Re: Buienradar Weather Lookup Plugin
Posted: Monday 01 February 2021 13:06
Hi, i'm using your plugin. It's working very good!ffes wrote: Wednesday 08 February 2017 22:11 Hi,
I put my first attempt to write a plugin for Domoticz on-line. It is a virtual weather station based on http://xml.buienradar.nl I have running on my installation at home for a couple of days now.
It can be found at https://github.com/ffes/domoticz-buienradar
At the moment after installing you need manually update your coordinates so the weather station nearby is automatically found. I hope there is a decent way to get this information from the Domoticz settings, but I have not found it yet.
Other then that it only works for the temperature at the moment. I need to figure out how I can generate some of the additional info you need to summit when for instance I add a humidity device.
Note that since it uses buienradar for weather information, it only works for location within (or close by) The Netherlands. Also note it only uses the xml feed of the weather information, not the rain images we all are so familiar with from buienradar.
Update 19-Feb-2017:
All relevant weather information (temperature, humitidy, barometer and wind) can be viewed.
a little "design" question:
sometimes a nice cloudy backgroup appears in the device tiles. But sometimes not.
any idea? Has probably something todo with browser cache?
