Page 20 of 49
Re: Dashticz - Module - Garbage collector
Posted: Monday 01 January 2018 20:25
by Derik
mm did update my dashticz to last beta.
look there are some other setting needed...
Only i cannot use the "old" css for adjust image and place and the css for tomorrow and today font.
I used this settings:
.trash .state div.trashtoday 		{ font-size: 30px; font-weight: 3; color: blue;margin-left: 29px; font-weight: bold; font-variant: small-caps;}
.trash .state div.trashtomorrow=	{ font-size: 27px; font-weight: 2; color: white; margin-left: 29px; font-variant: small-caps;}
.trash .state div.trashrow 		{ font-size: 25px; font-weight: 1; color: red; margin-left: 29px; font-variant: small-caps;} /// alle tekst
.trashcan				{ height: 65px; width: 65px; margin-left:; margin-top: 20px;}
Only that is not function any more.
Someone have new css for the latest garbage js?
xx
Posted: Monday 01 January 2018 21:02
by aiolos
Ah, those classes are accidentally removed in the whole refactor. I create a PR for it.
Also note that after 'trashtomorrow' you have an '=', that's not valid css.
Posted: Monday 01 January 2018 21:16
by Derik
mm thanks for the typo..
Only the image is see very small in my setup.
And no color and i set the color on true in the config:
config['garbage_use_names'] 	= true;
config['garbage_use_colors']	= true;
config['garbage_icon_use_colors'] = true;
Just a very smal "kliko" in the left upper corner. without a color...
And i see in the img. map all the jpg that he can should use.
Posted: Monday 01 January 2018 21:57
by timyboyb
Since my town Groningen is also not digital available I try to get the ical from google working and make my own. He says only "loading". What to do? how to check the diffrent parts?
Posted: Monday 01 January 2018 22:05
by JacEngels
timyboyb wrote: Monday 01 January 2018 21:57 Hello,
Maybe for Groningen this link can be used and implemented: https://gemeente.groningen.nl/afvalwijzer/groningen
Posted: Monday 01 January 2018 22:32
by timyboyb
JacEngels wrote: Monday 01 January 2018 22:05
thanks for the idea but this is only a table view page, no ical orso.
I tried the google API as well but that one is also not loading...
Posted: Monday 01 January 2018 22:34
by Derik
you have to set all into the last beta
Posted: Monday 01 January 2018 22:49
by timyboyb
Derik wrote: Monday 01 January 2018 22:34 you have to set all into the last beta
what is the best way to install that last version? just starting up with this but know some basics here and there. Sourcetree? working in atom but also new there.
Posted: Monday 01 January 2018 22:52
by Derik
mmm I don't now.
My way.
Save the custom and custom css and perhaps your custom images.
Then remove all the dash maps
Then upload the new dash map
The replace all the custom
Posted: Monday 01 January 2018 23:09
by timyboyb
Derik wrote: Monday 01 January 2018 22:52 mmm I don't now.
My way.
oh, thanks man, it's working.
Posted: Monday 01 January 2018 23:28
by Derik
timyboyb wrote: Monday 01 January 2018 23:09
My way.
Change your "old" setting in to the new in the wiki..
There are some bugs..
Posted: Monday 01 January 2018 23:38
by timyboyb
My way.
Ah oké, what specifically? Where do I look for?
Verstuurd vanaf mijn HTC 10 met Tapatalk
Posted: Tuesday 02 January 2018 14:46
by Derik
Rob..
I do have the latest beta...
Only my icon is very small.
And when i use my old css there is no change of any hing..
config:
/*//////////////////////////// Afval  \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\*/
config['garbage_company'] 	= 'mijnafvalwijzer';
config['garbage_zipcode'] 	= '6656AW';
config['garbage_street'] 	= 'park33';
config['garbage_housenumber'] 	= '29';
config['garbage_maxitems'] 	= '3';
config['garbage_width'] 	= '6';
config['garbage_hideicon'] 	= 0;
config['garbage'] = {
    gft:	{kliko: 'green', 	code: '#375b23', name: 'GFT-Folie'},
    pmd: 	{kliko: 'orange', 	code: '#db5518', name: 'PMD'},
    rest: 	{kliko: 'grey', 	code: '#5e5d5c', name: 'Restafval'},
    papier: 	{kliko: 'blue', 	code: '#153477', name: 'Papier'},
    kca:	{kliko: 'red', 		code: '#b21807', name: 'Chemisch afval'},
    brown: 	{kliko: 'brown', 	code: '#7c3607', name: 'Bruin'},
    black: 	{kliko: 'black',	code: '#000000', name: 'Zwart'},};
and..
css:
.trash .state div.trashtoday 		{ font-size: 30px; font-weight: 3; margin-left: 29px; font-weight: bold; font-variant: small-caps;}
.trash .state div.trashtomorrow		{ font-size: 27px; font-weight: 2; margin-left: 29px; font-variant: small-caps;}
.trash .state div.trashrow 		{ font-size: 25px; font-weight: 1; margin-left: 29px; font-variant: small-caps;} /// alle tekst
.img.trashcan				{ height: 65px; width: 65px; margin-left:; margin-top: 20px;}
So perhaps i need a total new css??
Or?
Posted: Tuesday 02 January 2018 17:41
by aiolos
Derik wrote: Tuesday 02 January 2018 14:46 Rob..
Or?
I just checked your config and css. Seems to work with the latest beta (please note that the changes to make this work were merged this morning.)
The given postalcode/housenumber doesn't give a result, but if I try another one, I see results. The layout is changed by the css then.
Posted: Tuesday 02 January 2018 18:08
by Derik
This is what i have..
Perhaps you can share your settings?
Posted: Tuesday 02 January 2018 20:08
by jdemas
Hi Rob,
sinds 1 of january rd4 isn't working at all.
can you look into it?
regards Jeffrey
Posted: Wednesday 03 January 2018 0:40
by aiolos
Derik wrote: Tuesday 02 January 2018 18:08 klein.jpg
Ah, I thought no css at all was working, but it is only the image. Use
div.col-icon { width: 100px !important;}
in your custom.css to also adapt the div around the icon. That one is by default fixed to max 50px width. (by using the 'inspect element' option in your browser and playing around with the elements you can see what happens if you disable on change css values)
Posted: Wednesday 03 January 2018 0:47
by Luxtux
I've created another pull request. so the scripts can assign garbagetypes to my city's ICAL file. I'm wondering if it maybe wouldnt be a better idea to have some config option for each type of garbage; instead of keep on adding different regex words for each language.
I have one little issue that I haven't been able to solve yet. I was able to hide some entries in the previous version of the garbage module (before nov 2017) by not defining some garbage types. The ICAL file that the city provides contains all types of bins that exist in their system; but not all of them interest me. E.g. I live in an apartment, so i don't care that they come and pick up cut grass.
Posted: Wednesday 03 January 2018 0:56
by aiolos
Thanks. Now that it gets some usage we can figure out what's handy to use. You are right about the adding stuff, I think we can solve it by adding a matching element in the config. That way everyone can change it to their specific situation.
For your problem with too much information a hiding option should be added, that makes sense. The earlier config had that option indeed.
And good news for the people in Groningen: implementation is on its way...
Posted: Wednesday 03 January 2018 1:07
by Derik
aiolos wrote: Wednesday 03 January 2018 0:40
Thanks for the tip try it tomorrow..
Only i cannot see the dash in my pc because the screen setting are different on my pc and my tablet..
Perhaps a solution for that?
