adval40
- Domoticz version: 4.11528
dashticz v3.1.2 master
domoticz 4.11590
I have install dasticz install few days ago with installer
V3
domoticz 4.11590
V3
alarm_guy1
Can anyone tell me how to make icons taller, I have sussed wider but cant make them taller.
I want only 3 icons on my Dashticz desktop, My lounge light, Heating and Temperature
I would like to make the light fairly large and the other 2 smaller
cheers
cheers
- dashticz.jpg (62.09 KiB) Viewed 19032 times
Lokonli
Fixed in latest beta.adval40 wrote: Sunday 05 January 2020 2:28 dashticz v3.1.2 master
domoticz 4.11590
V3
You can test with:
git checkout beta
git pull
git checkout master
Lokonli
Do you only want to make the icon itself taller (the bulb) or the whole block?alarm_guy1 wrote: Monday 06 January 2020 21:13 Can anyone tell me how to make icons taller, I have sussed wider but cant make them taller.
cheers
Should the three blocks fill the complete screen?
alarm_guy1
Ideally the light one about 75% of screen and the other 2 to fill the bottom 25% ish.
I want use the tablet a as light switch basically so come Into the room and treat the tablet as a light switch so most of the screen utilised as the switch. The heating bit will just be smaller as you would approach the tablet and deliberately choose a specific temperature cheers
adval40
Re: place on multiple screens stationclock
adval40 wrote: Saturday 04 January 2020 15:55 I cannot put a stationclock on more than 1 screen
on the first screens the clock is shown but on the next screens i cannot see the stationclock
If i take a normal clock it see the clock on every screen
exactly the same problem with graphs on multiple screens
i have updated to beta 3.30
the stationclock works on every screen now
but graph_2 (for example) works only on screen 1
I see the border but I cannot see data
thanks in advance Ad pe1dgwCode: Select all
var columns = {} columns[1] = {} columns[1]['blocks'] = ['graph_2','graph_5','2_1','2_2','5_1'] columns[1]['width'] = 5; columns[2] = {} columns[2]['blocks'] = [esp_trap_groen,esp_trap_blauw,esp_trap_rood,tl_meettafel,oprit,tuin_w51,tuin_w53,temp_garage,gsm_ad,gsm_rabia,gsm_carsina,gsm_marije,currentweather_big_owm,weather_owm,'news_nualg',publictransport.ovinfobus] columns[2]['width'] = 5; columns[3] = {} columns[3]['blocks'] = ['stationclock',garbage,calendars.combined,buttons.buienradar]; columns[3]['width'] = 2; columns[4] = {} columns[4]['blocks'] = ['stationclock',garbage,calendars.combined,buttons.buienradar]; columns[4]['width'] = 2; var screens = {} screens[1] = {} screens[1]['background'] = 'bg13.jpg'; screens[1]['columns'] = [1,2,3] screens[2] = {} screens[2]['background'] = 'bg13.jpg'; screens[2]['columns'] = [1,2,4] screens[3] = {} screens[3]['background'] = 'bg14.jpg'; screens[3]['columns'] = [1,2,4]
Lokonli
Currently the number of graphs is limited to one per device.adval40 wrote: Monday 06 January 2020 23:41adval40 wrote: Saturday 04 January 2020 15:55 I cannot put a stationclock on more than 1 screen
Adding support for multiple graphs per device requires some more effort.
I'll add it to the Github issue list.
Lokonli
As a starting point, try the following CONFIG.js (with your own device ids)alarm_guy1 wrote: Monday 06 January 2020 23:24 Ideally the light one about 75% of screen and the other 2 to fill the bottom 25% ish.
var config = {}
config['domoticz_ip'] = 'http://192.168.178.18:8080';
config['hide_topbar'] = 1; // To hide the top bar
blocks[382] = {
width:12
blocks[27] = {
width:6
blocks['56_1'] = {
width:6
var columns = {}
columns[1] = {}
382, 27,'56_1'
columns[1]['width'] = 12;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg2.jpg';
screens[1]['columns'] = [1]
.block_382 {
height: 70vh !important;
padding-top: 100px !important;
.block_27 {
height: 25vh !important;
.block_56_1 {
.fas, .far {
font-size: 80px !important;
.title {
font-size: 50px !important;
.value {
font-size: 30px !important;
.lastupdate {
font-size: 20px !important;
.col-icon {
width: 90px !important
.col-data {
width: calc(100% - 90px) !important
alarm_guy1
Hi Lokonli,
Thanks for the continued support, things dont quite look the same for me
I edited CONFIG.js and custom.css
My IDX's are 10 (Dimmer) 226 (Heating Temperature chooser) and 58(Outsdie Garden temperature)
but that doesn't show up even if I leve out the _1 in both files
Cheers
var config = {}
config['domoticz_ip'] = 'http://192.168.xxx.xxx:8080';
blocks[10] = {
width:12
blocks[226] = {
width:6
blocks['58_1'] = {
width:6
var columns = {}
columns[1] = {}
10, 226,'58_1'
var screens = {}
screens[1] = {}
.block_382 {
.block_27 {
.block_56_1 {
.fas, .far {
.title {
.value {
.lastupdate {
.col-icon {
.col-data {
}- Attachments
- Dashticz1.jpg (205.78 KiB) Viewed 18972 times
Lokonli
Probably you have to add to CONFIG.js:
(otherwise you only see the devices marked as favorite in Domoticz)
config['use_favorites'] = 0
alarm_guy1
Thankyou.
Sorted now
Sorted now
JeroenL
- Domoticz version: 2023.2
Re: need some help with cam auth
What worked for me is the format:pvklink wrote: Tuesday 26 November 2019 17:36
This is my entry for the xiamoi (also tried username etc etc.)
https://192.168.20.52/cgi-bin/currentpi ... xx&pwd=xxx
is it possible to write a script for this so that i dont have to logon?
https://User:[email protected]/cgi ... entpic.cgi
Hope it works for you too
dannybloe
Peeps, this thread is going to be closed as it is too long be useful anymore. Please feel free to post new topics and let's try to stick to the topic and keep them short.
Danny
Danny
