Page 19 of 32
Re: Testers wanted!
Posted: Tuesday 13 December 2016 18:25
by mirasp
Hi, recently I don't see anything
2016-12-13 18-12-55.jpg (21.25 KiB) Viewed 4951 times
the same after update do v.3.5877
Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative) in logs every time after domoticz reboot
API key in place, MyDomoticz enable and Apps Allowed disabled in settings
browser cache cleared
thanks in advance for help
Re: Testers wanted!
Posted: Tuesday 13 December 2016 19:22
by chimit
mirasp wrote:Hi, recently I don't see anything
If you get that message in your logs, then probably you are using the latest stable version of Domoticz.
In order to use MyDomoticz you need to switch to beta channel updates.
Or just be patient for the new stable release.
Re: Testers wanted!
Posted: Tuesday 13 December 2016 19:44
by mirasp
Ok, thanks
Re: Testers wanted!
Posted: Tuesday 13 December 2016 22:27
by Rolfie
chimit wrote:
Rolfie wrote:Hi,
Recently I installed Domoticz (D) and also created the MyDomoticz (MD) account. But the dashboard from my D is not showing up in MD. I do have an API key that shows up in my settings. I'm running the beta channel (fully updated) and my log entry just displays:
PROXY: Authenticate result: success.
I do have a different error in my log that I think started when I switched from stable to beta, but not sure if thats related:
Error: PluginSystem: Failed load 'libpython3.5.so', Python probably not installed on system.
Already tried clearing my cache and refreshing my browser. Do you might have an idea what the issue could be? Thanks.
Rolf
In case you created more than one account, the api key might be different from the one that you use to log in.
I'm just using one account.
Re: Testers wanted!
Posted: Wednesday 14 December 2016 8:48
by chimit
Rolfie wrote:
chimit wrote:
Rolfie wrote:Hi,
Rolf
If you PM me that account, I'll have a look for you.
Re: Testers wanted!
Posted: Wednesday 14 December 2016 12:50
by chimit
Thanks @Rolfie for reporting that the dashboard has issues with the some Firefox and Edge browsers.
We will look into the issue.
Re: Testers wanted!
Posted: Thursday 29 December 2016 20:12
by bbos
Mydomoticz has stopped working 2 days ago (after working for a couple of weeks).
After logging I can see that my instance is red.
The only thing which changed on my setup is that my rooters are now cascaded (iso 2 rooters with each a hdcp server).
This is what I see in the log:
2016-12-29 19:47:36.493 Proxymanager started.
2016-12-29 19:47:51.673 PROXY: Authenticate result: IP not whitelisted.
2016-12-29 19:48:51.695 Error: PROXY: timeout occurred, reconnecting
after trying some things I am seeing:
2016-12-29 19:59:51.208 Error: PROXY: Error resolving domoproxy.domoticz.com: Host not found (authoritative)
any tips how I could solve this problem?
Re: Testers wanted!
Posted: Thursday 29 December 2016 20:16
by chimit
bbos wrote:Hi,
In the settings of the Domoticz icon in your dashboard, check if the proper IP address of your Domoticz connection is listed.
When in doubt, just make it empty.
Possibly it can also be an ipv6 address.
== Rene
Re: Testers wanted!
Posted: Thursday 29 December 2016 21:08
by bbos
chimit wrote:
bbos wrote:Hi,
== Rene
This fixed the problem! thank you very much!
Re: Testers wanted!
Posted: Monday 16 January 2017 18:13
by desertdog
" the settings of the Domoticz icon in your dashboard,"
where would that be. I can't find anywhere where i can change an ip address
Re: Testers wanted!
Posted: Monday 16 January 2017 19:45
by chimit
If you click on the name "My Domoticz" (by default) you will get the settings screen.
Re: Testers wanted!
Posted: Monday 23 January 2017 11:09
by tontze
I just made MD account, it just wont work :) API key is i its place and enabled from settings. Nothing appears, in wiki it says to look possible errors in logs, what logs and where ?
Re: Testers wanted!
Posted: Monday 23 January 2017 11:31
by chimit
tontze wrote:I just made MD account, it just wont work :) API key is i its place and enabled from settings. Nothing appears, in wiki it says to look possible errors in logs, what logs and where ?
You can access the Domoticz logs from the settings menu in Domoticz.
What browser are you using?
Re: Testers wanted!
Posted: Monday 23 January 2017 11:35
by tontze
I'm using Chrome.
Re: Testers wanted!
Posted: Monday 23 January 2017 11:42
by tontze
I'm using Chrome.
2017-01-23 12:07:01.630 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
This kind of error found from log
Re: Testers wanted!
Posted: Monday 23 January 2017 11:54
by tontze
tontze wrote:
I'm using Chrome.
Yeah, thought i was in beta channel, but i wasnt .. Sry for the trouble ...
Re: Testers wanted!
Posted: Wednesday 25 January 2017 23:21
by BluesBro
Is there a way to include user:password on the my.domoticz path for instant log in?
EXAMPLE:
https://my.domoticz.com/my/user:passwor ... /Dashboard
Re: Testers wanted!
Posted: Thursday 26 January 2017 21:04
by tontze
mydomo is down ?
2017-01-26 21:57:45.758 Error: PROXY: timeout occurred, reconnecting
2017-01-26 21:57:45.759 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Re: Testers wanted!
Posted: Thursday 26 January 2017 21:37
by bobvanoijen
No connection here either:
2017-01-26 21:34:16.264 Error: PROXY: timeout occurred, reconnecting
2017-01-26 21:34:16.264 Error: PROXY: Handshake failed, reconnecting: Operation canceled
my.domoticz.com says:
Last seen: 26-01-2017 11:40:20
Last visited: 26-01-2017 15:01:56
Re: Testers wanted!
Posted: Thursday 26 January 2017 22:43
by berglund76
I have the same problem..
