Buienradar Weather Lookup Plugin
svdhaar
Re: Buienradar Weather Lookup Plugin
Post by svdhaar »
ffes wrote: Wednesday 08 February 2017 22:11 Hi,
I put my first attempt to write a plugin for Domoticz on-line. It is a virtual weather station based on http://xml.buienradar.nl I have running on my installation at home for a couple of days now.
It can be found at https://github.com/ffes/domoticz-buienradar
At the moment after installing you need manually update your coordinates so the weather station nearby is automatically found. I hope there is a decent way to get this information from the Domoticz settings, but I have not found it yet.
Other then that it only works for the temperature at the moment. I need to figure out how I can generate some of the additional info you need to summit when for instance I add a humidity device.
Note that since it uses buienradar for weather information, it only works for location within (or close by) The Netherlands. Also note it only uses the xml feed of the weather information, not the rain images we all are so familiar with from buienradar.
Update 19-Feb-2017:
All relevant weather information (temperature, humitidy, barometer and wind) can be viewed.
Hi, i'm using your plugin. It's working very good!
a little "design" question:
sometimes a nice cloudy backgroup appears in the device tiles. But sometimes not.
any idea? Has probably something todo with browser cache?
niki_lauda
Post by niki_lauda »
Gettting this error, any thoughts?
2021-02-28 18:45:30.557 Python Plugin System: (BR) Devices checked and created/updated if necessary
2021-02-28 18:45:30.557 Python Plugin System: (BR) Retrieve weather data from http://xml.buienradar.nl/
2021-02-28 18:45:30.590 Python Plugin System: (BR) Going to try another Buienradar URL
2021-02-28 18:45:30.590 Python Plugin System: (BR) Retrieve weather data from https://api.buienradar.nl/
2021-02-28 18:45:30.666 Python Plugin System: (BR) XML parsing error: no element found: line 1, column 0
2021-02-28 18:45:30.666 Python Plugin System: (BR) No XML file found, try again later
2021-02-28 18:45:30.589 Error: Python Plugin System: (BR) Foutje in de BR Plugin: HTTP Error 400: Bad Request URL: http://xml.buienradar.nl/
2021-02-28 18:45:54.054 Python Plugin System: (BR) Devices checked and created/updated if necessary
2021-02-28 18:45:54.055 Python Plugin System: (BR) Retrieve weather data from http://xml.buienradar.nl/
2021-02-28 18:45:54.088 Python Plugin System: (BR) Going to try another Buienradar URL
2021-02-28 18:45:54.088 Python Plugin System: (BR) Retrieve weather data from https://api.buienradar.nl/
2021-02-28 18:45:54.148 Python Plugin System: (BR) XML parsing error: no element found: line 1, column 0
2021-02-28 18:45:54.148 Python Plugin System: (BR) No XML file found, try again later
2021-02-28 18:45:54.087 Error: Python Plugin System: (BR) Foutje in de BR Plugin: HTTP Error 400: Bad Request URL: http://xml.buienradar.nl/ [/code]
