Page 19 of 28
Re: Python Plugin : Broadlink
Posted: Sunday 09 January 2022 12:47
by DrMacabre
Thank you, what’s my domoticzplugin/import directory ? You mentioned android in your reply, am i missing something ?
Posted: Sunday 09 January 2022 13:04
by zak45
DrMacabre wrote: Sunday 09 January 2022 12:47 Thank you, what’s my domoticzplugin/import directory ? You mentioned android in your reply, am i missing something ?
when you install the Broadlink plugin, severals directories should be created under your domoticz plugin directory, "import" should be one if them.
Yep, android for tasks that need to be done on your android phone.
Posted: Sunday 09 January 2022 13:14
by DrMacabre
Ok so i was doing it right but the import dir wasn’t created during the installation of the plugin though, i had to do it manually and all 3 json files are in it but nothing ever happened after i clicked the econtrol button on the web interface. Do you think this might be an issue due to ownership attributes of the json files or something ?
Posted: Sunday 09 January 2022 13:22
by zak45
yes .. can be.
this is the directory structure for the import process (windows):
Posted: Sunday 09 January 2022 13:25
by DrMacabre
Oh ok, i see, that’s Broadlink/ini/import/ not Broadlink/import/ that’s why.
Thank you.
Posted: Wednesday 12 January 2022 0:12
by albebert
Learn RF is not working for me.
i've an hex code for my remote from Broadlink Manager :
JgA6AAsSDBIMEgsHFwcXBhcHFwcXBxcGGAYXBxcHFwcXBhcHFwcXEwsHFxILEwsTCxMLBxYTCwcXBxAADQUAAAAAAAAAAAAAAAAAAA==
anyone can send me a sample ini file for RF command please ?
edit :
with broadlink_cli.py i can learn RF and send it !
so just need to make a corect ini file for the plugin
Posted: Wednesday 12 January 2022 11:43
by zak45
albebert wrote: Wednesday 12 January 2022 0:12 Hi,
edit :
that's strange, if it work with broadlink_cli.py this should work with the GUI, same program used !!!??
Posted: Wednesday 12 January 2022 11:51
by albebert
zak45 wrote: Wednesday 12 January 2022 11:43
edit :
yes it's strange ^^ same program yes, i use the cli from plugin folder (fresh install with install.py and fresh domoticz install on a debian 9 )
not a big problem i don't learn RF all days :) so if i've a example of RF ini i can deal with it
in fact for now i've created a shell script that i call with dummy switch that use the broadlink_cli.py and it work well :)
Posted: Wednesday 12 January 2022 12:14
by zak45
Just tried on my installation, no problem...
here is the ini file from the code I learned (windows system):
[DEFAULT]
pluginkey = Broadlink
pluginname = RM2
pluginfolder = C:\Program Files (x86)\Domoticz\plugins\Broadlink\
hardwareid = 31
unit = 017
customname = RF
[Device]
host = 192.168.1.xxx
mac = b4cccceeffaa
[LearnedCode]
017 = b2009e02085b0909092d082c090a080a092c092c080a090a082d080a082d0909092c092c090a082c090a092c080a090a082c092c090a092c080a0909092c090a082d082c090a092c090a080a082d092c080a092c080b082c090a080a092c092c0909090a082d092c080a0909092d080a092c080a092c0909092c090a082d082c090a080a092c0900015b085b0909092c092c090a0909092c092c080a090a082c090a082d080a092c092c090a092b090a092c080a090a082d082c090a092b090a0909092c090a082c092c090a092c090a080a092c092c080a092c0909092c090a0909092c092c080a0909092d092c080a090a082d080a082d080a092c0909092c090a082d082c090a0909092c0800015c085b090a082d082c090a080a092c092c09090909092d080a082d0909092c092c080b092c080a092c080a090a082d082c090a092c080a090a082d080a082d092b090b082c090a080a092c092c0909092c090a082c090a080a092c092c0909090a082d092c0909090a082d080a092c0909092c0909092d080a092c082c090a0909092c0900015b085b090a082c092d080a080a092c092c090a080a082d0909092c0909092c092c090a092c080a092c090a080a082d082d080a092c0909090a082d080a082d092c080b082c090a080a092c092c090a082c090a082c090a0909092c092c090a080a092c092c080a090a092c080a092c090a082c090a082d080a082d082d080a090a082c0900015b085b090a082d092b090a0909092c092c0909090a082d0909092c0909092c092c090a092c0909092c090a080a082d092b090a092c080b080a082d080a092c092c080b082c090a080a092c092c090a082c090a082c090a0909092c092c090a080a082d092c090a080a082d080a092c0909092c0909092d080a082d082d080a0909092d080005dc092c090a080a082d082d
Posted: Wednesday 12 January 2022 12:17
by albebert
thanks a lot.
i'll try it !
Posted: Wednesday 12 January 2022 12:27
by zak45
Here it is your command:
[DEFAULT]
pluginname = RM2
hardwareid = 31
unit = 017
customname = RF
[Device]
mac = b4cccceeffaa
[LearnedCode]
017 =
26003a000b120c120c120b07170717061707170717071706180617071707170717061707170717130b0717120b130b130b130b0716130b07170710000d050000000000000000000000000000
the code you have supplied is a Base64 code, so need to be converted to Hex first.
you can create an ini file on the import folder and click the import button, this should create your ini file automatically.
Posted: Tuesday 18 January 2022 17:23
by mojso
@zak45
the plugin worked perfectly until yesterday. but from today I get this error
2022-01-18 17:18:09.815 Error: BR3: Traceback (most recent call last):
2022-01-18 17:18:09.815 File "/home/pi/domoticz/plugins/Broadlink/plugin.py", line 1746, in send
2022-01-18 17:18:09.815 DEVICE.send_data(SENDCOMMAND)
2022-01-18 17:18:09.815 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 639, in send_data
2022-01-18 17:18:09.815 response = self.send_packet(0x6a, packet)
2022-01-18 17:18:09.815 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 349, in send_packet
2022-01-18 17:18:09.815 payload = self.encrypt(payload)
2022-01-18 17:18:09.815 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 236, in encrypt
2022-01-18 17:18:09.815 encryptor = self.aes.encryptor()
2022-01-18 17:18:09.815 File "/usr/lib/python3/dist-packages/cryptography/hazmat/primitives/ciphers/base.py", line 121, in encryptor
2022-01-18 17:18:09.815 self.algorithm, self.mode
2022-01-18 17:18:09.815 File "/usr/lib/python3/dist-packages/cryptography/hazmat/backends/openssl/backend.py", line 295, in create_symmetric_encryption_ctx
2022-01-18 17:18:09.815 return _CipherContext(self, cipher, mode, _CipherContext._ENCRYPT)
2022-01-18 17:18:09.815 File "/usr/lib/python3/dist-packages/cryptography/hazmat/backends/openssl/ciphers.py", line 112, in __init__
2022-01-18 17:18:09.815 self._backend._ffi.from_buffer(cipher.key),
2022-01-18 17:18:09.815 TypeError: from_buffer() cannot return the address of the raw string within a bytes or unicode object
2022-01-18 17:18:09.815 Error: BR3: Warning : Code sent ....Probably timeout
I think after installing the thermostat weekly sheduler I can no longer use Broadlink, I uninstalled the thermostat weekly sheduler but the Broadlink plugin did not work
Posted: Wednesday 19 January 2022 11:37
by zak45
look at your cryptography module, maybe try to install last version.
Posted: Wednesday 19 January 2022 11:53
by mojso
zak45 wrote: Wednesday 19 January 2022 11:37 look at your cryptography module, maybe try to install last version.
please how to reinstall the cryptography module.
sudo pip install cryptography --upgrade - now I get this error
2022-01-19 12:15:01.942 Error: BR3: ERR : remote_plugin--_Error receive / save file from Cloud Drive : https://synnas.publicvm.com:4430/s/pNbw6pD7w33TTQX/download_--21
2022-01-19 12:15:01.943 Error: BR3: No transport, write directive to '127.0.0.1:47058' ignored.
2022-01-19 12:15:12.767 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=711&switchcmd=On
2022-01-19 12:15:36.977 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=712&switchcmd=On
2022-01-19 12:15:44.076 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=711&switchcmd=On
2022-01-19 12:17:09.936 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=712&switchcmd=On
2022-01-19 12:20:11.083 Error: BR3: Traceback (most recent call last):
2022-01-19 12:20:11.083 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 369, in send_packet
2022-01-19 12:20:11.083 response = cs.recvfrom(2048)
2022-01-19 12:20:11.083 socket.timeout: timed out
2022-01-19 12:20:11.083 During handling of the above exception, another exception occurred:
2022-01-19 12:20:11.083 Traceback (most recent call last):
2022-01-19 12:20:11.083 File "/home/pi/domoticz/plugins/Broadlink/plugin.py", line 1803, in broadlink_connect
2022-01-19 12:20:11.083 DEVICE.auth()
2022-01-19 12:20:11.083 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 270, in auth
2022-01-19 12:20:11.083 response = self.send_packet(0x65, payload)
2022-01-19 12:20:11.083 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 374, in send_packet
2022-01-19 12:20:11.083 raise exception(0xfffd)
2022-01-19 12:20:11.083 broadlink.exceptions.DeviceOfflineError: The device is offline
2022-01-19 12:20:11.083 Error: BR3: Error to connect to Broadlink device: 192.168.1.117
2022-01-19 12:23:00.658 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=951&switchcmd=On
2022-01-19 12:23:04.079 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=951&switchcmd=On
2022-01-19 12:23:07.612 Error: Error opening url: http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=951&switchcmd=On
2022-01-19 12:25:11.294 Error: BR3: Traceback (most recent call last):
2022-01-19 12:25:11.294 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 369, in send_packet
2022-01-19 12:25:11.294 response = cs.recvfrom(2048)
2022-01-19 12:25:11.294 socket.timeout: timed out
2022-01-19 12:25:11.294 During handling of the above exception, another exception occurred:
2022-01-19 12:25:11.294 Traceback (most recent call last):
2022-01-19 12:25:11.294 File "/home/pi/domoticz/plugins/Broadlink/plugin.py", line 1803, in broadlink_connect
2022-01-19 12:25:11.294 DEVICE.auth()
2022-01-19 12:25:11.294 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 270, in auth
2022-01-19 12:25:11.294 response = self.send_packet(0x65, payload)
2022-01-19 12:25:11.294 File "/usr/local/lib/python3.7/dist-packages/broadlink/__init__.py", line 374, in send_packet
2022-01-19 12:25:11.294 raise exception(0xfffd)
2022-01-19 12:25:11.294 broadlink.exceptions.DeviceOfflineError: The device is offline
2022-01-19 12:25:11.294 Error: BR3: Error to connect to Broadlink device: 192.168.1.117
I succeeded.
I reinstalled the crypto module.
I deleted the browser history.
I set up Local Networks again (no username / password):
Posted: Wednesday 19 January 2022 16:46
by zak45
Great !
Posted: Saturday 22 January 2022 17:31
by zak45
vceklic wrote: Saturday 22 January 2022 9:23Anyone?
Should work now.
Posted: Monday 24 January 2022 16:54
by garycooper
Hi, sorry but link doesn't work anymore.
Posted: Friday 28 January 2022 8:27
by kollemt
I have installed the Broadlink plugin on my Raspberry Pi.
All is working ok in Domoticz to control my tvs.
Only after a reboot I always get always the attached error and always have to deactivate and activate the broadlink hardware to avoid the device shows Red.
How to get rid of this message ?
Posted: Friday 28 January 2022 13:07
by zak45
Sorry, but your screenshot is not 'readable'.
provide full text log.
Posted: Friday 28 January 2022 15:00
by kollemt
In problem log after a reboot and a domoticz stop and start
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: (Broadlink) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Broadlink/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: Module Import failed, exception: 'InternalError'
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: Error Line details not available.
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: Exception traceback:
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 129 in '/home/pi/domoticz/plugins/Broadlink/plugin.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 12 in '/usr/local/lib/python3.7/dist-packages/requests_toolbelt/__init__.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 12 in '/usr/local/lib/python3.7/dist-packages/requests_toolbelt/adapters/__init__.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 12 in '/usr/local/lib/python3.7/dist-packages/requests_toolbelt/adapters/ssl.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 55 in '/usr/lib/python3/dist-packages/requests/__init__.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 59 in '/usr/lib/python3/dist-packages/requests/packages/__init__.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 49 in '/usr/lib/python3/dist-packages/requests/packages/__init__.py', function vendored
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 47 in '/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 8 in '/usr/lib/python3/dist-packages/OpenSSL/__init__.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 12 in '/usr/lib/python3/dist-packages/OpenSSL/rand.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 6 in '/usr/lib/python3/dist-packages/OpenSSL/_util.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 195 in '/usr/local/lib/python3.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py', function <module>
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 151 in '/usr/local/lib/python3.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py', function init_static_locks
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 134 in '/usr/local/lib/python3.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py', function _ensure_ffi_initialized
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 120 in '/usr/local/lib/python3.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py', function _register_osrandom_engine
2022-01-28 08:17:40.233 Error: Broadlink TV woonkamer: ----> Line 78 in '/usr/local/lib/python3.7/dist-packages/cryptography/hazmat/bindings/openssl/binding.py', function _openssl_assert
2022-01-28 08:17:54.728 Error: Broadlink TV slaapkamer: ERR : remote_plugin--_Error receive / save file from Cloud Drive : https://synnas.publicvm.com:4430/s/pNbw ... nload_--21
2022-01-28 08:45:10.687 Error: Broadlink TV woonkamer: ERR : remote_plugin--_Error receive / save file from Cloud Drive : https://synnas.publicvm.com:4430/s/pNbw ... nload_--21
