Page 3 of 3
Re: Withings WS-50 Scale Syncer - Temperature & CO2
Posted: Saturday 29 October 2016 10:35
by Derik
kick....
dear all..
Does some have the weigt options implement in Domoticz...
The temp and co is nice, only the scale is what i mis..
There is a api..
http://oauth.withings.com/api/doc
Only i do not understand a &^%&^of all that data....
Looks that this nice hardware have more potention in domoticz..
My wife weight rising....
Eveyday a mail to ... you are to,,,,,
when she lost some weight, send a mail, good job love..
Some one?
Posted: Thursday 09 February 2017 21:37
by Nautilus
Any idea what changed in the api around 31.1.2017? Now getting just:
Withings WS-50 Syncer Version 0.4.6
[-] Attaching database /home/pi/domoticz/domoticz.db [version 110]
[-] Authenticating at account.withings.com
HTTP ERROR 500
I'll try to check it but if someone knows already...
Posted: Thursday 09 February 2017 23:44
by dynasticorpheus
Nautilus wrote:Any idea what changed in the api around 31.1.2017? Now getting just:
HTTP ERROR 500
They implemented protection against cross-site request forgery (CSRF) hence a csrf_token needed to be added to the authentication request. Should be fixed through latest commit dd74fce. Please confirm this is also working on your end.
Posted: Friday 10 February 2017 0:49
by Nautilus
Indeed it works, thanks a lot!
edit: for reference to others, I first ran:
sudo apt-get install libxml2-dev libxslt-dev python-dev
sudo pip install lxml
Posted: Friday 10 February 2017 11:48
by dynasticorpheus
Nautilus wrote:Indeed it works, thanks a lot!
edit: for reference to others, I first run
I added a requirements.txt file to repository to clarify the required depandancies
Posted: Saturday 11 February 2017 11:36
by Derik
Dear all.
Is there somebody that have the weight working in Domoticz....
Posted: Saturday 11 February 2017 11:45
by Nautilus
Derik wrote:Dear all.
I think there was someone here who had a working IFTTT example on how to update the weights. See
viewtopic.php?f=38&t=9482&p=74115&hilit ... ttt#p66051
Posted: Monday 03 July 2017 15:50
by dynasticorpheus
Code has been updated and is now working again after Withings became part of the Nokia company.
Posted: Monday 03 July 2017 15:55
by Derik
Thanks...
Only is there perhaps a option to read the weight of the scale??
Posted: Monday 03 July 2017 22:40
by Nautilus
dynasticorpheus wrote:Code has been updated and is now working again after Withings became part of the Nokia company.
Works great, thanks!
Posted: Saturday 21 April 2018 17:48
by felix63
I thought to give it another try. Still not getting any data. Request has been (re)installed. Would you have any other suggestions?
- Spoiler: show
- pi@viola:~ $ sudo pip install requests --upgrade
Downloading/unpacking requests from https://files.pythonhosted.org/packages ... 193a40a38b
Downloading requests-2.18.4-py2.py3-none-any.whl (88kB): 88kB downloaded
Downloading/unpacking certifi>=2017.4.17 (from requests)
Downloading certifi-2018.4.16-py2.py3-none-any.whl (150kB): 150kB downloaded
Downloading/unpacking idna>=2.5,<2.7 (from requests)
Downloading idna-2.6-py2.py3-none-any.whl (56kB): 56kB downloaded
Downloading/unpacking chardet>=3.0.2,<3.1.0 (from requests)
Downloading chardet-3.0.4-py2.py3-none-any.whl (133kB): 133kB downloaded
Downloading/unpacking urllib3>=1.21.1,<1.23 (from requests)
Downloading urllib3-1.22-py2.py3-none-any.whl (132kB): 132kB downloaded
Installing collected packages: requests, certifi, idna, chardet, urllib3
Found existing installation: requests 2.4.3
Not uninstalling requests at /usr/lib/python2.7/dist-packages, owned by OS
Found existing installation: chardet 2.3.0
Not uninstalling chardet at /usr/lib/python2.7/dist-packages, owned by OS
Found existing installation: urllib3 1.9.1
Not uninstalling urllib3 at /usr/lib/python2.7/dist-packages, owned by OS
Successfully installed requests certifi idna chardet urllib3
Cleaning up...
but running the script still yields no results:
pi@viola:~/domoticz/scripts/python $ ./ws50-sync.py -u [email protected] -p yyyyyyy -d /home/pi/domoticz/domoticz.db -t 441 -c 440 -l 7 -f -r
Withings WS-50 Syncer Version 0.4.9
[-] Attaching database /home/pi/domoticz/domoticz.db [version 118]
[-] Authenticating at scalews.withings.net
[-] Removing existing data from table METER
[-] Downloading all measurements recorded after 2018-04-14 17:43:47 (7 day limit)
[-] Updating CO2 HOURLY table with 0 measurements [TRUE]
[-] Removing existing data from table MULTIMETER_CALENDAR
[-] Updating CO2 YEARLY table with 0 measurements [TRUE]
[-] Calculating daily MIN, MAX & AVG values
[-] Removing existing data from table TEMPERATURE
[-] Updating TEMPERATURE HOURLY table with 0 measurements [TRUE]
[-] Removing existing data from table TEMPERATURE_CALENDAR
[-] Updating TEMPERATURE YEARLY table with 0 measurements [TRUE]
[-] Nothing to commit, closing database
Posted: Tuesday 24 July 2018 23:42
by Nautilus
dynasticorpheus wrote: Monday 03 July 2017 15:50
I guess they've done another change. I'm getting some authentication related errors:
Withings WS-50 Syncer Version 0.4.8
[-] Dry run mode enabled, no changes to the database will be made
[-] Attaching database /home/pi/domoticz/domoticz.db [version 129]
From cffi callback <function _verify_callback at 0x75f09130>:
File "/usr/local/lib/python2.7/dist-packages/OpenSSL/SSL.py", line 309, in wrapper
_lib.X509_up_ref(x509)
AttributeError: 'module' object has no attribute 'X509_up_ref'
File "/home/pi/domoticz/scripts/ws50-sync.py", line 258, in <module>
main()
File "/home/pi/domoticz/scripts/ws50-sync.py", line 221, in main
deviceid, sessionkey = authenticate_withings(args.username, args.password)
File "/home/pi/domoticz/scripts/ws50-sync.py", line 125, in authenticate_withings
requests.head(URL_USAGE, timeout=3, headers=HEADER, allow_redirects=True, verify=pem)
File "/usr/local/lib/python2.7/dist-packages/requests/api.py", line 98, in head
return request('head', url, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/requests/adapters.py", line 506, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='goo.gl', port=443): Max retries exceeded with url: /z6NNlH (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')],)",),))
It seems that at least Oauth1.0 is now deprecated (
http://developer.health.nokia.com/oauth2/).
Posted: Friday 17 August 2018 9:16
by kimhav
dynasticorpheus wrote: Monday 03 July 2017 15:50Code has been updated and is now working again after Withings became part of the Nokia company.
Guess that we can expect this to change again as Nokia
sold of the Withings section back to the founder again and that end of this year Withings will be fully separated once again.
Posted: Sunday 19 August 2018 19:30
by kimhav
Following notification is provided at the above API documentation page:
This documentation is deprecated.
The Health Mate API is now fully functional with OAuth 2.0 authentication protocol.
Therefore, the OAuth 1.0 process will no longer be supported beginning:
November 30, 2018
Please refer to the new documentation for migrating to OAuth 2.0.
Please have a look at our other important non-backward-compatible changes in our release note.
Posted: Sunday 09 September 2018 11:57
by dynasticorpheus
A bit late to the party as I a moved over to Home Assistant. Just did a full update and it is still working for me so am I missing something?
Please note I am not using their official API as they do not support the temperature / CO2 part. (Basically the main reason for building this script)
[-] Attaching database /home/dynasticorpheus/x-tools/builds/domoticz-x64/domoticz.db [version 129]
[-] Downloading all measurements recorded after 2018-09-08 11:53:24 (1 day limit)
[-] Updating CO2 HOURLY table with 0 measurements [FALSE]
[-] Updating CO2 YEARLY table with 44707 measurements [FALSE]
[-] Updating TEMPERATURE HOURLY table with 0 measurements [FALSE]
[-] Updating TEMPERATURE YEARLY table with 44707 measurements [FALSE]
Nautilus wrote: Tuesday 24 July 2018 23:42
main()
Posted: Saturday 15 September 2018 1:19
by Nautilus
dynasticorpheus wrote: Sunday 09 September 2018 11:57
Indeed, works fine after switching to Python 3
Sorry for the false alarm...
