I am running on the latest beta for a while now and it seems it is working without issues (knock on wood). Or at least, it continues wordking already for I would guess at least 2 weeks. Really, really glad indeed.
The only issue I could have noticed (i didn't drill down my logs enough to be certain), is switching my Evohome status (e.g. from Away to Home) by a json command, and it being switched back again (perhaps it didnt arrive well enough and the controller told Domoticz again it was Away, which it shouldnt). Anyway, I realise explaining this situation is hard enough to be logical, ony if I am certain I still do have a small issue, I would report here again. For now, I am enjoying the possibility to control my Evohome by my Domoticz setup.
Evohome controlling
MikeyMan
Re: Evohome controlling
Any updates on this?
Been trying to add Evohome to my Domoticz. This seems to work okay.
Temp reads out and graph also works.
But i cannot set anything on the dashboard. On the temp page it does work though.
When i try to access the settings through Dashticz i only get the temp readouts.
DanD
@MikeyMan
Which type of Evohome Hardware device have you set-up in Domoticz (Web script/Web API/Serial device)? Are you running the latest beta or another version? If you can give me a little more info, I'll see if I can help troubleshoot the problem.
Regards,
Dan
Regards,
Dan
Windows 7, Raspberry Pi3, Honeywell Evohome Wifi, HGI80 + RFBee(s)
MikeyMan
@DanDDanD wrote: Saturday 20 October 2018 20:15 @MikeyMan
Regards,
Dan
I have an evohome WiFi system with the touch controller set up as thermostat for the living room. Will be expanding in the future to 9 more zones.
I am running the latest stable of the domoticz software at the moment, with the API.
DanD
@MikeyMan
Thanks for the additional information, I think I now understand your set-up and problem. As well as a zone sensor on the Temperature tab which allows setpoint control and graphing, you should also see an EvoTouch device on the switches tab which provides the usual quick actions. These devices can be added to your dashboard by clicking on the star on each device within the Temperature/Switches tabs. However, the only controls available via the dashboard for Evohome devices are the quick actions on the EvoTouch device.
Does this help at all?
Dan
Dan
MikeyMan
Thanks Dan, does help.DanD wrote: Tuesday 23 October 2018 15:24 @MikeyMan
Dan
Seems all is working as it should.
I just expected a way to set a specific temperature. Not easily possible i guess.
Should i be able to change the quick actions or temperature on the floorplan?
The evohome touch doesn't show up on the dash when i use the star though...
DanD
@MikeyMan,
You have to make the temperature settings using the SET buttons on each temperature device on the Temperature page and this also allows you to either set a permanent override or an end date/time. I'll take a look at why the Evohome controller isn't appearing on the dashboard as I'm seeing the same behaviour today on my test system.
Dan
Dan
