Domoticz App
pgas37
Re: Domoticz App
Post by pgas37 »
Domoticz v 3.8153
Raberrypi v3
Ios app on iphone
I cannot connect my iphone using my external ip. Xxx:6144, using loginname and password.
Port 6144 on the router is forwarded to the internal ip adress.
I tried it many times, no mistake in ip, pwd, etc.
Use of only my internal ip in the app within the network all works fine.
Can anyone help?
Paul
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
pgas37 wrote: Wednesday 07 February 2018 13:39
http or https?
If you use https, please make sure that you've setup a correct CA signed certificate
https://letsencrypt.org/
pgas37
Re: Domoticz App
Post by pgas37 »
i use http
Cavas
Target OS: OS X
Re: Domoticz App
Post by Cavas »
galadril wrote: Monday 29 January 2018 10:23
Cavas wrote: Tuesday 23 January 2018 17:19 I bought it for notification but I don't have any sounds on notifications.
it shoud use the sound settings that all notifications use
Thanks for answer but nothing...
In Domoticz app and notification center all is configured. But in Setup / Mobile Devices, when I click on the green arrow I see the notification banner but no sound.
pgas37
Re: Domoticz App
Post by pgas37 »
Because i still cannot connect with the Domoticz-app (http:// ext-ip, port 6144( forwarded in the router) ID+passw)
I installed NMAP (sudo apt-get install nmap) and i checked if port 6144 on the internal ip-adress was open.
It is NOT open so Domoticz seems not to listen on the remote shared port for Domoticz-clients.
If I use e.g. port 6100 or 4000 in the Domoticz setup NMAP reports an open TCP-port. Forwarding those ports on the router does not solved the problem.
I updated en upgraded the raspberrypi.
Anyone any suggestion?
thanks
Paul
NMAP report:
pi@raspberrypi:~ $ nmap 192.168.178.59
Starting Nmap 6.47 ( http://nmap.org ) at 2018-02-18 11:08 CET
Nmap scan report for 192.168.178.59
Host is up (0.00099s latency).
Not shown: 995 closed ports
PORT STATE SERVICE
21/tcp open ftp
22/tcp open ssh
443/tcp open https
5900/tcp open vnc
8080/tcp open http-proxy
Nmap done: 1 IP address (1 host up) scanned in 0.34 seconds
lsp242
Domoticz version: 16960
Re: Domoticz App
Post by lsp242 »
I've a issue with graphs from P1 readings. The frist graph pulled works fine (fe Gas), but switch to the other in this case electric, that graph wont show.
Can the graphs be the same lay out as on Domoticz page?
Gadget freak - Domoticz beginner - ios and android user
baekmark
Domoticz version: Latest
Re: Domoticz App
Post by baekmark »
I'm having the same problem, showing the first graph is fine - all through the graphs is a bit pointy - but showing the next sensor produce no graph :(
I have the paid version
Keep up the good work
BR
Lars
jacola
Re: Domoticz App
Post by jacola »
i am quite frustrated,
have my domoticz system up and running and the app downloaded.
latest IOS etc, all should be fine.
even with "use our demo setup" i get stuck with the same point.
can verify the connection settings fine
but don't get anywhere else, no UI, no "home" screen. just stuck with the network settings dialog ?
what am i doing wrong ?
johannes
mikeoo
Re: Domoticz App
Post by mikeoo »
jacola wrote: Monday 26 March 2018 2:32 i am quite frustrated,
johannes
App is working fine on my iPad Air2 with latest IOS.
Just test is it and also verify the connection again and is working fine. Get also all sensor in the Gui.
Check firewall / logfiles domoticz etc to see if you can find some info. Do you test it with local or external settings.
Test it all first with local settings so your Domotiz and Apple are both in the same network.
Remove App --> restart iPhone/iPad --> install app again and try again.
DewGew
Domoticz version: V4.10618
Re: Domoticz App
Post by DewGew »
Is it possible to add "choose access point" ? When I'm on wifi at work the app thinks I am local connection. Then I have to switch off wifi to use the app.
jacola
Re: Domoticz App
Post by jacola »
problem found .. i put in a directory .. as that was also part of the demo settings, and connection has confirmed ok but got stuck in that place.
removing the directory made it work ..
now i really like it :)
johannes
remb0
Re: Domoticz App
Post by remb0 »
We made an interview. pm if you have feedback, please.
https://gadget-freakz.com/2018/04/inter ... rk-heinis/
Thanks Mark!
twentysevendk
Re: Domoticz App
Post by twentysevendk »
Notifications don't work in the application. I use built-in notifications (configured from sensors), as well as notifications sent by "notify" command from dzVents script. None of them is notified in the App. However, when I press the green arrow in the mobile devices tab, I get a notification, though without sound.
When trying to change a user variable from the App, don't get a chance to type in a float number, there is no button for a decimal point on the built-in keyboard.
Has anyone met these issues before and know how to fix?
gorstj
Re: Domoticz App
Post by gorstj »
Does remote access via mydomoticz.com work?
Tried using but can't get it working for me
galadril
Re: Domoticz App
Post by galadril »
There is a new beta coming with the next changelog:
- New permium feature > Passcode, Touch ID and Face ID support
- Reworked the settings page
- Various fixes on crash reports
- Updated libraries (Xamarin version)
galadril
Re: Domoticz App
Post by galadril »
gorstj wrote: Sunday 15 April 2018 21:39 Does remote access via mydomoticz.com work?
No sorry... hope that the developer from mydomoticz gets some free time to work together...
galadril
Re: Domoticz App
Post by galadril »
twentysevendk wrote: Saturday 14 April 2018 19:41 Has anyone met these issues before and know how to fix?
There is also a fix for notifications in the next upcoming beta..
So please wait for the next version for your fix..
FunFair
Re: Domoticz App
Post by FunFair »
Wrong topic sorry
Rvaart
Re: Domoticz App
Post by Rvaart »
Is a live feed from a camera currently possible in the app?
Takkie32
Re: Domoticz App
Post by Takkie32 »
Just started today with the app. Can i get some help with the server settings pls. Local i can connect with 192.168.... but on 4G it doesnt work. On the Ziggo modem i have opened port 8084. The ip is the one i can find on whatsmyip? Can someone push me the right way please. Btw i am using the payed iPhone app.
Cheers,
Ronald
