Page 19 of 120
Re: Domoticz app 2.0
Posted: Thursday 31 December 2015 14:55
by pepeEL
RoadXY wrote:ben92 wrote:when changing color, it is possible to keep this color when we returns to the dimmer.
When you go back to the color picker once you have set the color, you mean?
ben92 wrote:I know for native vpn but maybe the app can connect to vpn automatically..... Its suggestion....
I know, thank you for your suggestion.
VPN support wil require a lot of coding for us so maybe we'll wil do this later.
I think that VPN is not need... i connect by vpn on my router and more user use router or nas with VPN
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Posted: Thursday 31 December 2015 14:57
by pepeEL
RoadXY wrote:pepeEL wrote:I send you info to PLANS to translation. In some languages should add string for 2 to 4 devices... Now is only for ONE and OTHER.
Seen and have made another suggestion as your suggestion is not possible in Android.
I know that it is possible in android. I use other project TVHClient and developer user other translation for one, few and other...
https://github.com/rsiebert/TVHClient/b ... lurals.xml
Posted: Thursday 31 December 2015 15:29
by Purejet
Hello, Nice to see an android app from Domoticz!
Have purchased it for my tablet and girlfriend phone.
But... i don't see the widgets, when i open the widgets inside android to add on the home screen, no one is from the domoticz app.
Anyone other with this issue?
EDIT: Just rebooted the phone a few times, and it is appearing now.
Hope that there come more dashboard-views for tablet
so we can dynamically change things than it would be an good alternative to ImperiHome (positions switches, graph elec, weather forecast view)
Posted: Thursday 31 December 2015 16:28
by jvdz
Last version looks good for the thermostat and the dimmers ! Thanks for that.
There is one thing that looks to be wrong in case of a "blinds_percentage":
Domoticz status -- App Status
Open Slider:0% switch:On (Should be Off)
Closed Slider:100% switch:On
xx% Slider: xx% switch:On
Maybe you could put that on your list to check?
Jos
Posted: Thursday 31 December 2015 16:30
by ThinkPad
Posted: Thursday 31 December 2015 16:31
by galadril
Verstuurd vanaf mijn Nexus 5 met Tapatalk
Feature request: secure panel
Posted: Thursday 31 December 2015 17:12
by svenker
Great app. Much better look than Dromotica.
Can you please integrate a nice secure panel in order to have a high quality security system ? This is the only piece I am missing.
Thanks in advance !
Sam
Posted: Thursday 31 December 2015 23:31
by nayr
Unfortunately, I cannot use this app because it does not support authentication with client tls certificates (x509)..
Posted: Thursday 31 December 2015 23:41
by wergeld
I have been trying unsuccessfully with the Lite app to connect to my domoticz install. I do not have a public-facing URL to view the site. I use on my internal network the IP assigned by my router (198.168.1.14). I can view this on my laptops and phones via any browser. I do have login authentication enabled.
When I use the Lite version of the app I set the following:
Server Address: 192.168.1.14
Protocol: HTTPS
Port: 80
Username: myusername
Password: mypassword
Start screen: Dashboard
Different Server Address: not enabled
When I go to the next screen I see this error:
Timeout or no connection
SSL handshake aborted:
ssl=0xb388b040: I/O error during system call, Broken pipe
Please correct the data on the previous page
I am using a self-signed certificate on my Pi 2 B. Could this be the issue?
I am not really sure what I am supposed to change.
Posted: Thursday 31 December 2015 23:46
by jvandenbroek
wergeld wrote:I have been trying unsuccessfully with the Lite app to connect to my domoticz install. I do not have a public-facing URL to view the site. I use on my internal network the IP assigned by my router (198.168.1.14). I can view this on my laptops and phones via any browser. I do have login authentication enabled.
Protocol: HTTPS
Port: 80
You're sure that you are using SSL on port 80? Self signed certificate works fine here with this app.
Sent from my SM-N9005 with Tapatalk
Posted: Friday 01 January 2016 4:08
by wergeld
Well, turns out it was port 8080. New Years hard cider helped me see that. Working great! Only have 2 temp sensors and a switch on my domoticz and all showing perfectly.
Bought the full version. Added widgets. Looking good. Few small wriggles here and there but no show stoppers for me.
Posted: Friday 01 January 2016 12:51
by ben92
Yes for the dimmmer, sorry for my english....
Posted: Friday 01 January 2016 12:58
by ben92
pepeEL wrote:RoadXY wrote:ben92 wrote:when changing color, it is possible to keep this color when we returns to the dimmer.
You say that you connect to the vpn, maybe the app can connect automaticaly if needed ... No wifi or not the good ssid.
I dont ask to implement vpn but just the connection.
Posted: Friday 01 January 2016 15:12
by RoadXY
I've investigated a little but we have to build are own.
There is no API to use the system VPN connections.
Posted: Friday 01 January 2016 21:30
by Rawkh
I've signed up just to compliment you on this nice app (well and a feature req.
) You guys have improved my domoticz experience lots and lots. Definitely 3 euros well spent!
The only thing I'm missing is an option to change the colours and (if possible) dim the lights of my Milight LEDs. Could you implement that as well? I can't seem to find the colour selecter option on the switch.
Posted: Friday 01 January 2016 21:47
by locogek
At the dashboard you can choose the color, dim them is also possible
Verstuurd vanaf mijn ONE A2003 met Tapatalk
Posted: Saturday 02 January 2016 1:10
by Rawkh
you're right it's working fine, just needed to change the device from an on/off switch to a dimmer
other question, could you make the changes from the colour wheel instantenous (like in the edit screen of domoticz itself)? The colours don't map one to one so I play around with the different options to get the colour I like.
Pressing the color button, selecting a colur and then pressing ok becomes quite tiresome I noticed.
Maybe you can add a cancel option so that people can revert the changes if they don't like the colour they selected?
Just a suggestion, love your work. As someone who is just starting to work as an app developer I can tell you that I really like the strict adherence to a minimal and material look.
Posted: Saturday 02 January 2016 2:22
by abuk
Firstly, just got to say how great the app is! This is a really good addon to Domoticz and is making the entire system really user friendly.
I am getting setup with the app, in paid mode, but I seem to have the same problem that @ehallq has as described below
ehallq wrote:The new description of the widgets (switch, temp etc) is wrong. Switch is temp and temp is switch in my case. Still get wrong widget when choosing one of my ac switches (i get a random scene). So the list in the widgetmeny is generated wrong
My first series of switches added clash with my scenes. Just thought I would add this post to show its not just the one user, but mainly to show my support for this great development.
Many Thanks
Posted: Saturday 02 January 2016 10:51
by RoadXY
Rawkh wrote:you're right it's working fine, just needed to change the device from an on/off switch to a dimmer
I'll add it to our list.
Thank you!
Posted: Saturday 02 January 2016 14:09
by pepeEL
I have a question. I see tat multilanguage will be add... But in menu settings will be available option set language ? I think that will be a good features to user can set language in menu settings... Can set own language or maybe other language
