Page 20 of 26
Re: Domoticz App
Posted: Wednesday 07 February 2018 13:39
by pgas37
Domoticz v 3.8153
Raberrypi v3
Ios app on iphone
I cannot connect my iphone using my external ip. Xxx:6144, using loginname and password.
Port 6144 on the router is forwarded to the internal ip adress.
I tried it many times, no mistake in ip, pwd, etc.
Use of only my internal ip in the app within the network all works fine.
Can anyone help?
Paul
Re: Domoticz App
Posted: Monday 12 February 2018 8:57
by galadril
pgas37 wrote: Wednesday 07 February 2018 13:39
http or https?
If you use https, please make sure that you've setup a correct CA signed certificate
https://letsencrypt.org/
Re: Domoticz App
Posted: Monday 12 February 2018 11:33
by pgas37
i use http
Re: Domoticz App
Posted: Thursday 15 February 2018 15:34
by Cavas
galadril wrote: Monday 29 January 2018 10:23
Cavas wrote: Tuesday 23 January 2018 17:19
I bought it for notification but I don't have any sounds on notifications.
it shoud use the sound settings that all notifications use
Thanks for answer but nothing...
In Domoticz app and notification center all is configured. But in Setup / Mobile Devices, when I click on the green arrow I see the notification banner but no sound.
Re: Domoticz App
Posted: Sunday 18 February 2018 11:18
by pgas37
Because i still cannot connect with the Domoticz-app (http:// ext-ip, port 6144( forwarded in the router) ID+passw)
I installed NMAP (sudo apt-get install nmap) and i checked if port 6144 on the internal ip-adress was open.
It is NOT open so Domoticz seems not to listen on the remote shared port for Domoticz-clients.
If I use e.g. port 6100 or 4000 in the Domoticz setup NMAP reports an open TCP-port. Forwarding those ports on the router does not solved the problem.
I updated en upgraded the raspberrypi.
Anyone any suggestion?
thanks
Paul
NMAP report:
pi@raspberrypi:~ $ nmap 192.168.178.59
Starting Nmap 6.47 (
http://nmap.org ) at 2018-02-18 11:08 CET
Nmap scan report for 192.168.178.59
Host is up (0.00099s latency).
Not shown: 995 closed ports
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
443/tcp open https
5900/tcp open vnc
8080/tcp open http-proxy
Nmap done: 1 IP address (1 host up) scanned in 0.34 seconds
Re: Domoticz App
Posted: Wednesday 21 February 2018 9:26
by lsp242
I've a issue with graphs from P1 readings. The frist graph pulled works fine (fe Gas), but switch to the other in this case electric, that graph wont show.
Can the graphs be the same lay out as on Domoticz page?
Re: Domoticz App
Posted: Wednesday 21 February 2018 19:32
by baekmark
I'm having the same problem, showing the first graph is fine - all through the graphs is a bit pointy - but showing the next sensor produce no graph
I have the paid version
Keep up the good work
BR
Lars
Re: Domoticz App
Posted: Monday 26 March 2018 2:32
by jacola
i am quite frustrated,
have my domoticz system up and running and the app downloaded.
latest IOS etc, all should be fine.
even with "use our demo setup" i get stuck with the same point.
can verify the connection settings fine
but don't get anywhere else, no UI, no "home" screen. just stuck with the network settings dialog ?
what am i doing wrong ?
johannes
Re: Domoticz App
Posted: Monday 26 March 2018 8:15
by mikeoo
jacola wrote: Monday 26 March 2018 2:32
johannes
App is working fine on my iPad Air2 with latest IOS.
Just test is it and also verify the connection again and is working fine. Get also all sensor in the Gui.
Check firewall / logfiles domoticz etc to see if you can find some info. Do you test it with local or external settings.
Test it all first with local settings so your Domotiz and Apple are both in the same network.
Remove App --> restart iPhone/iPad --> install app again and try again.
Re: Domoticz App
Posted: Monday 26 March 2018 11:29
by DewGew
Is it possible to add "choose access point" ? When I'm on wifi at work the app thinks I am local connection. Then I have to switch off wifi to use the app.
Re: Domoticz App
Posted: Monday 26 March 2018 19:34
by jacola
problem found .. i put in a directory .. as that was also part of the demo settings, and connection has confirmed ok but got stuck in that place.
removing the directory made it work ..
now i really like it
johannes
Re: Domoticz App
Posted: Monday 09 April 2018 19:55
by remb0
We made an interview. pm if you have feedback, please.
https://gadget-freakz.com/2018/04/inter ... rk-heinis/
Thanks Mark!
Re: Domoticz App
Posted: Saturday 14 April 2018 19:41
by twentysevendk
Notifications don't work in the application. I use built-in notifications (configured from sensors), as well as notifications sent by "notify" command from dzVents script. None of them is notified in the App. However, when I press the green arrow in the mobile devices tab, I get a notification, though without sound.
When trying to change a user variable from the App, don't get a chance to type in a float number, there is no button for a decimal point on the built-in keyboard.
Has anyone met these issues before and know how to fix?
Re: Domoticz App
Posted: Sunday 15 April 2018 21:39
by gorstj
Does remote access via mydomoticz.com work?
Tried using but can't get it working for me
Re: Domoticz App
Posted: Tuesday 22 May 2018 19:27
by galadril
There is a new beta coming with the next changelog:
- New permium feature > Passcode, Touch ID and Face ID support
- Reworked the settings page
- Various fixes on crash reports
- Updated libraries (Xamarin version)
Re: Domoticz App
by galadril
gorstj wrote: Sunday 15 April 2018 21:39
No sorry... hope that the developer from mydomoticz gets some free time to work together...
Re: Domoticz App
Posted: Tuesday 22 May 2018 19:28
by galadril
twentysevendk wrote: Saturday 14 April 2018 19:41
There is also a fix for notifications in the next upcoming beta..
So please wait for the next version for your fix..
Re: Domoticz App
Posted: Saturday 02 June 2018 20:04
by FunFair
Wrong topic sorry
Re: Domoticz App
Posted: Monday 04 June 2018 17:35
by Rvaart
Is a live feed from a camera currently possible in the app?
Re: Domoticz App
Posted: Sunday 10 June 2018 22:03
by Takkie32
Just started today with the app. Can i get some help with the server settings pls. Local i can connect with 192.168.... but on 4G it doesnt work. On the Ziggo modem i have opened port 8084. The ip is the one i can find on whatsmyip? Can someone push me the right way please. Btw i am using the payed iPhone app.
Cheers,
Ronald
