Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
CorGre
Re: Temperature & Humidity Sensor compatible with RFXCOM/Domoticz
Post by CorGre »
Westcott wrote:I got one from Banggood - it worked straight away with RFXtrx
http://www.banggood.com/433MHz-Wireless ... 8820141020
I bought those but how do I see them in Domoticz?
They are on. But not visible. What setting does my RFXCOM need to communicate with them.
Westcott
Post by Westcott »
Enable Rubicson
Andyyyy
Post by Andyyyy »
I have the same with RFXTRX and Rubicson is enabled, but i get no new devices ...
SweetPants
Post by SweetPants »
Done "Accept new hardware" in settings?
Andyyyy
Post by Andyyyy »
Yes, i also tried the RFXmngr... only with rubicson/alecto/bangood activated...
but nothing to see...
I only have a RFXtrx433 !!! thats the reason why these sonsors wont work... :-(
kubrik
Post by kubrik »
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
rotero
Domoticz version: V2.2284
Post by rotero »
I ordered (and received) 2 of these Banggood thermometers, but I cannot use them.
They are working perfect with RFXCOM RFXtrx433E USB 433.92MHz Transceiver, but not with the Type2 firmware (which I need for my Philips power switches). They are working with the Ext & Ext2 firmware.
If someone is interested in these 2 Banggood thermometers, you can buy them from me for €17,00 (excl. shipping).
The good thing is: I live in the Netherlands (Nieuw-Vennep) and you don't have to wait 6 weeks for your order from China! :lol:
Please let me know if you are interested!
Regards,
Rob
kubrik
Post by kubrik »
Arrived... it works (Rubicson).
tjofras
Post by tjofras »
JohnBoy32 wrote:Only £ 7,70, looking better and (most likely like Cresta and Bresser etc.) of course made in China! Free shipping!
http://www.aliexpress.com/item/AOK-2011 ... 12106.html
I can confirm that these are working exactly as they should and also battery-life is fine. I do not have any complaints.
The only point I want to make is that it is old-fashioned to think that something bought on Amazon (or in a local shop) with a non-Chinese brand is made in Europe/US and therefore is better quality; most likely it is made in China and probably in the same factory.
Maybe the one with the nice English brand is made by child hands in People's Republic of Korea.
Please don’t fool yourself or others.
Can anyone please confirm these sensors still works with the rfxtrx433e and the latest firmware? I read someone was having problems with an AliExpress sensor and the latest rfxtrx-firmware?
Edit: I just realized the "product is no longer available", does anyone know of another temp/humid sensor that works with rfxtrx that is available on AliExpress now?
krizzz
Post by krizzz »
I am also looking to expand my temperature sensors and the Cresta TX-320 which at my preferred supplier was around 10 euros is not any longer available. So i am looking for new opportunities.
kognor
Post by kognor »
https://www.banggood.com/DANIU-433MHz-W ... 8820141020
How many of these can you use simultaneously next to each other connected to 1 domoticz system?
I want to monitor temp and humidity in about 7 rooms + 1 outdoor.
Is this possible connecting 8 of these sensors to 1 domoticz system? Or do the rf addresses interfere?
Thanks in advance for the information!
novakmi
Post by novakmi »
kognor wrote: Wednesday 20 September 2017 9:01 https://www.banggood.com/DANIU-433MHz-W ... 8820141020
These sensors offer only 3 channels. So 3 of these is OK. More will probably interfere.
marxkemp
Post by marxkemp »
I got these in 3 rooms and 1 outdoors
kognor
Post by kognor »
I thought I let you guys know...
In the meantime i'm testing with 5 of these on the same channel. Now running 3 weeks next to eachother without any interference.
Don't know yet about batterij life...?!
LouiS22
Post by LouiS22 »
kognor wrote: Tuesday 24 October 2017 7:58 I thought I let you guys know...
Great news, but there will be a point (in theory) when two of them are gonna report in the exact same second which may result in interference.
kognor
Post by kognor »
I have my thoughts about the accuracy of the humidity on these daniu sensors. Any info would greatly help! Because I have no idea if I'm looking at correct data :-s
Anyone have any experience with the correctness of the measurements?
iffen5
looking for a thermometer that can handle high temperatures
Post by iffen5 »
I have used Rubicson's bending thermometer but it works badly. Is anyone who has tried any other thermometer or solution where you can measure temperatures up to 300 degrees?
Rgds Ingemar
Jantje007
Domoticz version: 3.8153
Post by Jantje007 »
- R-Pi2B Domoticz V3.8153
- RFXtrx433E Version: Ext/1024
Just received this kit.
Sensor works perfect.
Excelvanv AOK-5060C, sensor AOK-2026 (recognized as: Rubicson/IW008T/TX95)
https://nl.aliexpress.com/item/EXCELVAN ... 05265.html
- OpenZWave USB Version: 1.4-2501
- Fibaro, KaKu, Eth008 Devantech, Cresta + cheap Chinese sensors
Joep123
Post by Joep123 »
kognor wrote: Wednesday 25 October 2017 17:52 I have my thoughts about the accuracy of the humidity on these daniu sensors. Any info would greatly help! Because I have no idea if I'm looking at correct data :-s
You're right. The humidity sensor is not accurate. My Kerui sensor showed 79% after showering and the Daniu sensor 52% :roll:
In my living room (next to each other) 48% (Kerui) - 44% (Daniu).
DeBaat
Domoticz version: V3.8153
Post by DeBaat »
Hai All,
I just recieved my Digoo TH1980 sensor set for temperature measurments for both indoor and outdoor.
After I inserted the batteries, it almost immediately showed in my Domoticz installation running on my Synology with an RFXCOM RFXtrx433E.
However, as I would expect both temperature values, it shows temperature and humidity values.
Already tried to reset the connection with both the domoticz as the communication between both sensor devices.
Any suggestions on how to fix this?
