.domoticz.com/wiki/Domoticz_ ... JSON wiki, starting with the ?type=command¶m=switchlight&idx=99&switchcmd=On (idx=99: change to your virtual switch idx that is used to define if Kodi is idle)
--repeat the event 2 but choosing the on ResumeAfterIdle instead and the same task 1
The event delay in seconds starts counting from the first second that Kodi is Idle, not as I expected 'after the screensaver kicks in, but right then when audio or video stops and no UI is used
@Dnpwwo:
I realize that I use the onIdle from within Kodi and use the time delay also from within that add-on. From just the Domoticz side it might be more difficult to create a timer within Domoticz, the idle time variable should be defined in the 'hardware' section of Domoticz, I guess.
Another practical approach could be: combine the OnScreenSaverActivated information with the current 'On' state in the Domoticz plugin. I assume that would also give a reliable 'idle' state, since 'On' is only displayed when no audio/video is playing. The screensaver also only kicks in when there is no UI interaction.
Posted: Wednesday 23 August 2017 17:26
by zak45
have installed Kodi 1.8.0, got this error every 10 seconds:
2017-08-23 17:24:16.857 (kodi) Initialized version 1.8.0, author 'dnpwwo'
2017-08-23 17:24:16.858 PluginSystem: Starting I/O service thread.
2017-08-23 17:24:16.909 (kodi) Connected successfully to: 192.168.1.12:9090
2017-08-23 17:24:16.959 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-23 17:24:16.960 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-23 17:24:20.326 (RFX433E) Temp + Humidity (433-TempSalon)
2017-08-23 17:24:26.373 (AeonStick) Lux (Z-Lux Dressing)
2017-08-23 17:24:26.427 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-23 17:24:26.512 (AeonStick) Temp (Z-Temperature Dressing)
2017-08-23 17:24:30.619 (RFX433E) Temp + Humidity (433-TempExt)
2017-08-23 17:24:36.442 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-23 17:24:43.098 (RM2 Salon) Calling message handler 'onHeartbeat'.
2017-08-23 17:24:46.454 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-23 17:24:48.668 (RFX433E) Energy (Compteur EDF)
2017-08-23 17:24:48.920 (RFX433E) Temp + Humidity (433-TempSDBE)
Posted: Thursday 24 August 2017 23:22
by zak45
Have put Debug on, should help....
2017-08-24 23:20:26.311 (kodi) 7b 22 6a 73 6f 6e 72 70 63 22 3a 22 32 2e 30 22 2c 22 6d 65 {"jsonrpc":"2.0","me
2017-08-24 23:20:26.312 (kodi) 74 68 6f 64 22 3a 22 50 6c 61 79 65 72 2e 47 65 74 41 63 74 thod":"Player.GetAct
2017-08-24 23:20:26.312 (kodi) 69 76 65 50 6c 61 79 65 72 73 22 2c 22 69 64 22 3a 31 30 30 ivePlayers","id":100
2017-08-24 23:20:26.312 (kodi) 31 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 1}
2017-08-24 23:20:26.362 (kodi) Received 39 bytes of data:.
2017-08-24 23:20:26.362 (kodi) 7b 22 69 64 22 3a 31 30 30 31 2c 22 6a 73 6f 6e 72 70 63 22 {"id":1001,"jsonrpc"
2017-08-24 23:20:26.362 (kodi) 3a 22 32 2e 30 22 2c 22 72 65 73 75 6c 74 22 3a 5b 5d 7d .. :"2.0","result":[]}
2017-08-24 23:20:26.363 (kodi) Calling message handler 'onMessage'.
2017-08-24 23:20:26.363 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-24 23:20:27.869 (RFX433E) Temp + Humidity (433-TempExt)
2017-08-24 23:20:29.372 (Orange) Calling message handler 'onHeartbeat'.
2017-08-24 23:20:33.378 (RM2 Salon) Calling message handler 'onHeartbeat'.
2017-08-24 23:20:36.335 (kodi) Calling message handler 'onHeartbeat'.
2017-08-24 23:20:36.335 (kodi) Sending 62 bytes of data:.
2017-08-24 23:20:36.335 (kodi) 7b 22 6a 73 6f 6e 72 70 63 22 3a 22 32 2e 30 22 2c 22 6d 65 {"jsonrpc":"2.0","me
2017-08-24 23:20:36.336 (kodi) 74 68 6f 64 22 3a 22 50 6c 61 79 65 72 2e 47 65 74 41 63 74 thod":"Player.GetAct
2017-08-24 23:20:36.336 (kodi) 69 76 65 50 6c 61 79 65 72 73 22 2c 22 69 64 22 3a 31 30 30 ivePlayers","id":100
2017-08-24 23:20:36.336 (kodi) 31 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 1}
2017-08-24 23:20:36.387 (kodi) Received 39 bytes of data:.
2017-08-24 23:20:36.387 (kodi) 7b 22 69 64 22 3a 31 30 30 31 2c 22 6a 73 6f 6e 72 70 63 22 {"id":1001,"jsonrpc"
2017-08-24 23:20:36.387 (kodi) 3a 22 32 2e 30 22 2c 22 72 65 73 75 6c 74 22 3a 5b 5d 7d .. :"2.0","result":[]}
2017-08-24 23:20:36.387 (kodi) Calling message handler 'onMessage'.
2017-08-24 23:20:36.387 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2017-08-24 23:20:44.338 (RFX433E) Temp + Humidity (433-TempSDBE)
2017-08-24 23:20:46.355 (kodi) Calling message handler 'onHeartbeat'.
2017-08-24 23:20:46.355 (kodi) Sending 62 bytes of data:.
2017-08-24 23:20:46.355 (kodi) 7b 22 6a 73 6f 6e 72 70 63 22 3a 22 32 2e 30 22 2c 22 6d 65 {"jsonrpc":"2.0","me
2017-08-24 23:20:46.356 (kodi) 74 68 6f 64 22 3a 22 50 6c 61 79 65 72 2e 47 65 74 41 63 74 thod":"Player.GetAct
2017-08-24 23:20:46.356 (kodi) 69 76 65 50 6c 61 79 65 72 73 22 2c 22 69 64 22 3a 31 30 30 ivePlayers","id":100
2017-08-24 23:20:46.356 (kodi) 31 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 1}
2017-08-24 23:20:46.406 (kodi) Received 39 bytes of data:.
2017-08-24 23:20:46.406 (kodi) 7b 22 69 64 22 3a 31 30 30 31 2c 22 6a 73 6f 6e 72 70 63 22 {"id":1001,"jsonrpc"
2017-08-24 23:20:46.406 (kodi) 3a 22 32 2e 30 22 2c 22 72 65 73 75 6c 74 22 3a 5b 5d 7d .. :"2.0","result":[]}
2017-08-24 23:20:46.407 (kodi) Calling message handler 'onMessage'.
2017-08-24 23:20:46.407 Error: (kodi) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
Posted: Friday 25 August 2017 4:00
by Dnpwwo
@zak45,
There was a plugin API change a few weeks ago and you appear to be attempting to run the new Kodi API against the previous Domoticz version (hence the parameter mismatch).
You need to upgrade Domoticz (if you are running the beta) or downgrade the Kodi plugin.
Posted: Friday 25 August 2017 13:17
by zak45
thanks lot @Dnpwwo
just to summarize: need Kodi v 1.7.1 with last stable Domoticz v 3.8153
