RFlink might support Mi-light and other protocols soon :)
Stuntteam
Re: RFlink might support Mi-light and other protocols soon :)
Post by Stuntteam »
Sorry for not being clear.
Please go to http://www.nemcon.nl/blog2/faq and check the section named "RFlink with NRF24L01:"
Ask if it is not clear and I will do my best to add some more info.
burton666
Post by burton666 »
Ahh, now I managed to pair a bulb. But I still have some problems, the colors are not "correct" and I am unable to turn the bulb off. Also I often have to select a color multiple times for it to change.
And a new question, If I pair a bulb with some random ID and then remove the bulb from domoticz. Can I still unpair it without knowing the bulb id ?
deennoo
Post by deennoo »
About unpairing : no you need id, RFLink is the same as a remote, if you don't have it you can't unpair.
http://domo-attitude.fr
Stuntteam
Post by Stuntteam »
in theory you could unpair it by guessing the id.. however.. it will take a long time to try all 65536 ID's
Redferne
Re: RE: Re: RFlink might support Mi-light and other protocols soon :)
Post by Redferne »
Stuntteam wrote:Sorry for not being clear.
How to enable milight and nodonrf from linux?
Sent from my SM-G930F using Tapatalk
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
So it's not possible to make the the SPI interfaces swappable in the firmware so we could use the onboard header if NODO is not used? I'm now in the situation that I cannot send/receive Mii light signals.
So my possible problems:
* Bad wiring (swapped)
* Bad connection (high impendance)
* Bad power supply
* Dodgy NRF24L01 board
* Not correctly activated in the Rflink configurator
* RF noise
The first 3 issues could be avoided by using the onboard header.
So I know what to do this sunday :)
I think I will kill my MySensor setup to salvage the NRF board, one less variable in the mix.
Edit:
Ok so I got it to work by using the power from the NODO NRF interface header and a new NRF24L01 board.
The RGBW function isn't quite working like it should. When I make a scene with 2 lights which I set to RGBW, and two which I set to RGB. Only one RGB light switches on with a color I didn't set.
The exact same setup wit the mii light wifi bridge works great. So it mus be sending more information to each light?
Stuntteam
Post by Stuntteam »
We will check that..
bizziebis
Post by bizziebis »
Thanks, if you need more information or some testing, please let me know.
deennoo
Post by deennoo »
bizziebis wrote:Thanks, if you need more information or some testing, please let me know.
Does your rflink is near the milight bridge ?
On m'y case RFLink is not central as the milight gateway, i ve to send order twice to light on/off or change color to m'y farest bulb.
bizziebis
Post by bizziebis »
They are 30 cm from eachother. The distance is not a problem.
It's not only in a scene I see now. When I switch on a light and afterwards a second light, they both change to the same color and when I move the slider the brightness of them both changes.
Maybe I have to pair them again using different ID's, and not only different zones. Looks like there is my problem now.
deennoo
Post by deennoo »
This is rbg bulb or rgbw ones ?
Got 10 rgbw Bulbs, on 6 group, 4 got the same group and id drive by a scène and set as rgbw dimmer, 2 others got same group & id set as on/off, other are individual group and id as on/off.
For those 4 who are driven by a scène no problème on color drive or dimmer set.
DanM
Post by DanM »
Given that the NRF24L01 connects directly to the mega, is a RFLink Gateway board required at all if you only want to control milights?
Stuntteam
Post by Stuntteam »
No, you can use just the milight part..
but while you are at it.. you might want to wire a cheap RF receiver as well, it is so much more fun :)
Larsja
Domoticz version: V2.3530
Post by Larsja »
Any tips on how to add my milight led controler fut038 to domoticz? I dont have a remote and i cant seem to find the create RFlink device everyone is talking about
Running on a rpi2 and version 3.4834 of domoticz
Raspberry Piet
Post by Raspberry Piet »
bizziebis wrote: It's not only in a scene I see now. When I switch on a light and afterwards a second light, they both change to the same color and when I move the slider the brightness of them both changes.
I experience this same behaviour with mine.
Larsja wrote:Any tips on how to add my milight led controler fut038 to domoticz? I dont have a remote and i cant seem to find the create RFlink device everyone is talking about
Need to update to beta release or wait for new stable version of Domoticz.
Stuntteam
Post by Stuntteam »
If you already have a recent beta, you might want to check with a different browser.. it seems the Domoticz buttons are not always shown depending on the browser type.
We are looking into the color/brightness issue..
bibo456
Post by bibo456 »
Hello everybody,
I have RGB strip led, and soon RGBW strip led, and are interested by your mi-light support.
My question is what HW do I need besides the RFlink I already have ?
Just a controller :
http://www.aliexpress.com/item/1pcs-dc1 ... 77760.html
or this :
http://www.aliexpress.com/item/2015-new ... 33255.html
Thank you for your feedback,
Last question, the controller can drive RGBW and RGB strip led ?
Stuntteam
Post by Stuntteam »
Only the first I think.
The second is a wifi bridge.. RFlink is a serial bridge but in combination with Domoticz you can reach it via Wifi anyway
bibo456
Post by bibo456 »
That's what I tought too.
thank you for your confirmation.
I will order one
datzmazzie
Domoticz version: 2.3430
Post by datzmazzie »
I allready have a NRF24L01 on my RFLink (the one thats comes with the RFLink) I think I don't us that one for any of my device. Is it possible to use that one for mi-light?
Verstuurd vanaf mijn E6653 met Tapatalk
Raspberry Pi 3B, Arduino Mega, RFLink
My Blog
