Page 20 of 184
Re: New Dashboard Design v2, with custom positioning
Posted: Thursday 06 April 2017 18:31
by robgeerts
It's working here.
It's possible that caching is the problem
Could you clean the cache of the browser?
You've got at least 2 columns more right now
I'll check for the rest of the layout like correct positioning of texts etc.
Posted: Thursday 06 April 2017 19:11
by SwordFish
robgeerts wrote:It's working here.
I send you a pm with a screenshot but i think the screenshot isn't send with it so here the screenshot.
Posted: Thursday 06 April 2017 20:00
by EdwinK
robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
I did so too, and it didn't work. So, setting it to 9090 made it work. Somehow that is the port that Kodi and Domoticz talk to each other.
Posted: Thursday 06 April 2017 20:06
by SwordFish
Its works great. Still not done but will go on tomorrow.
Posted: Thursday 06 April 2017 20:16
by robgeerts
EdKo66 wrote:robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
Thanks, will give it a try!
Posted: Thursday 06 April 2017 20:18
by robgeerts
Train and traffic info (both dutch) are working again:
Sample usage:
columns[2]['blocks'] = ['train','traffic']
Posted: Thursday 06 April 2017 20:31
by robgeerts
robgeerts wrote:EdKo66 wrote:robgeerts wrote:No, I set my port to 8080 in Kodi, so used that port in Domoticz too.
Too bad... didn't work.
I'm using port 9090 now.. (set in kodi and domoticz).
IP + Port is correct:
2017-04-06 20:27:54.424 Kodi: (Kodi) Connected to '192.168.1.11:9090'.
2017-04-06 20:27:54.425 Kodi: (Kodi) Event: 'On'.
The remote is sending a signal but Kodi doesn't do anything...
App on the phone is working correctly (having the same ip/port)
Posted: Thursday 06 April 2017 20:37
by HansieNL
Maybe an icon in front of the text?
fa-train / fa-car
Posted: Thursday 06 April 2017 20:41
by HansieNL
Rob ,what Kodi do you use? Application, LibreELEC or OpenELEC?
Posted: Thursday 06 April 2017 21:13
by robgeerts
HansieNL wrote:Maybe an icon in front of the text?
fa-train / fa-car
Done!
LibreElec, should work out of the box..
Posted: Thursday 06 April 2017 21:58
by HansieNL
I had same kind of problem. I couldn't use Kodi (LibreELEC) in Domoticz a few months ago, but it worked in OpenELEC. Kore app worked well with both versions. OpenELEC and LibreELEC seems not to handle the remote control exactly the same way. I did a LibreELEC update and now it works (just checked to be sure).
Have you already checked if there's a LibreELEC update for your device.
Posted: Thursday 06 April 2017 22:07
by robgeerts
Thanks, I'll check later.
Currently I'm working on a multiple screen-function (as requested bij @SwordFish via PM).
This means, you can have 3 (or whatever) columns on the main screen but you can swipe it to left/right for more columns.
This way you can create 1 dashboard for switches, sliders and stuff like that and 1 dashboard for media players, news etc..
Posted: Thursday 06 April 2017 22:12
by SwordFish
Thanks for that. You really keep going tonight
Bydeway I use the windows version of Kodi, maybe that is the difference.
Posted: Thursday 06 April 2017 23:40
by Dropshot
This dashboard looks amazing!
I've downloaded and extracted the zip to a subfolder in domoticz and changed CONFIG. Question: should it run instantly, or am I missing something, since I don't see a new dashboard?
Posted: Friday 07 April 2017 0:02
by Maartenkr
This is really great!
2 quesions
how do I put a name above it like switch?
and how can i get buienradar back the map?
Posted: Friday 07 April 2017 8:40
by robgeerts
Dropshot wrote:This dashboard looks amazing!
If you downloaded it to a subfolder, you have to call it like this:
http://192.168.1.20:8084/subfolder/index.html
So, first your regular domoticz-path, then subfolder, then index.html
Maartenkr wrote:This is really great!
2 quesions
You can enter a title by defining him first, in config.js just after
like:
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
If you've done this, you can use it like:
columns[1]['blocks'] = ['blocktitle_1',106,204,248,295]
What do you mean with your question about buienradar?
Posted: Friday 07 April 2017 9:14
by SwordFish
I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
Is this correct and that works only with dimmers?
It also don't work if i do idx_3.
Edit: Also the calendar button isn't displaying correct.
Sorry i have the time. Had surgery and sitting at home
Posted: Friday 07 April 2017 9:32
by robgeerts
SwordFish wrote:I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
I tried this, for my scene with idx 3, and it works:
var blocks = {}
blocks['s3'] = {}
blocks['s3']['width'] = 12;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1','s1','s3',233,62]
columns[1]['width'] = 5;
Whats wrong with the calendar button?
Edit: Sorry, i see your screenshot now
Posted: Friday 07 April 2017 9:35
by SwordFish
robgeerts wrote:SwordFish wrote:I'm filling in my dashboard and i noticed that a block with a scene in my case never gets bigger than 4 even if i fill in 12.
var blocks = {}
blocks['s3'] = {}
var columns = {}
columns[1] = {}
Damm those quotes, i only fill them in by columns
Posted: Friday 07 April 2017 9:37
by robgeerts
Preview with multiple dashboards:
