not sure what your problems with this modules are.
i have the zw+ version with aotec gen5 stick
i only have the controller associated with group1(the rest is empty)
temp reading ok
lux reading ok
when motion de devices react as follows
00=no reaction, probably because no groups are associated
28=no raction,probably because no groups are associated
32=no reaction,probably because no groups are associated
33= no reaction,probably because no groups are associated
35= reaction, this is my pir sensor which i use to trigger events
when i put a light module in group 2 and trigger motion that light switches on(so association group 2 works
did you include the module right?
i mean, you are probalby using the correct config file but did you clean out the zwcfg_xxxx.xml file
stop zwave (goto setup-hardware, select zwave stick unselect enabled and press update)
make sure you got the right config file
make sure the id of the module 0x1001 0x801) is mapped to that config file
edit zwcfg_xxxx.xml and delete ONLY the node entry which belongs to the fgms module
start zwave (goto setup-hardware, select zwave stick select enabled and press update)
i attached my file
