Page 19 of 35
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Posted: Wednesday 13 November 2019 20:11
by WimV
So what I would do on my side.
- At domoticz startup, you can see the python version it will use, I will compare it with the one I m using on the system with "python3 -- version"
- If it's not the same I will switch the version with "update-alternatives"
- Then I will test if request library is working on my system
pi@raspberrypi:~ $ python3
Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import requests
>>> exit()
- Then I will test it in a plugin, for exemple the deconz one removing the except loop (with adding requests in the import line a second time)
- If I have an error, an import error I think, hopping for more information from domoticz.
- I will search where is the lib is on my system, looking with a file browser and add the path in the python code
import sys
sys.path.append('/usr/local/lib/python3.6/site-packages')
On this exemple, I realy have a folder called "requests" in '/usr/local/lib/python3.6/site-packages' and it's the one that is working for the version I m using.
- If it's not working yet, ask on domoticz forum why the "requests" lib can't be used on python 3.x.x with domoticz
[/quote]
Ok, I will try dis.
I let you know
Posted: Thursday 21 November 2019 15:25
by gemas
First of all sorry if this question has been asked/answered before. I couldn't find any reference to this question.
I'm wondering if you dim your lights with a ikea/hue device in domoticz while keeping the upper/lower button pressed.
So that you gradually dim your lights with 1 button press.
Now I'm dimming with every button press 10% using dzvents. So going from 0 to 100% needs 10 button clicks.
Posted: Thursday 21 November 2019 17:17
by Thorgal789
Good question.
The plugin can trigger an event for long press is starting, an other for button release, but I don't see a way to make the luminosity increase by one during this period.
Need to check.
Posted: Friday 22 November 2019 19:22
by Thorgal789
gemas wrote: Thursday 21 November 2019 15:25
Ok so I have found 2 ways
- using phoscon
- with domoticz using this script
--Ikea remote
if (devicechanged['deCONZ - TRÅDFRI remote control'] == 'L +') then
a = otherdevices_svalues['deCONZ - chambre']
a = tonumber(a) + 5
commandArray['deCONZ - chambre'] = 'Set Level: '..a
-- bulb
if (devicechanged['deCONZ - chambre']) then
if (otherdevices['deCONZ - TRÅDFRI remote control'] == 'L +') then
a = tonumber(a) + 5
The script is not finished, and can be optimised, but this method is working, I think you can do same with dzevent.
Posted: Tuesday 26 November 2019 21:54
by WimV
Hi Thorgal789
I can not use the plugin in a docker container because i do not install python inside the container.
But i have now install the plugin on a normal domoticz and the plugin works oké.
Thanks.
Posted: Wednesday 27 November 2019 17:00
by Thorgal789
It's not possible to install python on the container that contain domoticz ?
So it mean it's not possible to install domoticz on a container ? Or it's your choice ?
Posted: Wednesday 27 November 2019 21:30
by WimV
It is possible, but I do not have time for that yet.
I try it another time for myself, and when it works I share it here.
For now it works well
Posted: Monday 02 December 2019 15:12
by havnegata
I'm on Domoticz V4.10162 and python version 2.7.13
I'm getting this error:
- Screen Shot 12-02-19 at 03.05 PM.PNG (12.68 KiB) Viewed 2032 times
Then I'm trying to install the missing libs: sudo -H pip install requests
- Screen Shot 12-02-19 at 03.10 PM.PNG (13.64 KiB) Viewed 2032 times
Can somebody point me in the right direction?
Posted: Monday 02 December 2019 17:44
by Thorgal789
There is so much possibilities, but wich one raspbian version have you, to have missing command here ?
I think it will be usefull to install pip.
BTW, domoticz use only python3 (and no python 2.X) so better to use sudo -H pip3 install requests
Posted: Tuesday 03 December 2019 20:12
by havnegata
Thanks for responding! If I run python -V I get Python 2.7.13 as output and Im running Raspbian Buster
Posted: Tuesday 03 December 2019 21:04
by Thorgal789
And pip isn"t installed by defaut on Buster ?
To have python3 version use
Try installing pip for python3
and then install requests
With "-H" option if needed.
Posted: Tuesday 03 December 2019 22:15
by havnegata
Sorry, I was wrong about the Raspbian version, it's Stretch. I think the reason I installed python 2.7.13 was that I had problems running python plugins under python3, it always seemed to crash domoticz. But do you think this will not be a problem for me?
Posted: Wednesday 04 December 2019 17:43
by Thorgal789
Bad luck for you, I think you are in same situation than them >
https://www.domoticz.com/forum/viewtopi ... 7&p=229684 , crash with message "fatal signal X" ?
And I m sorry for you, but domoticz NEED python 3 to use plugin >
https://www.domoticz.com/wiki/Using_Python_plugins
Posted: Thursday 05 December 2019 14:54
by havnegata
Thorgal789 wrote: Tuesday 03 December 2019 21:04
I did as you described, but how do I force Domoticz to use Python V3 instead of V2.7.13?
Edit: now it's using python v 3.5.3, but the errors are the same (missing requests library)
Posted: Thursday 05 December 2019 18:27
by Thorgal789
What is the result of "sudo pip3 install requests", if you have installed pip before ofc ?
Posted: Thursday 05 December 2019 19:55
by havnegata
- Screen Shot 12-05-19 at 07.54 PM.PNG (17.41 KiB) Viewed 1981 times
Posted: Friday 06 December 2019 17:46
by Thorgal789
Arf, an other user had exectly same problem, without solution (just previous page)
So, when you start domoticz on log you will see the python3 version domoticz will use, check if it's the same than your : python 3.5.3
You can try with the -H flag > sudo -H pip3 install requests
Or add this at the start of the plugin code, line 48
import sys
sys.path.append('/usr/local/lib/python3.5/dist-packages')
Posted: Saturday 07 December 2019 2:51
by havnegata
Thanks! Working night shift so will try when getting home in the morning!
Posted: Sunday 08 December 2019 16:34
by havnegata
Thorgal789 wrote: Friday 06 December 2019 17:46
import sys
Thanks for your support! This code seemed to be success, although I still only have my Conbee installed and no sensors or switches, but at least no errors are showing! Great support!!
Posted: Sunday 08 December 2019 16:54
by Thorgal789
No problem, but just for confirmation, if you remove theses 2 lines, you have again the error message about request lib ? (You are the first one that this solution have worked)
