dzVents 1.0 released
dannybloe
Re: dzVents 1.0 released
Peepz, please use the tracker on GitHub for bugs/problems/errors. That way I can better keep tracker of things.
dhanjel
- Domoticz version: 3.5146
Seriously, this should be merged with the main code and be the main engine for lua scripts.
So much simpler to work with in every way possible.
I am trying to get a notification sent when my dishwasher is done (consumption stays around 3.3w for a couple of minutes),
but it seems to through some errors.
Any ideas?
2016-06-06 14:25:19.037 Error: EventSystem: in Dishwasher_Monitor: [string "commandArray = {}..."]:6: bad argument #1 to 'pairs' (table expected, got nil)Code: Select all
active = false,
['timer'] = 'every minute'
data = {
readingHistory = {
history = true,
maxItems = 3
notificationSent = {
initial = false
execute = function(domoticz, switch, triggerInfo)
local consumption = domoticz.devices['Kök, Diskmaskin'].WActual
domoticz.data.readingHistory.add(consumption)
local average = domoticz.data.readingHistory.avg()
if (average == 3.3 and not domoticz.data.notificationSent)
then
domoticz.data.notificationSent = true
domoticz.notify('Diskmaskinen klar!',
'Diskmaskinen har precis kört klart aktuellt program.',
domoticz.PRIORITY_LOW)
elseif (average > 100)
then
domoticz.data.notificationSent = false
dannybloe
Working on itdhanjel wrote:Seriously, this should be merged with the main code and be the main engine for lua scripts.
In the same log there should be a list of all the command array items that dzVents prepares and sends back to Domoticz. Can you post that list?dhanjel wrote: I am trying to get a notification sent when my dishwasher is done (consumption stays around 3.3w for a couple of minutes),
Any ideas?Code: Select all
return { active = false, on = { ['timer'] = 'every minute' }, data = { readingHistory = { history = true, maxItems = 3 }, notificationSent = { initial = false } }, execute = function(domoticz, switch, triggerInfo) local consumption = domoticz.devices['Kök, Diskmaskin'].WActual domoticz.data.readingHistory.add(consumption) local average = domoticz.data.readingHistory.avg() if (average == 3.3 and not domoticz.data.notificationSent) then domoticz.data.notificationSent = true domoticz.notify('Diskmaskinen klar!', 'Diskmaskinen har precis kört klart aktuellt program.', domoticz.PRIORITY_LOW) elseif (average > 100) then domoticz.data.notificationSent = false end end }
HenFre
- Domoticz version: 3.8771
Excuse a beginner, but is this included when I started from BETA ver. 3.5187 och does I always have to install it separately?
Domoticz on Raspberry PI 3 since 2016.
dannybloe
For now you have to install it separately (which means copying some files over to the right location and renaming the settings file). See the README.md.
dhanjel
Thats all I got.
I do have a single entry of this as well,
2016-06-06 15:02:51.720 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection_manager::start
dannybloe
That line is not related to dzVents.dhanjel wrote:Thats all I got.
But what if you don't send the notification but do a print statement instead?
I get the feeling that there's some other script that is causing problems. Do you have other scripts in the ../scripts/lua folder besides script_device_main.lua?
dhanjel
Nope, this is my only script. Will debug a bit more later.
Sent from my Nexus 6P using Tapatalk
Atmosphere
Hi Danny, It's still happening...dannybloe wrote:
Did you find anything yet?
2016-06-06 03:40:03.465 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 05:25:02.595 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 10:55:03.267 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 14:35:03.204 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 17:25:03.270 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value) -
dannybloe
Well, u gotta do some debugging then
. Maybe turning on debug logging in the settings gives some clues.
dhanjel
One step in the right direction. It seemed I had to many parameters to the execute-function.
Next bump in the road, it seems that the power consumption always is null.
HTTP Fetch is configured
active = true,
data = {
execute = function(domoticz)
if (consumption == nill)
then
domoticz.log("Consumption could not be read.", domoticz.LOG_INFO)
domoticz.log("Current consumption: " .. consumption, domoticz.LOG_INFO)
then
--domoticz.notify('Diskmaskinen klar!',
-- 'Diskmaskinen har precis kört klart aktuellt program.',
-- domoticz.PRIORITY_LOW)
domoticz.log("Dishwasher done", domoticz.LOG_INFO)
then
}Code: Select all
2016-06-07 07:52:00.441 LUA: =====================================================
2016-06-07 07:52:00.441 LUA: >>> Handler: dishwasher
2016-06-07 07:52:00.441 LUA: .....................................................
2016-06-07 07:52:00.441 LUA: Consumption could not be read.
2016-06-07 07:52:00.441 LUA: <<< Done
2016-06-07 07:52:00.441 LUA: -----------------------------------------------------
dannybloe
Ok, the best step next is to look into the file devices.lua. First of all, that file should exist and be recent (not older than the fetch interval as set in the setttings file). If that is the case you can open the file and find the Kök device and see if it has the proper wattage listed. Also check that the name is exactly the same as you use in your code. (Can you post the piece for your device here?)dhanjel wrote:One step in the right direction. It seemed I had to many parameters to the execute-function.
Next bump in the road, it seems that the power consumption always is null.Code: Select all
return { active = true, on = { ['timer'] = 'every minute' }, data = { readingHistory = { history = true, maxItems = 3 }, notificationSent = { initial = false } }, execute = function(domoticz) local consumption = domoticz.devices['Kök, Diskmaskin'].WActual if (consumption == nill) then domoticz.log("Consumption could not be read.", domoticz.LOG_INFO) else domoticz.data.readingHistory.add(consumption) domoticz.log("Current consumption: " .. consumption, domoticz.LOG_INFO) local average = domoticz.data.readingHistory.avg() if (average == 3.3 and not domoticz.data.notificationSent) then domoticz.data.notificationSent = true --domoticz.notify('Diskmaskinen klar!', -- 'Diskmaskinen har precis kört klart aktuellt program.', -- domoticz.PRIORITY_LOW) domoticz.log("Dishwasher done", domoticz.LOG_INFO) elseif (average > 100) then domoticz.data.notificationSent = false end end end }Code: Select all
2016-06-07 07:52:00.441 LUA: ===================================================== 2016-06-07 07:52:00.441 LUA: >>> Handler: dishwasher 2016-06-07 07:52:00.441 LUA: ..................................................... 2016-06-07 07:52:00.441 LUA: Consumption could not be read. 2016-06-07 07:52:00.441 LUA: ..................................................... 2016-06-07 07:52:00.441 LUA: <<< Done 2016-06-07 07:52:00.441 LUA: -----------------------------------------------------
Another thing you can do is dump the device state to the logs: domoticz.logDevice(domoticz.devices). It should show all the attributes on the device (although Domoticz has the tendency to swallow some log messages if they come too fast and too many in a row).
I'm just looking at the code that sets the WActual value:
if (device.deviceType == 'General' and device.deviceSubType == 'kWh') then
device.addAttribute('WhTotal', tonumber(device.rawData[2]))
device.addAttribute('WActual', tonumber(device.rawData[1]))
local todayFormatted = httpDevice.CounterToday or ''
-- risky business, we assume no decimals, just thousands separators
-- there is no raw value available for today
local s = string.gsub(todayFormatted, '%.', '')
s = string.gsub(s, '%,', '')
s = string.gsub(s, ' kWh', '')
device.addAttribute('WhToday', tonumber(s))
In the mean time you can also look at the rawData attribute of the device in your case. It is likely that it holds the actual usage as well.
So, plenty of starting points to investigate this. I'm sure we can nail this bugger
dhanjel
I don´t see a deviceType, only subType.
It is a Fibaro Wall Plug.
(Tried to change the name since I have many with the same name since consumptions are separate devices in Domoticz compared to for instance Fibaro)
If I do
I only get
Perhaps I managed so install someting incorrectly.
I don´t have any device in the devices.lua file with property WActual
["AddjMulti"]= 1.0,
["AddjMulti2"]= 1.0,
["AddjValue"]= 0.0,
["AddjValue2"]= 0.0,
["BatteryLevel"]= 255,
["CustomImage"]= 0,
["Data"]= "3.4 Watt",
["Description"]= "",
["Favorite"]= 0,
["HardwareID"]= 2,
["HardwareName"]= "Z-Wave",
["HardwareType"]= "OpenZWave USB",
["HardwareTypeVal"]= 21,
["HaveTimeout"]= true,
["ID"]= "0001901",
["LastUpdate"]= "2016-06-07 07:40:22",
["Name"]= "Kök, Diskmaskin Förbrukning",
["Notifications"]= "false",
["PlanID"]= "0",
["PlanIDs"]= { 0 },
["Protected"]= false,
["ShowNotifications"]= true,
["SignalLevel"]= "-",
["SubType"]= "Electric",
["Timers"]= "false",
["Type"]= "Usage",
["TypeImg"]= "current",
["Unit"]= 2,
["Used"]= 1,
["XOffset"]= "0",
["YOffset"]= "0",
["idx"]= "97"
If I do
2016-06-07 09:03:00.261 LUA: =====================================================
2016-06-07 09:03:00.261 LUA: >>> Handler: dishwasher
2016-06-07 09:03:00.261 LUA: .....................................................
2016-06-07 09:03:00.261 LUA: ----------------------------
2016-06-07 09:03:00.261 LUA: An error occured when calling event handler dishwasher
2016-06-07 09:03:00.261 LUA: /home/daniel/domoticz/scripts/lua/dzVents/Domoticz.lua:269: attempt to concatenate field 'name' (a nil value)
2016-06-07 09:03:00.261 LUA: <<< Done
2016-06-07 09:03:00.261 LUA: -----------------------------------------------------
dannybloe
Well, I found an omission in my code and indeed it didn't recognize Usage devices and their WActual information. I just release 1.0.2 that should fix this. Please check it out.
1.0.2:
1.0.2:
- Added device description attribute.
- Added support for setting the setpoint for opentherm gateway.
- Added timedOut boolean attribute to devices. Requires http data fetching to be anabled.
- Properly detects usage devices and their Wattage.
dhanjel
Sweet, that part seems to work fine now.
Just need to wait until I can run the dishwasher again to test
2016-06-07 09:38:00.233 LUA: =====================================================
2016-06-07 09:38:00.233 LUA: >>> Handler: dishwasher
2016-06-07 09:38:00.233 LUA: .....................................................
2016-06-07 09:38:00.233 LUA: Current consumption: 3.4
2016-06-07 09:38:00.233 LUA: <<< Done
2016-06-07 09:38:00.233 LUA: -----------------------------------------------------
dannybloe
3.4 Watt when it's not running? I'd get a new onedhanjel wrote:Sweet, that part seems to work fine now.Just need to wait until I can run the dishwasher again to testCode: Select all
2016-06-07 09:38:00.233 LUA: ===================================================== 2016-06-07 09:38:00.233 LUA: >>> Handler: dishwasher 2016-06-07 09:38:00.233 LUA: ..................................................... 2016-06-07 09:38:00.233 LUA: Current consumption: 3.4 2016-06-07 09:38:00.233 LUA: ..................................................... 2016-06-07 09:38:00.233 LUA: <<< Done 2016-06-07 09:38:00.233 LUA: -----------------------------------------------------
dhanjel
Its when it's idle. When it is powered off it is near 0. (It has a display that is on)
dhanjel
is it possible to retrieve a device by id instead of name? I have a lot of devices with the same name
dannybloe
Of course you can do it by id: domoticz.devices[123]. However, I strongly advise against having devices with the same name as dzVents has no way of keeping them apart in an easy way because Domoticz sends the stuff name-based. I'd rename the devices to make them unique.
jkimmel
- Domoticz version: 2021.1
Because there s no other place where scripts can showed, here my contribution based on the help of @dannybloe.
It is about heating control:
1. control heat circuits by setpoints:2. control heatpump:
I'm sure dannybloe will have a look at this and will comment if there is a need.
active = true,
['timer'] = 'every 10 minutes',
local function regulate(setpoint, temperature, boiler)
if (temperature < setpoint) and (boiler.state == 'Off') then boiler.switchOn()
if (boiler.state == 'On') then boiler.switchOff()
local spSalon = tonumber(domoticz.devices['Setpoint Salon'].state)
local tSalon = domoticz.devices['Salon'].temperature
local bSalon = domoticz.devices['FB 21 Heizkreis Salon']
local spBath = tonumber(domoticz.devices['Setpoint Bad'].state)
local tBath = domoticz.devices['Bad'].temperature
local bBath = domoticz.devices['FB 42 Heizkreis Bad']
local spBuero = tonumber(domoticz.devices['Setpoint Buero'].state)
local tBuero = domoticz.devices['Buero'].temperature
local bBuero = domoticz.devices['FB 23 Heizkreis Buero']
local spSchlafzimmer = tonumber(domoticz.devices['Setpoint Schlafzimmer'].state)
local tSchlafzimmer = domoticz.devices['Schlafzimmer'].temperature
local bSchlafzimmer = domoticz.devices['FB 32 Heizkreis Schlafzimmer']
local spGaestebad = tonumber(domoticz.devices['Setpoint Gaestebad'].state)
local tGaestebad = domoticz.devices['Gaestebad'].temperature
local bGaestebad = domoticz.devices['FB 41 Heizkreis Gaestebad']
regulate(spSalon, tSalon, bSalon)
regulate(spBath, tBath, bBath)
regulate(spBuero, tBuero, bBuero)
regulate(spSchlafzimmer, tSchlafzimmer, bSchlafzimmer)
regulate(spGaestebad, tGaestebad, bGaestebad)
active = true,
local Wp = domoticz.devices['FB 33 Wärmepumpe']
if (bSalon == 'On') or (bBath == 'On') or (bBuero == 'On') or (bSchlafzimmer == 'On') or (bGaestebad == 'On') and (Wp.state == 'Off')
then Wp.switchOn()
else if (Wp.state == 'On')
then Wp.switchOff()
}Rfxcom
Raspi 4
Raspi 4
