Netatmo authentication changes Oct 2022
homeJLB
Domoticz version: 2024.7
Re: Netatmo authentication changes Oct 2022
Post by homeJLB »
I believe the problem is with some curl options, and my guess is the user-agent.
void HTTPClient::SetGlobalOptions(void *curlobj)
	CURL *curl=(CURL *)curlobj;
	curl_easy_setopt(curl, CURLOPT_HTTPAUTH, CURLAUTH_BASIC | CURLAUTH_DIGEST);
	curl_easy_setopt(curl, CURLOPT_WRITEFUNCTION, write_curl_data);
	curl_easy_setopt(curl, CURLOPT_ACCEPT_ENCODING, "");
	curl_easy_setopt(curl, CURLOPT_FOLLOWLOCATION, 1L);
	curl_easy_setopt(curl, CURLOPT_UNRESTRICTED_AUTH, 1L);
	curl_easy_setopt(curl, CURLOPT_USERAGENT, m_sUserAgent.c_str());
	curl_easy_setopt(curl, CURLOPT_CONNECTTIMEOUT, m_iConnectionTimeout);
	curl_easy_setopt(curl, CURLOPT_TIMEOUT, m_iTimeout);
	curl_easy_setopt(curl, CURLOPT_SSL_VERIFYPEER, m_bVerifyPeer ? 1L : 0);
	curl_easy_setopt(curl, CURLOPT_SSL_VERIFYHOST, m_bVerifyHost ? 2L : 0); //allow self signed certificates
	curl_easy_setopt(curl, CURLOPT_NOSIGNAL, 1);
	std::string domocookie = szUserDataFolder + "domocookie.txt";
	curl_easy_setopt(curl, CURLOPT_COOKIEFILE, domocookie.c_str());
	curl_easy_setopt(curl, CURLOPT_COOKIEJAR, domocookie.c_str());
chrominator
Post by chrominator »
Could be.
I've just compiled a version after having added a user agent, and it works fine (start/restart/reboot).
Since it is not the first time I compile a version that works first and fails after a while, I'll wait a bit before saying it's successful.
chrominator
Still working....
2025-04-05 10:21:58.050 Status: Netatmo: Requesting new access_token
2025-04-05 10:21:58.579 Status: Netatmo: HttpUrl: https://api.netatmo.com/oauth2/token?
2025-04-05 10:21:58.579 Status: Netatmo: HttpData: grant_type=refresh_token&refresh_token=58373dfakedata28d1de3|cab06etoken_refreshed59f45&client_id=67client_id6afa3&client_secret=PE0client_secretkn
2025-04-05 10:21:58.580 Status: Netatmo: ExtraHeaders: User-Agent: Domoticz/Version 2025.1 (build 16611)
2025-04-05 10:21:58.580 Status: Netatmo: ExtraHeaders: Content-Type: application/x-www-form-urlencoded;charset=UTF-8;
2025-04-05 10:21:58.581 Status: Netatmo: returnHeader: HTTP/2 200
2025-04-05 10:21:58.581 Status: Netatmo: returnHeader: date: Sat, 05 Apr 2025 08:21:58 GMT
2025-04-05 10:21:58.581 Status: Netatmo: returnHeader: content-type: application/json
2025-04-05 10:21:58.582 Status: Netatmo: returnHeader: cache-control: no-store
2025-04-05 10:21:58.582 Status: Netatmo: returnHeader: x-azure-ref: 20250405T082158Z-17dc6868955nc685hC1PRAzd480000000280000000006ra0
2025-04-05 10:21:58.583 Status: Netatmo: returnHeader: x-cache: CONFIG_NOCACHE
2025-04-05 10:21:58.584 Status: Netatmo: We refreshed our token ...
2025-04-05 10:21:58.584 Status: Netatmo: Login 1
2025-04-05 10:21:58.585 Status: Netatmo: Get HomesData Details
2025-04-05 10:21:58.753 Status: Netatmo: Home id Thermostat updated.
2025-04-05 10:21:58.753 Status: Netatmo: Home Status Details, size (number of homes) is 1
2025-04-05 10:21:58.977 Netatmo: General/Percentage ( Thermostat - Bat. Lvl)
2025-04-05 10:21:58.986 Netatmo: Setpoint (Consigne Netatmo)
2025-04-05 10:21:58.998 Netatmo: Temp (Netatmo)
2025-04-05 10:21:59.001 Netatmo: Light/Switch (Chauffage)
2025-04-05 10:21:59.006 Netatmo: Light/Switch (Planning Thermostat)
2025-04-05 10:21:59.010 Netatmo: Light/Switch (Thermostat - Mode)
2025-04-05 10:21:59.013 Status: Netatmo: Parse Persons
2025-04-05 10:21:59.013 Status: Netatmo: HomeStatus parsed
2025-04-05 10:21:59.183 Status: Netatmo: Status 1
I think I will issue a PR. :D
jcb2
Post by jcb2 »
Good news, thanks for your job !
chrominator
PR issued.
Now we just have to keep our fingers crossed that it works for everyone.
cadkey
Post by cadkey »
chrominator wrote: Saturday 05 April 2025 9:34 I've just compiled a version after having added a user agent, and it works fine (start/restart/reboot).
https://github.com/domoticz/domoticz/is ... 2764622607
jcb2
Post by jcb2 »
With the new beta 16619 of today it is ok for me.
I hope for future also :)
phil35
Domoticz version: 2023.1
Post by phil35 »
When this beta will release as a stable version?
Thanks for the work done.
Phil
Production platform uses domoticz v2023.1
Production platform (for Netatmo and Zigbee) uses domoticz v2024.7
As soon as you confirmed the betas are working for Netatmo....
If you are using Netatmo I would advise to use the latest beta as soon as possible. There is no other major issue in beta (other than in current stable....)
jcb2
Post by jcb2 »
Finnaly this new beta is not good for me:
2025-04-08 07:32:13.758 Error: Météo: Error data ... url: https://api.netatmo.com/api/getstationsdata?&get_favorites=true&, response: {"error":{"code":3,"message":"Access token expired"}}
2025-04-08 07:32:13.925 Error: Météo: Error data ... url: https://api.netatmo.com/api/homesdata?&get_favorites=true&, response: {"error":{"code":3,"message":"Access token expired"}}
No luck
PS : after one restart, the connexion is ready.
Wimpi
Domoticz version: 2025.1
Post by Wimpi »
After update to Version: 2025.1 (build 16626)
Netatmo works again, thanks!!! :D
cadkey
Post by cadkey »
Hello everyone.
I'm glad I could help the Domoticz community by proposing the header solution with user-agent:
And taken up by @chrominator to make the PR. 👍
I don't know Domoticz, but I do know the Netatmo API.
Hopefully that was the only problem.
jcb2
Post by jcb2 »
For me also OK with beta 16626 !
I hope for an long time :)
Thanks for your effort.
GJKNL
Post by GJKNL »
Also updated to 16626. Netatmo works for a few hours, then I get
Error: Netatmo: Error data ... url: https://api.netatmo.com/api/getstations ... rites=true&, response: {
2025-04-09 15:43:03.991 "error": {
2025-04-09 15:43:03.991 "code": 3,
2025-04-09 15:43:03.991 "message": "Access token expired"
2025-04-09 15:43:03.991 }
2025-04-09 15:43:04.146 Error: Netatmo: Error data ... url: https://api.netatmo.com/api/homesdata?& ... rites=true&, response: {
2025-04-09 15:43:04.146 "error": {
2025-04-09 15:43:04.146 "code": 3,
2025-04-09 15:43:04.146 "message": "Access token expired"
2025-04-09 15:43:04.146 }
After updating Netatmo in Domoticz it starts working again for a few hours.
Did I miss something? I have read this threat a few times , but sometimes it is a bit acabadabra for me.
Wimpi
Post by Wimpi »
GJKNL wrote: Wednesday 09 April 2025 15:55 Also updated to 16626. Netatmo works for a few hours, then I get
Today the same problem …
Ik works for a couple of hours … and then the same problems
cadkey
Post by cadkey »
@JurgenLB fixed the issue here:
https://github.com/domoticz/domoticz/pull/6297
GJKNL
Post by GJKNL »
For the time being, I added a data timeout of 30 mins in the Netatmo hardware. This seems to work for now.
jcb2
Post by jcb2 »
I have also this new issue from this night.
One restart does not solve the issue.
Probably need to wait a little bit to retry.
sailmich
Post by sailmich »
cadkey wrote: Thursday 10 April 2025 0:23 @JurgenLB fixed the issue here:
Not for me. I'm on domoticz beta 16626. I always get errors after a couple of hours.
 2025-04-15 14:11:13.036 Error: Netatmo: Error data ... url: https://api.netatmo.com/api/homesdata?&get_favorites=true&, response: {
2025-04-15 14:11:13.036 "error": {
2025-04-15 14:11:13.036 "code": 3,
2025-04-15 14:11:13.036 "message": "Access token expired"
To get rid of it I do have to hit the update button for netatmo on domoticz hardware page.
Cheers
@gizmocuz is a couple of weeks absent pull requests and beta builds have some delay.
