Page 19 of 37
Re: ELV Max! Heating control system
Posted: Friday 04 November 2016 11:30
by blackdog65
Skippiemanz wrote:Aaah i see! My next step is to control my boiler with the OTGW so i then also switch to Hot Water only during the summer months!
Sadly my boiler doesn't support OTGW, but I didn't turn my heating off during summer. I meant to but it slipped my mind. The heating stayed off and a couple of weeks ago I thought "Ooh it's chilly... time to fire up the boiler" and it actually came on that evening by itself!!! I really do have a smart home... it read my mind! :lol:
Posted: Friday 04 November 2016 11:46
by Westcott
Window sensor update :idea:
Apparently the device type is in the M data, so in maxCmd_M it's dtype.
Looking in http://www.domoticaforum.eu/viewtopic.p ... 4&start=30
HeatingThermostat = 1,
HeatingThermostatPlus = 2,
WallMountedThermostat = 3,
ShutterContact = 4,
PushButton = 5
The previous post explains the window sensor state -
I found the Data for the window sensor.
Was my own fault, it is at the same place as the thermostate mode, so i thought i got thermostate values - but it was a window sensor ;)
so if you take the same position of data that gives you the thermostate mode (auto, manu etc) the last two bits give "10" when the window is open.
Time to find out what 01 and 11 are ;)
Posted: Friday 04 November 2016 12:07
by Skippiemanz
Westcott wrote:Window sensor update :idea:
ShutterContact = 4,
PushButton = 5
Ok Here goes nothing.. Tried to Copy/Change the part where the devices are beeing checked
if (data_len == 13) then   -- WallMountedThermostat (dev_type 3)
        valve_pos = -1
        s = hex:sub(17,18)
        setpoint = tonumber(s,16) / 2
        s = hex:sub(23,26)
        temp = tonumber(s,16) / 10
        dtype = "Thermostat"
      elseif (data_len == 12) then -- HeatingThermostat (dev_type 1 or 2)
        s = hex:sub(15,16)
        valve_pos = tonumber(s,16)
        s = hex:sub(17,18)
        if (mode ~= 2) then
          s = hex:sub(19,22)
          temp = 0
        dtype = "Valve"
      elseif (data_len == 14) then -- ShutterContact (dev_type 4)
        s = hex:sub(15,16)
        s = hex:sub(17,18)
        if (mode ~= 2) then
          s = hex:sub(19,22)
          temp = 0
        dtype = "Contact"
*EDIT* Ok, No succes... Damn i need to learn this :twisted:
Posted: Friday 04 November 2016 13:39
by mvzut
blackdog65 wrote:As to your window sensors, although it would be nice to see them in Domoticz (long term), if they were taken out of the script (i.e. the script doesn't look for or read them) they would still function and work nice (short term).
Sean
For the time being, I changed the script in the Wiki in such a way that it doesn't process "valves" which are actually door/window sensors. This only works if their names end with "-Sens". In this way, it won't try to update Domoticz devices for the sensor(s), which don't exist, so it shouldn't give these nil error messages anymore.
Ideally we find a way to actually detect the device type and state of door/window sensors. I'm sure we'll eventually get there.
If this works, we should also update the text that explains the naming scheme.
Posted: Friday 04 November 2016 14:03
by Skippiemanz
Sean
Tested and working! Thanks!(Again!)
Posted: Friday 04 November 2016 15:06
by Westcott
Hi Skippiemanz,
They are indeed dev_type 4, but data format is the same as a valve - length 13.
It might be possible to guess from its data or name which device type it is.
One way would be to create a cross-reference table of device names and types at the top of the code.
More elegant would be to create this table by reading the M data.
My own controller code has a lookup table of Max ID vs Domoticz device names.
Posted: Friday 04 November 2016 15:37
by jmbjmbjmb
I have been running the test script every minute for 2 days to plot the obtained temperatures and valve %.
As I do not have wall thermostats, this is relying on the temperature provided by the thermostat.
I believe that I read somewhere that this temperature is updated only after the valve % has changed so it does not get necessarily updated very often.
and this is what I observe when looking at the obtained data over 2 days. The temperature would suddenly jump from e.g., 19.1 to 20.9 (and when that happens I then see that the % has changed). Sometimes the temperature=0 for a while.
Has anyone had more success without wall thermostats ? or should I conclude that I need to buy these wall thermostats to have something reliable ?
Posted: Friday 04 November 2016 15:51
by Westcott
Any type of temperature measuring device is fine, Z-wave, RFXtrx, RFlink, etc.
Doesn't have to be a Max.
Regarding window sensors, pretend they are valves, but just use the mode.
Posted: Saturday 05 November 2016 10:12
by Skippiemanz
Westcott wrote:Regarding window sensors, pretend they are valves, but just use the mode.
Thansk! i will give this a try next week..
In the mean time, does anyone have the problem that the valve script wont turn on the CH_switch?
2016-11-05 10:11:00.292 LUA: *** Heating Script Output ***
2016-11-05 10:11:00.293 LUA: Hal Room valve is open 100 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.293 LUA: Hal Room last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.293 LUA: Zolder RoomV valve is open 0 percent Setpoint temperature is 16.50C
2016-11-05 10:11:00.293 LUA: Zolder RoomV last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.293 LUA: Tijn Room valve is open 100 percent Setpoint temperature is 17.50C
2016-11-05 10:11:00.293 LUA: Tijn Room last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.293 LUA: Noa Room valve is open 100 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.293 LUA: Noa Room last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.293 LUA: Kamer RoomL valve is open 100 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.293 LUA: Kamer RoomL last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.294 LUA: Kamer RoomR valve is open 100 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.294 LUA: Kamer RoomR last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.294 LUA: Zolder RoomD valve is open 0 percent Setpoint temperature is 16.50C
2016-11-05 10:11:00.294 LUA: Zolder RoomD last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.294 LUA: Kantoor Room valve is open 54 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.294 LUA: Kantoor Room last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.294 LUA: Badkamer Room valve is open 53 percent Setpoint temperature is 18.50C
2016-11-05 10:11:00.294 LUA: Badkamer Room last seen 2016-11-05 10:10:01 Elapsed time 59
2016-11-05 10:11:00.295 LUA: Badkamer Room temperature is 18.50 Centigrade
2016-11-05 10:11:00.295 LUA: Badkamer Room last seen 2016-11-04 14:30:01 Elapsed time 70859
2016-11-05 10:11:00.295 LUA: Kamer RoomR temperature is 18.50 Centigrade
2016-11-05 10:11:00.295 LUA: Kamer RoomR last seen 2016-11-04 14:30:01 Elapsed time 70859
2016-11-05 10:11:00.295 LUA: Kantoor Room temperature is 18.50 Centigrade
2016-11-05 10:11:00.295 LUA: Kantoor Room last seen 2016-11-04 14:30:01 Elapsed time 70859
2016-11-05 10:11:00.295 LUA: Tijn Room temperature is 17.50 Centigrade
2016-11-05 10:11:00.295 LUA: Tijn Room last seen 2016-11-04 14:35:01 Elapsed time 70559
2016-11-05 10:11:00.295 LUA: Noa Room temperature is 18.50 Centigrade
2016-11-05 10:11:00.295 LUA: Noa Room last seen 2016-11-04 14:40:01 Elapsed time 70259
2016-11-05 10:11:00.296 LUA: Zolder RoomD temperature is 16.50 Centigrade
2016-11-05 10:11:00.296 LUA: Zolder RoomD last seen 2016-11-04 14:28:58 Elapsed time 70922
2016-11-05 10:11:00.296 LUA: Zolder RoomV temperature is 16.50 Centigrade
2016-11-05 10:11:00.296 LUA: Zolder RoomV last seen 2016-11-04 14:28:50 Elapsed time 70930
2016-11-05 10:11:00.296 LUA: Hal Room temperature is 18.50 Centigrade
2016-11-05 10:11:00.296 LUA: Hal Room last seen 2016-11-04 14:22:08 Elapsed time 71332
2016-11-05 10:11:00.296 LUA: Kamer RoomL temperature is 18.50 Centigrade
2016-11-05 10:11:00.296 LUA: Kamer RoomL last seen 2016-11-04 14:30:01 Elapsed time 70859
2016-11-05 10:11:00.296 LUA: Number of valves open more than 50% is 7 valves
2016-11-05 10:11:00.296 LUA: Highest valve open value is 100 percent
2016-11-05 10:11:00.297 LUA: Lowest thermostat reading is 16.5 Centigrade
2016-11-05 10:11:00.297 LUA: Current state - Boiler is OFF
2016-11-05 10:11:00.297 LUA: PercentMax (100%) Boiler On value (50%) Boiler Off value (30)%
2016-11-05 10:11:00.297 LUA: Number of valves open more than 50% is 7 valves. Minimum valves setting 2
2016-11-05 10:11:00.297 LUA: Maximum open value 100% Override value 99%
Even if i turn it on mannualy it will turn af after 1 minute so the script checks and does something.
*EDIT* Just saw that the script in the wiki was changed. If i use that one and the same problem. But ive i turn on the boilerswitch it wont turn it off so it doesn't switch the boiler
**EDIT 2** Just changed al the variables to hard switch names in the code and now everything works. So maybe has something to do with the quotes?
- Script Variables
PercentMax = 0
TempMin = 100
ValveCount = 0
MissingDeviceCount = 0
SendAnEmail = false
HeatingSwitch = "Heating"
BoilerSwitch = "CH_Switch"
HolidaySwitch = "xx"
And they are used as:
  -- Perform logic
      if printDebug == true then
      -- view the settings to understand logic performance
         print ("PercentMax (" .. PercentMax .. "%) " .. "Boiler On value (" .. BoilerOnPercent .. "%) " .. "Boiler Off value (" .. (BoilerOnPercent - HysterysisOffPercent) .. ")% ")
         print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves. Minimum valves setting " .. MinValves )
         print ("Maximum open value " .. PercentMax .. "%" .. " Override value " .. ValvePercentOveride .."%")
      print (" ")
      if (otherdevices['HolidaySwitch'] == 'Off')then -- Not on holiday
   if (otherdevices['HeatingSwitch'] == 'On')then -- It's time to heat the house
            if (otherdevices['BoilerSwitch'] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
                     print ("Test passed - Boiler is OFF ")
               if (PercentMax > BoilerOnPercent) then
                     print ("Test passed - Radiators are open beyond the threshold ")
                  if (ValveCount >= MinValves) or (BoilerOnPercent >= ValvePercentOveride) then
                     print ("Test passed - Either multiple valves are open or override count is reached ")
                  commandArray['BoilerSwitch']='On' -- turn on boiler
                        if printData == true then
                        print ("Command sent - Turn ON Boiler ")
Is this correct?
Posted: Saturday 05 November 2016 16:01
by blackdog65
The
is a typo as the "xx" should be as in the script but other than that, this is an exact copy of what I have running (including the typo) and it works for me.
I modded the script to have variables for the switches for ease, but I'm open to being wrong as I'm not a coder.
Posted: Saturday 05 November 2016 16:09
by blackdog65
Give it a run with
printData = false
printDebug = false
set to "True" and see what you get
Sean :D
Re: RE: Re: ELV Max! Heating control system
Posted: Saturday 05 November 2016 16:41
by Skippiemanz
blackdog65 wrote:Give it a run with
printData = false
printDebug = false
Sean :D
Already have that.
Ik just says boiler off even when manually switched on. I also changed "xx" to holiday and made a corresponding virtual switch.
Ive got it running now by just hard wratten the switch names in the code.
Posted: Saturday 05 November 2016 16:56
by blackdog65
One of the draw backs of the script is that t can't be over-ridden or boosted. When running correctly, if you switch the heat on (or off) manually, the next time the script runs it will set the heating how it thinks best. Having said that, when it runs properly you don't need to... and if Domoticz dies (i.e. raspberry sd card fried) the manual switches will work.
Having tried StellaZ and Smartwares (and choked on the price of Danfos and EvoHome) I still think this is by far the best so far :D
Posted: Saturday 05 November 2016 23:01
by Skippiemanz
Dont get me wrong! I love the stuff youve created!
Maybe this causes my Problems https://r.tapatalk.com/shareLink?url=ht ... are_type=t
Events not working after update to 3.5837
Posted: Saturday 05 November 2016 23:08
by blackdog65
I'm on V3.5862 and it's running sweet :D
BTW, I didn't "create" anything... I'm the "King of Copy & Paste" :lol:
Sean
Posted: Monday 07 November 2016 12:42
by daveabbott007
Skippiemanz wrote: In the mean time, does anyone have the problem that the valve script wont turn on the CH_switch?
Skippiemanz / all, Hi, Firstly Great work all, i have been watching this develop and love all the work you guys have been putting in, my system is not fully working yet (not getting temp or setpoint readings form MAX to Domoticz, script is reading them but domoticz not updating. Valves are fine) but its certainly getting there.
i noticed the same problem and have manged to fix it in my version of the script, NOTE: i am running the script via the Events LUA (Time) page not in a file in the LUA folder (not sure if it makes a difference).
The 2 problems i noticed were,
1. around line 26- TempMin = 100, should be TempMin = 10 (or whatever you want for your lowest temp?)
2. loads of instances of hard coded device names instead of variable name I.E. 'BoilerSwitch' instead of BoilerSwitch,
Here is my adjusted code if you want to try it,
-- script_time_Heating Valves.lua
-- Version 1.9 27/10/16
-- Script to read the % open of radiator valves
-- All radiator valves are labelled "<room name>-Rad"
-- search is made for "-Rad" to indicate a radiator valve
-- If found it will be interrogated for % open value
-- Thermostat are named <room name>-Stat so a search is made for "-Stat" to indicate thermostats
-- If found it will be interrogated for temperature value
-- If demand is greater than BoilerOnPercent value then fire up boiler
-- If demand is less than BoilerOnPercent minus HysterysisOffPercent then switch off boiler
-- Preset Values
BoilerOnPercent = 30               -- percentage valve open at which the boiler will be turned on
HysterysisOffPercent = 20             -- percentage below BoilerOnPercent to switch off the boiler
MinValves = 2                      -- Number of Valves that need to be open before boiler is turned on
ValvePercentOveride = 75            -- Percentage value of valve open required to override MinValves value (one room is very cold)
HolidayMinTemp = 10                -- Minimum room temperature before boiler is turned on during holiday period
HolidayHysterysisTemp = 2             -- Value to increase house temperature by while in holiday mode if boiler is turned on due to low temperatures
MissingDevicesTime = 86400            -- Value in seconds to allow before reporting a device has not been updated
email = "[email protected]"             -- email address for warnings
-- Script Variables
PercentMax = 0
TempMin = 10
ValveCount = 0
SendAnEmail = false
HolidaySwitch = "Holiday"
-- Set printing to log options (true / false)
printData = true
printDebug = false
-- Get current date & time
t1 = os.time()
local currentDate = os.date("*t");  -- sets up currentDate.[table]
-- (currentDate.year [full], .month [1-12], .day [1-31], .hour [0-23], .min [0-59], .sec [0-59], .wday [0-6 {Sun-Sat}])
sCurrentTime = currentDate.year .. "-" .. currentDate.month .. "-" .. currentDate.day .. " " .. currentDate.hour .. ":" .. currentDate.min .. ":" .. currentDate.sec
function TimeElapsed(s) -- expects date & time in the form of 2010-01-23 12:34:56
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference -- in seconds
       -- print blank line in log
         print (" ")
         print (" *** Heating Script Output ***")
         print (" ")
       -- Get Data from Radiator Valves
      for i, v in pairs(otherdevices) do -- Get all devices in the database
         v = i:sub(-4,-1) -- Grab the last four characters of the device name
            if (v == '-Rad') then -- are the last four characters "-Rad"? If so we have a Radiator Valve
                RoomName = i:sub(1,-5) -- Get the rest of the name, which will be the room name
                sSetTempValue = otherdevices_svalues[RoomName..'-Stat']
                sValvePercentOpen = otherdevices_svalues[i]
                sLastUpdateTime = otherdevices_lastupdate[i]
                sElapsedTime = TimeElapsed(otherdevices_lastupdate[i])
                message = RoomName .. " valve is open " .. sValvePercentOpen .. " percent " .. " Setpoint temperature is " .. sSetTempValue .. "C"  -- for debug
                message2 = RoomName .. " last seen " .. sLastUpdateTime  ..  " Elapsed time " .. sElapsedTime
                  print (message)
                  print (message2)
                -- check for missing devices
                if sElapsedTime > MissingDevicesTime then
                SendAnEmail = false
                MissingDeviceCount = MissingDeviceCount + 1
                -- get the % value of the most open Radiator Valve
                if tonumber(sValvePercentOpen) > PercentMax then
                  PercentMax = tonumber(sValvePercentOpen)
                -- Count the number of valves that are open more than BoilerOnPercent
                if tonumber(sValvePercentOpen) >= BoilerOnPercent then
                  ValveCount = ValveCount + 1
         print (" ")
      -- Get Data from Thermostats
         v = i:sub(-5,-1) -- Grab the last five characters of the device name
            if (v == '-Stat') then -- are the last five characters "-Stat "? If so we have an EQ-3 Thermostat
                RoomName = i:sub(1,-6) -- Get the rest of the name, which will be the room name
                  sTemp = otherdevices_svalues[i] -- get the temperature
                message = RoomName.." temperature is " .. sTemp .. " Centigrade "  -- for debug
                  print(message)
                  print(message2)
                -- get the lowest temperature of the thermostats
                if tonumber(sTemp) < TempMin then
                  TempMin = tonumber(sTemp)
                SendAnEmail = true                      -- change this to false if you do not require emails to be sent
         print (" ")
         print ("Number of valves open more than " .. BoilerOnPercent .. "% is " .. ValveCount .." valves")
         print("Highest valve open value is " .. PercentMax .." percent ")
         print("Lowest thermostat reading is " .. TempMin .." Centigrade ")
         print (" ")
      if (otherdevices[BoilerSwitch] == 'On')then
         print ("Current state - Boiler is ON ")
         print ("Current state - Boiler is OFF ")
   -- Check the elapsed time and email if overdue
      if (SendAnEmail == true) then
         print (" ")
         print("Heating Script: missing device email sent to " .. (email) );
         notifyString = os.date("Domoticz Alert # The current time is %X on %A Lost contact with " .. MissingDeviceCount .. " Heating script devices, check if Max!Buddy is running.  #") .. (email)
         commandArray['SendEmail'] = notifyString
      -- Perform logic
      print (" ")
      if (otherdevices[HolidaySwitch] == 'Off')then -- Not on holiday
   if (otherdevices[HeatingSwitch] == 'On')then -- It's time to heat the house
            if (otherdevices[BoilerSwitch] == 'Off') then --If a minimum of 'MinValves' valves are on by more that pre-set value BoilerOnPercent
                  commandArray[BoilerSwitch]='On' -- turn on boiler
         if (PercentMax < (BoilerOnPercent - HysterysisOffPercent) or (ValveCount < MinValves)) and (otherdevices[BoilerSwitch] == 'On')  then -- If the number of valves open more than BoilerOnPercent minus HysterysisOffPercent
            commandArray[BoilerSwitch]='Off' -- turn off boiler
                     print ("Command sent - Turn OFF Boiler ")
      else -- on holiday
         if (TempMin <= HolidayMinTemp) and (otherdevices[BoilerSwitch] == 'Off') then  -- house is very cold
         if (TempMin >= (HolidayMinTemp + HolidayHysterysisTemp)) and (otherdevices[BoilerSwitch] == 'On') then  -- house is warm enough
            commandArray[BoilerSwitch]='Off' -- turn on boiler
      print (" ")
Posted: Monday 07 November 2016 13:08
by blackdog65
daveabbott007 wrote:NOTE: i am running the script via the Events LUA (Time) page not in a file in the LUA folder (not sure if it makes a difference).
Hi Dave, many thanks for the input!
You are spot on with the variables, that was my error :oops: I'm totally pants with code. I've used your cleaned up version and it works... though bizarrely my version was working for me too :?
It also works in the domoticz/scripts/lua folder for me too though... very odd.
Can't think why the max script isn't updating your sensors. I had a new thermostat and valve arrive on Saturday and adding them into my existing set-up was soooo easy. I have 5 rooms covered now and will keep adding one room a month until the wife says "STOP!" :D
What have you named your devices in the max app and in domoticz?
Sean
Posted: Monday 07 November 2016 13:54
by daveabbott007
Sean
Hi Sean, i am so glad to have been of some assistance, i ave been taking code from this forum for so long and it feels nice to have finally given something back.
Here is my device list from domoticz and max_test.lua, i cant spot any difference in the names (but i have been going name-blind lately)
Domoticz device screen
214	EQ3	14126	1	RachaelsBedroom-Stat	Thermostat	SetPoint	19	-	-		07/11/2016 12:12
206	EQ3	82206	1	RachaelsBedroom-Rad	General	Percentage	38.00%	-	-	07/11/2016 12:00
200	EQ3	14118	1	RachaelsBedroom		Temp	LaCrosse TX3		0.0 C	-	-		01/11/2016 23:10
211	EQ3	14123	1	MasterBedroom-Stat		Thermostat	SetPoint	19	-	-		07/11/2016 12:12
208	EQ3	82208	1	MasterBedroom-Rad		General	Percentage	22.00%	-	-	07/11/2016 12:00
201	EQ3	14119	1	MasterBedroom			Temp	LaCrosse TX3		0.0 C	-	-		01/11/2016 23:10
216	EQ3	14128	1	LivingRoom2-Stat		Thermostat	SetPoint	19	-	-		07/11/2016 12:12
204	EQ3	82204	1	LivingRoom2-Rad		General	Percentage	29.00%	-	-	07/11/2016 12:00
215	EQ3	14127	1	LivingRoom1-Stat		Thermostat	SetPoint	19	-	-		07/11/2016 12:13
203	EQ3	82203	1	LivingRoom1-Rad		General	Percentage	27.00%	-	-	07/11/2016 12:00
196	EQ3	14114	1	LivingRoom			Temp	LaCrosse TX3		22.2 C	-	-	06/11/2016 00:15
218	EQ3	0001412A	1	Holiday				Light/Switch	Switch	Off	-	-		06/11/2016 21:45
221	EQ3	0		1	HeatingControl			Light/Switch	Selector 	Level: 10 %	-	-07/11/2016 12:07
217	EQ3	14129	1	Heating				Light/Switch	Switch	On	-	-		06/11/2016 18:25
210	EQ3	14122	1	DinningRoom-Stat		Thermostat	SetPoint	19	-	-		07/11/2016 12:12
205	EQ3	82205	1	DinningRoom-Rad		General	Percentage	21.00%	-	-	07/11/2016 12:00
197	EQ3	14115	1	DinningRoom			Temp	LaCrosse TX3		0.0 C	-	-		01/11/2016 23:10
213	EQ3	14125	1	ConnorsRoom-Stat		Thermostat	SetPoint	19	-	-		07/11/2016 12:12
209	EQ3	82209	1	ConnorsRoom-Rad		General	Percentage	23.00%	-	-	07/11/2016 12:00
198	EQ3	14116	1	ConnorsRoom			Temp	LaCrosse TX3		0.0 C	-	-		01/11/2016 23:10
219	EQ3	0001412B	1	CH_Switch				Light/Switch	Switch	On	-	-		07/11/2016 12:10
212	EQ3	14124	1	Bathroom-Stat			Thermostat	SetPoint	19	-	-		07/11/2016 12:12
207	EQ3	82207	1	Bathroom-Rad			General	Percentage	56.00%	-	-	07/11/2016 12:00
199	EQ3	14117	1	Bathroom				Temp	LaCrosse TX3		0.0 C	-	-		01/11/2016 23:10
MAX_Test.lua
pi@domoticz:~$ lua maxtest.lua
Rooms
Bathroom        15D01D
ConnorsRoom     12E51A
DinningRoom     12E6DB
MasterBedroom   138296
LivingRoom      1386FD
RachaelsBedroom 13837F
Devices
Bathroom-Rad    15D01D
ConnorsRoom-Rad 12E51A
DinningRoom-Rad 12E6DB
LivingRoom2-Rad 138766
MasterBedroom-Rad       138296
LivingRoom1-Rad 1386FD
RachaelsBedroom-Rad     13837F
Device status
Valve           LivingRoom2-Rad 		Setpoint=20     Temp=19.2       Valve pos=29    Battery=OK      Mode=Manual
Valve           LivingRoom1-Rad 		Setpoint=20     Temp=21.6       Valve pos=20    Battery=OK      Mode=Manual
Valve           DinningRoom-Rad 		Setpoint=20     Temp=20 	      Valve pos=21    Battery=OK      Mode=Manual
Valve           MasterBedroom-Rad  	Setpoint=20     Temp=20.6       Valve pos=22    Battery=OK      Mode=Manual
Valve           RachaelsBedroom-Rad     Setpoint=20     Temp=19.3       Valve pos=38    Battery=OK      Mode=Manual
Valve           ConnorsRoom-Rad 		Setpoint=20     Temp=20.4       Valve pos=23    Battery=OK      Mode=Manual
Valve           Bathroom-Rad    		Setpoint=20     Temp=19.1       Valve pos=56    Battery=OK      Mode=Manual
Added Debug back into Script_time_max.lua
2016-11-07 12:50:00.728 LUA: Valve LivingRoom2-Rad Setpoint=18 Temp=22.3 Valve pos=0
2016-11-07 12:50:00.728 LUA: Domoticz setpoint LivingRoom2-Stat updated
2016-11-07 12:50:00.729 LUA: Valve LivingRoom1-Rad Setpoint=18 Temp=23.2 Valve pos=0
2016-11-07 12:50:00.729 LUA: Domoticz setpoint LivingRoom1-Stat updated
2016-11-07 12:50:00.729 LUA: Valve DinningRoom-Rad Setpoint=18 Temp=23 Valve pos=0
2016-11-07 12:50:00.729 LUA: Domoticz setpoint DinningRoom-Stat updated
2016-11-07 12:50:00.729 LUA: Valve MasterBedroom-Rad Setpoint=18 Temp=22.3 Valve pos=0
2016-11-07 12:50:00.729 LUA: Domoticz setpoint MasterBedroom-Stat updated
2016-11-07 12:50:00.730 LUA: Valve RachaelsBedroom-Rad Setpoint=18 Temp=20.7 Valve pos=0
2016-11-07 12:50:00.730 LUA: Domoticz setpoint RachaelsBedroom-Stat updated
2016-11-07 12:50:00.730 LUA: Valve ConnorsRoom-Rad Setpoint=18 Temp=22.3 Valve pos=0
2016-11-07 12:50:00.730 LUA: Domoticz setpoint ConnorsRoom-Stat updated
2016-11-07 12:50:00.730 LUA: Valve Bathroom-Rad Setpoint=18 Temp=22.5 Valve pos=0
2016-11-07 12:50:00.730 LUA: Domoticz setpoint Bathroom-Stat updated
2016-11-07 12:50:00.732 EventSystem: Fetching url...
2016-11-07 12:50:00.733 EventSystem: Fetching url...
2016-11-07 12:50:00.734 EventSystem: Fetching url...
2016-11-07 12:50:00.735 EventSystem: Fetching url...
2016-11-07 12:50:00.736 EventSystem: Fetching url...
2016-11-07 12:50:00.736 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_max.lua
i cant see whats up with names, Temps will not update in Domoticz, Setpoints will not update in Domticz from Max But max will change if i change Domoticz setpoints.
Any help or ideas greatfully recived
Dave
Posted: Monday 07 November 2016 14:58
by Skippiemanz
Dave,
Thanks for your update on the code! I will change it to your version in the WiKi!
Do you log out of the max application? Also completly close the java app from the task bar? Maybe that has something to do with it? Your name scheme seems correct!
Posted: Monday 07 November 2016 15:21
by blackdog65
Skippiemanz wrote:Dave,
Thanks Skippiemanz, saved me a job :D
@Dave, it looks to me that the max_test.lua and threfore script_time_max.lua is only reading your radiator valves and not seeing the wall stats... though where it gets the "LivingRoom" temp from is a mystery. :? Do you have wall stats fitted? If not, have you set
local useWMT = true --Set to true if there is a wall mounted thermostat in every room
to false in script_time_max.lua?
I hope this help... and Skippiemanz may be right about logging out of the MAX app.
Sean
