izSynth: make domoticz talk with many TTS engines in a easy way
All kinds of 'OS' scripts
korniza
Domoticz version: V3.6028
Re: izSynth: make domoticz talk with many TTS engines in a easy way
Post by korniza »
I feel so happy guys!
As I included bluetooth tags to every famiy keyrings, domoticz (FHEM presence-> Domoticz Switch) recognise who is getting home and welcome him/her using izsynth. I have also some other bluetooth panic buttons that when they get pressed, there is a voice that prompt for security password before running lock down of the property!
I like to ask if there is available an option to direct sound to another audio output (for example bluetooth speakers) which are not the default of system, so I can use it on a LUA using time criteria.
>>>> Google Home <<<<<
jin
Post by jin »
korniza wrote:I feel so happy guys!
Nice idea korniza! ;)
korniza
Post by korniza »
hm...bug found!
I just reboot my raspberry and appeared that no voice prompt can be reproduced from domoticz.
When I run command from shell is working. After creating the file manualy from console, domoticz also plays it. I suppose has to do with previliges. Any fix for this?
Error: Error executing script command (/home/pi/domoticz/scripts/izsynth). returned: 256
..."]:27: attempt to index global 'devicechanged' (a nil value)string "--
>>>> Google Home <<<<<
toreandre
Post by toreandre »
korniza wrote:hm...bug found!
What happens to the "returned: 256" error if you put " & " after the on/off action in domoticz?
About the nil value error, isnt that a lua specific error?
woody4165
Post by woody4165 »
Nice idea the BT stuff!
Can you share (maybe in another post) how you did it?
korniza
Post by korniza »
If I use "&" at the end of on/off Action, issue not resolved.
I also checked /dev/shm folder after reboot raspberry and triggering voice prompt from domoticz. No sound output from speakers. here are the files:
drwxr-x--- 2 root root 60 May 4 12:41 izsynth-20160504-124120
drwxr-x--- 2 root root 60 May 4 12:41 izsynth-20160504-124154
Running from console the same command (example: izsynth -e voicerss -v en-gb -t "Panic Button Triggered! Please stay calm while emergency process initiating. " ) I get a sound output from speakers and there are extra files on /dev/shm.
-rw-r--r-- 1 pi pi 624522 May 4 12:45 Panic_Button_Triggered__Please_stay_calm_while_emergency_process_initiating__.wav
-rw-r--r-- 1 pi pi 239754 May 4 12:44 Welcome_home.wav
So the issue is that using domoticz does not create wav files. Hope it helps for debugging.
>>>> Google Home <<<<<
micbou
Post by micbou »
This is such an awesome idea! Going to use that too... thanks. Which tags are you using and did you use this script? viewtopic.php?t=5214
jin
Post by jin »
korniza wrote: Running from console the same command (example: izsynth -e voicerss -v en-gb -t "Panic Button Triggered! Please stay calm while emergency process initiating. " ) I get a sound output from speakers and there are extra files on /dev/shm.
mmmm.... I must try to reboot my rpi to see if that problem happen to me too... anyway, in your text I see a problematic character: "!"
You have that problem with all izsynth buttons? can you make a new button with a simple:
script://izsynth test
I think that we need gizmocuz to solve that problem.
Kind regards
korniza
Post by korniza »
Kind regards
I test this simple button and also I get the same issue
2016-05-05 00:52:09.587 (Synth) Light/Switch (test)
2016-05-05 00:52:09.915 Executing script: /home/pi/domoticz/scripts/izsynth
2016-05-05 00:52:13.143 Error: Error executing script command (/home/pi/domoticz/scripts/izsynth). returned: 256
and checking the files
~/domoticz $ sudo ls -l /dev/shm/izsynth-20160505-005210/
total 4
-rw-r----- 1 root root 5 May 5 00:52 test.txt
there is only the txt file but not the wav file. :|
>>>> Google Home <<<<<
jin
Post by jin »
This is a domoticz bug, please post a bug report.
korniza
Post by korniza »
As I don't like to mess this thread about howto for bluetooth, please take a look on hardware/software was used on viewtopic.php?f=28&t=10640 . I feel glad to share ideas with you guys. Domoticz users are rocket engineers, but they do not know it :lol: :lol: :D
>>>> Google Home <<<<<
korniza
Post by korniza »
jin wrote:This is a domoticz bug, please post a bug report.
Can you confirm that issue can be reproduced also to your system? anyone other can perform the test and trigger voice button after restarting raspberry?
>>>> Google Home <<<<<
jin
Post by jin »
pi@domoticzpi ~/domoticz/scripts $ uptime
 21:12:30 up 95 days,  1:41,  1 user,  load average: 0,25, 0,09, 0,07
sigh ;( pity for my uptime :)
rebooted and izsynth recreated without problems the recordings when pressing the button.
this is my screenshot:
2016-05-05 21:16:48.900 User: Admin initiated a switch command
2016-05-05 21:16:48.901 (Virtual) Light/Switch (Talker)
2016-05-05 21:16:49.398 Executing script: /home/pi/domoticz/scripts/izsynth
2016-05-05 21:16:52.964 User: Admin initiated a switch command
2016-05-05 21:16:52.966 (Virtual) Light/Switch (Talker)
2016-05-05 21:16:53.903 Executing script: /home/pi/domoticz/scripts/izsynth
I don't know because you get return code 256
toreandre
Post by toreandre »
Just made a clean install of the izsynth on one of my RPi's running domoticz 3.5051 and latest OSMC (debian jessie).
From the commandline i can get sound, but there is a problem. When i execute the command from the wiki only the last word in the sentence is beeing played.
$HOME/domoticz/scripts/izsynth -e voicerss -v en-us -t "I love Domoticz Home Automation System"
So i tried to make the sentence longer and now i hear ".... system test test test"
$HOME/domoticz/scripts/izsynth -e voicerss -v en-us -t "I love Domoticz Home Automation System test test test"
It seems like there is some problems with timing somewhere.
EDIT: Did some further testing, if i execute the "i love domoticz" sentence and exute it a second time WHILE the first sentence is already playing on the speakers i can hear the full sentence.
korniza
Post by korniza »
it is strange but today script start to work but not for voicerss! also ispeech was busted as they add a extra prompt "powered by ispeech". We need an extra TTS machine. @Jin did you checked the API of IVONA? It supports 5000 prompts/month for free!
https://www.ivona.com/us/for-business/speech-cloud/
take also a look on pyvona (pyhton + ivona API)
http://zacharybears.com/pyvona/
>>>> Google Home <<<<<
micbou
Post by micbou »
mmmm.... your config is right...
I tested creating a "Virtual Button" of type "Selector Switch" (..) but the script works perfectly and I can hear the voice when I activate the button...
can you try putting the full path of the script? like:
script:///home/osmc/domoticz/scripts/izsynth test
I reinstalled IzSynth with Naturalreaders instead of VoiceRSS and it works like a charm now. Thanks for your help!!
micbou
Post by micbou »
It really had something to do w/ VoiceRSS. I tried using it with my sonos integration and have the same issue there. (no error, no sound)
korniza
Post by korniza »
micbou wrote:It really had something to do w/ VoiceRSS. I tried using it with my sonos integration and have the same issue there. (no error, no sound)
It is working through console but not from domoticz. suppose it has to do with API key that is not parsed from default conf?
>>>> Google Home <<<<<
micbou
Post by micbou »
indeed. Wonder if anybody has found some sort of fix
jin
Post by jin »
micbou wrote:indeed. Wonder if anybody has found some sort of fix
can you paste the output of following commands? (run from the user running domoticz)
echo $HOME
ls -al $HOME/.config/izsynth
cat $HOME/.config/izsynth/izsynth.conf
ls -al /dev/shm
ls -al $HOME/domoticz/scripts
ps aux | grep domoticz | grep -v grep
uname -a
Thankyou!
